7 Order Web Service Reference
This chapter provides information about Oracle Communications MetaSolv Solution (MSS) Order Web Service.
About the Order Web Service
The Order Web Service enables an external system to import and maintain order information in MSS. Order Web Service operations enable you to:
Create, get, update, and finish an order.
Complete, reopen, and a transfer task for an order.
Assign a provisioning plan to an order.
Process a supplement order.
Get and update CNAM/LIDB and E911 data.
The following summarizes the CNAM/LIDB and E911 data terms:
Calling Name (CNAM) is a telephone service used to display the name and telephone number of the caller.
Line Database (LIDB) is a telephone service used to verify a telephone number for toll service and third-party billing, such as for validation of calling card numbers.
E911 is a telephone service used to provide emergency (911) operators with the caller's telephone number and location.
About the Order Web Service Packaging
The Order Web Service is packaged in the MSS_WebService.ear file, which contains the order.war file. When the installer deploys the EAR file, the Order Web Service is automatically deployed and ready to use.
The MSS_WebService.ear file also includes the other MSS web service operations. See "Web Services Overview" for information about these operations.
About the Order WSDL, WAR, and Schema Files
The Order Web Service is defined by the OrderAPI.wsdl file and is supported by numerous schema files. The WSDL file and supporting schema files are located in the order.war file.
See "Understanding How MSS Defines Web Services" for more information about WSDL and WAR files, and about their directory locations in the EAR file.
About Order Schema Files
Numerous schema files support the Order Web Service. Within the order.war file, the schema files are located in the WEB-INF/wsdls directory. These schemas are categorized as common schemas, entity schemas, and data schemas, and API schemas.
Entity Schemas
The entity schemas define elements, such as keys and types, specific to the web service.
The Order entity schemas are defined in the following files:
CustomerManagementEntities.xsd
InventoryManagementEntities.xsd
MIPCommonEntities.xsd
OrderManagementEntities.xsd
ServiceEntities.xsd
Data Schemas
The data schemas contain numerous complex type structures, enumerations, and simple types.
The Order data schemas are defined in the following files:
CustomerManagementData.xsd
InventoryManagementData.xsd
OrderAncillaryManagementData.xsd
OrderManagementData.xsd
ServiceData.xsd
ServiceOrderData.xsd
addTaskRequest Operation
The addTaskRequest operation enables external systems to add a task to an existing provisioning plan assigned order which is not completed.
The following are the request and response structures:
Request Structure: addTaskRequest
Response Structure: addTaskRequestResponse
addTaskRequest
The addTaskRequest element contains the input information for the operation. Each row in Table 7-1 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-1 Payload Information for the Request
| Name | Defined As | Type Description | File Name |
addTaskRequest |
element |
momAddTaskRequest |
OrderAPI.wsdl |
momAddTaskRequest |
element |
addTaskRequestValue |
OrderManagementAPI.xsd |
element |
AddTaskRequestValueType |
ComplexType |
ComplexType with task, taskKey, addTaskPolicy |
OrderManagementData.xsd |
task |
element |
Task |
Task |
ComplexType |
ComplexType with a list of fields |
OrderManagementEntities.xsd |
taskKey |
element |
TaskOrderKey |
TaskOrderKey |
ComplexType |
addTaskPolicy |
element |
AddTaskPolicy |
AddTaskPolicy |
ComplexType |
Table 7-2 describes the required fields for addTaskRequest.
Table 7-2 Required Fields
| File Name | Data Type | Field Description |
primaryKey |
string |
A system-assigned identifier for the document number. Value should be zero for creating new order. |
The addTaskRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-3 describes the returned information in the response.
Table 7-3 Payload Information for the Request
addTaskRequestResponse |
element |
addTaskResponse |
OrderAPI.wsdl |
addTaskResponse |
element |
addTaskResponseValue |
element |
AddTaskResponseValueType |
ComplexType |
ComplexType with task, planKey, planDefinition |
task |
element |
Task |
Task |
ComplexType |
planKey |
element |
PlanKey |
PlanKey |
ComplexType |
planDefinition |
element |
PlanDefinition |
PlanDefinition |
ComplexType |
addTaskJeopardyRequest Operation
This operation enables external systems to add jeopardy information for a task. Adding jeopardy information with reason codes identifies a task as being at risk of completing late and specifies the reason for the risk.
Request Structure: addTaskJeopardyRequest
Response Structure: addTaskJeopardyResponse
The addTaskJeopardyRequest element contains the input information for the operation. Each row in Table 7-4 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-4 Payload Information for the Request
addTaskJeopardyRequest |
element |
momAddTaskJeopardyRequest |
OrderAPI.wsdl |
element |
addTaskJeopardyRequestValue |
element |
AddTaskJeopardyRequestValueType |
complexType |
Contains a list of fields |
Table 7-5 describes the required fields for addTaskJeopardyRequest.
Table 7-5 Required Fields
| Field Name | Data Type | Field Description |
jeopId |
int |
Oracle-generated sequence that uniquely identifies the object in the MSS database. |
docNum |
OrderKey |
System-assigned identifier for the document number. |
taskNum |
TaskKey |
System-assigned identifier for the task. |
jeopardyReasonCode |
string |
Four-digit numeric code for identifying why a key date was missed and why a task was not performed by the scheduled completion date. |
The addTaskJeopardyResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-6 describes the returned information in the response.
