2 Building Base Cartridges
This chapter explains how to build base cartridges using the SDK. It discusses the sample Cisco base cartridge source files provided with the SDK. A brief overview of the steps required to build base cartridges is given, followed by detailed sections explaining all the required activities. Included are steps to try out the procedures on the supplied sample Cisco base cartridge source files.
For details on installing the SDK and the required third party tools, plus a detailed overview of all SDK concepts, a discussion of cartridge components, and an explanation of how cartridges integrate with the network processor, refer to IP Service Activator SDK Installation and Setup Guide.
This guide assumes:
That Oracle Communications IP Service Activator is deployed to a directory which will be referred to as Service_Activator_home. This directory is typically
C:\Program Files\Oracle Communications\Service Activator
That you have successfully installed the SDK to a directory which will be referred to as SDK_home
That the required versions of additional third party tools to support the SDK are installed correctly
That you have set up the required environment variables to support the SDK functions
For details on installing the SDK and the third party tool versions, refer to IP Service Activator SDK Developer Overview Guide.
Building a Base Cartridge
This section lists the steps required to build a base cartridge. Following a brief introduction to these steps, each step and all the activities required to execute it are covered in detail.
The steps to build a base cartridge are:
Creating a Base Cartridge Source Directory and Skeleton Properties File
In order to create your own base cartridge, you need to establish a uniquely named directory structure for the source files, and create the skeleton properties file that will be used to generate the starting source files.
Performing Device Characterization and Customizing the Skeleton Properties File
This step is an analysis of how the device performs the functions that the base cartridge is going to manage. You will need to gather information on login and logout sequences, prompts, and more.
Each cartridge you create with the SDK requires a skeleton properties file. In this file, you will edit the property values that control the generation of the cartridge source files. For complete details on all properties, refer to "Base Cartridge Generation Properties".
Generating Cartridge Source Files
This step uses the SDK tools to read the skeleton properties file and create the skeleton cartridge source files.
Customizing the Cartridge Source Files
This step is where most of your development effort will be spent. The key cartridge source components include:
Device Model (DM) schema definition
Service Model (SM) to DM transform
DM validation
Annotated DM to CLI transform
Message (success/warning/error) pattern definitions
There are many other source file components you may need to create or modify including files that support audit services, options, capabilities, and pre- and post-checks. These are described later in this chapter.
Compiling and Packaging the Cartridge
This step uses the SDK tools to compile and package the cartridge.
Performing Standalone Tests
Unit and device tests are created as part of the generated skeleton source files and are run using the SDK tools.
About the Provided Sample Base Cartridge
This section describes the provided sample base cartridge.
Components of the Provided Sample Base Cartridge
A sample working base cartridge for Cisco IOS devices, called cisco, is provided with the SDK in the form of:
A skeleton.properties file
This file is used to generate the source files for the sample base cartridge. For more information, see "Generating the Sample Base Cartridge Source Files".
Three pre-edited source files that demonstrate the edits required by the generated source files to produce a working cisco sample base cartridge.
...\audit\auditTemplate.xml
...\messages\successMessages.xml
...\xquerylib\dm2cli-common.xq
The provided sample source files are located in
SDK_home\samples\baseCartridge\cisco\...
while the generated sample cartridge source files are placed in
SDK_home\baseCartridges\cisco\...
Completing the Sample
To complete the sample, you can copy the provided files over their generated counterparts; or you can edit the generated files.
Purpose of the Provided Sample Base Cartridge
The pre-completed skeleton properties file illustrates how to populate the fields in the file for a working base cartridge. The provided sample source files are based on those generated by the sample base cartridge skeleton.properties file, but are customized further for Cisco IOS. This illustrates the typical post-generation steps you need to perform.
It can be useful to perform a diff between the customized sample source files and a set of generated sample skeleton source files, and then examine the difference between them.
The main values provided by the base cartridge sample are:
Shows how to fill out the skeleton properties for a base cartridge
Provides material to increase your understanding of the roles of the various prompt-related regular expressions
Demonstrates implementation of the config version check optional function
Lets you inspect the generated source files to see how a simple, working, base cartridge is constructed.
Lets you complete, compile and package the overwritten generated sample source files into a working base cartridge and deploy it in a test system.
Lets you take a copy of the provided skeleton properties file, relocate and rename it, and use it as the starting point to generate your own skeleton cartridge source files.
Sample Skeleton Properties File
The sample skeleton properties file that is used to create the source files for the cisco sample base cartridge is called
SDK_home\samples\baseCartridge\cisco\skeleton.properties
This properties file is pre-populated with the information needed to construct the starting source files for the cisco sample base cartridge - a working base cartridge that will support Cisco IOS devices.
Some of the generated source files will require editing or you can overwrite them with the provided source files.
As you read through the base cartridge creation steps, instructions are given on how to use the sample to test some of the SDK tools and commands.
Refer to "Base Cartridge Generation Properties" for details on all the properties implemented in the sample properties file which create the source files for the sample.
To create your own base cartridge, you will need to establish a directory structure for the source files, and create a skeleton properties file to generate the starting source files.
When deciding upon a directory structure for a new base or service cartridge care must be taken to choose a unique base directory name. If the path of a file in the new cartridge is the same as the path of a file in a deployed cartridge, undesirable behavior could occur.
The simplest method is to copy the sample skeleton.properties file and edit it for your own use.
To copy and edit the sample file:
Create a unique name that identifies the type of device the cartridge will support for your new base cartridge. This name will be referred to as target_device_name.
Create a new directory to hold your cartridge source files. For example:
SDK_home\baseCartridges\target_device_name
Copy the sample skeleton.properties file into your directory:
copy SDK_home\samples\baseCartridge\cisco\skeleton.properties SDK_home\baseCartridges\target_device_name
Edit your skeleton.properties file and change cisco to the target_device_name in the following entries:
## base cartridge name sdk_global_cartridgeName=target_device_name . . . ## packaging structure sdk_global_package=com.metasolv.serviceactivator.cartridges.target_device_name
Performing Device Characterization and Editing the Skeleton Properties File
To construct a base cartridge, you will need to identify the key aspects of a device's characteristics in order to configure the cartridge to appropriately interface with the device. This information is used to edit the skeleton properties file. The skeleton properties file is used to generate a set of customized cartridge source files for you to use as the starting point for your base cartridge.
As you gather the information in the categories below, refer to "Base Cartridge Generation Properties" for details on the how the information you collect is specified in the skeleton properties file.
Basic device characteristics include:
Discovery method: how IP Service Activator will be able to discover the device
Access: how to log in and log out of the device
Configuration mode: commands for entering and exiting a read/write configuration-type mode (e.g. privileged mode)
Prompts: the characters used by the device to represent a user-input prompt in various modes and circumstances
Audit commands: commands to retrieve the entire running configuration for the device for the purposes of comparing a persisted expected configuration with the actual configuration that is on the device
Saving the running configuration: commands to manage start-up and running configurations
Discovery Method
IP Service Activator primarily uses SNMP for discovery. The policy server component queries the device using SNMP MIBs and constructs the device topology, its interfaces and sub-interfaces in the IP Service Activator object model.
