4 Monitor and Trace Tab
The Monitor and Trace tab displays the results of filtered SIP session data from the Oracle® Enterprise Session Border Controller. The page displays the results in a common log format for local viewing.
Monitor and Trace supports the following summary reports
that you can export to a PC.
- Sessions
- Registrations
- Subscriptions
- Notable events
Each report provides sorting, searching, and paging functionality. You can customize the columns in each report and use the buttons on the page to display additional information or to perform a task.
The SIP Monitor and Trace function can store messages per
session and it can store cumulative sessions across all report types. Once the
sessions maximum is reached, the system removes the oldest call and adds the
newest call.
- On systems with less than
4GB of RAM, the system can store:
- 50 messages
- 2,000 sessions
- On systems with more than
- 50 messages
- 4,000 sessions
The system can perform live paging from Monitor and Trace tables.
Monitor and Trace does not support multiple, simultaneous viewers. Only one user at a time can view Monitor and Trace information.
