4.3 ELAP Messages
This section includes Table 4-4. For alarm-related banner messages that appear on the UI browser screen in the Message Box described in ELAP GUI Main Screen, refer to Alarms and Maintenance for ELAP for alarm recovery procedures.
4.3.1 ELAP Error Messages
Table 4-4 ELAP Error Messages
E1000 |
Unknown error <error number>. No error text is available. |
E1001 |
Invalid menu selection: <menu selection> |
E1002 |
Invalid syntax: <input> |
E1003 |
Mate ELAPs may not have the same designation. |
E1004 |
ELAP software is running. You must stop the ELAP software before performing this operation. |
E1005 |
ELAP software is not running. You must start the ELAP software before performing this operation. |
E1006 |
Mate ELAP not available |
E1007 |
Could not eject media: <device> |
E1008 |
Could not read file: <file name> |
E1009 |
Active PDBA is not available. |
E1010 |
This host is not an ELAP. |
E1011 |
Cannot find ELAP <A|B> (host name <host name>) |
E1012 |
Subscription (SP= <subscription number>) does not exist. |
E1013 |
Subscription (SP= <subscription number>) already exists. |
E1014 |
SP <identifier> does not exist. |
E1015 |
IMSI <identifier> does not exist. |
E1016 |
DN <identifier> does not exist. |
E1017 |
PDBI error: <error text> |
E1018 |
DN <identifier> already associated with IMSI <identifier>. |
E1019 |
Device <device> unavailable. |
E1020 |
Remote PDB unavailable. |
E1021 |
IP address <address> is not authorized for PDB access. |
E1022 |
RN <identifier> does not exist. |
E1023 |
Invalid value for <prompt >: <value>: Valid values are <range>. Hit the Escape key to abort the command. |
E1024 |
MTSU error: <error text> |
E1025 |
File lock failed: <file name> |
E1026 |
Environment variable <variable name> not defined. |
E1027 |
ssh error: <error text> |
E1028 |
IP address <IP address> is already authorized for PDBI access. |
E1029 |
IP address <IP address> is not authorized for PDBI access. |
E1030 |
Operation timed out waiting for a response from the PDBA. |
E1031 |
Operation timed out waiting for a response from the RTDB. |
E1032 |
Operation aborted by user. |
E1033 |
Unexpected response received from the PDBA: id=<txid>, return code=<return code> |
E1034 |
Unexpected response received from the RTDB: id=<txid>, return code=<return code> |
E1035 |
Script <script name> failed: status=<status> |
E1036 |
ELAP configuration failed. Please use the configuration menu to manually configure the ELAP sync and DSM networks. |
E1037 |
One or more ELAP software processes did not start |
E1038 |
One or more ELAP software processes did not stop |
E1039 |
Transaction log query failed: <error text> |
E1040 |
Transaction log response file was not created. |
E1041 |
Transaction log response file could not be parsed. |
E1042 |
Transaction log export failed: <error text> |
E1043 |
The specified ELAP was not available. |
E1044 |
Remote ELAP software is running. You must stop the remote ELAP software before performing this operation. |
E1045 |
RTDB copy operation failed. |
E1046 |
Improperly encoded alarm string. Re-check source. |
E1047 |
RTDB did not respond to query. |
E1048 |
Invalid response received from RTDB. |
E1049 |
Could not connect to <device or process>: <error text> |
E1050 |
Secure shell daemon is not running on mate ELAP. Config files could not be synchronized !!! |
E1051 |
No feature(s) specified. |
E1052 |
Both ELAP and EPAP features specified. |
E1053 |
This action may only be performed on the local ELAP. |
E1054 |
Another user is currently performing this same action. |
E1055 |
Missing mandatory parameter: <parameter> |
E1056 |
Unexpected parameter was provided:<parameter> |
E1057 |
The ELAP must be in Forced Standby mode for this operation. |
E1058 |
An internal error in the <parameter> occurred: <error text> |
E1059 |
The passwords did not match. |
E1060 |
The provisioning addresses for MPS A and B must be different. |
E1061 |
The provisioning addresses for MPS A and B must be on the same network. |
E1062 |
The default router must be on the same network as MPS A and MPS B. |
E1063 |
The local and remote PDB addresses must be different. |
E1064 |
This action may only be performed on ELAP A. |
E1065 |
<device or process> must be configured. |
E1066 |
The requested user <user> was not found. |
E1067 |
The requested group <group> was not found. |
E1068 |
The password entered was not correct. |
E1069 |
The new password has been used too recently. |
E1070 |
The provided password does not meet the security requirements. Reason: <reason text> |
E1071 |
The specified group already exists. |
E1072 |
This action may only be performed on ELAP B. |
E1073 |
The file you have attempted to upload is larger than the <number> bytes of allocated storage space. |
E1074 |
LPU batch failure: <error text> |
E1075 |
This action must be done on the Active PDBA. |
E1076 |
This action may only be performed while the LSMS connection is disabled. |
E1077 |
File system violation: <error text> |
E1078 |
File '<file name>' was empty |
E1079 |
There are no PDBI connections available. Try again later. |
E1080 |
The provisioning addresses for the main and backup networks must be different. |
E1081 |
The specified IP already exists. |
E1082 |
The specified IP does not exist. |
E1083 |
The maximum number of authorized UI IPs has been reached. |
E1084 |
This action may only performed on a provisionable MPS. |
E1085 |
The specified address is local to this MPS. |
E1086 |
PDBA has had a replication error. |
E1087 |
The port number is already configured for another service. |
E1088 |
Attempt to access the PDBA was not successful. |
E1089 |
Duplicate entry the system <entry> already exists. |
E1090 |
The <input> must be the same length. |
E1091 |
The beginning <input> is past the ending. |
E1092 |
The range would overlap the existing range <start range> to <end range>. |
E1093 |
The <value> does not exist. |
E1094 |
Must enable or disable both VIPs simultaneously. |
E1095 |
Unable to perform requested operation because PDBA Proxy enabled. |
E1096 |
<value> must not be configured for this action. |
E1097 |
The maximum capacity for this provisioning has been reached. |
E1098 |
Unable to establish SSH tunnel to <machine identifier> machine. |
E1099 |
Invalid IP Address/Username/Password combination. |
E1100 |
Task Scheduler error: <error text>. |
E1101 |
Both the entered DSM IPs are same. |
E1102 |
Loopback IP is same as Main/Backup DSM IP. |
E1103 |
IP address <IP address> is not authorized to perform this action: <error text> |
E1104 |
The localhost can not be removed from the access list. |