The amount of detail on the device retrieved through this basic SNMP discovery process may be sufficient to start construction of your base cartridge. You can test this by discovering your device as you normally would in the IP Service Activator client. Refer to the Service Activator online Help for more information about discovering one or more devices.
For additional information, see the discussion of network discovery and representation in IP Service Activator Concepts.
External Discovery
If the basic IP Service Activator SNMP discovery process does not properly discover the device, or leaves out critical details (such as interfaces, sub-interfaces, or VCs), consider developing an external discovery process.
An external discovery process consists of an application, typically written in Java, that connects to the device and then constructs the device topology and its parts in IP Service Activator using one of the available programming interfaces. The connection method can be telnet, SNMP, or whatever else is appropriate.
For Java-based external discovery processes, OJDL is the appropriate programming interface. If the external discovery process is authored using a shell script or perl, for example, then OSS Integration Manger (OIM) CLI commands would be used to interface with IP Service Activator.
It is beyond the scope of this document to describe exactly how to program an external discovery process. However, relevant programming interface information can be found in IP Service Activator OSS Java Development Library Guide and IP Service Activator OSS Integration Manager Guide.
The parsing of information retrieved from the device for relevant information is in the domain of the external discovery process.
At a minimum, an external discovery process should create a device object in IP Service Activator with the required attributes set (such as device type, version, and so forth). It should create the main interfaces under the device with appropriate attributes such as interface type, bandwidth, speed, etc. If necessary, it should populate IP Service Activator with any sub-interfaces present on the device.
Access: Logging In
This section describes the two aspects of the access device characteristic.
Logging In
When you create your cartridge's skeleton properties file, it must be configured for one of the login methods supported by the SDK. These are:
TACACS
SSH
Anonymous
Password-only
All of these login methods have similarities. Typically, the device presents a prompt for a username, and then a prompt for a password. The anonymous login method involves no prompts. The password-only login method prompts only for a password without a user name.
The skeleton properties which indicate the login methods supported by the device are:
sdk_authenticationTacacs_supported
sdk_authenticationSsh_supported
sdk_authenticationAnonymous_supported
sdk_authenticationPasswordOnly_supported
At least one of these properties must be set to true.
The login prompts used by the device are defined in the properties file as regular expressions. For example:
sdk_authenticationTacacs_useridPrompt=.*Username:
In this example, .*Username: is a regular expression that matches any line ending with the text "Username:". When the network processor matches input received from the device using this regular expression, it is recognized as a prompt for a TACACS username. The network processor then sends the username to the device.
Depending on the login procedure for the device, supply values appropriately for related login properties. For example, if you set sdk_authenticationTacacs_supported to true in the properties file, you will also need to specify values for many of the following additional properties:
sdk_authenticationTacacs_passwdPrompt
sdk_authenticationTacacs_errorPrompt
sdk_authenticationTacacs_enablePasswdPrompt
sdk_authenticationTacacs_enablePasswdPasswdPrompt
sdk_authenticationTacacs_enablePasswdErrorPrompt
If the device has two levels of authentication, then the ..._enablePasswdPrompt property should also be defined. The device presents this prompt when a user attempts to enter privileged mode (e.g. by entering the enable command on a Cisco device).
Tip:
To get the required prompt information for setting the login properties, connect to an actual device and take note of the prompts the device presents. Be sure to test invalid parameters so you can capture error messages returned, and use these in setting the various login error properties.
Configuration Mode
Most devices have two modes of operation: user (read-only), and configuration (read-write) mode. User mode allows you to query the device about its hardware, configuration or statistics, but bars you from making changes. Configuration mode allows modification of the device's configuration. For example, Cisco devices use the command configure terminal (or conf t for short).
In the skeleton properties file, specify the exact commands to enter and exit configuration mode on the device:
sdk_configMode_cmd
sdk_configModeTerminate_cmd
Prompt Matching
The Network Processor determines when a command it has sent to a device has been received by the reception of a prompt from the device.
The response time varies by device and command. On a slow connection, sending and receiving the command, and receiving the prompt may take a number of seconds. The Network Processor waits until it has received the return prompt to be sure that the command was received correctly.
Care must be taken when configuring a regular expression to match a prompt because prompts are configurable on a per-device basis. Additionally, prompts can change throughout the communication session.
For example, when a device is being configured, the prompt may change to show which area of the configuration is currently being worked on.
In a session:
The device presents the prompt mydevice> after successful login.
The prompt changes to mydevice# when the user enters privileged mode.
The prompt changes to mydevice(config)# when configuring.
The prompt may change to variants of mydevice(config-*)# when configuring.
In order to match a prompt, the Network Processor attempts to discover the prompt upon logging in. It remembers the original prompt and uses it throughout the communication session.
When configuring your base cartridge, the sdk_getConfiguration_matchPattern property defines a regular expression to be used by the Network Processor to discover the prompt upon login by matching the pattern with the responses from the device. There are also properties to define text which precedes and text which follows the prompt.
Table 2-1 lists the prompt definition properties and their matched regular expression.
Table 2-1 Prompt Definition Properties
| Prompt Definition Property | Description of Regular Expression |
sdk_getConfiguration_matchPattern |
After a successful login, Network Processor uses this expression to match on the prompt. The expression must contain one group that matches the core prompt. The network processor then uses this core prompt as a pattern to match on. Example: sdk_getConfiguration_matchPattern=([^>#\\n]*)[>#] This specifies that the prompt includes everything except the characters ">" and "#" or a new line that comes before one of the characters ">" or "#". The prompt "mydevice>" would match and the word "mydevice" would become the core prompt pattern. |
sdk_getConfiguration_prePendPattern |
Regular expression to match text which prepends the prompt, such as a command number (e.g. “10: mydevice>:), or whites pace. Example: sdk_getConfiguration_prePendPattern=\\n This specifies that the prompt could be preceded by a blank line. |
sdk_getConfiguration_appendPattern |
Regular expression to match text which follows the prompt, such as a special character Example: sdk_getConfiguration_appendPattern=(([>#])|(\\(.*\\)#)) This specifies that the prompt could be followed by the characters ">" or "#", or some context in parentheses followed by the character "#". It would match with: mydevice>
mydevice#
mydevice(config)#
mydevice(config-pmap)# |
sdk_getConfiguration_errorPattern |
Regular expression to match error response from login. |
sdk_getConfiguration_hostPattern |
Pattern to match the hostname within the prompt. |
Audit Commands
An audit compares the configuration that the Network Processor has persisted for the device with the actual configuration that is retrieved from the device. Commands not administered by IP Service Activator are filtered out.
