E Query Server Maintenance Procedures
This appendix contains detailed, step-by-step query server procedures, as well as information about the automated system check feature, the query server error log, and how to retrieve information from the LNP database fields.
Introduction
LSMS Maintenance Procedures
Figure E-1 illustrates a query server configuration scenario depicting how the LSMS might be directly connected to a query server, or indirectly connected to daisy-chained query servers. Refer to this figure when performing the maintenance procedures described in this section.
This scenario includes the following:
- One master (LSMS)
- One remote system
- Five query servers:
- One directly connected slave (Query Server A)
- One directly connected master/slave (Query Server B)
- Two daisy-chained slaves (Daisy-chained Query Servers C and E)
- One daisy-chained master/slave (Daisy-chained Query Server D)
Client applications on each query server represent a Service Provider application that queries the replicated LSMS LNP databases using supported MySQL database APIs.
Process all updates to the query server database through the master.Figure E-1 Query Server Configuration Scenario
Automatic Monitoring of Query Servers
The lsmsQueryServer script monitors the connectivity and status of each directly connected query server to ensure that it is replicating the LSMS LNP database. During failure and recovery of the connection with the query servers, the LSMS does one or more of the following:
Displays a notification on the graphical user interface (GUI notification)
Posts a Surveillance notification at five-minute intervals to Serial Port 3 used by Surveillance
Sends a trap to a Network Management System (NMS) if the optional Remote Monitoring feature is installed
For information about the notifications posted, see 8098 and 8099.
The LSMS does not monitor the connectivity or status of the daisy-chained query servers.Modify the MySQL Port for Query Servers
Since the MySQL port is a well-known port, for security purposes you can use the LSMS GUI to change the configured MySQL port for a query server.
To avoid database replication issues, configure the same MySQL port for LSMS that you configure for the query server. For information about configuring the MySQL port for LSMS on the MySQL Port submenu, refer to the Configuration Guide.For the MySQL Port for Query Servers, there are four options under as shown:
Figure E-2 Change configured QS MySQL Port
- Create
Choosing Create displays the Create QS MySQL IP:Port menu.
Figure E-3 Create QS MySQL IP:Port
To start, all IP addresses that are configured to use default port 3306 are selectable in the QS MySQL IP field. Select an IP address, add the desired port in the QS MySQL Port field, click OK (or Apply followed by OK), and a Create Successful message is displayed.
The valid QS MySQL Port range is 1024-65535. An error message is displayed if a port outside of this range is entered.
After Create is used, the IP/Port combination is stored in a hidden file on LSMS,
/usr/TKLC/lsms/tools/.qs.mysql.port. IP addresses that are assigned to particular ports are not displayed the next time Create is used. - Modify
Choosing Modify displays the Modify QS MySQL IP:Port menu.
Figure E-4 Modify QS MySQL IP:Port
The QS MySQL IP field displays the IP addresses that were configured using Create and saved in
/usr/TKLC/lsms/tools/.qs.mysql.port. You can modify the port associated with an IP address, click OK (or Apply followed by OK), and a Modify Successful message is displayed.After Modify is used,
/usr/TKLC/lsms/tools/.qs.mysql.portis updated with the modified IP/Port combination. - View
Choosing View displays the View QS MySQL IP:Port menu.
Figure E-5 View QS MySQL IP:Port
The QS MySQL IP field displays the IP addresses that are stored in
/usr/TKLC/lsms/tools/.qs.mysql.port, and the QS MySQL Port field lists the corresponding port for each IP address. - Delete
Choosing Delete displays the Delete QS MySQL IP:Port menu.
Figure E-6 Delete QS MySQL IP:Port
Use this option to delete an IP/Port combination from
/usr/TKLC/lsms/tools/.qs.mysql.port. Deleted IP/Port entries result in that LSMS subsequently connecting using default port 3306.
Check Connection Status of Directly Connected Query Servers
You can check the connection status of query servers that are directly connected to the LSMS. The connection status for each query server (denoted by hostname and IP address) is displayed as "Connected", "Disconnected" or "Not Reachable."
To check the connection status, use the following procedure:
Maintain the Binary Log on Query Servers
Use this procedure to purge the binary log of a query server platform that will have one or more daisy-chained query servers. (Perform this procedure on Query Servers B and D, as shown in Figure E-1.)
Monitor the binary log size and delete unnecessary binary log files on a weekly basis, following the steps listed below.Check MySQL Replication Status on Query Servers
Use the following procedure to check MySQL replication status on query servers:
Start MySQL Replication on Query Servers
Use the following procedure to start MySQL replication on the query server:
Stop MySQL Replication on Query Servers
Use the following procedure to stop MySQL replication on the query server:
Check for Running Backups
Both database backups and query server snapshots use the same file space on the LSMS. Before creating a snapshot on the LSMS, perform the procedure described in “Checking for Running Backups” to ensure that no database backups are running.
Caution:
If you attempt to create a snapshot while a backup is running, the backup will be interrupted, and the next time a backup is performed, it will take much longer to complete.The following tasks also use temporary file space (as does a snapshot), so you may run out of file space if you attempt to create a snapshot after you have started but not yet finished any of these tasks:
- Starting the standby server (changing its state from UNINITIALIZED "INHIBITED" to STANDBY) using the procedure described in “Starting a Server”
- Running the
importcommand - Running the
quickauditcommand
Reload a Query Server Database from the LSMS
This procedure reloads a corrupted or backlevel query server's database by copying the LSMS LNP database. If the LSMS is configured with multiple query servers, reload a query server from another query server (that is currently synchronized with the LSMS) to prevent NPAC-to-network element traffic from being interrupted (see “Reload a Query Server Database from Another Query Server”).
The following method of reloading a query server may briefly interrupt provisioning on the LSMS while a snapshot of the LNP database occurs. Therefore, choose this method only when other methods for synchronizing the query server are not feasible. The time required to accomplish this procedure depends on the bandwidth of the customer's network and the amount of data to be reloaded. To minimize service interruption, perform this procedure during a scheduled maintenance period.Reload a Query Server Database from Another Query Server
This procedure reloads a corrupted or backlevel query server's LNP database by copying another query server's LNP database. If the LSMS is configured with multiple query servers and at least one is currently synchronized, it is recommended to reload a query server from another query server (instead of from the LSMS) to prevent NPAC-to-network element traffic from being interrupted.
