2 Using the FTRA
This chapter contains information regarding the various ways to use the FTRA.
FTRA Initialization
To start the FTRA, double-click the FTRA icon on the desktop. When the application starts, the FTRA window is displayed.
STP Connection Configuration Menu
Before database tables can be retrieved from an STP or command files can be sent to an STP, the STP must be defined in the STP Connection Configuration database.
Select Edit > STP Connection Configuration.
The below figure shows the description of the fields, buttons, and boxes in the STP Connection Configuration Menu window.
Figure 2-1 STP Configuration
STP Configuration
Table 2-1 STP Connection Configuration Menu Description
Item Description
Fields
STP Name
The STP name must contain at least one alphanumeric character and a maximum of 64 upper-case alphanumeric characters. The STP Name must always be entered in uppercase regardless of the Caps Lock key setting on your keyboard.
This field also provides a drop down list for selecting stored STP configuration records.
Primary IP Address
It is the primary IP Terminal card address of the associated STP (used for telnet sessions). The FTRA uses this IP Terminal card address first when connecting to the STP. The primary IP Terminal card address is the IP address of a service module in the associated EAGLE.
Backup IP Address
It is the backup IP Terminal card address of the associated STP (used for telnet sessions). The FTRA uses this IP address when the connection using the primary IP address fails. The backup IP address is the IP address of anotherservice module in the same EAGLE.
The FTRA does not attempt to make a Telnet connection with the backup IP address (if the backup IP address is configured) of the alternate service module on the EAGLE if the connection with the primary IP address is established but no IP terminal is available.
STP UserName
It is the user name assigned to the user by the STP system administrator (used for telnet sessions).
STP Password
It is the password assigned to the user by the STP system administrator (used for telnet sessions).
FTP UserName
It is the username assigned to the user by the administrator (used for FTP). Any FTP user name with symbols must be enclosed within double quotation marks. (For example, to specify the FTP user namemylogin#1, you would enter “mylogin#1”).
FTP Password
It is the FTP password assigned to the user by the administrator (used for FTP)
Buttons
Refresh
It displays the data of the STP configuration record typed in the STP Name field. If an STP name is selected from the STP Name drop down list, the data fields are automatically displayed.
Test
It verifies that the FTRA can successfully connect and login to the EAGLE through an available telnet terminal at the specified IP Terminal card address.
The STP Connection Configuration Menu window has two Test buttons, one for the Primary IP address, and one for the Backup IP address.
Select
It selects the displayed STP name to be connected to the FTRA.
Add
It adds a newly entered STP configuration record and associated data to the STP Connection Configuration database.
Modify
It modifies the fields of the displayed STP configuration record.
Delete
It deletes the displayed STP configuration record and associated data from the STP Connection Configuration database.
Close
It closes the STP Connection Configuration Menu window.
Boxes
Secure Connection
It enables the FTRA to use a secure IP connection to the STP.
To use a secure connection for the FTRA to EAGLE communication, make sure the EAGLE OA&M IP Security Enhancements feature is enabled and activated, and SSH and SECURITY parameters are ON. The OA&M IP security feature can be verified by entering the rtrv-ctrl-feat command at the EAGLE.
If the EAGLE OA&M IP Security Enhancements feature is not enabled or activated, perform the “Activating the EAGLE OA&M IP Security Enhancements Controlled Feature” procedure in Database Administration - System Management User's Guide and enable and activate the EAGLE OA&M IP Security Enhancements feature.
The SSH and SECURITY parameters can be verified by following the below mentioned procedures:
  1. To verify the SSH parameter, enter the command rtrv-secu-dflt. If it is not ON, enter chg-secu-dflt:ssh=on command to turn it ON.
  2. To verify the SECURITY parameter, enter the command rtrv-ftp-serv. If the SECURITY feature for the required FTP Server entry is not ON, use chg-ftp-serv command to turn it ON.
This box should be unchecked if the EAGLE OA&M IP Security Enhancements feature is not enabled or activated, and will not be enabled or activated, or either of SSH and SECURITY parameter is not ON.
If this box is checked, the public key fingerprint for the EAGLE specified in this window must be installed onto the FTRA for the FTRA and the specified EAGLE to use a secure connection. After the STP is added to the STP Connection Configuration database, add the public key fingerprint to the FTRA. For this, see the "Secure EAGLE Host Key Provisioning' section.
Use STP and FTP UserNames, Passwords for all STPs Box
All the STP and FTP user names and passwords of all the provisioned STPs are changed to the user name and password of the displayed STP name. This change occurs only when the Add or Modify buttons are used.
Displaying an Existing STP Configuration Record
An existing STP configuration record can be displayed by either selecting the STP Name from the STP Name drop down list, or by re-entering the STP name in the STP Name field in the STP Connection Configuration Menu window and clicking the Refresh button.
To Use the STP Name Drop Down List
  1. In the STP Connection Configuration Menu window, click on the STP Name drop down list and select the appropriate STP name.
    Figure 2-2 Selecting an STP Name from the STP Name Drop Down List
  2. When the STP name is selected, the STP configuration record for the specified STP is displayed. The Refresh, Test, Select, Delete, and Close buttons are enabled.
Entering the STP Name
  1. Type the STP name in the STP Name field in the STP Connection Configuration Menu window. The Refresh, Test, Select, Delete, and Close buttons are enabled.
    Figure 2-3 Selecting an STP Configuration Record by Typing in the STP Name Field
  2. Click the Refresh button. The STP configuration record for the specified STP is displayed.
    Figure 2-4 STP Configuration Record
  3. If the STP name was entered incorrectly, or is not in the STP configuration record database, the "STP Name does not exist" error message is displayed.
Testing an STP Configuration Record
  1. Select Edit > STP Connection Configuration from the FTRA window.
    The STP Connection Configuration Menu window opens.
  2. Display the STP configuration record to be modified.
    For more information, see "Displaying an Existing STP Configuration Record" procedure.
  3. Click the Test button.
    The Connectivity Test Log window opens. See Figure 2-5 and Figure 2-6.
    The Connectivity Test Log contains the events of the Test process and any error messages that may have occurred. The Connectivity Test Log window opens at the start of the Test process and is automatically cleared whenever a subsequent Test process is initiated.
    Figure 2-5 Connectivity Test Log Window with No Errors
    img/t-connectivity-test-log-window-no-errors-42.jpg
    Figure 2-6 Connectivity Test Log Window with Errors
    img/t-connectivity-test-log-window-errors-42.jpg
  4. When the test is complete, the Command Complete window opens.
    Click OK to continue.
Clearing the Connectivity Test Log Display
The display can be cleared, enabling new entries to be captured to the log. Once the log is cleared, the existing entries are lost unless the log is saved to a file or printed before the display is cleared.
  1. Select File > Clear Display in the Connectivity Test Log window.
    The Connectivity Test Log display clears.
Printing the Connectivity Test Log
  1. Select File > Print in the Connectivity Test Log window.
    The Print window opens.
Saving the Connectivity Test Log to a File
  1. Select File > Save in the Connectivity Test Log window.
    The Save window opens.
  2. Select a location for the file, and enter the file name and file type (with either the .doc or .txt extensions).
  3. Select Save.
    A saved file confirmation window opens with “Data saved to file.”
Modifying an Existing STP Configuration Record
  2. Display the STP configuration record being modified.
    For more information, see the "Displaying an Existing STP Configuration Record" procedure.
  3. Select and change the STP configuration record parameters.
    The Modify button is enabled when new data is entered into any of the fields, or when the Use STP and FTP UserNames and Passwords for all STPs box is checked.
    The STP name cannot be changed.
  4. To apply the changes, click Modify.
    The displayed STP configuration record is modified, and all fields are cleared. To confirm that the STP configuration data has been modified, the STP Data Modified window is displayed. Click OK in the STP Data Modified window to continue.
    Caution:
    If the Use STP and FTP UserNames and Passwords for all STPs box is checked, then all user names and passwords for all STPs in the STP Configuration database are changed to the user name and password for the displayed STP.