In order to perform an audit, the Network Processor must be able to parse all of the commands on the device. Most devices allow this by providing a command that returns the entire configuration of the device (e.g. show-running-configuration on Cisco).
The required properties to configure auditing for a base cartridge are:
sdk_audit_supported
sdk_showRunningConfig_supported
sdk_showRunningConfig_cmd
To enable auditing, the base cartridge properties sdk_audit_supported and sdk_showRunningConfig_supported should be set to true. The property sdk_showRunningConfig_cmd should be set to the exact command to retrieve the current configuration of the device.
For complete details on these properties, refer to "Base Cartridge Generation Properties".
Saving the Running Configuration
Some devices have both a running configuration — the configuration that is currently executing on the device, and a startup configuration — the configuration that is loaded upon restart of the device. The startup configuration is stored on disk whereas the running configuration is usually only stored in memory.
Devices with running and startup configurations typically support the copying of one configuration to the other. For example, when a new configuration is applied to a device it may then be backed up to the startup configuration.
The properties that are used by the SDK to support this are:
sdk_saveRunningConfig_supported: set this to true to indicate support for copying the running configuration to the startup configuration
sdk_saveRunningConfig_cmd: set this to the exact command to copy the running configuration to the startup configuration
Configuration Version
IP Service Activator, when generating device models, generates a new configuration version statement that conforms to the following format:
YYYY-MM-DDTHH:MM:SS.sssZ
This configuration version is stored in the device model and is written to the device along with the general configuration commands.
The configuration version, read back from the device during audit and subsequent configuration updates, is used to determine if the last persisted device model is in sync with what is on the device. If the device and device model configuration versions match, then the last persisted device model should match with the commands on the device. If the configuration versions don't match, then either the last persisted device model is out of date or the device is out of sync with IP Service Activator.
The configuration version functionality consists of several sub-functions that an SDK developer needs to be aware of.
Configuration versioning in the target and last device models
Configuration versioning on the network devices
Configuration version pre-check prior to committing configuration changes to a device
Configuration version auditing
The first function is always performed by the cartridge framework. In other words, the target, and consequently, the last device models automatically contain configuration version information.
The last three functions are optional in the SDK. An SDK developer can enable them with the sdk_configurationversion_supported property. When set to true, the source file generator generates XQuery functions responsible for the following:
Transforming the configuration version in the annotated device model into CLI commands.
Retrieving the configuration version from the device, comparing it with the configuration version in the last device model and, when out-of-sync, raising faults that prevent making further configuration changes to a device that is out of sync.
SkeletonGeneratorProperties
The configuration version functions are further parameterized using 4 more properties which are only relevant when sdk_configversion_supported is set to true.
These properties are:
sdk_configversion_updateCmd=alias exec IpsaConfigVersion: the prefix of the CLI command that updates the configuration version on the device. The entire command is formed by appending the configuration version to it. For example:
alias exec IpsaConfigVersion 2007-08-12T12:59:00.234Z
sdk_configversion_removeCmd=no alias exec IpsaConfigVersion: the prefix of the CLI command that removes the configuration version from the device. The entire command is formed by appending the configuration version to it. For example:
no alias exec IpsaConfigVersion? 2007-08-12T12:59:00.234Z
sdk_configversion_showCmd=show aliases exec | include IpsaConfigVersion: the CLI command that retrieves the configuration version from the device. The result from this command is expected to be a single line which, among other things, must contain the configuration version.
sdk_configversion_extractCmd=IpsaConfigVersion? +(.+): a regular expression that, when applied against the result from sdk_configversion_showCmd must match, so that its first group is bound to the configuration version string.
The values assigned to the above properties illustrate what is suitable for generating a skeleton cisco IOS cartridge.
The SDK provides a tool to generate the base cartridge source files from the skeleton properties file. Once the source files are generated, you will need to edit the source files to complete your base cartridge.
Ensure that you save copies of any cartridge source files you alter prior to re-generating from the skeleton.properties file to ensure that you do not lose customization work. Alternatively, modify the skeleton.properties file so that a new target directory name is used. In either case, you will need to manually merge any alterations you made in the previous iteration if you want those changes to persist.
To generate the sample base cartridge source files using the data from the sample skeleton properties file:
Set the cartridge version string variable. For example, if the cartridge version is 1.0, on a Windows host, type the command:
set VERSION_STRING=1.0
In SDK_home, either:
Run the included batch file to run the cartridge generator script:
genbc samples\baseCartridge\cisco\skeleton.properties
or
Type in the command to run the cartridge generator script:
ant -DtemplateType=baseCartridge -DpropFile=SDK_home\samples\baseCartridge\cisco\skeleton.properties
To use the batch file, you must first add SDK_home\bin to your PATH variable where SDK_home is the SDK directory.
Result of Generation Process
The directory structure you created previously (see "Creating a Base Cartridge Source Directory and Skeleton Properties File") has been extended by using the sdk_global_cartridgeName value from the skeleton properties file. The cartridge source files generated under SDK_home\baseCartridges\sdk_global_cartridgeName\ include:
build.xml: ant build file to build the base cartridge
src\synonyms.xml: used by the audit process
src\...\audit\auditTemplate.xml: stub file for audit commands
src\...\capabilities\empty_caps.xml: stub file for capabilities information
src\...\messages\: contains .xml files with success, error and warning message patterns
src\...\options\options.xsd: stub schema file for cartridge options
src\...\schema\devicemodel.xsd: contains the stub base cartridge device model schema
src\...\test\: resources for testing the base cartridge
src\...\transforms\: transforms including pre-check, SM to DM, annotated DM to CLI, DM validation, and a restore template for Configuration Management support
src\...\xquerylib\: additional XQueries for SM to DM, DM to CLI, DM upgrade, DM version and pre-check.
src\...\cisco\auditLogging.properties: used to set property values for audit logging
src\...\cisco\Registry.xml: identifies the base cartridge instance
src\...\cisco\Customization.xml: can be used to override Registry.xml
A log file is also created within the logs directory:
SDK_home\logs\generator.log
To continue working with the sample base cartridge, go to "Completing the Sample Cartridge Source Files".
Generating Your Base Cartridge Source Files
When you create your own base cartridge, the cartridge name and the root folder for the generated source are based on the sdk_global_cartridgeName property value in the skeleton properties file. See "Creating a Base Cartridge Source Directory and Skeleton Properties File" for details. The property value is incorporated into the cartridge source files in place of sdk_global_CartridgeName.
To generate your skeleton base cartridge source files using your customized skeleton properties file:
genbc \baseCartridges\<sdk_global_cartridgeName>\skeleton.properties
or
ant -DtemplateType=baseCartridge -DpropFile=SDK_home\baseCartridges\sdk_global_cartridgeName\skeleton.properties
Result of the Generation Process
This extends the SDK directory structure in a similar manner to what is described in "Generating the Sample Base Cartridge Source Files".
It is possible to use a different name for the skeleton properties file. If you choose to do this, supply the new name instead of skeleton.properties in the ant commands.