Replication on the query server may be interrupted while a snapshot of the LNP database occurs. The time required to accomplish this procedure depends on the bandwidth of your network and the amount of data to be reloaded.Clean Up After Failed or Interrupted Snapshot
If a snapshot fails or is interrupted, the /dev/vgapp/dbbackup volume will remain in the file space that is temporarily used by both backups and snapshot creation. If this volume is present when another snapshot is attempted, the new snapshot will fail.
If a snapshot fails, perform the following procedure to clean up the file space that is used for temporarily storing snapshot information. If this file space is not cleaned up, any future snapshot attempts will fail.
Automated System Check
The automated system check feature (syscheck) detects, diagnoses, and displays a summary of the overall health of the LSMS server. An LSMS application-specific module, qs_app (System Class) reports on the status of query server direct connections with the LSMS. The status of each connection is displayed on the screen as "OK", "WARNING", or "FAILURE".
Manually Checking Query Server Status
Although syscheck runs automatically and records output in the syscheck log, users can run the syscheck command to check query server status. To manually check query server status, perform the following procedure:
Automated System Check OK Status
When syscheck detects no problems with query server direct connections, output similar to the following appears.
Figure E-7 Automated System Check Output Example - OK
Automated System Check FAILURE Status
When syscheck detects one or more of the following failures, output similar to the following appears.
- The LSMSDB tool, which is utilized to obtain connection status, does not exist.
- The LSMSDB tool fails to connect to the database server.
- The query server hostname is not associated with corresponding Internet Protocol (IP) addresses in the
/etc/hostsfile. - The platform hosting a query server could not be pinged (Not Reachable). The hostname of the query servers that fail the
pingcheck is reported.
Figure E-8 Automated System Check Output Example - FAILURE
Automated System Check WARNING Status
When syscheck detects that one or more query servers are not connected and replicating the LSMS database, output similar to the following appears. The hostname of the query servers that fail the connections check is reported.
Figure E-9 Automated System Check Output Example - WARNING
Query Server Error Log
The query server error log (see the example shown in Figure E-10) contains the following information, if applicable:
- When
mysqldwas started and stopped - Critical errors found when running
mysqld - Replication errors and warnings
- Warnings if
mysqlddetects a table that needs to be automatically checked or repaired
The query server error log is assigned a name based on the name of your host and appended with a .err extension (for example, <hostname>.err) and is located in one of the following directories:
- On the LSMS, in
/var/TKLC/lsms/db - On a query server, in
/usr/mysql1. On a Windows machine,mysqldwrites this log directly toC:\mysql\data\mysql.err.Note:
Because the query server error log continuously increases in size, it is the user's responsibility to monitor it. To manually delete the log, first shut down the server. Alternatively, execute themysql-log-rotatescript inside your crontab.
Figure E-10 Query Server Error Log Example
Retrieving Information from LNP Database Fields
The LNP database is in table format. Following are the characteristics of the table rows and columns:
Each column contains a value for each row.
The table does not contain gaps or short columns.
Each row is a single entity, and the columns describe the attributes of those entities.
Each column has a name and a type, such as a string or a number. (See Table E-1 throughTable E-3 for the LNP database table names and associated fields.)
To obtain information (name, type, if field contains a Null, key fields, default value, and so forth) for each field of a table on the query server, perform the following steps:
LNP Database Tables and Fields
The Query Server database consists of replicated copies of the LSMS LNP database tables listed in Table E-1, Table E-2, and Table E-3.
In the table below, names of regional LNP database tables and fields may be split between lines. This does not imply a space in the name of the table or field.Table E-1 Regional Database Tables and Fields
| Regional (<Region>) DB) LNP Database Tables | Fields | |||
| SubscriptionVersion | versionID | tn | lrn | newCurrentSp |
| classDPC | classSSN | lidbDPC | lidbSSN | |
| isvmDPC | isvmSSN | cnamDPC | cnamSSN | |
| wsmscDPC | wsmscSSN | LnpType | billingId | |
