Unassign or Move Devices Between Organizations
Administrators have the ability to transfer devices between organizations and also can remove a device from an organization if needed.
Context: When devices are moved, it triggers automatic updates to the device's hardware group, configurations, and applications based on the destination organization's settings.
Before You Begin:
- To confirm the device's current organization, select the Inventory tab.
- Identify the source and destination organizations by selecting the Organizations tab and navigating to the organizational hierarchy page