Troubleshooting the Cartridge Generation
This section discusses where to find information to help you resolve cartridge generation issues.
Using an Alternate Directory Structure
If you are not using the standard directory structure to lay out all the configuration policies, base cartridges and service cartridges being developed using the SDK, then you must modify the Java sample build.xml file to ensure that all instances of sdkDir are replaced with valid paths to the respective files. The preferred way to do this is to set sdkDir to the top level directory for all the SDK-based artifacts.
Base Cartridge Generator Message Logging
The logging level of the cartridge generator can be controlled by editing the settings in the SDK_home\config\logging.properties file.
The default is to log debug level messages. Output is sent to both stdout and a logging file: SDK_home\logs\generator.log.
Troubleshooting Property File Attributes
If a mandatory attribute in the cartridge properties file is missing, source file generation will terminate prematurely. Refer to the log file to ensure that mandatory values are set. Lines such as:
Verify property set: propertyName propertyValue
indicate that the mandatory attribute named is being verified.
Lines such as:
Testing property: propertyName propertyValue
indicate that the propertyValue is being tested to ensure it compiles as a proper regular expression. If propertyValue does not compile correctly, code generation does not stop, but the following message is generated:
Testing property (suspicious pattern): sdk_testBadRegex_Pattern |)_+
When creating your cartridges, you will need to make appropriate edits to the skeleton source files to support the particular functionality you want to implement for your device.
The key cartridge source components you need to create and/or modify include:
Service Model (SM) to Device Model transform
Device Model validation
Annotated Device Model to CLI transform
Device Model Schema Definition
This device model extends the Network Processor's base device model to realize the new services being administered by the cartridge.
Service Model to Device Model Transform
This XQuery or java transform transforms the device-independent service model to a device-specific device model.
It is essential that the service model Definition IDs, which identify policy definitions, and Association IDs, which identify the links between defined policies and their target objects and their representative concretes in IP Service Activator, flow through from the service model to the device model.
Device Model Validation
If the cartridge registry entry <dmValidation> contains a dmValidation entry, the Network Processor will invoke this function to validate the transformed device model. This would capture logical faults as opposed to syntax faults which would be caught by the device model validation using deviceModel.xsd.
Annotated Device Model to CLI Transform
The Network Processor compares the target device model with the last device model that was persisted to the database after the last successful push to the device. The Network Processor annotates the target device model. For each policy object, the annotation includes the smId, a dmId that is generated by the Network Processor and a changeType which indicates whether configuration is being added, deleted or modified on the device.
The Network Processor invokes the <dmToCli> entry in the cartridge instance. This transforms the annotated device model into a CLI document that is a list of native configuration commands to be sent to the device.
Message Pattern Definitions
As part of the creation of a base cartridge, you will need to create success, error, and warning message pattern files. This section explains how to analyze device responses and create the appropriate entries in the message XML files.
For an overview of the concepts behind message files, refer to IP Service Activator SDK Developer Overview Guide.
Device Response Analysis
To analyze the device's response to issued commands, the responses are matched against known success, warning, and error patterns. Note the following:
A response from the execution of a single command may include multiple messages, and may be split across more than one line.
The response is treated as a single line for pattern matching.
In order to handle cases where responses match multiple types of response, patterns, a comparison order is employed as follows:
Success patterns are matched first. If the command response matches a success pattern, the command response is a success response.
If the command response does not match any success pattern, warning patterns are matched. The command response may be a blocking or non-blocking warning response.
If the command response does not match any success pattern or warning pattern, error patterns are matched. The command response may be an error response, if a match is found, or unknown error response, if a match is not found. The difference is that the fault message for a known error response will include the message associated with the error pattern.
If the command response does not match any success pattern, or warning pattern, or error pattern, the response is considered an unknown error response.
Example Device Response Pattern Match
This section contains an example of a response to a command which matches multiple types of response patterns.
Command sent:
rate-limit output access-group 100 8000 2000 2000 conform-action set-mpls-exp-transmit 0 exceed-action set-mpls-exp-transmit 1
Response received:
Illegal normal burst size
Increasing normal burst size to 4470
Illegal extended burst size
Increasing extended burst size to 4470
"set-mpls-exp-imposition-transmit" and "set-mpls-exp-imposition-continue"
not allowed in output rate-limit command.
Blocking warning pattern matched:
<!-- in theory, we could ignore this and continue. However, we receive the same message when removing the policing rule. This means a user could see the warning, correct the problem, and then see the warning return. --> <cmd:warningPattern blocking="true"> <cmd:pattern>(?s).*Illegal .* burst size.*Increasing .* burst size.*</cmd:pattern> </cmd:warningPattern> <cmd:warningPattern>
In this example the actual response pattern to match against the command response is:
The response also matches this unknown error response:
However, blocking warning patterns are matched first, so the outcome is:
Response is a blocking warning response.
Defining Device Response Patterns
As part of the base cartridge creation process, you must define the list of device command response patterns. Valid response pattern files are in XML format and conform to the cliModel.xsd schema.
Success, warning, and error response patterns are all defined as regular expressions.
Defining Success Response Patterns
The location of the successMessages.xml file is referenced in the successMessages element in each registry entry in the Registry.xml file.
To define success patterns:
Edit successMessages.xml and add success patterns as necessary, based on your observations of responses received from the actual device when particular commands are sent.
Success patterns are specified as regular expressions. For example, the following success pattern contains a comment between <!-- and --> and a pattern which will match a response containing the text QoS Reserved Bandwidth has been modified. Configuration may be affected."
<cmd:successPattern> <!-- -undo qos reserved-bandwidth command being issued --> <cmd:pattern>(?s).*QoS Reserved Bandwidth has been modified. Configuration may be affected.*</cmd:pattern> </cmd:successPattern>
Defining Warning Response Patterns
The location of the warningMessages.xml file is referenced in the warningMessages element in each registry entry in the Registry.xml file.
To define warning patterns:
Edit warningMessages.xml and add warning patterns as necessary.
A warning pattern is non-blocking by default.
For example:
<cmd:warningPattern> <cmd:pattern>(?s).*startup-config file open failed.*</cmd:pattern> </cmd:warningPattern>
To define a warning pattern as blocking:
In the warning pattern definition, set blocking="true"
For example:
Defining Error Response Patterns
The location of the errorMessages.xml file is referenced in the errorMessages element in each registry entry in the Registry.xml file.
To define error patterns:
Edit errorMessages.xml and add error patterns as necessary.
For example, the following error pattern contains a comment between <!-- and --> and a pattern which will match a response containing the text
Invalid input. The fault message will include the rejected command and the messageInvalid inputassociated with the error pattern.<cmd:errorPattern> <cmd:pattern>(?s).*Invalid input.*</cmd:pattern> <cmd:message>Invalid input</cmd:message> </cmd:errorPattern>
Options
Using the options framework in IP Service Activator, you can customize the configuration style for different device types and IOS combinations.
