9 Field Replaceable Units
This chapter describes the components of an E5-APP-B card that can be replaced in the field and includes procedures for replacing each type of field replaceable unit (FRU).
Introduction
Oracle Communication EAGLE Application B Cards (E5-APP-B) are complete application server platforms and are designed for the high-availability environments required by telephony networks. They are installed in an EAGLE shelf.
Even with the advanced reliability of the E5-APP-B design, hardware failures may still occur. The E5-APP-B card is designed for easy maintenance when replacements are needed.
This chapter highlights the E5-APP-B card components that are field replaceable units (FRU) and provides procedures for replacing them.
This chapter explains how to remove a card from the EAGLE. The procedures include the administrative commands required to take a card out of service and place it back into service.
In the event a numbered event message is encountered, refer to the appropriate procedure in the Unsolicited Alarm and Information Messages Reference.
Additional information about each command can be found in the EAGLE Commands User's Guide.
Removing and Replacing E5-APP-B Cards
This section gives procedures on removing and replacing the E5-APP-B card and drive modules.
Removing and Replacing a Drive Module Assembly
Procedure - Remove and Replace a Drive Module Assembly
