3.5.2 Procedure 12 CONFIGURE CHRONY SERVERS
Table 3-16 Procedure 12 CONFIGURE CHRONY SERVERS
| STEP # | This procedure configures the NTP server setting for both servers. Note: Estimated time of completion is 5 minutes. Check off (√) each step as it is completed. Boxes have been provided for this purpose under each step number. Should this procedure fail, Contact Oracle technical services and ask for FULL UPGRADE ASSISTANCE. | |
1. ☐ |
MPS A: Switch user to elapconfig. |
2. ☐ |
MPS A: Press Return to continue. |
Caution: This is the first login of the text user interface. Please review the following checklist before continuing. Failure to enter complete and accurate information at this time will have unpredictable results.
3. ☐ |
MPS A: Enter elapdev and root password when prompted. |
4. ☐ |
MPS A: Select choice 7, Configure NTP Server Menu. |
5. ☐ |
MPS A: The Configure NTP Server Menu is displayed. Select choice 2, Add External NTP Server. |
6. ☐ |
MPS A: The ELAP Configure NTP Server Menu is displayed. Enter choice 1, Display External NTP Server. |
7. ☐ |
MPS A: The ELAP Configure NTP Server Menu is displayed. Select choice, Exit. Otherwise, if more Chrony servers are to be added, then repeat steps 1 to 6. |
8. ☐ |
MPS A: Run the following command. Note: The “chronyc ntpdata” command will work after the servers have been assigned with an IP. Hence, the step 8 and 9 will work only after the network configuration is done. |
Make sure that delay and offset is zero. If delay and offset is not zero, follow step 9, otherwise skip step 9. |
9. ☐ |
MPS A: Run the following command. |
10. ☐ |
MPS A: Note down the timestamp in log. |
Run the following command :
This procedure is complete!