| endUserLocation Value | endUserLocation Type | activation Timestamp | downloadReason | |
| SVType | alternativeSPID | |||
| NumberPoolBlock | blockId | npanxx_x | lrn | newCurrentSP |
| wsmscDPC | wsmscSSN | activationTimestamp | downloadReason | |
| ServiceProvLRN | serviceProviderId | id | lrn | creationTimeStamp |
| downloadReason | ||||
| ServiceProv NPA_NXX | serviceProviderId | id | npanxx | creationTimeStamp |
| effectiveTimeStamp | downloadReason | |||
| ServiceProv NPA_NXX_X | serviceProviderId | id | npanxx_x | creationTimeStamp |
| effectiveTimeStamp | modifiedTime Stamp | downloadReason | ||
| ServiceProvNetwork | serviceProvId | serviceProvName | serviceProvType | |
| Where <Region> is one of the following: | Canada | MidAtlantic | Midwest | Northeast |
| Southeast | Southwest | WestCoast | Western | |
Table E-2 Supplemental Database Tables and Fields (Part 1)
| Supplemental (supDB) LNP Database Tables | Fields | |||
| DefaultGtt | groupName | npanxx | spid | |
| ain_set | ain_tt | ain_dpc | ain_ssn | |
| ain_xlat | ain_ri | ain_ngt | ain_rgta | |
| in_set | in_tt | in_dpc | in_ssn | |
| in_xlat | in_ri | in_ngt | in_rgta | |
| class_set | class_tt | class_dpc | class_ssn | |
| class_xlat | class_ri | class_ngt | class_rgta | |
| lidb_set | lidb_tt | lidb_dpc | lidb_ssn | |
| lidb_xlat | lidb_ri | lidb_ngt | lidb_rgta | |
| isvm_set | isvm_tt | isvm_dpc | isvm_ssn | |
| isvm_xlat | isvm_ri | isvm_ngt | isvm_rgta | |
| cnam_set | cnam_tt | cnam_dpc | cnam_ssn | |
| cnam_xlat | cnam_ri | cnam_ngt | cnam_rgta | |
| wsmsc_set | wsmsc_tt | wsmsc_dpc | wsmsc_ssn | |
| wsmsc_xlat | wsmsc_ri | wsmsc_ngt | wsmsc_rgta | |
| OverrideGtt | groupName | lrn | spid | |
| NpaSplit | oldNpa | newNpa | nxx | startPDP |
| endPDP | region | status | ||
| LsmsServiceProvider | spid | description | contactInfo | |
Table E-3 Supplemental Database Tables and Fields (Part 2)
| GttGroup | name | description | ||
| EmsInterface | clli | emsType | primaryAddress | secondaryAddress |
| mateClii | pointCode | matePointCode | capabilityPoint Code | |
| gttGroup | tnFilter | ownerSpid | componentInfo | |
| contactInfo | dcmAddress | retryinterval | retryCount | |
| pingMethod | ||||
| TnFilter | spid | name | description | filterType |
| regions | npanxxType | npanxxs | ||
| NpacRegion | region | npacSmsName | lsmsPsel | lsmsSsel |
| lsmsTsel | lsmsNsap | primaryNpacPsel | primaryNpacSsel | |
| primaryNpacTsel | primaryNpacNsap | primaryNpac FtpAddress | secondaryNpac Psel | |
| secondaryNpacSsel | secondaryNpacTsel | secondaryNpac Nsap | secondaryNpac FtpAddress | |
| active | componentInfo | contactInfo | lastChanged Timestamp | |
| currentNpac | ||||
| <Region>Npac Measurements | yyyydddhh | Binds | SuccessOps | FailedOps |
| <Clii>Eagle Measurements | yyyydddhh | |||
| updTnSuccess | updTnFail | DelTnSuccess | DelTnFail | |
| updDGttSuccess | updDGttFail | DelDGttSuccess | DelDGttFail | |
| updOGttSuccess | updOGttFail | DelOGttSuccess | DelOGttFail | |
| updSplitSuccess | updSplitFail | DelSplitSuccess | DelSplitFail | |
| Binds | LsmsRetries | NERetries | ||
| <Region>PublicKey | id | listId | keyId | status |
| exponent | modulus | |||
| <Region>PrivateKey | id | listId | keyId | status |
| keyval | ||||
| LsmsUser | name | golden | groupName | inactivityTimeout |
| LsmsUserSpid | lsmsUser | spid | ||
| Where <Clii> is the Common Language Location Indicator of the EMS/EAGLE to which that LSMS is connected. | ||||
In Table E-3, by default, the following Supplemental (SupDB) LNPDatabase Tables are not replicated. To replicate these tables, refer to the Note in Step 1 of the topic, “MySQL Replication Configuration for Query Servers” in Appendix A of the Configuration Guide.-
<Region>PublicKey
<Region>PrivateKey
LsmsUser
LsmsUserSpid
Query Server Database Structure
This section contains the database structure needed to develop customer-provided applications on the query servers.
-- Create NpacRegion table
-- One NpacRegion defines the configuration of the primary and secondary
NPAC.
CREATE TABLE NpacRegion
-- Region name
region VARCHAR(40) NOT NULL,
-- SMS Name defined by NPAC
npacSmsName TINYBLOB,
-- OSI address of LSMS
lsmsPsel TINYBLOB,
lsmsSsel TINYBLOB,
lsmsTsel TINYBLOB,
lsmsNsap TINYBLOB,
-- OSI address of primary NPAC
primaryNpacPsel TINYBLOB,
primaryNpacSsel TINYBLOB,
primaryNpacTsel TINYBLOB,
primaryNpacNsap TINYBLOB,
primaryNpacFtpAddress TINYBLOB,
-- OSI address of secondary NPAC
secondaryNpacPsel TINYBLOB,
secondaryNpacSsel TINYBLOB,
secondaryNpacTsel TINYBLOB,
secondaryNpacNsap TINYBLOB,
secondaryNpacFtpAddress TINYBLOB,
-- Region is active
active BOOL NOT NULL DEFAULT 0,
-- Component Info (stored as CSV string)
componentInfo BLOB NOT NULL,
