2.2 Installation Phases
The general installation strategy is to IPM the E5-APP-B server and then install the application.
The following table illustrates the progression of the installation process by procedure with estimated times. The estimated times and the phases that must be completed may vary due to differences in typing ability and system configuration. The phases outlined in Table 6are to be executed in the order they are listed.
Table 2-4 Installation Phases
Phase Elapsed Time (Minutes) Activity Procedure
This Step Cum.
Connectivity setup
15
15
Set up connectivity to the MPS Servers.
Procedure 1
Verify install
5
20
Verify this should be an install.
Procedure 23
Requirements check
15
35
Verify requirements for install are met.
Procedure 24
IPM both servers
90
125
IPM both ELAP servers with TPD 8.10
Procedure 7
Pre-install health check
5
130
Run the syscheck utility to verify that all servers are operationally sound.
Procedure 21
Configure both servers
10
140
Set hostname, designation, function, time zone and time on both servers
Procedure 8
Install Servers
30
170
Install software on sides 1A and 1B
Procedure 9
Configure Switches
30
200
Configure the Switches
For Telco Switch-Procedure 11
For Cisco Switch- Procedure A.2
Post-install application processing
30
230
Perform first time configuration.
Procedure 12
Procedure 13
Post-incremental upgrade health check
5
235
Run the syscheck utility to verify all servers are operationally sound.
Procedure 21
LSMS SSH Key Exchange
10
245
Perform SSH key exchange with the LSMS.
Procedure 17
Accept the upgrade after successful installation
10
255
Accept the upgrade on both MPS-A and
MPS-B
Procedure 22
10
265
Procedure 21
