3.3.1 Procedure 4 LSMS SERVDI BACKUP
Table 3-8 Procedure 4 LSMS SERVDI BACKUP
STEP # This procedure provides steps to complete LSMS servdi backup
1.
LSMS:
Login to Active LSMS server as root user.
login: root
Password: <root_password>
2.
Change the user to lsmsadm.
# su –lsmsadm
3.
Enable the servdi feature
lsmsadm@lsmspri ~]$ dbcfginternal SERVDI_ENABLED Y
Note: The SERVDI feature will not be available within a GUI instance until the GUI is restarted.
Update complete
4.
Verify that servdi feature has been enabled.
lsmsadm@lsmspri ~]# lsmsdb -c features | grep "SERVDI_ENABLED" Y SERVDI_ENABLED
5.
LSMS:
Log in to the LSMS GUI as a member of the permission group that is authorized to perform this operation.
LSMS login dialog with service provider ID, username, and password fields.
6.
Select the LSMS icon.
Right click on LSMS
icon
LSMS-> LNP
Database
Synchronization ->
ELAP Reload via
DB image
LSMS menu path to create an ELAP reload database image.
7.
Click on generate image
Start Database Image Generation dialog with transaction counts and the Generate Image button.
This procedure is complete!