-- Contact Info (stored as CSV string)
contactInfo BLOB NOT NULL,
-- Last changed timestamp set by npacagent
lastChangedTimestamp CHAR(14) NOT NULL, -- Default now
-- Current npac in use set by npacagent
currentNpac ENUM("Primary", "Secondary") DEFAULT "Primary",
-- Region name is primary key
PRIMARY KEY (region)
TYPE = MyIsam;
INSERT INTO NpacRegion
(region, npacSmsName,
lsmsPsel, lsmsSsel, lsmsTsel, lsmsNsap,
primaryNpacPsel, primaryNpacSsel, primaryNpacTsel, primaryNpacNsap,
primaryNpacFtpAddress,
secondaryNpacPsel, secondaryNpacSsel, secondaryNpacTsel,
secondaryNpacNsap, secondaryNpacFtpAddress,
componentInfo, contactInfo, lastChangedTimestamp)
VALUES ("Canada", "Region8 NPAC Canada",
"cw7", "cw7", "", "rk6",
"", "", "", "0x00000000",
"0.0.0.0",
"0.0.0.0",
'"NPAC","TKLC","LSMS","Tekelec, Inc.","6.0","1.0"',
'"Lsms Admin","admin@tekelec.com","5200 Paramount
Parkway","Morrisville","NC","","USA","27560","9194605500","8005551234","1
234","9195551234"',
DATE_FORMAT(NOW(), "%Y%m%d%h%i%s")),
("MidAtlantic", "Mid-Atlantic Regional NPAC SMS",
"cw1", "cw1", "", "rk6",
"0.0.0.0",
"0.0.0.0",
234","9195551234"',
("Midwest", "Midwest Regional NPAC SMS",
"cw0", "cw0", "", "rk6",
"0.0.0.0",
"0.0.0.0",
234","9195551234"',
("Northeast", "Northeast Regional NPAC SMS",
"cw2", "cw2", "", "rk6",
"0.0.0.0",
"0.0.0.0",
234","9195551234"',
("Southeast", "Southeast Regional NPAC SMS",
"cw3", "cw3", "", "rk6",
"0.0.0.0",
"0.0.0.0",
234","9195551234"',
("Southwest", "Southwest Regional NPAC SMS",
"cw4", "cw4", "", "rk6",
"0.0.0.0",
"0.0.0.0",
234","9195551234"',
("WestCoast", "WestCoast Regional NPAC SMS",
"cw6", "cw6", "", "rk6",
"0.0.0.0",
"0.0.0.0",
234","9195551234"',
("Western", "Western Regional NPAC SMS",
"cw5", "cw5", "", "rk6",
"0.0.0.0",
"0.0.0.0",
234","9195551234"',
DATE_FORMAT(NOW(), "%Y%m%d%h%i%s"));
-- Create LsmsServiceProvider table
CREATE TABLE LsmsServiceProvider
-- The service provider id (Primary Key)
spid CHAR(4) NOT NULL,
-- Description of the service provider
description CHAR(80) NOT NULL,
-- Contact Info (stored as comma separated value string)
-- Primary key is the spid
PRIMARY KEY (spid)
TYPE = MyIsam;
-- Create LsmsUser table
CREATE TABLE LsmsUser
-- The user name (Primary Key)
name CHAR(64) NOT NULL,
golden BOOL NOT NULL DEFAULT 0,
-- The Assigned permission group
groupName CHAR(4) NOT NULL,
-- The assigned inactivity timeout
inactivityTimeout CHAR(11) NOT NULL DEFAULT '-1',
-- Primary key is the user name
PRIMARY KEY (name)
TYPE = MyIsam;
-- Create default 'golden' users
INSERT INTO LsmsUser (name, golden)
VALUES('lsmsadm',1), ('lsmsuser',1), ('lsmsview',1),
('lsmsall',1), ('lsmsuext',1);
-- Create GttGroup table
CREATE TABLE GttGroup
-- The group name (Primary Key)
-- Description of the GttGroup
-- Services in GttGroup are for storing default TT/SSN values
-- AIN Service
ain_set BOOL NOT NULL DEFAULT 0,
ain_tt TINYINT UNSIGNED NOT NULL,
ain_dpc CHAR(9) NOT NULL,
ain_ssn CHAR(3) NOT NULL,
ain_xlat TINYINT UNSIGNED NOT NULL,
ain_ri TINYINT UNSIGNED NOT NULL,
ain_ngt TINYINT UNSIGNED NOT NULL,
ain_rgta BOOL NOT NULL,
-- IN Service
-- CLASS Service
class_set BOOL NOT NULL DEFAULT 0,
class_tt TINYINT UNSIGNED NOT NULL,
class_dpc CHAR(9) NOT NULL,
class_ssn CHAR(3) NOT NULL,
class_xlat TINYINT UNSIGNED NOT NULL,
class_ri TINYINT UNSIGNED NOT NULL,
class_ngt TINYINT UNSIGNED NOT NULL,
class_rgta BOOL NOT NULL,
-- LIDB Service
lidb_set BOOL NOT NULL DEFAULT 0,
lidb_tt TINYINT UNSIGNED NOT NULL,
lidb_dpc CHAR(9) NOT NULL,
lidb_ssn CHAR(3) NOT NULL,
lidb_xlat TINYINT UNSIGNED NOT NULL,
lidb_ri TINYINT UNSIGNED NOT NULL,
lidb_ngt TINYINT UNSIGNED NOT NULL,
lidb_rgta BOOL NOT NULL,
-- ISVM Service
isvm_set BOOL NOT NULL DEFAULT 0,
isvm_tt TINYINT UNSIGNED NOT NULL,
isvm_dpc CHAR(9) NOT NULL,
isvm_ssn CHAR(3) NOT NULL,
isvm_xlat TINYINT UNSIGNED NOT NULL,
isvm_ri TINYINT UNSIGNED NOT NULL,
isvm_ngt TINYINT UNSIGNED NOT NULL,
isvm_rgta BOOL NOT NULL,
-- CNAM Service
cnam_set BOOL NOT NULL DEFAULT 0,
cnam_tt TINYINT UNSIGNED NOT NULL,
cnam_dpc CHAR(9) NOT NULL,
cnam_ssn CHAR(3) NOT NULL,
cnam_xlat TINYINT UNSIGNED NOT NULL,
cnam_ri TINYINT UNSIGNED NOT NULL,
cnam_ngt TINYINT UNSIGNED NOT NULL,
cnam_rgta BOOL NOT NULL,
-- WSMSC Service
wsmsc_set BOOL NOT NULL DEFAULT 0,
wsmsc_tt TINYINT UNSIGNED NOT NULL,
wsmsc_dpc CHAR(9) NOT NULL,
wsmsc_ssn CHAR(3) NOT NULL,
wsmsc_xlat TINYINT UNSIGNED NOT NULL,
wsmsc_ri TINYINT UNSIGNED NOT NULL,
wsmsc_ngt TINYINT UNSIGNED NOT NULL,
wsmsc_rgta BOOL NOT NULL,
-- Primary key is the group name
PRIMARY KEY (name)
TYPE = MyIsam;
-- Create GttGroupSpid table
-- This table is used to associate a GttGroup to an authorized
-- LsmsServiceProvider. The many-many relationship between the two
-- is stored by this table a group-spid combinations.