    Caution:
    It is recommended that the setting for the Secure Connection box is not changed, unless you have verified that the new setting for the Secure Connection box will match the state of the EAGLE OA&M IP Security Enhancements feature, and SSH and SECURITY parameters on the STP.
    The state of the EAGLE OA&M IP Security Enhancements feature can be verified by entering the rtrv-ctrl-feat command at the EAGLE. If the EAGLE OA&M IP Security Enhancements feature is not enabled or activated, or either SSH or SECURITY parameter is turned OFF, the Secure Connection box should be unchecked. If the EAGLE OA&M IP Security Enhancements feature is enabled and activated, and SSH and SECURITY parameters are turned ON, the Secure Connection box should be checked.
    To change the state of the EAGLE OA&M IP Security Enhancements feature, perform the “Activating the EAGLE OA&M IP Security Enhancements Controlled Feature” procedure in Database Administration - System Management User's Guide.
    To change the state of SSH parameter, use chg-secu-dflt command. To turn it ON, use chg-secu-dflt:ssh=on. To turn it OFF, use chg-secu-dflt:ssh=off.
    To change the state of SECURITY parameter, use chg-ftp-serv command with required server entry and change the SECURITY parameter appropriately.
    If the STP configuration record being changed is shown in the Current STP Selected field, a Modify Warning window is displayed.
    Click Yes to continue.
    If you do not wish to apply the changes, click the Refresh button in the STP Connection Configuration Menu window. This resets the STP configuration record values.
  5. Verify that the changes were made.
Deleting an STP Configuration Record
  1. Select Edit >STP Connection Configuration from the FTRA window.
  2. To display the STP configuration record being deleted, see "Displaying an Existing STP Configuration Record" procedure.
    The Delete button is enabled when an existing STP configuration record is displayed.
  3. To delete the STP configuration record, click the Delete button.
    The Delete STP window opens.
    Click OK to delete the STP configuration record. The STP configuration record is deleted.
  4. Verify the STP name is no longer in the STP Connection Configuration database.
    See "Displaying an Existing STP Configuration Record" procedure for same.
Selecting the Current STP
Before retrieving database tables from an EAGLE, or sending commands to an EAGLE, that STP name must be shown in the STP Connection Configuration Menu window as the current STP. The Current STP Selected: indicator in the STP Connection Configuration Menu window shows which STP is the current STP.
  1. Display an existing STP configuration record.
    See "Displaying an Existing STP Configuration Record" procedure.
  2. Click the Select button.
  3. The selected STP name appears in the title bar of the window, and Current STP Selected:<STP Name> appears in the STP Connection Configuration Menu.
  4. If you do not wish to use the STP name selected in step 2, click the No button in the STP Selection Change window.
    The current STP configuration record is displayed.
An EAGLE using secure connections has a unique host key for each service module in the EAGLE. This key is used by the FTRA to positively identify or authenticate each service module’s telnet server on the EAGLE. The FTRA will not connect to an unauthenticated server. The FTRA authenticates the server by matching its pre-installed host key with the key received from the EAGLE when the connection between the EAGLE and the FTRA is made.
This procedure adds the IP addresses of the EAGLE to the FTRA in the hosts.xml file placed in the cfg directory under the FTRA installation directory.
This procedure must be performed for each IP Terminal card on each EAGLE that the FTRA will connect to, but only for EAGLE using secure connections to connect to the FTRA. This procedure must be performed before any secure connection between the EAGLE and the FTRA is initiated.
If an IP address has not been added to the FTRA’s hosts.xml file and you try to initiate a secure connection to the EAGLE, you will receive the STP Primary IP address is missing from host.xml file. To use this IP address with security. check the secure connection checkbox and add IP address in hosts.xml file. warning message.
If the warning message is received, either clear the Secure Connection check box in the STP Configuration Record for the STP or add the IP address to the FTRA’s hosts.xml file.
Once the IP Terminal card is installed into the EAGLE, the public host key fingerprint for the service module will change only when power to the service module is disrupted by removing the service module from the shelf, then reinserting the service module into the shelf, or as the result of any event that interrupts power to the service module. Re-initializing the service module will not change the public host key fingerprint for the service module. This procedure will have to be performed for each public host key fingerprint on the EAGLE that has changed.
The public host key fingerprint is added to the FTRA’s hosts.xml file. If the public host key fingerprint has not been added to the FTRA’s hosts.xml file, and you try to initiate a secure connection to the EAGLE, you will receive the STP Primary IP address is missing from host.xml file. To use this IP address with security either clear the secure connection checkbox or add it's host key to this hosts.xml file. warning message.
If the above warning message is received, then either clear the Secure Connection check box in the STP Configuration Record for the STP, or add the public host key fingerprint to the FTRA’s hosts.xml file.
The verification that the keys are installed on the FTRA is called strict host key checking. By default, strict host key checking is on. This enforces server (EAGLE) strong authentication, designed to provide security between the FTRA and the EAGLE. This also prevents a hostile server from tricking the FTRA into exposing any EAGLE login and password combinations.
Caution:
Do not set strict host key checking to off, unless your network is in a controlled and secure environment. If you set strict host key checking to off, the Connectivity Test Log will warn you each time you try to connect that the EAGLE public host key fingerprint has not been added to the hosts.xml file on the FTRA.
To set the strict host key flag:
  1. Open the application start file using any text file editor. On the Windows platform, open the ftra.bat file. On the Linux platform, open the ftra file.
  2. Insert the below mentioned text strings in the application start file, depending on whether you want strict host key checking on or off.
    • -DstrictHostKeyChecking=1 for setting strict host key checking to on (this is the default setting).
    • -DstrictHostKeyChecking=0 for setting strict host key checking to off
    This text string can be inserted anywhere between the %JRE_HOME%\bin\java and -cp text strings as shown in the following example.
    %JRE_HOME%\bin\java -Dstricthostkeychecking=1 -Ddebuglevel=2 -Dsshtools.home=%FTRA2_HOME% -Dftra2rootdir=%FTRA2_HOME% -cp ftra3.jar com.tekelec.ftra.gui. InterfaceSelector %1
  3. Save the changes and close the application start file.
  4. Use the rept-stat-card:appl=ips command to see the location of IPS cards in the system. On the EAGLE, enter the rtrv-trm command.
    The location of the service module is shown in the LOC column with the TELNET terminal type.
    This is an example of the possible output.
    rlghncxa03w 13-09-25 16:07:48 GMT  EAGLE 45.0.0
    CARD   VERSION      TYPE      GPL       PST          SST        AST
    1111   131-010-000  IPSM      IPSHC     IS-NR        Active     -----
    1317   -----------  IPSM      IPS       OOS-MT       Isolated   -----
    2217   131-010-000  IPSM      IPS       IS-NR        Active     -----
    Command Completed.
