3.5.2 Procedure 5 Disconnect NPAC from LSMS
Table 3-10 Procedure 5 - Disconnect NPAC from LSMS
STEP # This procedure disconnects NPAC from LSMS. Estimated time: 5 minutes
☐1.
LSMS Active server:
Log in to the server as the user “lsmsadm”.
Login: lsmsadm
Password: <lsmsadm_password>
☐2.
LSMS Active server:
Stop all connected NPAC regions
Run the following command to list the active NPAC regions
$ dbnames -n all -a
Canada CanadaDB
MidAtlantic MidAtlanticDB
Midwest MidwestDB
Northeast NortheastDB
Southeast SoutheastDB
Southwest SouthwestDB
WestCoast WestCoastDB
Western WesternDB
Note: The above output shall vary depending on LSMS configuration. Note: Store this output as it will be required during DB restore phase post upgrade.
Run the following command to stop an NPAC region.
$ lsms stop <region name>
Checking if npacagent is running. .. Yes.
Stopping npacagent....
OK.
npacagent stopped: Wed Jan 2 05:52:42 2014
Command complete.
Run the above command for all active regions.
☐3.
LSMS Active server:
Login to LSMS GUI
Login to LSMS Active GUI through VIP as ‘lsmsall’ user.
☐4.
LSMS Active server:
Deactivate all active regions
Click on the NPAC region.
Go to the menu Configure -> LNP System -> NPAC -> Modify -> Primary Uncheck the ‘Activate Region’ checkbox and click ‘OK’.
Modify LNP System NPAC dialog with the Activate Region checkbox clear.
Note: Similarly, Deactivate all the active NPAC regions.
This procedure is complete!