To do this, you define and document configuration options for a cartridge, and implement the variations in the service model to device model transform, and the annotated device model to CLI transform, based on the option values.
Option values for specific device type and IOS combinations are specified in option configuration files, which are registered by cartridge units in the Registry.xml file. The option configuration files, and the registry entries that reference them, may be customized by the system administrator once the cartridge is deployed.
Defining Options
When you use the cartridge skeleton generator tool to generate the base cartridge source files, a skeleton XML schema file named options.xsd is automatically created. This file contains the schema for the cartridge configuration options. Occurrences of ${sdk_global_cartridgename} are substituted with your cartridge's name in the resultant options.xsd file.
Add configuration option definitions to an options file to handle such things as device command format variants.
Using options.xsd as a starting point, create one configuration option file for each set of device type, and IOS combinations for which the same set of option values are required. For example, if option values correspond to command variants, then a configuration option file defines the set of command variants for a set of device type and IOS combinations.
Configuration options defined in options.xsd include:
Name: xml element name such as cartridge.sdk_global_cartridgeName.sampleEnumerationOption
Type: defines restrictions on the allowable values
Default value: the value to be used if the option value is unspecified
Example option definition from options.xsd:
<xs:element name="cartridge.<sdk_global_cartridgeName>.sampleEnumerationOption" minOccurs="0" default="value3">
<xs:simpleType>
<xs:restriction base="opt:StringValue">
<xs:enumeration value="value1"/>
<xs:enumeration value="value2"/>
<xs:enumeration value="value3"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
Document the details of the configuration options for the cartridge such that the options may be configured at deployment time. For each option, this includes:
The option name
Possible values
Default value
The effect of setting the option values such as command variants
Registering Options
Option files for base cartridges are registered by cartridges in the Registry.xml file and options files for service cartridges are registered in the Extension.xml file. A valid option configuration file for a cartridge is in XML format and conforms to the cartridge options schema.
Here is an example of an option configuration file which uses the options defined in the sample options.xsd schema. Substitute the cartridge name for ${sdk_global_cartridgeName}. In this example, value1 is set for sampleEnumerationOption, and the default values defined for the remaining options will be used.
<?xml version="1.0" encoding="UTF-8"?>
<base:options xsi:type="CartridgeOptions" xmlns="http://www.metasolv.com/serviceactivator/${sdk_global_cartridgeName}/options" xmlns:base="http://www.metasolv.com/serviceactivator/options" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<cartridge.${sdk_global_cartridgeName}.sampleEnumerationOption>value1</sampleEnumerationOption>
</base:options>
To register an option configuration file, add a reference to it in the <options> entries in the Registry.xml file.
Implementing Options
Variations in the service model to device model, and device model to CLI transforms are implemented based on option values. For this purpose, the option values are made available to the transforms at execution time. The options-common.xq module in the networkprocessor.jar file can be imported by the XQuery modules implementing the transforms, to provide methods for retrieving the option values.
To import options-common.xq:
Enter the following command syntax:
import module namespace options = "options-common-functions" at "resource://metasolvcom/metasolv/serviceactivator/networkprocessor/xquerylib/options-common.xq";
A sample XQuery code to retrieve sample option value (where value3 is the default value) follows:
if (options:getStringOption("cartridge.${sdk_global_cartridgeName}.sampleEnumerationOption", "value3") = "value1") then
. . .Customizing the Registry
When a cartridge is installed, by extracting it to the Service_Activator_home directory, it creates a sample registry configuration directory under it such as Service_Activator_home\Config\networkprocessor\ciscoSampleRegistry. The name of the sample directory is sdk_global_cartridgeNameSampleRegistry. This directory contains samples of the various configuration files that you may want or need to customize.
One of the main files that you will need to edit, to customize any SDK registry entry, is the customization registry file. A sample of this file exists in the sample directory. The name of the file is sdk_global_cartridgeName.xml. To use the customization registry file to customize the SDK registries, edit the file and then copy it to the directory Service_Activator_home\Config\networkprocessor\Custom\Registries. The next time the Network Processor is restarted, the customizations will override the cartridge's registry entries.
The name of the file, as it exists in the Service_Activator_home\Config\networkprocessor\Custom\Registries directory is not actually important. It is the name field within the file that indicates which SDK registry the customization will edit.
The customization file must conform to the cartridge.xsd schema.
Cisco Sample
A sample custom Cisco registry follows:
<registry xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.metasolv.com/serviceactivator/networkprocessor/cartridgeregistry/ ../cartridge.xsd"
xmlns="http://www.metasolv.com/serviceactivator/networkprocessor/cartridgeregistry/">
<customizations>
<name>cisco</name>
<audit>
<auditTemplate>
<auditTemplateEntry>
<auditTemplateFile>com/metasolv/serviceactivator/
cartridges/cisco/units/cu1/audit/auditTemplate.xml</auditTemplateFile>
<appliesTo>
<deviceTypes useRegex="true">.*</deviceTypes>
<osVersions useRegex="true">.*</osVersions>
</appliesTo>
</auditTemplateEntry>
</auditTemplate>
</audit>
<messages>
<success>com/metasolv/serviceactivator/cartridges/cisco/messages /successMessages.xml</success>
<warning>com/metasolv/serviceactivator/cartridges/cisco/ messages/warningMessages.xml</warning>
<error>com/metasolv/serviceactivator/ cartridges/cisco/messages /errorMessages.xml</error>
</messages>
<capabilities>
<capabilitiesEntry>
<capsFile>com/metasolv/serviceactivator/cartridges /cisco/capabilities/cisco_default.xml</capsFile>
<appliesTo>
<deviceTypes useRegex="true">Cisco.*</deviceTypes>
</appliesTo>
</capabilitiesEntry>
</capabilities>
<options>
<optionsEntry>
<optionsFile>com/metasolv/serviceactivator/cartridges/cisco/options/cisco_options.xml</optionsFile>
<appliesTo>
</appliesTo>
</optionsEntry>
</options>
</customizations>
</registry>
</registry>Customization File Entries
The relevant parts of the customization file are:
AuditTemplate
Specifies a list of auditTemplateEntry. Each entry specifies an auditTemplateFile and the deviceTypes and osVersions that the audit template is to be used for.
The auditTemplateFile specifies the path to the auditTemplate file relative to the directory Service_Activator_home\Config\networkprocessor.
When multiple auditTemplateEntry are specified, the first matching entry is used for a device. For this reason, more specific device specifications should be placed before less specific device specifications.
When a custom auditTemplate entry is specified, it replaces all auditTemplate entries that may have been specified in the default registry. The custom entries are not merged with the default entries; they replace the default entries.
AuditQuery
Specifies a list of auditQueryEntry. Each entry specifies an auditQueryFile and the deviceTypes and osVersions that the audit query file is to be used for.
