Cloud Connector Application Management
Cloud Connectors rely on applications to perform their operations and Oracle Enterprise Communications Platform (Oracle ECP) provides the minimum set of applications required to run the system. You can install and manage other applications to meet the needs of your deployment with the tools Oracle ECP provides.
| Edge ID | The ID number of the selected Cloud Connector. The ID number of the selected Cloud Connector. Valid values: 5 to 100 alphanumeric characters with only the underscore and hyphen special characters allowed. The edge ID must be unique for the tenant. |
| Serial Number | The serial number of the selected Cloud Connector. The serial number of the selected Cloud Connector. Valid values: 5 to 100 alphanumeric characters with only the underscore and hyphen special characters allowed. |
| MAC Address | The MAC address of the selected Cloud Connector. Valid values: Hexadecimal 0-9, A-F, and a-f. Format: XX:XX:XX:XX:XX:XX or XX-XX-XX-XX-XX-XX or XXXX.XXXX.XXXX . |
| Model | The model name of the selected Cloud Connector. Valid values: 0-100 alphanumeric characters with only the underscore, hyphen, and space special characters allowed.. The model must start with an alphanumeric character. |
| Application | The name of the application. |
| Version | The version of each application currently installed. |
| Installed | The date when the current version of the software was installed. |
| Type | The type of application. |
| Status | The current state of the application. Active | Created | Running | Paused | Exited | Unknown. |
You cannot stop or remove system applications.| Package Name | The names and versions of the available packages. |
| Creator | The name of the person or entity that created the application. (Optional—May or may not display a name.) |
| Creation Date | The date when the version of the package was created. |
| Expiration Date | The date when the version of the package expires. |
| Documentation | The link to the package Release Notes or other documentation, if available. |
| Package Contents | The description of each component in the selected package. |
| Version | The version of each component in the selected package. |
The Manage Platform drawer shows the deployment options below the selected package. The only supported choice at this time is Immediate, which deploys the package right away when you click Deploy.
To see more details about the applications on a particular Cloud Connector, click the name of the Cloud Connector on the Cloud Connector Inventory page to go to the Edge Node Details page. On the Edge Node Details page, click the Applications tab. In the Applications drop-down list, click the application you want to know about.
