3 FULL UPGRADE PROCEDURES
This document defines the step-by-step actions performed to run a software Full upgrade to ELAP 11.1.x.
The ELAP application can be installed, or full upgraded based on the table below.
Table 3-1 Full upgrade paths for E5APPB-02
| TPD Release for IPM | ELAP Initial Installation Release |
8.10.1.16.0_150.39.0 |
11.1.0.0.0 |
Upgrade Source Release |
Upgrade Destination Release |
10.2 |
11.1.0.0.0 |
The following table illustrates the progression of the Full upgrade process by procedure with estimated times. The estimated times and the phases that must be completed may vary due to differences in typing ability and system configuration. The phases outlined in i and ii are to be executed in the order they are listed.
