C.1 Copying File Using SCP
Table C-1 Copying File Using SCP
STEP # This procedure will help copying the license file from a desktop to LSMS server
☐1.
Server X: Login to
server where license file is present
Logging to server using ID and password where license file is copied
☐2.
Server X: SCP the file
from server to LSMS server
scp <license file> root@<LSMS IP>: /usr/local/netech/etc/license
☐3.
LSMS MPS: Check if the license file has been copied correctly
Run command to check for license file :
$ cat /usr/local/netech/etc/license
Expected Output: Contents of license file should be displayed
This procedure is complete!
