Deactivate a SIM Card on a Cloud Connector
You may find it easier to deactivate a SIM card from the Oracle Enterprise Communications Platform (Oracle ECP) Edge Node Details page than from the SIM Card Details page. For example, you do not need to know the name of the SIM card to deactivate directly from an Cloud Connector.
Before You Begin
  • Confirm the target SIM card is Activated.
Context
After you successfully perform the following procedure, the Cloud Connector using the deactivated SIM card can no longer use cellular services. The procedure does not affect Wi-Fi or Ethernet services.
Procedure
  1. Access the Edge Nodes Inventory page and click the name of the Cloud Connector you want to affect.
    Oracle ECP displays the Edge Nodes Details page.
  2. On the Cloud Connector Details page, click the three ellipses in the left pane.Oracle ECP displays the actions menu.
  3. On the Device Details page, click the ellipses at the top of the left pane to display the Actions menu.
  4. On the Actions menu, click Manage SIM Activation State.
  5. In the Manage SIM Activation State panel (displayed on the right), locate the SIM you wish to manage. Select the Deactivate checkbox.
  6. In the actions menu, click Deactivate SIM.
    Oracle ECP displays a confirmation dialog.
  7. Click Update to apply your changes.
    In a few moments, Oracle ECP displays a success message and changes the SIM Activation State to Deactivated.