CREATE TABLE GttGroupSpid
-- Group name
gttGroup CHAR(64) NOT NULL,
-- Spid
spid char(4) NOT NULL,
-- Force GttGroup,LsmsServiceProvider combinations to be unique
PRIMARY KEY (gttGroup, spid),
-- Not used by MySql but included for documentation
FOREIGN KEY (gttGroup) REFERENCES GttGroup(groupName),
FOREIGN KEY (spid) REFERENCES LsmsServiceProvider(spid)
TYPE = MyIsam;
-- Create LsmsUserSpid table
-- This table is used to associate a LsmsUser to an authorized
CREATE TABLE LsmsUserSpid
-- User name
lsmsUser CHAR(64) NOT NULL,
-- Spid
-- Force LsmsUser,LsmsServiceProvider combinations to be unique
PRIMARY KEY (lsmsUser, spid),
FOREIGN KEY (lsmsUser) REFERENCES LsmsUser(name),
TYPE = MyIsam;
-- Create DefaultGTT Table
CREATE TABLE DefaultGtt
-- The group this DefaultGtt belongs to
groupName CHAR(64) NOT NULL, -- Foreign key
-- NPA-NXX of the DefaultGtt
npanxx CHAR(6) NOT NULL,
-- The SPID that created the DefaultGtt
-- AIN Service
-- IN Service
-- CLASS Service
-- LIDB Service
-- ISVM Service
-- CNAM Service
-- WSMSC Service
-- DefaultGtt npanxx's are unique within each group
PRIMARY KEY (groupName, npanxx),
FOREIGN KEY (groupName) REFERENCES GttGroup(name)
TYPE = MyIsam;
-- Create OverrideGtt Table
CREATE TABLE OverrideGtt
-- The group this OverrideGtt belongs to
-- LRN of the OverrideGtt
lrn CHAR(10) NOT NULL,
-- The SPID that created the OverrideGtt
-- CLASS Service
-- LIDB Service
-- ISVM Service
-- CNAM Service
-- WSMSC Service
-- OverrideGtt lrns are unique within each group
PRIMARY KEY (groupName, lrn),
TYPE = MyIsam;
-- Create EmsInterface table. A row in the EmsInterface table can
represent
-- either a MpsInterface or a OapInterface object
CREATE TABLE EmsInterface
-- The CLLI (Primary Key)
clli CHAR(10) NOT NULL,
emsType ENUM("OAP", "MPS") NOT NULL,
-- The IP address of the primary interface
primaryAddress TINYBLOB NOT NULL,
-- The IP address of the secondary interface
secondaryAddress TINYBLOB NOT NULL,
-- The method to use to verify the presence of the MPS
pingMethod ENUM("PING", "SSH", "NONE") NOT NULL,
-- The mate CLLI
mateClli CHAR(10) NOT NULL,
-- Point code
pointCode CHAR(9) NOT NULL,
-- Point code of the mate
matePointCode CHAR(9) NOT NULL,
-- Capability point code
capabilityPointCode CHAR(9) NOT NULL,
-- GttGroup assigned to the EmsInteraface
gttGroup CHAR(64) NOT NULL DEFAULT ""
REFERENCES GttGroup(name),
-- TnFilter assigned to the EmsInteraface
tnFilter CHAR(64) NOT NULL DEFAULT ""
REFERENCES TnFilter, -- via FOREIGN KEY (ownerSpid, tnfilter)
-- ServiceProvider to which this EmsInterface is assigned
ownerSpid CHAR(4) NOT NULL DEFAULT ""
REFERENCES LsmsServiceProvider(spid),
-- The last fields are only used when the row represents a
-- OAP interface. The row is used to construct both OapInterface
-- objects and MpsInterface objects which are subclasses of
EmsInterface
-- OAP dcmAddress
dcmAddress TINYBLOB NULL DEFAULT NULL,
-- OAP retry interval
retryInterval INTEGER NULL DEFAULT NULL,
-- OAP retry count
retryCount INTEGER NULL DEFAULT NULL,
-- Primary key is the CLLI name
PRIMARY KEY (clli),
FOREIGN KEY (ownerSpid, tnFilter) REFERENCES TnFilter
TYPE = MyIsam;
-- Create TnFilter table. A row in the EmsInterface table can represent
-- either a RegionTnFilter or a NpaNxxTnFilter object
CREATE TABLE TnFilter
-- The LsmsServiceProvider this TnFilter belongs to
spid char(4) NOT NULL, -- Foreign key
-- The name of the TnFilter
-- Description of the TnFilter
-- The filter type (NpaNxxTnFilter or RegionalTnFilter)
filterType ENUM("Regional", "NpaNxx") NOT NULL,
-- If RegionalTnFilter, the region to send
regions SET("Not Used", "Canada", "MidAtlantic", "Midwest",
"Northeast",
"Southeast", "Southwest", "WestCoast", "Western")
NOT NULL,
-- If NpaNxxTnFilter, the filter type
npanxxType ENUM("Include", "Exclude") NOT NULL,
-- If NpaNxxTnFilter, the npa-nxxs to send
npanxxs LONGBLOB NOT NULL,
-- TnFilter names are unique within LsmsServiceProvider
PRIMARY KEY (spid, name),
TYPE = MyIsam;
-- Create private and public key tables
-- The first four fields define a base class Key in the object interface
-- +-- PrivateKey
-- Key <--|
-- +-- PublicKey
-- Each subclass and table has the key values for the key type.