    rlghncxa03w 05-09-17 15:08:45 GMT EAGLE 34.0.0
    TRM  TYPE     COMM        FC    TMOUT MXINV DURAL
    1    VT320    9600-7-E-1  SW    30    5     99:59:59
    2    KSR      9600-7-E-1  HW    30    5     INDEF
    3    PRINTER  4800-7-E-1  HW    30    0     00:00:00
    4    VT320    2400-7-E-1  BOTH  30    5     00:30:00
    5    VT320    9600-7-O-1  NONE  30    5     00:00:30
    6    VT320    9600-7-E-2  SW    30    9     INDEF
    7    PRINTER  9600-7-N-2  HW    30    5     00:30:00
    8    KSR     19200-7-E-2  BOTH  30    5     00:30:00
    9    VT320    9600-7-E-1  SW    30    7     00:30:00
    10   VT320    9600-7-E-1  HW    30    5     00:30:00
    11   VT320    4800-7-E-1  HW    30    5     00:30:00
    12   PRINTER  9600-7-E-1  HW    30    4     00:30:00
    13   VT320    9600-7-O-1  NONE  30    5     00:30:00
    14   VT320    9600-7-E-2  SW    30    8     00:30:00
    15   VT320    9600-7-N-2  HW    30    5     00:30:00
    16   VT320    9600-7-E-2  BOTH  30    3     00:30:00
    TRM  TYPE      LOC              TMOUT MXINV DURAL      SECURE
    17   TELNET    1111             60    5     00:30:00   yes
    18   TELNET    1111             60    5     00:30:00   yes
    19   TELNET    1111             60    5     00:30:00   yes
    20   TELNET    1111             60    5     00:30:00   yes
    21   TELNET    1111             60    5     00:30:00   yes
    22   TELNET    1111             60    5     00:30:00   yes
    24   TELNET    1111             60    5     00:30:00   yes
    TRM  TRAF LINK SA  SYS PU  DB  UIMRD
    1    NO   YES  NO  YES NO  YES YES
    2    NO   NO   NO  NO  NO  NO  NO
    3    YES  YES  YES NO  YES YES YES
    4    YES  NO   NO  NO  NO  NO  NO
    5    NO   YES  NO  NO  NO  NO  YES
    6    NO   NO   YES NO  NO  NO  NO
    7    YES  YES  YES YES YES YES YES
    8    NO   NO   NO  NO  YES NO  YES
    9    NO   YES  NO  NO  NO  YES NO
    10   NO   NO   NO  NO  NO  NO  YES
    11   YES  YES  YES YES YES YES YES
    12   YES  YES  YES YES YES YES YES
    13   NO   YES  NO  NO  NO  NO  YES
    14   NO   NO   YES NO  NO  NO  NO
    15   YES  YES  YES NO  YES YES YES
    16   NO   NO   NO  NO  YES NO  YES
    17   NO   NO   NO  NO  NO  NO  NO
    18   NO   NO   NO  NO  NO  NO  NO
    19   NO   NO   NO  NO  NO  NO  NO
    20   NO   NO   NO  NO  NO  NO  NO
    21   NO   NO   NO  NO  NO  NO  NO
    22   NO   NO   NO  NO  NO  NO  NO
    23   NO   NO   NO  NO  NO  NO  NO
    24   NO   NO   NO  NO  NO  NO  NO
  5. Display the IP address assigned to the service module using the rtrv-ip-lnk command, specifying the card location of the service module shown in Step 4 and the port=a parameter.
    For this example, enter this command.
    rtrv-ip-lnk:loc=1111:port=a
    The following is an example of the possible output.
    rlghncxa03w 14-01-17 15:08:45 GMT EAGLE5 40.0.0
    LOC   PORT IPADDR           SUBMASK        DUPLEX SPEED MACTYPE AUTO MCAST
    1111  A    192.168.54.96    255.255.255.0  HALF   100   DIX     NO   NO
    If the Security Administration (SA) setting for all the terminals assigned to the service module specified in this procedure is set to YES, see the rtrv-trm output in EAGLE and skip this step .
  6. Change the Security Administration setting on the terminals assigned to the service module with the chg-trm command and specify the number of the terminals whose Security Administration setting is NO, and with the sa=yes parameter.
    chg-trm:sa=yes:trm=<TELNET terminal number>
    When the chg-trm command gets successfully completed, this message should appear.
    rlghncxa03w 05-09-17 15:08:45 GMT EAGLE5 34.0.0
    CHG-TRM: MASP A - COMPLTD
    When the service module is installed into the EAGLE, UIM 1493 is generated. The EAGLE IP addresses must be added to the FTRA in the hosts.xml file.UIM 1493 contains the DSA key fingerprint that needs to be added to the hosts.xml file. If you recorded the DSA key fingerprint for the service module when UIM 1493 was generated, skip Step 7 and go to My Oracle Support (MOS).
    Caution:
    If you are performing Step 7 from a telnet terminal, make sure the step is being performed from a telnet terminal that is not assigned to the service module being initialized. When the service module is initialized, you will lose all telnet connections supported by the service module.
  7. Obtain the DSAkey fingerprint for theservice module by performing the init-card command and specifying the location of the service module.
    init-card:loc=1111
    After the init-card command has been executed, UIM 1494 is generated. The DSAkey fingerprint is at the end of the output, in the hexadecimal format, and is shown in bold in this output example.
    0021.1494    CARD 1111     INFO    SSH Host Keys Loaded
                 DSA Server Host Key FTRA-formatted Fingerprint=
                  84 7c 92 8b c 7c d8 19 1c 6 4b de 5c 8f c5 4d
                 Report Date:05-03-17  Time:15:08:45
    If you wish to change the public host key fingerprint on the service module, remove and reinsert the service module. The public host key fingerprint does not change until the service module loses power. However, contact the My Oracle Support (MOS) before removing and reinserting the service module.
  8. Edit the FTRA hosts.xml file (in the $FTRA_HOME/cfg directory on Linux, or %FTRA_HOME%\cfg folder on Windows), using any text file editor. Add the Service Module IP address from the rtrv-ip-lnk output shown in Step 5.
    • To allow or deny host access, use the HostAuthorizations, AllowHost, and DenyHost elements and specify the appropriate Service Module IP address as shown in the following example:
      <HostAuthorizations>
      <!-- Add AllowHost elements here -->
      <AllowHost>10.248.13.56</AllowHost>
      <!-- Add DenyHost elements here -->
      <DenyHost>10.248.13.56</DenyHost>
      </HostAuthorizations>
    • To allow a host access, use the following format:
      <AllowHost>="<Service Module IP Address>"</AllowHost>
    • To deny a host access, use the following format:
      <DenyHost>="<Service Module IP Address>"</DenyHost>
    • DSA public key fingerprint is shown in the output of UIM 1493 when the service module is installed and in the output ofUIM 1494 when the init-card command is performed in Step 7. It has the following format:
    The value 767 preceding the DSA public key fingerprint is the length of the key in bytes. On your EAGLE, this value may be different. See the FTRA Connectivity Test Log to verify this value. The outputs of UIM 1493 or 1494 do not contain this value.
    The following is a sample /ftra/cfg/hosts.xml file before the new DSA fingerprint information is added.
    <?xml version="1.0" encoding="UTF-8"?>
    <AllowHost HostName="192.168.54.36" Fingerprint="767: 4a 9 ec d3 70 34 d2 91 f7 8b 75 a8 95 37 98 35"/>
    <AllowHost HostName="192.168.54.216" Fingerprint="767: bc 76 ac 53 1e fd 72 16 3e 9c dc d7 23 25 6 59"/>
    /// Add new fingerprints HERE, after last allowed host in the above list.
    The sample /ftra/cfg/hosts.xml file after the new DSA fingerprint information is added.
    <AllowHost HostName="192.168.54.96" Fingerprint="767: 84 7c 92 8b c 7c d8 19 1c 6 4b de 5c 8f c5 4d"/>
    There should be no duplicate IP addresses in this file.
  9. Save the file and exit the text editor.
  10. A secure connection can now be established to the IP address used in this procedure.
    Either add the STP containing the IP address to the STP Configuration Record, or if the IP address is already defined in the STP Configuration Record, change the existing record for this STP with the IP address used in this procedure. While adding a new STP record, or changing an existing STP record, make sure the Secure Connection check box is checked.
  11. After the STP record has been added or changed to use a secure connection, test the connection by performing the procedure.
    If the connection test is passed, the IP address is successfully installed.
    If the connection is refused, the Connectivity Test Log indicates there is a mismatched key entry as shown in the following example, and the Host Key Mismatch! pop-up window is displayed.
    2003-07-11 14:22:56.117: Stp Connectivity Test Process Manager: Testing STP11805011201
    2003-07-11 14:22:56.227: Telnet Terminal Session Manager: Initiating Secure Telnet Session with Eagle: 192.168.53.71:22
    2003-07-11 14:22:56.808: HostKeyVerification: Host 192.168.53.71 cannot be authenticated due to mismatched key entry!.
    The options in the Host Key Mismatch! pop-up window are as follows:
    Allow Once
    The key is temporarily stored for the current session and the connection is made.
    Always Allow
    The key is permanently stored and the connection is made.
    Don't Allow
    The key is not added and the connection is not made.