The auditQueryFile specifies the path to the auditQuery file relative to the directory Service_Activator_home\Config\networkprocessor.
When multiple auditQueryEntry are specified, the first matching entry is used for a device. For this reason, more specific device specifications should be placed before less specific device specifications.
When a custom auditQuery entry is specified, it replaces all auditQuery entries that may have been specified in the default registry. The custom entries are not merged with the default entries; they replace the default entries.
auditQuery is only be valid for specific cartridges.
Success
Specifies a custom success messages file. The path to the file is specified relative to the directory Service_Activator_home\Config\networkprocessor.
Warning
Specifies a custom warning messages file. The path to the file is specified relative to the directory Service_Activator_home\Config\networkprocessor.
Error
Specifies a custom error messages file. The path to the file is specified relative to the directory Service_Activator_home\Config\networkprocessor.
Capabilities
Specifies a list of capabilitiesEntry. Each entry specifies a capabilitiesFile and the deviceTypes and osVersions that the capabilities file is to be used for.
The capabilitiesFile specifies the path to the capabilities file relative to the directory Service_Activator_home\Config\networkprocessor.
When multiple capabilitiesEntry are specified, the first matching entry is used for a device. For this reason, more specific device specifications should be placed before less specific device specifications.
When a custom capabilities entry is specified, it replaces all capabilities entries that may have been specified in the default registry. The custom entries are not merged with the default entries; they replace the default entries.
Options
Specifies a list of optionsEntry. Each entry specifies an optionsFile and the deviceTypes and osVersions that the options file is to be used for.
The optionsFile specifies the path to the options file relative to the directory Service_Activator_home\Config\networkprocessor.
When multiple optionsEntry are specified, the first matching entry is used for a device. For this reason, more specific device specifications should be placed before less specific device specifications.
When a custom options entry is specified, it replaces all options entries that may have been specified in the default registry. The custom entries are not merged with the default entries; they replace the default entries.
Raising Faults
You can have your cartridge raise a fault to the Network Processor using the method AddFaultByThreadAndAbort() which is part of the FaultCollector. This method raises a fault and causes transformation to abort immediately.
The AddFaultByThreadAndAbort() method throws an AbortTransformException exception.
Since this java exception is invoked in an XQuery, Saxon throws it to syserr. On UNIX, the Network Processor shell script is modified to discard all syserr output.
To complete the sample cartridge source files:
Do one of the following:
Copy the files provided in SDK_home\samples\baseCartridge\cisco\ over their counterparts in the generated source directory (SDK_home\baseCartridge\cisco\)
or
Edit the generated sample source files to complete their content development.
The provided files demonstrate the edits required to complete the generated sample source to produce a working sample base cartridge.
You can examine the contents of the sample files and by highlighting in some manner (change bars, etc.), you can observe what was added, or modified to complete the sample.
The files to be copied or edited are:
successMessages.xml
dm2cli-common.xq.xml
auditTemplate.xml
Compiling the Cartridge
Base cartridge source files are compiled using ant. The compilation process creates the required XML beans for the cartridge and packages them into a .zip file.
An existing CLASSPATH environment variable may interfere with the CLASSPATH required by the SDK. It is therefore recommended that the CLASSPATH environment variable be unset in the session where the SDK is being used. For example:
set CLASSPATH=
To compile the cartridge:
Compile the ciscoBanner sample service cartridge source files using the following command:
ant package -f SDK_home\baseCartridges\cisco\build.xml -
Once you have completed editing your base cartridge source files, compile them using the following command:
ant package -f SDK_home\baseCartridges\sdk_global_cartridgeName\build.xml
This results in the following additions to the cartridge directory structure:
SDK_home\baseCartridges\sdk_global_cartridgeName\ build.xml AuditTrailsReports beansrc classes lib sdk_global_cartridgeName.jar sdk_global_cartridgeNametests.jar package sdk_global_cartridgeName-baseCartridge-${env.VERSION_STRING}.zip sdk_global_cartridgeName-baseCartridge-${env.VERSION_STRING}.manifest
Troubleshooting Cartridge Compilation
Compilation problems are caused by schema or XQuery errors. To debug these problems, load the schema into an XML schema aware editor. This makes it much easier to find and correct problems in the schema.
Manifest File
When an SDK cartridge is built, a manifest file is created listing all of the files that are packaged into the cartridge zip file. Installation of the cartridge places the manifest file into the uninstall directory of the IP Service Activator installation.
Implementing Pre- and Post-Checks
Pre- and post-checks provide the ability verify information on a device when the annotated DM to CLI transform executes, before the general configuration is sent. This allows you to confirm that prerequisites to the configuration are met.
After configuration is sent, you have the opportunity to have a post-check invoked to verify some aspect of the commands that were sent to the device.
For further information on pre- and post-checks, see IP Service Activator SDK Developer Overview Guide.
Testing in a Standalone Environment
Test scripts are created as part of the base cartridge skeleton generation process. For more information, see "Generating Cartridge Source Files".
Unit Tests
The unit test is generated with the skeleton cartridge source files.
To run unit tests:
After you have compiled the cartridge, enter the following command:
ant unittests -f=SDK_home\baseCartridges\sdk_global_cartridgeName\build.xml
This runs tests which are intended to prove that the main transform stages of the cartridge (i.e. service model to device model and annotated device model to CLI) will generate the output documents correctly.
Device Tests
The device test is generated with the skeleton cartridge source files. Its configuration can be modified after the skeleton has been generated. The device test configuration file is:
SDK_home\cartridges\sdk_global_cartridgeName\test\devicetests\DeviceTests.properties
DeviceTests.properties contains parameters for running the device test, including the host to connect to and the userid and password.
To run device tests:
Enter the following command:
ant devicetests SDK_home\cartridges\sdk_global_cartridgeName\test\devicetests\DeviceTests.properties
The device tests validate that the login and prompt checks are correct for the actual device. If any are incorrect, one of the following errors results:
Incorrect login prompt
Incorrect password prompt
Timeout attempting to read the default prompt. This indicates a problem with the promptMatchPattern
When managing a Cisco device with old alias information for IpsaConfigVersion configured on the device, the device state changes to Intervention Required due to IP Service Activator validation pre-check. If this behavior is undesired during device testing, manually remove the alias command from the device, delete the error message in the IP Service Activator client, and re-commit the transaction.
Troubleshooting the Standalone Tests
Typical login and prompt problems include:
Connectivity to the device.
If there are problems connecting to the device, ensure the device supports telnet connections to the default port (23).
If the command executor is unable to determine the login or password prompt, ensure its regular expression matches the responses seen when logging in manually.
Timeouts waiting for prompts.
The command executor can time-out waiting for a prompt if the regular expression for it is incorrect. Ensure the regular expression matches the device responses correctly.
Success/error message problems:
Errors while sending commands.
If errors are encountered while sending commands, the device may be sending responses that are not defined in the success messages file. This can apply to any non-login command sent to the device. Any responses outside of the prompt that are not defined in the success messages file are considered errors.
