7.3.11 Changing the State of a Subsystem Application
The procedures in this section are used to set the state of an existing subsystem application to either online or offline using the chg-ss-appl command. The chg-ss-appl command uses the following parameters..
:appl – the application type, LNP
:nstat - the new state of the subsystem application.
The online or offline status of the subsystem application is shown in the STAT field of the rtrv-ss-appl command output.
The rept-stat-lnp command displays the operating state (in or out of service) of the subsystem.
If the subsystem application is to be taken online, the subsystem application must be offline.
If the subsystem application is to be taken offline, the subsystem application must be online. The subsystem must be taken out of service (OOS-MT-DSBLD) with the inh-map-ss command before it can be taken offline.
