About Edge Node Filter Chips
To refine the data displayed on the Oracle Enterprise Communications Platform (Oracle ECP) Edge Nodes Inventory page, you can narrow a search by using the default filter chips, typing the name of a column header, or typing other text in the Search field.
Default Edge Node Filter Chips
The default filter chips, located below the Search field, are based on a subset of the column headings available for the page. The Search field is empty by default. You add filter chips to the Search field by clicking them. You can add multiple filter chips to the Search field and you can combine them with those you create from the column headings.
When you click the filter chip, Oracle ECP, moves it into the Search field. You can add multiple filter chips to the Search field and you can combine them with custom filter chips.
When a filter chip is in the Search field, click it to see the list of additional filter values available for that filter type. For example, the Life Cycle State filter chip offers Active, Inactive, Onboarded, and Shipped as additional filters.
The following table lists and describes the default filter chips on the Edge Nodes Inventory page.
  • Filter Chip—Displays the name of the filter chip type.
  • Default Filter—Displays the name of the default filter among those available for the filter chip type.
  • All Filters—Lists all the parameters available for the filter chip type.
Filter Chip Default Filter All Filters
Customer The customer at the top of the list. Any other customer
Connectivity State Connected Connected | Disconnected
Connectivity Type Cellular Cellular | Ethernet | Satellite
Data Plan 0MB 0MB | 500 MB | 100MB | 2GB | 3GB | 5GB | 10GB | 20GB | 100GB | 500GB
Organization Unassigned Unassigned | All Organizations
GBU The GBU at the top of the list. Any other GBU.
Lifecycle State Active Active | Inactive | Onboarded | Shipped
Network Priority No No | Yes
MNO The MNO at the top of the list. Any other MNO
MNO Account The MNO Account at the top of the list. Any other MNO account
Usage Status In Use In Use | Not In Use
Live Location Reporting enabled Shows compatible edge nodes with GPS location reporting enabled. An edge node without a reported position cannot be plotted on the map.
Custom Filtering
When you want to search the Edge Nodes Inventory Page Column Headers that are not represented by a default filter chip, you can type arbitrary text of your choice into the Search field. For example, suppose you want to see results for Serial Number. Type some or all of the word and press Enter. Oracle ECP searches the Serial Number column and displays results for Serial Number. You can combine custom filters with the default filter chips to get specific results. Oracle ECP limits the number of custom filters to three.
