3.5.1 Procedure 4 Disconnect ELAP from LSMS
Table 3-9 Procedure 4 - Disconnect ELAP from LSMS
STEP # This procedure disconnects the ELAP from LSMS.Estimated time: 5 minutes Note: This procedure needs to be executed on all the connected ELAPs.
☐1.
ELAP Active server:
Verify ELAP 10.2 install
Note: Verify the following.
  1. ELAP 10.2 is successfully installed and configured.
  2. ELAP 10.2 is connected to Eagle for data download
☐2.
LSMS Active server:
Log in to the server as the user “lsmsadm”.
Login: lsmsadm
Password: <lsmsadm_password>
☐3.
LSMS Active server:
Disconnect the connected ELAPs
$ eagle status
Look for all connected ELAPs and disconnect each of them.
$ eagle stop <ELAP CLLI>
eagle: Stopping...
eagle: eagleagent STPA stopped at Tue Apr 26 05:48:52 2023
☐4.
ELAP Active server:
Login to ELAP GUI
Login to the ELAP (connected to LSMS) GUI through VIP as uiadmin.
☐5.
ELAP Active server:
Disable the Bulk Download
Go to menu Maintenance -> LSMS HS Bulk Download -> Change Enabled Click on ‘Disable LSMS Bulk Download for this ELAP’ button.
ELAP A page offering to disable LSMS bulk download.
ELAP A success message confirming that LSMS bulk download is disabled.
☐6.
ELAP Active server:
Disable the LSMS Connection
Go to menu Maintenance -> LSMS Connection -> Change Enabled Click on ‘Disable LSMS Connection’ button.
ELAP A page offering to disable the LSMS connection.
ELAP A success message confirming that the LSMS connection is disabled.
☐7.
All connected ELAPs:
Disconnect LSMS connection
Repeat the steps 4 to 6 for all ELAPs connected to LSMS.
This procedure is complete!