Testing in an IP Service Activator Environment
To run the cartridge in an IP Service Activator environment:
Unzip the cartridge file sdk_global_cartridgeName-baseCartridge-${env.VERSION_STRING}.zip to the runtime environment of the Network Processor Network_Processor_home.
Restart the network processor to load sdk_global_cartridgeName.jar.
To observe the cartridge loading operation see:
Service_Activator_home\logs\networkProcessor.log
Service_Activator_home\AuditTrails\npsdk_global_cartridgeName.log
Verification of Deployment
Once the Network Processor has started, it will raise information faults in the system indicating each cartridge registered. The new base cartridge should be indicated. If this does not happen, check the network processor log; it will contain the details on why the cartridge was not loaded. If the log does not indicate the problem, check that the cartridge was deployed to the correct location.
Free-form Testing Using CTM
If the CTM module is installed, it can be used to send commands to the base cartridge.
To configure CTM:
Find TABLE in database called XTM_DRIVER_TYPE
Add the name of your new cartridge's driverType to the list
For example, from the sqlplus command line:
insert into xtm_driver_type values (‘cisco');
Problem Isolation and Resolution
Problems with the base cartridge should fall into one of the following categories:
Environmental/loading of the base cartridge
Cartridge transform errors: if the transform has been customized, it must produce the correct results. If not, this can cause configuration to be rejected and faults to be raised.
Device discovery: ensure that the core IP Service Activator system can discover the device. If the SNMP discovery works but the capabilities fetch fails, this can indicate the cartridge is not registered for the correct device type/OS combination.
Device access: ensure the correct session type (SSH/telnet) has been selected as well as the correct userid and password. If problems persist, ensure the same prompts are used in the device tests. These can be used to help isolate the problem.
Command problems:
The auditTrail log shows commands being sent to the device. Use the auditTrail log to identify commands begin sent and whether or not they are being accepted.
Attempt the same commands manually on the device. Take note of any responses from the device. These may need to be added to the success messages for the cartridges.
Audit Trail Logging
Audit trail logging records the commands sent to devices by the base cartridge, and any service cartridges that extend the services of the base cartridge.
Setting Audit Trail Logging Properties
The default audit logging properties are defined in auditLogging.properties in the cartridge jar file.
Once the cartridge is deployed, the audit logging properties can be overridden by the system administrator. For this purpose, the cartridge .zip file includes a copy of the auditLogging.properties file in the vendor specific sampleRegistry directory located in:
Service_Activator_home\Config\networkProcessor\sdk_global_cartridgeNameSampleRegistry\auditLogging.properties
where sdk_global_cartridgeName is the name of the cartridge.
When the skeleton cartridge source files are generated, occurrences of sdk_global_deviceNameLowerCase, as shown below in the source auditLogging.properties template file, are replaced with value of the property sdk_global_deviceName converted to all lowercase characters. The property sdk_global_deviceName is a property in the skeleton.properties file. For example, if sdk_global_deviceName=Cisco then cisco will be substituted for sdk_global_deviceNameLowerCase in the output auditLogging.properties file.
To set different default values for the audit logging properties:
edit auditLogging.properties. For example:
# Audit output # There are alternatives for file rollover. # # The current default is to rollover a log when it reaches 8MB. # log4j.appender.sdk_global_deviceNameLowerCaseAudit=org.apache.log4j.RollingFileAppender # log4j.appender.sdk_global_deviceNameLowerCaseAudit.MaxFileSize=8MB # log4j.appender.sdk_global_deviceNameLowerCaseAudit.MaxBackupIndex=1 # # An alternative would be to rollover at the end of each day. # To do this, replace the 3 lines shown above with the following. # log4j.appender.sdk_global_deviceNameLowerCaseAudit=org.apache.log4j.DailyRollingFileAppender # log4j.appender.sdk_global_deviceNameLowerCaseAudit.DatePattern='.'yyyy-MM-dd # log4j.loggerFactory=com.metasolv.serviceactivator.util.logging.TraceLoggerFactory log4j.logger.com.metasolv.serviceactivator.networkprocessor.AuditLogger.sdk_global_deviceNameLowerCase=info, sdk_global_deviceNameLowerCaseAudit log4j.appender.sdk_global_deviceNameLowerCaseAudit=org.apache.log4j.RollingFileAppender log4j.appender.sdk_global_deviceNameLowerCaseAudit.File=AuditTrails/npsdk_global_cartridgeName.audit.log log4j.appender.sdk_global_cdeviceNameLowerCaseAudit.MaxFileSize=8MB log4j.appender.sdk_global_cdeviceNameLowerCaseAudit.MaxBackupIndex=1 log4j.appender.sdk_global_deviceNameLowerCaseAudit.layout=org.apache.log4j.PatternLayout log4j.appender.sdk_global_deviceNameLowerCaseAudit.layout.ConversionPattern=%d{yyyy-MM-dd HH:mm:ss}%m%n
To override the default audit logging properties once the cartridge is deployed:
Append the contents of auditLogging.properties found in the install directory at
to the logging.properties file located in
Service_Activator_home\Config\networkProcessor\com\metasolv\serviceactivator\networkprocessor\logging.properties
Adjust audit logging properties as necessary.
Adjusting the Audit Trail Logging Level
To change the audit trail logging level from debug to info:
Modify the line:
log4j.logger.com.metasolv.serviceactivator.networkprocessor.AuditLogger.sdk_global_cartridgeName=debug, ${sdk_global_cartridgeName}Auditto:
log4j.logger.com.metasolv.serviceactivator.networkprocessor.AuditLogger.sdk_global_cartridgeName=info, sdk_global_cartridgeNameAudit
Adjusting the Audit Trail Log File Size and Number of Previous Versions
To change the audit log file size:
Modify the value of MaxFileSize. For Example:
log4j.appender.sdk_global_cartridgeNameAudit.MaxFileSize=8MB
To change the number of previous versions of the audit log file:
Modify the value of MaxBackupIndex. For example:
log4j.appender.sdk_global_cartridgeNameAudit.MaxBackupIndex=1
Adjusting the Audit Trail Log File Rollover Strategy
IP Service Activator uses a rollover strategy to prevent log files from becoming too large.
To configure a log file to roll over when it reaches a specified size:
Use the following settings in the auditLogging.properties file:
log4j.appender.sdk_global_cartridgeNameAudit=org.apache.log4j.RollingFileAppender log4j.appender.sdk_global_cartridgeNameAudit.MaxFileSize=8MB log4j.appender.sdk_global_cartridgeNameAudit.MaxBackupIndex=1
To configure a log file to roll over at the end of each day:
log4j.appender.sdk_global_cartridgeNameAudit=org.apache.log4j.DailyRollingFileAppender log4j.appender.sdk_global_cartridgeNameAudit.DatePattern='.'yyyy-MM-dd
Device Model Upgrades
Once a cartridge is constructed and deployed, it will carry with it a device model version identifier (e.g 1.0). If a subsequent release of the cartridge is constructed which involves a non-trivial device model change, then the device model version would be incremented to 2.0, as an example, to distinguish it from the predecessor cartridge.
