3.7.1 Procedure 12 LSMS Initial Configuration
Table 3-17 Procedure 12 - LSMS Initial Configuration
STEP # This procedure does the initial configuration on the LSMS servers. Estimated time: 15 minutes
☐1.
MPS A: Log in to the server as the user “root”.
Login: root
Password: <root_password>
☐2.
MPS A:
Start lsmsmgr utility by logging in as lsmsmgr user
# su - lsmsmgr
☐3.
MPS A:
Select “Initial Configuration”
Main Menu with Initial Configuration selected.
☐4.
MPS A:
Select “yes”
Select OK and press [ENTER]
Select running options dialog with Run All set to yes.
☐5.
MPS A:
Enter password for “lsmsadm” Select
Initial configuration prompt for the lsmsadm password.
☐6.
MPS A:
Enter password for “admusr” Select
Initial configuration prompt for the admusr password.
☐8.
MPS A:
Enter the NAS password used to login into NAS console. Accept the default serial port (ttyS6) when prompted for the path to the NAS console device.
NAS backup configuration prompt showing the serial device /dev/ttyS6.
☐9.
A message is displayed indicating the lsmsadm Key Exchange was successful. A message is displayed indicating the admusr Key Exchange was successful. A message is displayed indicating the Time Synchronization was successful. A message is displayed indicating the Database creation was successful.
A message is displayed indicating the NAS Backup Configuration was successful. A message is displayed indicating the inhibiting of the node was successful.
Select Exit and press [ENTER] repeatedly to exit lsmsmgr
☐10.
MPS A:
Switch to mate
#ssh mate
☐11.
MPS B:
Start lsmsmgr
# su - lsmsmgr
☐12.
MPS B:
☐13.
MPS B:
Select “yes”
☐14.
MPS B:
Initial configuration prompt for the NAS root password.
☐15.
A message is displayed indicating the NAS Backup Configuration was successful. Select Exit and press [ENTER] repeatedly to exit lsmsmgr
☐16.
MPS B:
Log into the LSMS B server via minicom.
# minicom mate
☐17.
MPS A:
Perform init 6 to reboot the LSMS B card.
# init 6
Watch for errors during boot process.
When the login prompt is displayed, exit from minicom.
☐18.
MPS A:
Log into the LSMS A server via minicom.
# minicom mate
☐19.
MPS B:
Perform init 6 to reboot the LSMS A card.
# init 6
This procedure is complete!