    If the connection test is passed, the public host key fingerprint is successfully installed. If the connection is refused, make sure that the information for the EAGLE and the FTRA shown in the Connectivity Test Log matches. The Connectivity Test Log shows the key received from the EAGLE host and the one contained in the hosts.xml file for the EAGLE host. The following is an example from the Connectivity Test Log containing a host key mismatch. The key received from the EAGLE host is shown in bold. The key contained in the hosts.xml file is shown in bold underline.
    2003-07-11 14:22:56.808: HostKeyVerification: ERROR: Host 192.168.53.71 cannot be authenticated due to a mismatched entry for this host in the hosts.xml file. The host key supplied by 192.168.53.71 is:  768: bb 7d 79 a2 7d ae 5d 5a 45 e2 44 58 cd 8a bd 83
    The current allowed key for 192.168.53.71 is:
                   768: ab 7d 79 a2 7d ae 5d 5a 45 e2 44 58 cd 8a bd 83
    2003-07-11 14:22:56.828: HostKeyVerification: Connection rejected...onHostKeyMismatch
FTP Server Configuration
An FTP server must be configured on the EAGLE using the FTP Server Configuration menu before database tables can be retrieved from the EAGLE, or command files can be sent to the EAGLE.
  • If the Secure Connection box in the STP Connection Configuration Menu window is checked, the IP address specified in the FTP Server Configuration menu must be the IP address of a secure FTP server. If the Secure Connection box in the STP Connection Configuration Menu window is not checked, the IP address specified in the FTP Server Configuration menu must be the IP address of a FTP server.
  • Any firewall between the FTRA and the FTP server configured in the FTP Server Configuration Menu window, must allow FTPs to the IP address specified in the FTP Server Configuration Menu window.
  1. Select Edit > FTP Server Configuration from the FTRA menu.
    The FTP Server Configuration Menu window opens.
    Figure 2-7 FTP Server Configuration Menu
    Table 2-2 FTP Server Configuration Menu Window Descriptions
    Item Description
    Fields
    IP Address
    The IP Address of the associated FTP Server.
    Path
    The complete path to the data tables transfer directory on the FTP Server.
    This directory must be the FTP user's default directory. This directory must be given complete read/write/execute permissions for all users. From Windows, this is commonly administered from within the FTP server software. From Linux, this is done with the chmod command. See your PC system documentation Linux man pages for full details on setting directory permissions.
    Subpath
    The subpath value used to inform EAGLE about the directory of data transfer. The subpath is the path of the data tables transfer directory relative to the user's default directory upon FTP login. A file separator ('\' or '/') is not used to begin the subpath string.
    For example, if C:\root\ftp is the FTP user's default directory and C:\root\ftp\data is the path of the data tables transfer directory, then the path and the subpath of the FTP Server Configuration should be set as:
    path = C:\root\ftp\data
    subpath = data
    Buttons
    Browse
    Opens the Select Starting Directory window to initiate a directory/file selection for the data tables.
    Set
    Stores the FTP server configuration data.
    Close
    Closes the FTP Server Configuration Menu window.
  2. Enter the IP address of the STP in the IP Address field.
  3. Enter the path for the FTP temporary data table storage area or click the Browse button.
    The Browse button opens the Select Starting Directory window to select the location for the temporary data table storage area.
    Figure 2-8 Select Starting Directory
    This directory must be given complete read/write/execute permissions for all users. From Windows, this is commonly administered from within the FTP server software. From Linux, this is done with the chmod command. Please see your PC system documentation or Linux man pages for full details on setting directory permissions.
    Table 2-3 Select Starting Directory Window Descriptions
    Item Description
    Fields
    Look in:
    A drop down menu that allows the user to browse through the directory structures.
    File Name:
    The name of the file to be selected.
    Files of type:
    A drop down menu that allows the user to select all files of a particular type.
    Buttons
    Select
    Takes the contents of the File Name field and loads it into the Path field of the menu
    Cancel
    Closes the Select Starting Directory window.
  4. Enter the Subpath.
    The image below shows the relationship between the path and the subpath:
    Figure 2-9 FTP Server Path and Subpath Relationship
    Consider the following points when setting the subpath:
    • The subpath must always be the last part of the path, starting after the user's default directory upon FTP login. If the value of subpath is not the last part of the path, the Invalid Sub Path warning is issued. For example, if the path value is set as C:\user\ftp\data and the subpath value is set as ftp\admin, the warning window is displayed and the FTP configuration data is not saved.
    • A file separator ('\' or '/') is not used to begin the subpath string. If a file separator is entered to begin the subpath, the same warning window is displayed and again the FTP configuration data is not saved.
    • The subpath is not a mandatory field only when the path is set as the FTP user's default directory. For example, if the FTP user's default directory is C:\root\ftp and the path is C:\root\ftp, then the subpath should be blank.
  5. Click Set.
    The FTP Server Data Set information window opens.
Retrieving Database Tables from an STP
Retrieve Tables Window
The Figure 2-10 is used to select the database tables to be retrieved from the selected STP. The Retrieve Tables window contains a list of predefined retrieve commands.
The Retrieve from STP and Retrieve from Local Database buttons determine whether new database tables are retrieved from the selected STP or if existing tables already retrieved from that STP will be used. If no tables exist for the selected STP, the Retrieve from Local Database button will be grayed out.
The output from the retrieve commands is converted to CSV files. When the retrieve operation is completed, the Command Complete window opens notifying the user if the retrieval was executed with or without errors. The Retrieve Tables Log opens allowing the user to view the events.
  • If you attempt to retrieve and convert the database tables for the GTT commands (rtrv-tt, rtrv-gtt) and the EGTT commands (rtrv-gttsel, rtrv-gttset, rtrv-gta) in the same retrieve tables request, you will receive a warning that errors can be caused by attempting to retrieve and convert the GTT and EGTT database tables from the same EAGLE. Click Yes to continue.
  • You may only retrieve and convert the tables corresponding to which feature is on, GTT or EGTT. If the EGTT feature is on, shown in the rtrv-feat output, the database tables for the rtrv-gttsel, rtrv-gttset, and rtrv-gta commands can be retrieved and converted. If the EGTT feature is off, the database tables for the rtrv-tt and rtrv-gtt commands can be retrieved and converted.
  • The errors will be caused when the retrieved GTT and EGTT database tables are converted to CSV files. Because only one set of the database tables, GTT or EGTT, can be retrieved and converted. The error will occur when the attempt is made to convert the database tables that could not be retrieved.
Figure 2-10 Retrieve Tables Window
The following Table shows the description of the fields and buttons in the Retrieve Tables window.
Table 2-4 Retrieve Tables Window Description
Item Description
Fields
Command List
Contains a predefined list of retrieve commands.
Selected Commands
These commands are used to determine which database tables are retrieved from the selected STP.
Any number of retrieve commands can be selected for retrieval.
Buttons
Add
Moves the highlighted commands from the Command List box to the Selected Commands box.
Remove
Moves any highlighted commands in the Selected Commands box back to the Command List box and places them in the Command List box in alphabetical order.
Reset
Moves all commands in the Command List box to the Selected Commands box. All highlights in the Selected Commands box are removed.
Retrieve
Initiates the retrieval of all the selected database tables represented by the selected retrieve commands. The database tables are transferred using an FTP connection and converted to CSV files.
Store
Stores the commands in the Selected Commands box which will be used by the Command Line Interface. This list is maintained even when the FTRA is shut down and restarted.
Load
Loads the commands into the Selected Commands box which are currently stored for Command Line Interface usage. This allows the user to verify the rtrv commands which will be executed by the Command Line Interface.
Retrieve from STP
Retrieves the database tables, based on the selected retrieve commands, from the selected STP instead of using the tables previously retrieved.
When selected, the FTRA uses the database table previously retrieved from the selected STP.
Close
Closes the Commands Menu window.
When a Retrieve Tables command is performed, the FTRA verifies that the EAGLE is running one of the supported releases. If the EAGLE is not supported, an error message is displayed and the Retrieve Tables command is terminated.
Figure 2-11 Retrieve Table Log - Release Not Supported Error
If the EAGLE release is supported, the Retrieve Tables command is performed and operations on the FTRA can continue.
