Activate a SIM Card on a Cloud Connector
You may find it easier to activate a SIM card from the Oracle Enterprise Communications Platform (Oracle ECP) Edge Node Details page than from the SIM Card Details page. For example, you do not need to know the name of the SIM card to activate directly from an Cloud Connector.
Before You Begin
- Confirm the target SIM card is assigned to the selected Cloud Connector and the SIM card state is "deactivated".
Context
After you successfully perform the following procedure, the Cloud Connector using the activated SIM card can use cellular services. This procedure does not affect Wi-Fi or Ethernet services.
Procedure