-- Create "Model" PrivateKey table
CREATE TEMPORARY TABLE IF NOT EXISTS TempPrivateKey
listId INT UNSIGNED,
keyId INT UNSIGNED,
status ENUM("Expired", "Valid", "InUse"),
keyval BLOB -- Max length 1024
TYPE = MyIsam;
-- Create CanadaPrivateKey table
CREATE TABLE CanadaPrivateKey
id INT UNSIGNED NOT NULL AUTO_INCREMENT,
PRIMARY KEY (id)
) SELECT * FROM TempPrivateKey;
-- Create NortheastPrivateKey table
CREATE TABLE NortheastPrivateKey
PRIMARY KEY (id)
-- Create MidAtlanticPrivateKey table
CREATE TABLE MidAtlanticPrivateKey
PRIMARY KEY (id)
-- Create MidwestPrivateKey table
CREATE TABLE MidwestPrivateKey
PRIMARY KEY (id)
-- Create SoutheastPrivateKey table
CREATE TABLE SoutheastPrivateKey
PRIMARY KEY (id)
-- Create SouthwestPrivateKey table
CREATE TABLE SouthwestPrivateKey
PRIMARY KEY (id)
-- Create WestCoastPrivateKey table
CREATE TABLE WestCoastPrivateKey
PRIMARY KEY (id)
-- Create WesternPrivateKey table
CREATE TABLE WesternPrivateKey
PRIMARY KEY (id)
-- Create "Model" PublicKey table
CREATE TEMPORARY TABLE IF NOT EXISTS TempPublicKey
keyId INT UNSIGNED,
exponent TINYBLOB, -- Max length 3
modulus TINYBLOB -- Max length 256
TYPE = MyIsam;
-- Create CanadaPublicKey table
CREATE TABLE CanadaPublicKey
PRIMARY KEY (id)
) SELECT * FROM TempPublicKey;
-- Create NortheastPublicKey table
CREATE TABLE NortheastPublicKey
PRIMARY KEY (id)
-- Create MidAtlanticPublicKey table
CREATE TABLE MidAtlanticPublicKey
PRIMARY KEY (id)
-- Create MidwestPublicKey table
CREATE TABLE MidwestPublicKey
PRIMARY KEY (id)
-- Create SoutheastPublicKey table
CREATE TABLE SoutheastPublicKey
PRIMARY KEY (id)
-- Create SouthwestPublicKey table
CREATE TABLE SouthwestPublicKey
PRIMARY KEY (id)
-- Create WestCoastPublicKey table
CREATE TABLE WestCoastPublicKey
PRIMARY KEY (id)
-- Create WesternPublicKey table
CREATE TABLE WesternPublicKey
PRIMARY KEY (id)
-- Create one measurements table for each region
-- Create "Model" NpacMeasurements table
CREATE TEMPORARY TABLE IF NOT EXISTS TempNpacMeasurements
yyyydddhh INT UNSIGNED NOT NULL,
Binds INT UNSIGNED NOT NULL DEFAULT 0,
SuccessOps INT UNSIGNED NOT NULL DEFAULT 0,
FailedOps INT UNSIGNED NOT NULL DEFAULT 0,
PRIMARY KEY (yyyydddhh)
TYPE = MyIsam;
-- Create CanadaNpacMeasurements table
CREATE TABLE CanadaNpacMeasurements
) SELECT * FROM TempNpacMeasurements;
-- Create NortheastNpacMeasurements table
CREATE TABLE NortheastNpacMeasurements
-- Create MidAtlanticNpacMeasurements table
CREATE TABLE MidAtlanticNpacMeasurements
-- Create MidwestNpacMeasurements table
CREATE TABLE MidwestNpacMeasurements
-- Create SoutheastNpacMeasurements table
CREATE TABLE SoutheastNpacMeasurements
-- Create SouthwestNpacMeasurements table
CREATE TABLE SouthwestNpacMeasurements
-- Create WestCoastNpacMeasurements table
CREATE TABLE WestCoastNpacMeasurements
-- Create WesternNpacMeasurements table
CREATE TABLE WesternNpacMeasurements
-- Create DbConfig table
CREATE TABLE DbConfig
keyType ENUM("Canada", "MidAtlantic", "Midwest", "Northeast",
"Southeast", "Southwest", "WestCoast", "Western",
"R9", "R10", "R11", "R12", "R13", "R14",
"R15", "R16", "R17", "R18", "R19", "R20", -- Future
Regions
"Internal", "Ebda", "Lsms") NOT NULL,
keyName TINYBLOB NOT NULL, -- Max length 256
description TINYBLOB NOT NULL DEFAULT "", -- Max length 256
value BLOB NOT NULL DEFAULT "", -- Max length 64K
-- keyName is unique within keyType
PRIMARY KEY (keyType, keyName(255))
TYPE = MyIsam;
INSERT INTO DbConfig (keyType, keyName, description, value)
VALUES
("Canada", "REQUEST_RETRY_NUMBER", "Retry times for NPAC
requests", "3"),
("Canada", "REQUEST_RETRY_INTERVAL", "Retry minutes for NPAC
requests", "2"),
("Canada", "RECOV_RETRY_NUMBER", "Retry times for NPAC
recovery requests", "3"),
("Canada", "RECOV_RETRY_INTERVAL", "Retry mintues for NPAC
recovery requests", "5"),
("MidAtlantic", "REQUEST_RETRY_NUMBER", "Retry times for NPAC
requests", "3"),
("MidAtlantic", "REQUEST_RETRY_INTERVAL", "Retry minutes for NPAC
requests", "2"),
("MidAtlantic", "RECOV_RETRY_NUMBER", "Retry times for NPAC
("MidAtlantic", "RECOV_RETRY_INTERVAL", "Retry mintues for NPAC
("Midwest", "REQUEST_RETRY_NUMBER", "Retry times for NPAC
requests", "3"),
("Midwest", "REQUEST_RETRY_INTERVAL", "Retry minutes for NPAC
requests", "2"),
("Midwest", "RECOV_RETRY_NUMBER", "Retry times for NPAC
("Midwest", "RECOV_RETRY_INTERVAL", "Retry mintues for NPAC
("Northeast", "REQUEST_RETRY_NUMBER", "Retry times for NPAC
requests", "3"),
("Northeast", "REQUEST_RETRY_INTERVAL", "Retry minutes for NPAC
requests", "2"),
("Northeast", "RECOV_RETRY_NUMBER", "Retry times for NPAC