  1. Select Edit > Commands > Retrieve Tables from the FTRA window. The Retrieve Tables window opens.
  2. To select commands in the Command List box of the Retrieve Tables window, click on a single command, a range of commands, or multiple commands.
  3. To move the commands selected in Step 2 to the Selected Commands box, click the Add button. The commands are moved to Selected Commands box.
    If no commands are being moved from the Selected Commands box to the Command List box, skip Step 4 and go to Step 5.
  4. To remove commands from the Selected Commands box, perform one of these steps:
    1. In the Selected Commands box, click on the command to be removed. It gets highlighted. Click the Remove button. The highlighted command is moved to the Command List box.
    2. To select a range of multiple commands to be removed, click on the first command and while holding down the Shift key, click on the last command to be removed. Click the Remove button. All highlighted commands are moved to the Command List box.
    3. Hold down the Ctrl key and click on each of commands to be removed. Click the Remove button. Only the highlighted commands are moved to Command List side.
    4. Click the Reset button. All commands in the Command List box are moved to the Selected Commands box. All highlights in the Selected Commands box are removed.
  5. To store the selected commands for the Command Line Interface, click the Store button on the Commands Menu window. Click OK to continue. To verify which retrieve commands are stored, click the Load button. The stored commands appear in the Selected Commands box.
    If database tables are to be retrieved from the selected STP, skip Step 6 and go to Step 7.
  6. To generate CSV files from database tables that are already retrieved from the selected STP, select the Retrieve from Local Database button after selecting the desired commands. Click the Retrieve button.
  7. Retrieve the database tables from the selected STP corresponding to the commands selected in Step 2 by selecting the Retrieve from STP button, then click the Retrieve button. The Retrieve Tables Log window opens and displays the message “Processing Retrieve Request, Please Wait” until the retrieve process completes.
    The telnet terminals on the EAGLE to which FTRA will be connecting should have their terminal settings set to all=no (use the EAGLE command chg-trm:trm=<telnet terminal>:all=no to make this setting and use the EAGLE command rtrv-trm to verify the EAGLE terminal settings). On an STP with heavy UIM output, this prevents the FTRA's terminal from being flooded with unrelated output, which could unnecessarily backlog command responses during FTRA operation
    If you are retrieving the database tables for any of these GTT commands (rtrv-tt, rtrv-gtt) and any of these EGTT commands (rtrv-gttsel, rtrv-gttset, rtrv-gta), see the beginning of this section.
    Figure 2-12 Retrieve Tables Log Window - Processing Retrieve Request
    This message is displayed until the retrieve process completes. The Command Complete window opens.
    1. If no errors occurred, the text ”Retrieve Tables processing completed without errors” “Please check Retrieve Tables Log for Results” appears in the Command Complete window.
    2. If errors occurred, the text ”Retrieve Tables processing completed with errors” “Please check Retrieve Tables Log for Results” appears in the Command Complete window.
      The Retrieve Table Log window opens. Click OK to continue.
Retrieve Tables Log
The Retrieve Tables Log contains the events of the retrieve processing and any error messages that may have occurred. The Retrieve Tables Log window opens after database tables have been retrieved from an STP and is displayed until the retrieve processing is complete. See the following figure:
Figure 2-13 Retrieve Tables Log Window without Errors
The Retrieve Tables Log displays the information of the CSV files generated for the selected retrieve commands. The filenames of the CSV files are displayed in ascending order except for the filename of the rtrv-stp CSV file. Since the rtrv-stp command CSV is not generated by the CSVGEN(X) utility, the CSV filename for the rtrv-stp command is not displayed in the sorted order with other CSV filenames, but it is displayed as the last entry in the filenames list. Since the Retrieve Tables Log is generated by the CSVGEN(X) utility, no record of processing the rtrv-stp command is displayed in this log. See the following figure as an example of the Retrieve Tables Log when the rtrv-stp command is processed
Figure 2-14 Retrieve Table Log with the RTRV-STP Command CSV Example
The log is automatically cleared when the next set of database tables are retrieved from an STP. Selecting View > Retrieve Tables Log from the menu also opens the Retrieve Tables Log window. See the following figure:
Figure 2-15 Retrieve Table Log with Errors
Clearing the Retrieve Tables Log Display
  • From the Retrieve Tables Log window, select File > Clear Display.
  • From the FTRA window, select View > Retrieve Tables Log. Select File > Clear Display in the Retrieve Tables Log window.
Printing the Retrieve Tables Log
Perform either step 1 or steps 2 and 3.
  1. Select File > Print in the Retrieve Tables Log window.
  2. Select View > Retrieve Tables Log from the View menu in the FTRA window.
  3. Select File > Print in the Retrieve Tables Log window.
Saving the Retrieve Tables Log to a File
  1. Select File > Save in the Retrieve Tables Log window.
    The Retrieve Tables Log window opens.
  3. Select File > Save in the Retrieve Tables Log window.
  4. Select a location for the file, and enter the file name and file type (with either the .doc or .txt extensions).
    The .doc file type is recommended. The user can use Microsoft Word to open the file, even if it is saved as a .txt file.
  5. Click Save.
  6. To save the file, click OK in the Saved file confirmation window to continue.
The FTRA Command Line Interface allows the user to retrieve the same database tables, using the EAGLE retrieve commands, from all configured STPs in the STP configuration database. The Store and Load buttons in the Retrieve Tables window are used to select these retrieve commands.
The Command Line Interface allows the user to change the STP Username and Password for an STP already configured in the system.
Before the Command Line Interface can be started, you must exit the FTRA application. To start the Command Line Interface retrieve process, enter the (ftra -c) at the DOS command prompt (in Windows) or at a shell command prompt (in Linux).
For modifying the Username and Password for an STP, three command line arguments have to be specified with the “-c” option (ftra –c stpname username password).
The user can automate this retrieve process through the use of external scheduling software such as Task Scheduled (on the Windows platform) and “cron” (on the Linux platform). Please see the platform's scheduling program for specifics on how to use the external scheduling software. For example, on the Linux platform, enter the man crontab command.
  1. Exit the FTRA application.
  2. On the Windows platform, at a DOS prompt, go to the \bin directory of the FTRA <install_directory> location.
  3. On the Linux platform, at a shell prompt, go to the /bin directory of the FTRA <install_directory> location.
  4. Enter the ftra -c stpname username password command. The stored rtrv commands are then sent to the provisioned STP. The data tables are retrieved and converted to the CSV file format.
    Result: The username and password shall be modified in the STP configuration for the specified stpname.
    Figure 2-16 FTRA Windows Scheduled Task
    The parameters specified in the command line are case sensitive. For example, an stpname specified as EAGLE, Eagle, or eagle are treated separately.
Figure 2-17 LINUX cron job scheduled via crontab
Figure 2-18 FTRA wrapper script example for LINUX
Figure 2-19 FTRA wrapper script example on LINUX for modifying STP configuration
  1. To automate the FTRA retrieve process, enter the ftra -c command, the path to the bin directory of FTRA i.e. <install_directory> and the start time in the external scheduling software such as Scheduled Task (in Windows, see ) or “cron” (in Linux).
    Result: When the start time is reached, the stored rtrv commands are sent to all the provisioned STPs. The data tables are retrieved and converted to CSV file format for the stored rtrv commands.
    However, to automate the FTRA retrieve process using three command line parameters, enter the ftra -c stpname username password command, the path to the bin directory of the FTRA such as <install_directory>, and the start time in the external scheduling software such as Scheduled Tasks (on Windows) or "cron" (on Linux).
    Result: The username and password shall be modified in the STP configuration for the specified stpname. When the start time is reached, the stored rtrv commands are sent to all provisioned STPs. The data tables will be retrieved and converted to CSV file format for the stored rtrv commands.
    If you are using “cron” on the Linux workstation, it might be necessary to create a wrapper script for FTRA to set environmental variables correctly
Updating Database Tables in the Selected STP
The Update Tables window is used to send EAGLE commands to the selected STP. The commands, in the form of a command file, are validated before being sent.
