Decommission a Cloud Connector
When you no longer want to use a Cloud Connector with Oracle Enterprise Communications Platform (Oracle ECP), you can remove it from your inventory with the following procedure. Oracle ECP retains historical information about the decommissioned Cloud Connector in the database after decommissioning.
Decommissioning a Cloud Connector is a final action. Once decommissioned, it can no longer re-onboard it to Oracle ECP. The Cloud Connector must be returned to Oracle before the hardware can be reused.When a cloud connector is decommissioned, Oracle ECP returns it to an unconfigured state. This helps remove the previous deployment configuration before the device is returned to Oracle.
When you decommission an Cloud Connector with a satellite connection, Oracle ECP deactivates the satellite service line and removes the satellite terminal from service. The satellite terminal becomes available for assignment to another Cloud Connector.
The Decommission action for a Cloud Connector in the Shipped lifecycle state is single-select. Bulk decommissioning of Shipped Cloud Connectors is not available.- Review Offboarding Requests on the Requests screen to monitor as this process completes.
