Reboot a Cloud Connector
When you need to reboot a Cloud Connector, you can do so from the Oracle Enterprise Communications Platform (Oracle ECP) Edge Nodes Inventory page.
Before You Begin
- On the Edge Nodes Inventory page, confirm that the target Cloud Connector is the Active Lifecycle State and is in the Connected Connectivity State.
Procedure