To send the command file to the selected STP, the command file is selected by entering the path and file name of the command file, or by selecting the file name of the command file from the Select window. The command file is then validated by clicking the Validate button in the Update Tables window. When the validation is completed, the Update Validation Complete window appears. From the Update Validation Complete window, the command file can be edited, sent to the selected STP or the Update Validation Complete window can be closed without sending the command file to the selected STP. The Update Tables Log contains the events of the command validation and any error messages that may have occurred.
The following table shows the description of the fields and buttons in the Update Tables window.
Figure 2-20 Update Table Window
Update Table Window
Table 2-5 Update Tables Window Description
Item Description
Fields
Command File
The path and file name of the command file are entered here. A command file contains the EAGLE commands used to modify database tables of the STP.
Stop on error box
If the box is checked, and an error is found during the validation of the commands, the validation stops and no further commands are validated. If the box is not checked, all commands are processed regardless of errors. The error results are displayed in the Update Tables Log.
Buttons
Browse
Opens the Select window to select the command file to send to the selected STP.
Validate
Validates the EAGLE commands using the offline database.
Close
Validating a Command File
  1. Select Edit > Commands > Update Tables in the FTRA window.
    The Update Tables window opens.
  2. Perform one of these steps.
    1. Enter the path and name of the command file in the Command File field.
    2. Click the Browse button.
      The Select window opens. Locate the folder containing the command file and click on the command file name. The command file name is highlighted. Click the Select button. The Select window disappears and the Update Tables window appears with the path and file name of the selected command file entered in the Command File field.
      The following table shows the description of the buttons in the Select window.
      Table 2-6 Select Window Descriptions
      Item Description
      Fields
      Look in:
      A drop down menu allowing the user to browse through the directory structures.
      File Name:
      Files of type:
      A drop down menu that selects all files.
      Buttons
      Select
      The contents of the File Name field and the path to the filename is loaded into the Command File field of the Update Tables window.
      Cancel
      Closes the Select window.
  3. To have the command validation stop if any errors are found, check the Stop on error box in the Update Tables window.
    If you wish to have the command validation processed regardless of any errors, uncheck the Stop on error box. The error results are displayed in the Update Tables Log.
    Figure 2-21 Update Tables Window with a Command File Selected and Stop on Error Box Checked
  4. Click the Validate button.
    The Update Tables Log window opens at the beginning of the validate process and displays the “Processing Validate Request, Please Wait” message until the validation of the command file is complete.
    When processing is finished, the Update Validation Complete window opens. Click OK to continue.
    Figure 2-22 Update Tables Log Window - Processing Retrieve Request
  5. The Update Tables Log window opens.
    It contains the events and error messages generated during the validation. .
Update Validation Complete Window
When the command validation has completed, the Update Validation Complete window opens notifying the user if the commands validated with or without errors. From the Update Validation Complete window, the command file can be edited, sent to the selected STP, or the window can be closed without sending the command file to the selected STP.
The following table shows the description of the buttons in the Update Validation Complete window.
Table 2-7 Update Validation Complete Window Description
Item Description
Edit
Opens the Command File Editor window and allows the user to make changes to the command file. To edit a command file, go to the section.
Commit
Sends the commands in the command file to the STP. A Command Complete window is opened and the Update Tables Log is updated.
If the Update Tables validation is completed with errors the Commit button is not displayed.
Stop
Closes the Update Validation Complete window without sending the commands in the command file to the STP.
Update Validation Complete Window with Errors
If the Update Validation Complete window shows that errors have occurred, the command file can be edited or the window can be closed without sending the command file to the selected STP. There is no Commit button in the Update Validation Completewindow and hence it prevents the sending of invalid commands.
To fix the errors in the command file, click the Edit button and go to the "Editing a Command File" section.
Sending a Command File to the Selected STP
To send the command file, click the Commit button in the Update Validation Complete window. The Commit button is shown only on the Update Validation Complete without Errors window. The validated command file is sent to the selected STP.
The Command Complete window opens and displays: “Update Tables processing completed without errors” and “Please check Update Tables Log for results.” Click OK to continue. The Update Tables Log contains the commit processing events.
Stopping Without Sending or Editing a Command File
To stop the process without sending or editing a command file, click the Stop button in the Update Validation Complete window. The Update Validation Complete window is closed. No changes are made to the command file and the command file is not sent to the selected STP.
To edit a command file, click the Edit button in the Update Validation Complete window. The Command File Editor window opens.
  1. When the editing is complete, perform one of the following steps.
    1. Select File > Save from the Command File Editor window.
      The command file is saved and the Command File Editor window remains open. The command file is not sent to the selected STP. The command file can be validated again in the Update Tables window.
    2. Select File > Save and Commit from the Command File Editor window.
      The command file is saved and the Command File Editor window closes. The Command Complete window opens and displays: “Update Tables processing completed without errors. Please check Update Tables Log for results.” Click OK to continue. The command file is sent to the selected STP. The Update Tables Log contains the commit processing events.
    3. Select File > Quit from the Command File Editor window.
      The Command File Editor window closes. The command file is not sent to the selected STP. If changes to the command file have been made, a window is displayed asking if you want to save the changes.
The Update Tables Log contains the processing events and any error messages that may have occurred during the validation and sending of a command file. The Update Tables Log window opens at the beginning of the validation process and displays “Processing Validate Request, Please Wait” until the command file validation is completed. The Update Tables Log window is automatically cleared when the next command file validation is started. Selecting View > Update Tables Log from the menu can also open the Update Tables Log window.
Clearing the Update Tables Log Display
  1. Select File > Clear Display in the Update Tables Log window.
  2. Select View >Update Tables Log in the FTRA window.
  3. Select File > Clear Display in the Update Tables Log window.
    The Update Tables Log display clears.
Saving the Update Tables Log to a File
  1. Select File > Save from the Update Tables Log window.
    The Update Tables Log opens.
  3. Select File > Save in the Update Tables Log window.
    The .doc file type is recommended. The user can use Microsoft Word to open the file even if it is saved as a .txt file
  5. To save the file, click the Save button.
    A Saved file confirmation window opens with “Data saved to file.” Click OK to continue.
Printing the Update Tables Log
  1. Select File > Print from the Update Tables Log window.
  3. Select File > Print from the Update Tables Log window.
The System Log
The System Log contains an event history and any errors that have occurred when database tables are retrieved from an STP, or command files are sent to an STP.
Figure 2-23 System Log Window
System Log Window
Clearing the System Log Display
  1. Select View >System Log in the FTRA window.
    The System Log window opens.
  2. Select File > Clear Display in the System Log window.
Printing the System Log
  2. Select File > Print in the System Log window.
Saving the System Log to a File
  2. Select File > Save in the System Log window.
  3. Select a location for the file, and enter the file name and file type (with either the .doc or .txt extensions).
    The .doc file type is recommended. The user can use Microsoft Word to open the file even if it is saved as a .txt file.
  4. To save the System Log to a file, click the Save button.
    A saved file confirmation opens with “Data saved to file”. Click OK to continue.
RTRV-STP Command
The rtrv-stp command provides a consolidated report of STP configuration on a system-wide basis.
Figure 2-24 Retrieve Tables window with rtrv-stp command selected for retrieval
RTRV-STP Command Retrieval Session
Below represented is the FTRA retrieval session when rtrv-stp command is supported on EAGLE. If the command is not supported on EAGLE, an error will be displayed and the retrieval session will be terminated.
Figure 2-25 Successful Retrieval Session for rtrv-stp command
Figure 2-26 Rtrv-stp Command unsupported on EAGLE release
About FTRA Window
The About FTRA window displays the version level of the FTRA and copyright information. To display the About FTRA window, select Help>About in the FTRA window.
FTRA release 4.5
FTRA 4.5 is compatible with EAGLE 45.0 and all future EAGLE releases.
SSH/SFTP Error Codes
Table 2-8 and Table 2-9 contain a list of the error codes that can be generated when making a secure connection between the FTRA, version 4.0 or greater, and the EAGLE. Each error code contains a brief description of the error and the suggested recovery action.
