F Resolution Of Known Customer Issues
Issue: startNode Command gets stuck in ACTIVE -> TO-ACTIVE
state
Description: It has been observed in LSMS that during startNode on active server, sometimes even after Node is started, the server gets stuck in ACTIVE -> TO_ACTIVE state as shown below:
$hastatus
ACTIVE "lsmspri->TO_ACTIVE"Solution:
Remove the file /usr/TKLC/plat/etc/HA/state.d/.haTransitionInProgress_lsmspri if issue is observed on primary server or /usr/TKLC/plat/etc/HA/state.d/.haTransitionInProgress_lsmssec if issue is observed on secondary server using command as mentioned below:
$ rm /usr/TKLC/plat/etc/HA/state.d/.haTransitionInProgress_lsmspri