("Northeast", "RECOV_RETRY_INTERVAL", "Retry mintues for NPAC
("Southeast", "REQUEST_RETRY_NUMBER", "Retry times for NPAC
requests", "3"),
("Southeast", "REQUEST_RETRY_INTERVAL", "Retry minutes for NPAC
requests", "2"),
("Southeast", "RECOV_RETRY_NUMBER", "Retry times for NPAC
("Southeast", "RECOV_RETRY_INTERVAL", "Retry mintues for NPAC
("Southwest", "REQUEST_RETRY_NUMBER", "Retry times for NPAC
requests", "3"),
("Southwest", "REQUEST_RETRY_INTERVAL", "Retry minutes for NPAC
requests", "2"),
("Southwest", "RECOV_RETRY_NUMBER", "Retry times for NPAC
("Southwest", "RECOV_RETRY_INTERVAL", "Retry mintues for NPAC
("WestCoast", "REQUEST_RETRY_NUMBER", "Retry times for NPAC
requests", "3"),
("WestCoast", "REQUEST_RETRY_INTERVAL", "Retry minutes for NPAC
requests", "2"),
("WestCoast", "RECOV_RETRY_NUMBER", "Retry times for NPAC
("WestCoast", "RECOV_RETRY_INTERVAL", "Retry mintues for NPAC
("Western", "REQUEST_RETRY_NUMBER", "Retry times for NPAC
requests", "3"),
("Western", "REQUEST_RETRY_INTERVAL", "Retry minutes for NPAC
requests", "2"),
("Western", "RECOV_RETRY_NUMBER", "Retry times for NPAC
("Western", "RECOV_RETRY_INTERVAL", "Retry mintues for NPAC
("Internal", "MAX_SPIDS", "Maximum Service Providers allowed.",
"32"),
("Internal", "EDR", "Enable Efficient Data Reperesentation
(EDR).", "N" ),
("Internal", "SNMP", "Enable SNMP Agent.",
"N" ),
("Internal", "AFT", "Enable Automatic File Transfer.",
"N" ),
("Internal", "WSMSC", "Enable wireless service feature.",
"N" ),
("Internal", "WSMSC_TO_EAGLE","Enable sending of WSMSA service to
Eagle.", "N" ),
("Internal", "IP_GUI", "Enable Web based ip gui.", "N" ),
("Internal", "SPID_SECURITY", "Enable SPID based security.",
"N" ),
("Internal", "MAX_USERS", "Maximum Number of Users",
"8" ),
("Internal", "ENHANCED_FILTERS","Enable Group and Regional filter
creation.", "N" ),
("Internal", "MAX_EAGLES", "Maximum number of eagles.",
"16"),
("Internal", "REPORT_GEN", "Enable report generator.",
"N" ),
("Internal", "REPORT_GEN_QUERY_ACTIVE","Report generator pid field",
"0" ),
("Internal", "QUERY_SERVER", "Enable Query Server feature",
"N" ),
("Internal", "INACTIVITY_TIMEOUT", "Gui and Shell inactivity timeout
feature", "N" ),
("Internal", "SYSTEM_INACTIVITY_TIMEOUT", "System wide GUI and Shell
inactivity timeout value", "15" ),
("Ebda", "CMD_ARGS", "EBDA command line arguments", ""),
("Lsms", "NPAC_SPID", "Spid used to connect to NPAC", ""),
("Lsms", "CONTACT_INFO", "Spid used to connect to NPAC", '"Lsms
234","9195551234"'),
("Lsms", "COMPONENT_INFO", "Spid used to connect to NPAC",
'"LSMS","TKLC","LSMS","Tekelec, Inc.","6.0","1.0"');
-- Create NpaSplit table
CREATE TABLE NpaSplit
-- The old npa
oldNpa char(3) NOT NULL,
-- The new npa
newNpa CHAR(3) NOT NULL,
-- The nxx
nxx CHAR(3) NOT NULL,
-- The start of the permissive dialing period
startPDP CHAR(8) NOT NULL,
-- The end of the permissive dialing period
endPDP CHAR(8) NOT NULL,
-- The region the split belongs to
region ENUM("Canada", "MidAtlantic", "Midwest", "Northeast",
"R15", "R16", "R17", "R18", "R19", "R20"), -- Future
Regions
-- The status of the npa split
status ENUM("NotSet", "Pending", "Active", "Error"),
-- Old npa, new npa and nxx form primary unique key
PRIMARY KEY (oldnpa, newnpa, nxx)
TYPE = MyIsam;
-- Create SubscriptionVersion table
-- The Fields are defined in the order and format that are defined by the
-- NPAC bulk data file. This allows the SQL LOAD DATA command to be used
-- to load tables which is extremely fast.
-- Revision History
-- 15-may-07 ARICENT Feature 110663: NANC 399
CREATE TABLE SubscriptionVersion
-- Required field (Primary key)
versionId INT NOT NULL,
-- Required field (10 numeric character unique key)
tn CHAR(10) NOT NULL,
-- Optional field (10 numeric characters, Empty string means not present)
lrn CHAR(10) NOT NULL DEFAULT "",
-- Required field (1-4 characters)
newCurrentSp CHAR(4) NOT NULL DEFAULT "0000",
-- Required field (14 characters "YYYYMMDDHHMMSS")
activationTimestamp CHAR(14) NOT NULL DEFAULT "00000000000000",
-- Optional field (9 characters, Empty string means not present)
classDPC CHAR(9) NOT NULL DEFAULT "",
-- Optional field (1-3 characters, Empty string means not present)
classSSN CHAR(3) NOT NULL DEFAULT "",
lidbDPC CHAR(9) NOT NULL DEFAULT "",
lidbSSN CHAR(3) NOT NULL DEFAULT "",
isvmDPC CHAR(9) NOT NULL DEFAULT "",
isvmSSN CHAR(3) NOT NULL DEFAULT "",
cnamDPC CHAR(9) NOT NULL DEFAULT "",
cnamSSN CHAR(3) NOT NULL DEFAULT "",
-- Optional field (1-12 numeric characters, Empty string means not present)