This section also contains procedures, following Table 2-8 and Table 2-9, for testing connectivity and network problems, and to verify that the setup for making secure connections is correct.
If secure connections to the EAGLE cannot be made, verify that the EAGLE OA&M IP Security Enhancements feature is enabled and activated by entering the rtrv-ctrl-feat command and verify the SSH and SECURITY parameters are ON by entering the rtrv-secu-dflt and rtrv-ftp-serv commands, respectively, at the EAGLE before performing any of the actions in Table 2-8 and Table 2-9.
If the EAGLE OA&M IP Security Enhancements feature is not enabled or activated, perform the “Activating the EAGLE O&AM IP Security Enhancements Controlled Feature” procedure in Database Administration - System Management User's Guide and enable and activate the EAGLE OA&M IP Security Enhancements feature.
If the SSH or SECURITY parameters are not ON, these parameters can be turned ON by entering chg-secu-dflt:ssh=on and chg-ftp-serv, respectively.
If any of the errors shown in Table 2-8 or Table 2-9 are encountered after the recovery procedure is verified, contact Customer Care center.
Table 2-8 FTP/SFTP/SSH Error Codes
SFTP SSH Generic Network Client Error Code Description Action/Recovery
User Errors
592
File open failed.
Invalid file name in the download list, or out of resources. Report this issue to Customer Care Center immediately.
593
The file name is already specified.
Report this issue to Customer Care Center immediately. (Internal SFTP implementation error).
594
Invalid Path
Verify that the path is valid in the FTP Server Configuration Menu window.
598
The SSHD daemon is not running on the destination system or the server IP address unavailable.
Verify that the IP address exists on network with a ping (See Connectivity Test – I and Connectivity Test – II). If the IP address exists on network, then verify that SSHD daemon is running on the destination machine using the ps -ef|grep sshd command.
629
The SFTP daemon is not running
Verify that the subsystem entry in the sshd_config file on the destination station is specified and points to the SFTP daemon.
633
User login failure.
Verify that the Username and Password in the STP Connection Configuration Menu window is valid and an account exists for the username and password on the SSHD server host.
SFTP Errors
SFTP Client Errors
597
SFTP client packet send failure
Perform these tests:
Make any fixes necessary and retry the connection.
If the problem persists, report the issue to Customer Care Center.
598
The SFTP connection is closed.
599
SFTP packet read failure
600
SFTP protocol error. The received message is larger than the expected packet size.
Verify that the SFTP/SSHD version is compatible with openSSH 3.0.2p1. Verify there is no network outage by performing the tests in Network Outage Trouble Shooting. If the error persists, report the issue to Customer Care Center.
601
SFTP client invalid ID failure
Notify Customer Care Center.
608
SFTP received an invalid ID in the response received during a read operation on remote directory.
609
SFTP handle mismatch error. This error is displayed when there is a failure to receive an expected handle upon successful READ/WRITE/
CREAT/TRUNC/EXCL of a file using SSH_FXP_OPEN on remote server.
610
Unexpected SSH2_FXP_ATTRS.
611
Unexpected SSH_FXP_NAME. SFTP using the SSH_FXP_OPENDIR opens a directory for reading. The server responds to this request with either aSSH_FXP_NAME or a SSH_FXP_STATUS message. This error code implies that an unexpected SSH_FXP_NAME is received.
612
The SFTP client uses the SSH_FXP_REALPATH request to have the server localize any given path name to an absolute path. This is useful for converting path names containing “..” components or relative pathnames without a leading slash into absolute paths. This error implies that there is a failure during this operation.
Check if the access to the path specified in the FTP Server Configuration Menu window is accessible and re-try the connection.
613
The SSH_FXP_READLINK request is used by the SFTP client to read the target of a symbolic link. The server will respond with aSSH_FXP_NAME packet containing only one name and a dummy attributes value. The name in the returned packet contains the target of the link. This failure implies that there is a failure during the READLINK operation.
614
The SFTP client receives SSH_FXP_DATA as a response to any file operations from the server. This error implies that the client received an unexpected SSH_FXP_NAME from the server.
615
The SFTP client received more data than expected.
616
The SFTP client failed to read the data from the file descriptor of the file specified for transfer.
SSH Client Errors
617
Excessive identity files. OpenSSH implementation contains the maximum of 100 identity files or the client configuration file is corrupted.
624
The debug levels allowed for SSH protocol in openSSH is 0-9. The client configuration file contains an error or is corrupted.
625
Failure to read the client configuration file.
626
Invalid compression level is specified in the client configuration file.
627
SSH failure to setup the IO with the server.
Verify that the SFTP/SSHD version is compatible with openSSH 3.0.2p1. Verify there is no network outage by performing these tests:
628
SSH failure to open the channel for theSSH connection with the server.
629
SSH failure to setup the channel for theSSH connection with the server.
630
SSH failure to verify the SSH client host key.
631
SSH user authentication failure. Please verify that only the password authentication is set to “yes” in the SSH server configuration file. See SSHD server configuration provided by vendor of the product. The FTRA and the EAGLE is compatible with openSSH 3.0.2p1.
Report the issue to Customer Care Center if the problem persists after the SSHD configuration file is verified.
632
The authentication method is NULL in the client software. This error is a failure to set the null authentication method.
Report this issue to Customer Care Center.
633
Permission is denied by the server due to authentication failure.
640
A bad message was received during the SSH authentication.
641
Missing authentication context, encountered during the SSH user authorization.
642
Failure during the public key read/verification operation.
643
Undefined SFTP SSH error.
644
UnexpectedSSH_FXP_STATUS error. An invalid status was received by the SFTP server.
645
A bad option was specified in the SSH client on the EAGLE.
646
An unsupported escape character was used in the SSH client on the EAGLE.
647
An unsupported cipher type was used in the SSH client on the EAGLE.
648
An unsupported MAC type was used in the SSH client on the EAGLE.
649
A bad port was used in the SSH client on the EAGLE.
656
Bad forwarding was used in the SSH client on the EAGLE.
657
Bad forwarding ports were specified in the SSH client on the EAGLE.
658
A bad dynamic port was specified in the SSH client on the EAGLE.
659
The host was not specified in the SSH client on the EAGLE.
660
An invalid option or argument was specified in the SSH client on the EAGLE.
661
The hostname was not specified in the SSH client on the EAGLE.
663
The SSH client was unable to load the cipher type on the EAGLE.
664
SFTP SSH SET NON BLOCKING CALL FAILURE
665
Compression is already enabled in the SSH client on the EAGLE.
666
Unknown cipher number on the SSH client on the EAGLE.
667
The SSH client key length is invalid.
668
No key is available on the SSH client on the EAGLE.
669
The secure connection was closed by the remote server, see the error on the SFTP/SSHD server side.
670
Connection failure due to network outage or the connection was lost due to a faulty SSHD/SFTP server or network.
671
An unexpected packet type was received from the SFTP/SSHD server.
672
A bad packet length was received from the SSHD/SFTP server.
673
A cryptographic attack was detected by the SSH client. Please notify the local system administrator.
Report the issue to Customer Care Center. This is not a software problem but there is a security threat. The keys/authentication may have to be updated immediately.
674
The SSH/SFTP client on the EAGLE failed to read from the remote side.
675
Corrupted check bytes were detected on the SSH/SFTP client on the EAGLE.
676
Corrupted MAC on input was detected by the SSH/SFTP client on the EAGLE.
Verify that the sshtools.xml file provided with FTRA software has the field as shown:
<!-- The Message Authentication Code configuration, add or override default mac implementations -->
<MacConfiguration>
<DefaultAlgorithm>hmac-md5</DefaultAlgorithm>
</MacConfiguration>
677
Corrupted pad on input was detected by the SSH/SFTP client on the EAGLE.
678
SSH/SFTP tried to close a connection that is already closed.
679
The SSH/SFTP client on the EAGLE failed to write to the remote side.
680
SSH/SFTP tried to set the packet size twice.
