C.2 Copying File Using USB
Table C-2 Copying File Using USB
| S T EP # | This procedure will help copying the license file from a desktop to LSMS server | |
☐1. |
Server X: Copy license file to USB |
Connect USB to desktop and copy the license file from desktop to USB. |
☐2. |
LSMS MPS: Confirm how the USB is enumerated on LSMS server |
Connect the USB to LSMS MPS which contains the license file and check on how it is enumerated using command : $dmesg | grep -i "removable disk"Expected output: sd 6:0:0:0: Attached scsi removable disk sdc This shows USB is enumerated as /dev/sdc |
☐3. |
LSMS MPS: Determine the partition name |
Run command fdisk –l on enumerated name device to determine partition name : This shows that partition name is /dev/sdc1 |
☐4. |
LSMS MPS: Copy license file from USB to MPS |
Run below command to copy the license file from USB |
☐5. |
LSMS MPS: Copy license file from /tmp directory |
$ cp /tmp/usb/<license-file> /usr/local/netech/etc/license |
☐6. |
LSMS MPS: Check if the license file has been copied correctly |
Run command to check for license file : $ cat /usr/local/netech/etc/licenseExpected Output : Contents of license file should be displayed |
☐7. |
LSMS MPS: Unmount the USB |
Unmount the USB using command : $umount /tmp/usb |
This procedure is complete! |