endUserLocationValue CHAR(12) NOT NULL DEFAULT "",
-- Optional field (2 numeric characters, Empty string means not present)
endUserLocationType CHAR(2) NOT NULL DEFAULT "",
-- Required field (1-4 characters, Empty string means not present)
billingId CHAR(4) NOT NULL DEFAULT "",
-- Required field (lspp(0), lisp(1), pool(2))
lnpType TINYINT UNSIGNED NOT NULL DEFAULT 0,
-- Required field (new(0), delete(1), modified(2), audit-descrepancy(3)
downloadReason TINYINT UNSIGNED NOT NULL DEFAULT 0,
wsmscDPC CHAR(9) NOT NULL DEFAULT "",
wsmscSSN CHAR(3) NOT NULL DEFAULT "",
-- Optional field (wireline(0), wireless(1), voIP(2), voWiFi(3), sv_type_4(4), sv_type_5(5), sv_type_6(6) )
svType TINYINT NOT NULL DEFAULT -1,
-- Optional field (1-4 CHARACTERS)
alternativeSPIDCHAR(4) NOT NULL DEFAULT "",
-- Primay key is the Npac SubscriptionVersion id
PRIMARY KEY (versionId),
-- TN must be indexed and unique
UNIQUE KEY tn (tn),
-- Index lrn, for LSMS Subscription Version by LRN reports
INDEX (lrn),
-- Index lrn, for LSMS Subscription Version by SPID reports
INDEX (newCurrentSp)
TYPE = MyIsam;
-- Create NumberPoolBlock table
CREATE TABLE NumberPoolBlock
blockId INT NOT NULL,
-- Required field (7 numeric characters, Unique key)
npanxx_x CHAR(7) NOT NULL,
-- Changed DEFAULT from "" to 0 when migrated MySQL from 4.1.11 to 5.0.37
alternativeSPID CHAR(4) NOT NULL DEFAULT "",
-- Primay key is the Npac NumberPoolBlock id
PRIMARY KEY (blockId),
UNIQUE KEY npanxx_x (npanxx_x),
-- Index lrn, for LSMS Number Pool Block by LRN reports
INDEX (lrn),
-- Index lrn, for LSMS Number Pool Block by SPID reports
TYPE = MyIsam;
-- Create ServiceProvNetwork table
CREATE TABLE ServiceProvNetwork
serviceProvId CHAR(4) NOT NULL,
-- Required field (1 - 40 characters)
serviceProvName CHAR(40) NOT NULL DEFAULT "",
-- Service Provider type
serviceProvType ENUM("wireline", "wireless", "non_carrier", "sp_type_3",
"sp_type_4", "sp_type_5") NULL DEFAULT NULL,
-- Prmary key is the Service Provider ID
PRIMARY KEY (serviceProvId)
TYPE = MyIsam;
-- Create ServiceProvLRN table
-- The Fields are defined in the order that are defined by the
CREATE TABLE ServiceProvLRN
-- Foreign key -> ServiceProvNetwork
-- Required field (Primary key within each ServiceProvNetwork)
id INT NOT NULL,
-- Required field (10 numeric characters)
creationTimeStamp CHAR(14) NOT NULL DEFAULT "00000000000000",
downloadReason TINYINT NOT NULL DEFAULT 0,
-- Primary key is the Npac id within each ServiceProvNetwork
PRIMARY KEY (serviceProvId, id),
-- Lrn is unique key within each ServiceProvNetwork
UNIQUE KEY lrn (serviceProvId, lrn),
-- Index lrn
INDEX (lrn),
FOREIGN KEY (serviceProvId) REFERENCES ServiceProvNetwork(serviceProvId)
TYPE = MyIsam;
-- Create ServiceProvNPA_NXX table
-- The Fields are defined in the order defined by the NPAC bulk data file
-- but the npac file formats the npanxx as 'npa-nxx'.
CREATE TABLE ServiceProvNPA_NXX
-- Required field (Primary Unique Key)
id INT NOT NULL,
-- Required field (6 numeric characters)
effectiveTimeStamp CHAR(14) NOT NULL DEFAULT "00000000000000",
-- NpaNxx is unique key within each ServiceProvNetwork
UNIQUE KEY npanxx (serviceProvId, npanxx),
-- Index npanxx
INDEX (npanxx),
TYPE = MyIsam;
-- Create ServiceProvNPA_NXX_X table
-- but the npac file formats the npanxx as 'npa-nxx-x'.
CREATE TABLE ServiceProvNPA_NXX_X
id INT NOT NULL,
-- Required field (7 numeric characters)
modifiedTimeStamp CHAR(14) NOT NULL DEFAULT "00000000000000",
UNIQUE KEY npanxx_x (serviceProvId, npanxx_x),
-- Index npanxx_x
INDEX (npanxx_x),
TYPE = MyIsam;
-- Create Eagle Measurements Table
-- $S is replaced by CLLI for EMS in Table Name (ie,
STPAEagleMeasurments)
CREATE TABLE $SEagleMeasurements (
UpdTnSuccess INT UNSIGNED NOT NULL DEFAULT 0,
UpdTnFail INT UNSIGNED NOT NULL DEFAULT 0,
DelTnSuccess INT UNSIGNED NOT NULL DEFAULT 0,
DelTnFail INT UNSIGNED NOT NULL DEFAULT 0,
UpdDGttSuccess INT UNSIGNED NOT NULL DEFAULT 0,
UpdDGttFail INT UNSIGNED NOT NULL DEFAULT 0,
DelDGttSuccess INT UNSIGNED NOT NULL DEFAULT 0,
DelDGttFail INT UNSIGNED NOT NULL DEFAULT 0,
UpdOGttSuccess INT UNSIGNED NOT NULL DEFAULT 0,
UpdOGttFail INT UNSIGNED NOT NULL DEFAULT 0,
DelOGttSuccess INT UNSIGNED NOT NULL DEFAULT 0,
DelOGttFail INT UNSIGNED NOT NULL DEFAULT 0,
UpdSplitSuccess INT UNSIGNED NOT NULL DEFAULT 0,
UpdSplitFail INT UNSIGNED NOT NULL DEFAULT 0,
DelSplitSuccess INT UNSIGNED NOT NULL DEFAULT 0,
DelSplitFail INT UNSIGNED NOT NULL DEFAULT 0,
LsmsRetries INT UNSIGNED NOT NULL DEFAULT 0,
NERetries INT UNSIGNED NOT NULL DEFAULT 0,
TYPE = MyIsam;";