681
A bad packet size was detected by the SSH/SFTP client on the EAGLE.
SSH/SFTP Connection/Setup Errors
682
The connection timed out when SSH tried to connect to SSHD.
683
The SSH connection was refused by the remote server.
684
The SSHD server is unreachable.
685
The network has reset.
686
The SSH/SFTP connection has been aborted.
687
The SFTP/SSH connection has been reset by the peer.
688
Failed to allocate network buffers.
689
The SSH/SFTP socket is already connected.
690
The SSH/SFTP socket is not connected.
691
The network channel is down.
692
The SSHD/SFTP server connection host is down.
694
SFTP client channel read failure.
695
SFTP client channel write failure.
696
SFTP client channel open failure.
Table 2-9 Generic Network Error Codes
SFTP/SSH Generic Network Client Error Code Description Action/Recovery
40
A destination address is required.
Verify that there is an FTP server entry on the EAGLE using the rtrv-ftp-serv command, and re-try the connection.
41
Protocol wrong type for socket
42
The protocol is not available.
43
The protocol is not supported.
44
The socket type is not supported.
45
The operation is not supported on the socket.
46
The protocol family is not supported.
47
The address family is not supported.
48
The address is already in use.
49
The requested address cannot be assigned.
50
Socket operation on non-socket
51
The network is unreachable.
Verify that the connection tests and network outage numbers match as shown in these sections:
52
The network dropped the connection on reset.
53
Software caused the connection to abort.
54
The connection was reset by the peer.
Verify that the connection tests pass and network outage numbers are within the allowed limits as shown in these sections:
55
No buffer space available.
56
The socket is already connected.
57
The socket is not connected.
58
Can't send after socket shutdown
59
Too many references: can't splice
60
The connection timed out.
Perform these tests and verify that the FTP server address responds to the ping command from the ISPM.
61
The connection was refused.
Verify that there is a FTP server is running on the remote station by performing the FTP Server Verification test.
62
The network is down.
65
There is no route to the host.
67
The host is down.
30
Read-only file system
32
Broken pipe
35
Unsupported value
Troubleshooting Procedures
Component: The FTP server IP address shown in the FTP Server Configuration Menu window.
Supported Version/Specification: Any FTP server compliant with IETF RFC 959.
Test: On the Linux platform, execute the netstat -a|grep 21 command to verify that the FTP server is running on the machine with the IP address shown in the FTP Server Configuration Menu window.
On the Windows platform, check the Task Manager to verify that the FTP daemon is running.
SFTP /SSHD Server Verification
Component: The SSHD /SFTP server IP address shown in the FTP Server Configuration Menu window.
Supported Version/Specification: Version compatible with openSSH 3.0.2p1.
Test: On the Linux platform, execute the ps -ef|grep sshd command. See Linux MAN pages for help with ps command.
On the Windows platform, use the Task Manager to verify that the SSHD daemon process is running.
On the Windows platform, use the Task Manager to verify that the FTP daemon is running.
Component: Connectivity Test - I.
Supported Version/Specification: N/A
Test: To verify that there is a network connection available between the EAGLE and the FTP/SFTP server shown in the FTP Server Configuration Menu window.
On an EAGLE terminal, enter the pass:loc=xxxx:cmd="ping yy.yy.yy.yy" command, where xxxx is location of the service module associated with the IP address entered in the STP Connection Configuration Menu window, and yy.yy.yy.yy is the IP address of the FTP/SFTP server shown in the FTP Server Configuration Menu window.
Expected Result:
The RTT time and data sizes may vary.
Command Accepted - Processing
    rlghncxa03w 05-09-31 13:57:59 GMT  EAGLE5 34.0.0
    Command entered at terminal #5.
    PASS: Command sent to card
    PING command in progress
    rlghncxa03w 05-09-31 13:58:01 GMT  EAGLE5 34.0.0
    PING yy.yy.yy.yy: 56 data bytes
    64 bytes from yy.yy.yy.yy: icmp_seq=0. time=10. ms
    64 bytes from yy.yy.yy.yy: icmp_seq=1. time=5. ms
    64 bytes from yy.yy.yy.yy: icmp_seq=2. time=5. ms
    ----yy.yy.yy.yy PING Statistics----
    3 packets transmitted, 3 packets received, 0% packet loss
    round-trip (ms)  min/avg/max = 5/6/10
    PING command complete
Component: Connectivity Test - II.
Supported Version/Specification: N/A.
Test: To verify that there is a network connection available between the EAGLE and FTP/SFTP server shown in the FTP Server Configuration Menu window.
Execute the ping -s zz.zz.zz.zz command on the FTP server machine where zz.zz.zz.zz is the IP address of the EAGLE shown in the STP Connection Configuration Menu window.
Expected Result:
ping -s zz.zz.zz.zz
PING zz.zz.zz.zz: 56 data bytes
64 bytes from e1011501-3-a (zz.zz.zz.zz): icmp_seq=0. time=5. ms
64 bytes from e1011501-3-a (zz.zz.zz.zz): icmp_seq=1. time=4. ms
64 bytes from e1011501-3-a (zz.zz.zz.zz): icmp_seq=2. time=5. ms
64 bytes from e1011501-3-a (zz.zz.zz.zz): icmp_seq=3. time=4. ms
----zz.zz.zz.zz PING Statistics----
4 packets transmitted, 4 packets received, 0% packet loss
round-trip (ms)  min/avg/max = 4/4/5
Component: Network Outage Troubleshooting
Test: To verify the TCP/IP traffic/network statistics are within the supported network statistics.
At the EAGLE, enter the pass:loc=xxxx:cmd="netstat -p tcp" command at the EAGLE terminal, where xxxx is location of the service module associated with the IP address entered in the STP Connection Configuration Menu window, and analyze the data from output which is similar to the following example output.
The specific information for the command may vary depending upon the system used.
> pass:loc=3102:cmd="netstat -p tcp"
    rlghncxa03w 05-09-31 19:32:52 GMT  EAGLE5 34.0.0
    TCP:
        161 packets sent
                156 data packets (28411 bytes)
                0 data packet (0 byte) retransmitted
                5 ack-only packets (1 delayed)
                0 URG only packet
                0 window probe packet
                0 window update packet
                0 control packet
        161 packets received
                156 acks (for 28255 bytes)
                0 duplicate ack+C2
                0 ack for unsent data
                5 packets (9 bytes) received in-sequence
                0 completely duplicate packet (0 byte)
                0 packet with some dup. data (0 byte duped)
                0 out-of-order packet (0 byte)
                0 packet (0 byte) of data after window
                0 window probe
                0 packet received after close
                0 discarded for bad checksum
                0 discarded for bad header offset field
                0 discarded because packet too short
        0 connection request
        1 connection accept
        1 connection established (including accepts)
        0 connection closed (including 0 drop)
        0 embryonic connection dropped
        156 segments updated rtt (of 157 attempts)
        0 retransmit timeout
                0 connection dropped by rexmit timeout
        0 persist timeout
        0 keepalive timeout
                0 keepalive probe sent
                0 connection dropped by keepalive
        0 pcb cache lookup failed
    NETSTAT command complete
Expected Result:
The network outage causes the TCP/IP problems such as:
  • Network latency
  • Packet drop
  • Duplicate packets.
If the TCP Packet Delay, TCP Packet Loss, TCP Packet Error, or TCP Out of Order values are greater than the values shown in Table 2-10, fix the network problems and retry the connection.
Table 2-10 TCP Fault Tolerance Table for FTP/SFTP
Protocol Fault Threshold Value
SFTP/FTP
TCP Packet Delay
175 milliseconds
SFTP/FTP
TCP Packet Loss
40% packet loss
SFTP/ FTP
TCP Packet Errors
10%
SFTP/FTP
TCP Out of Order
30% of packets with offset of 30 packets
SSH/SFTP/SFTPD/SSHD Protocol Troubleshooting
For more information on SSH/SFTP/SFTPD/SSHD protocol troubleshooting, see SSH, the Secure Shell: The Definitive Guide, First Edition, Barrett and Silverman, O’Reilly, February 2001.