In order to deploy the updated cartridge into the production environment, an upgrade path for any existing persisted device models is required.
The cartridge developer is responsible for identifying that a device model upgrade is required, and if so:
Updating the cartridge version
Updating and unit testing the upgrade source code related to the modified device model
The following sections describe this process in detail.
Identifying that a Device Model Upgrade is Required
Once a cartridge is deployed in production, a non-trivial change to the devicemodel.xsd in the next version of the cartridge will require a custom upgrade transform.
Examples of non-trivial changes are:
You introduce mandatory elements
You remove elements
You completely modify an existing elements
You reorder elements
Updating the Cartridge Version
When you create a cartridge, within the skeleton.properties file, the cartridge version is set in the <sdk_cartridgeVersion> property. This cartridge version is used to identify the version of the device model as seen in the cartridge file:
SDK_Home\basecartridges\cisco\src\com\metasolv\serviceactivator\cartridges\cisco\xquerylib\dm-version.xq
Increment the cartridge version whenever a significant change to the device model has occurred which requires a non-trivial upgrade to an existing device model. For more information about Device Model upgrades, see IP Service Activator SDK Developer Overview Guide.
The cartridge version is set in the file dm-version.xq:
declare variable $dmver:version := "2.0";
The version format can be a, a.b, or a.b.c (i.e. major, major.minor, major.minor.sub-minor), where a, b, c represent numeric values.
Updating the Device Model Upgrade Transform
When you use the cartridge skeleton generator tool to generate the base cartridge source files, a skeleton XQuery file called DmUpgrade.xq is automatically created.
To implement the upgrade transform:
Edit DmUpgrade.xq.
For example, if the device model has an existing element named 'myelement' which requires an upgrade transform, implement the upgrade transform in DmUpgrade.xq as follows:
(: -*- nxml -*- :) import module namespace dmver = "dm-<sdk_global_cartridgeName>-version" at "dm-version.xq"; declare namespace dm="http://www.metasolv.com/serviceactivator/<sdk_global_cartridgeName>"; declare namespace lib="http://www.metasolv.com/serviceactivator/devicemodel"; <lib:device xsi:type="dm:<sdk_global_cartridgeName>Device" xmlns:dm="http://www.metasolv.com/serviceactivator/<sdk_global_cartridgeName>"> { dmver:getUpgradeAppInfo(), for $element in /lib:device/* return if (fn:local-name($element) = 'appInfo') then () else if (fn:local-name($element) = 'myelement') then (: implement transform for 'myelement' here :) else $element } </lib:device>
Unit Testing the Device Model Upgrade Transform
When you use the cartridge skeleton generator tool to generate the base cartridge source files, a skeleton java file named DmUpgradeTests.java is automatically created. This file contains the device model upgrade unit tests.
To test the upgrade transform for an existing element in the device model named 'myelement' that requires an upgrade transform implemented in DmUpgrade.xq:
Create a sample device model XML file that includes data requiring an upgrade. In the sample code below, the file is named sampleDeviceModel.xml.
Implement a test in DmUpgradeTests.java.
The test will load sampleDeviceModel.xml, transform the XML using the upgrade transform, and use methods in BaseSdkTest to verify the resulting upgraded device model, thereby validating the upgrade transform.
In the sample code below, the test method is named testUpgradeFromVersionX.
Run the unit tests using the following command syntax:
ant unittests SDK_home\cartridges\sdk_global_cartridgeNamebuild.xml
A code sample follows:
package ${sdk_global_package}.test;
import com.metasolv.serviceactivator.sdk.test.TestUtilsInterface;
import com.metasolv.serviceactivator.sdk.test.BaseSdkTest;
import com.metasolv.serviceactivator.util.XmlUtil;
import org.apache.xmlbeans.XmlObject;
import java.io.File;
public class DmUpgradeTests extends BaseSdkTest {
static private final String testUpgradeFromPackageName = "${sdk_global_customPackage}/test/models/upgradeFrom";
public static final String dmUpgradeTransform = "${sdk_global_customPackage}/xquerylib/DmUpgrade.xq";
static private final String upgradeFromDeviceModelXmlFile = testUpgradeFromPackageName + "/sampleDeviceModel.xml";
static private TestUtilsInterface testUtils = null;
protected void setUp() throws Exception {
testUtils = getTestUtils();
public void testUpgradeFromVersionX() throws Exception {
XmlObject oldDm = loadXml(DmUpgradeTests.upgradeFromDeviceModelXmlFile);
XmlObject upgradedDm = transform(oldDm, null, DmUpgradeTests.dmUpgradeTransform, false);
// System.out.println("Transformed:\n" + XmlUtil.bean2xml(upgradedDm));
// use methods in BaseSdkTest to verify upgradedDm here
}Audit
Audit functionality is controlled by an audit template and an audit query file. The names of these files are specified in the Registry.xml file.
The audit template file is used by the audit process for devices provisioned using a command line interface (CLI).
The audit query file is used by the audit process for devices provisioned using an XML interface. Different audit template and audit query files can be specified for different device types and OS versions.
For complete details on audit, refer to IP Service Activator SDK Developer Overview Guide.
Uninstalling Base Cartridges
Cartridges are uninstalled using the uninstallCartridge.sh script, which resides in the bin directory of the IP Service Activator installation. This script takes the name of the manifest file, which contains a list of all installed cartridge files, as a parameter, and uses its contents to uninstall the cartridge. (See "Manifest File".)
You can include the base directory of the IP Service Activator installation as a parameter to the script. If you do not, the script queries the ORCHcore package to locate the base directory of the IP Service Activator installation.
The uninstallCartridge.sh script sorts the manifest file in reverse order, then deletes files, and then directories. Only empty directories are removed; this ensures that the script will not remove directories used by other cartridges.
You can use a relative path to specify the manifest file, but it must be relative to the current directory (where you are running the uninstall script from). You can also use an absolute path. To verify that the manifest file is in the directory, use the command “ls<manifest>" using the same value that is provided to the script.
To uninstall the base cartridge:
uninstallCartridge manifest_file [Service_Activator_Home] [-k | -v]
Use the -k option to leave empty directories. The -v (verbose) option produces extra output from the script.
After the cartridge is uninstalled, restart the Network Processor.
Uninstalling a cartridge or configuration policy developed using the SDK does not remove the Network Processor's device model entries that reference this cartridge or configuration policy. This information is maintained because it is unknown whether you are uninstalling the cartridge or configuration policy to remove it or to upgrade it.
Removing a Generated Cartridge from the SDK
To remove a generated cartridge from the SDK installation:
Delete all contents under SDK_home\cartridges\sdk_global_cartridgeName.
