A Deployment Configuration Examples
This appendix contains examples of three deployment configurations:
Small (100 users)
Medium (300 to 400 users)
Large (1000 users)
The hardware proposed for each deployment size is based on the equation for calculating capacity presented in "Hardware Sizing Guidelines".
The examples presented here are based on the number of concurrent users, which is only one criteria used to determine hardware sizing. The examples are general and are intended as a learning tool. Estimates on equipment and configuration settings cannot be exact because needs vary between MetaSolv Solution installations based on criteria such as the number of users, the volume of transactions, whether the application is being used on a WAN, and so on. To ensure that you have planned for the appropriate equipment and software, Oracle recommends that you contact its Professional Services Organization before you proceed with an installation.
When assessing your business situation to estimate hardware needs, you should consider a combination of factors such as API transactions and the type and number of transactions being processed, then adjust accordingly.
Small Deployment Example (100 users)
The following sections describe a small deployment example and include details on deployment size assumptions and hardware configuration.
Deployment Description
Table A-1 shows the size assumptions made for this deployment example.
Table A-1 Size Assumptions for a Small Deployment
| Size and Usage Requirement | Nonclustered Nonredundant Environment | Clustered Redundant Environment |
Number of concurrent users |
100 |
100 |
Number of orders per day |
8,000 |
8,000 |
Circuit assignment |
700 |
700 |
Number of trouble tickets |
4,000 |
4,000 |
Reliability/availability |
98% |
99.5% |
Hardware Configuration
Table A-2 shows the hardware configurations for this deployment example.
Table A-2 Example Small Deployment Hardware Configuration
| Computer | Nonclustered Nonredundant Environment | Clustered Redundant Environment |
Client computer (one per user) |
Windows-based computer (2.6+ GHz; 8 GB+ RAM) |
Administration server computer |
N/A |
You can use the WebLogic application server computer (below) to handle the administration server as well. No additional hardware is needed. |
WebLogic application server computer |
1 SPARC T8-1
2 SPARC T8-1
External load balancers |
N/A |
***2 load balancers Customer's choice Example: F5 BIG-IP LTM |
Database server (Oracle) computer |
1 SPARC T8-1
2 SPARC T8-1 (Active/Passive)
Background Processor computer |
1 Windows-based computer
2 Windows-based computers
*Clustering with non-redundancy does not apply here. Oracle recommends one Oracle application server per 2 CPUs.
**Only one Oracle Application Server will reside on each computer.
***Access Oracle requirements for hardware load balancer. See the following website:
For a configuration example using BIG-IP LTM as hardware load balancer, see the following website:
https://www.f5.com/services/resources/deployment-guides/oracle-weblogic-121-103-big-ip-v114-ltm-aam
Medium Deployment Example (300 to 400 users)
The following sections describe a medium deployment example, and include details on size assumptions and hardware configuration.
Table A-3 shows the size assumptions for this deployment example.
Table A-3 Size Assumptions for a Medium Deployment
| Size and Usage Requirement | Clustered Nonredundant Environment | Clustered Redundant Environment |
300-400 |
300-400 |
30,000 |
30,000 |
3,000 |
3,000 |
16,000 |
16,000 |
99.5% |
99.9% |
Table A-4 shows the hardware configurations for this deployment example.
Table A-4 Example Medium Deployment Hardware Configuration
| Computer | Clustered Nonredundant Environment | Clustered Redundant Environment |
Windows-based computer (3.4+ GHz; 8 GB+ RAM) |
N/A |
1 SPARC T8-1
2 SPARC T8-1
*** 1 load balancer Customer's choice Example: F5 BIG-IP LTM |
1 SPARC T8-1
2 SPARC T8-1
*For better performance and reliability, a clustered environment is recommended for medium-sized customers.
**The recommendation is for four Oracle application server processes to run on each computer.
Large Deployment Example (1,000 users)
The following sections describe a large deployment example, and include details on size assumptions and hardware configuration.
Table A-5 shows the size assumptions for this deployment example.
Table A-5 Size Assumptions for a Large Deployment
1,000 |
1,000 |
100,000 |
100,000 |
7,200 |
7,200 |
42,000 |
42,000 |
99.5% |
99.9% |
Hardware Recommendations
Table A-6 shows the hardware configurations for this deployment example.
Table A-6 Example Large Deployment Hardware Configuration
Windows-based computer (3.4+ GHz; 512 MB+ RAM) |
N/A |
1 SPARC T8-2
2 SPARC T8-2
***1 load balancer Customer's choice Example: F5 BIG-IP LTM |
1 SPARC T8-2
2 SPARC T8-2
*For better performance and reliability, a clustered environment is recommended for large-sized customers.
**The recommendation is for eight Oracle application server processes to run on each computer.