Table 7-6 Payload Information for the Response
addTaskJeopardyRequestResponse |
element |
Contains the addTaskJeopardyResponse string |
OrderAPI.wsdl |
Table 7-7 describes the error messages for the operation.
Table 7-7 Error Messages for the Operation
| Error Message | Cause | Resolution |
The document number is not found. |
The provided document number does not exist in the database. |
Verify and pass in a valid document number. |
The jeopardy reason code is not valid. |
An invalid jeopardy reason code was provided in the request. |
Verify and provide a valid jeopardy reason code value in the request. |
assignProvPlanRequest Operation
This operation assigns a provisioning plan to the order. This operation takes the provisioning plan ID and order key as the input.
Request Structure: assignProvPlanRequest
Response Structure: assignProvPlanRequestResponse
The assignProvPlanRequest element contains the input information for the operation. Each row in Table 7-8 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-8 Payload Information for the Request
assignProvPlanRequest |
element |
assignProvisionPlanProcedureRequest |
OrderAPI.wsdl |
element |
AssignProvisionPlanProcedureValue |
complexType |
Extension of MetaSolvAssignProvPlanValue Contains a list of fields |
Table 7-9 describes the required fields for ProvPlanRequest.
Table 7-9 Required Fields for ProvPlanRequest
OrderKey |
OrderKey |
Document number of the order to assign the provisioning plan. |
ProvisioningPlanKey |
string |
Provisioning plan key value to be assigned to this order. |
The assignProvPlanRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-10 describes the returned information in the response.
Table 7-10 Payload Information for the Response
assignProvPlanRequestResponse |
element |
assignProvisionPlanProcedureResponse |
OrderAPI.wsdl |
element |
mommekey |
Mommekey |
element |
MetaSolvOrderKeyChoice |
complexType |
metaSolvOrderKey |
metaSolvOrderKey |
element |
OrderKey |
OrderKey |
complexType |
Extension of ManagedEntityKey Contains a list of fields |
Table 7-11 describes the error messages for the operation.
Table 7-11 Error Messages for the Operation
Miscellaneous Error: Tasks cannot be assigned. Order status is invalid. |
Tasks are requested assignment when the order status is not valid for task assignment. |
Change the status of the input order number or change the input order number. |
billingTelephoneNumberRequest Operation
This operation assigns the billing telephone number (BTN) on an order that has multiple telephone numbers. This operation assigns and unassigns the billing telephone number. It takes the number inventory ID as input for the telephone number.
Request Structure: billingTelephoneNumberRequest
The billingTelephoneNumberRequest element contains the input information for the operation. Each row inTable 7-12 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-12 Payload Information for the Request
| Name | Defined As | Type Definition | File Name |
billingTelephoneNumberRequest |
element |
billingTelephoneNumber |
OrderAPI.wsdl |
complexType |
Table 7-13 describes the required fields for billingTelephoneNumberRequest.
Table 7-13 Required Fields for billingTelephoneNumberRequest
documentNumber |
long |
Document number of the order where the billing telephone number is being set. |
servItemId |
long |
Corresponding Service Item ID for the billing telephone number values. |
BtnFunctionEnum |
Enum |
Corresponding BTN function ' 0 - Assign and 1 - Unassign'. |
nbrInvId |
long |
Corresponding Number Inventory ID of the telephone number. |
billingTelephoneNumberRequestResponse
The billingTelephoneNumberRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-14 describes the returned information in the response.
Table 7-14 Payload Information for the Response
billingTelephoneNumberRequestResponse |
element |
billingTelephoneNumberResponse |
OrderAPI.wsdl |
complexType |
Contains the documentNumber integer for the order |
Table 7-15 describes the error messages for the operation.
Table 7-15 Error Messages for the Operation
BTN Assign/UnAssign is allowed only for ''pending'' or ''electronically received'' orders. |
You are requesting an assign or unassign of billing telephone number for an order that is not in correct status. |
You can only perform this action when the order is pending or electronically received. |
completeTaskRequest Operation
This operation completes a task for an order. It takes order number and task number as input and marks the task as complete.
This completeTaskRequest operation is used for only complete task requests. The following are in the schema files, however this operation does not support:
updateServicesInOrderProcedureValue
updateOrderTaskGWEventValue
To execute these operations use the updateOrderRequest operation.
Request Structure: completeTaskRequest
Response Structure: completeTaskRequestResponse
completeTaskRequest
The completeTaskRequest element contains the input information for the operation. Each row in Table 7-16 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-16 Payload Information for the Request
completeTaskRequest |
element |
updateOrderManagementRequest |
OrderAPI.wsdl |
element |
updateValue |
updateValue |
element |
MetaSolvUpdateProcedureValueChoice |
complexType |
completeTaskProcedureValue |
element |
CompleteTaskProcedureValue |
complexType |
See Table 7-17 |
Table 7-17 defines CompleteTaskProcedureValue.
Table 7-17 CompleteTaskProcedureValue Definition
complexType |
whyMissInputs |
element |
WhyMissInputType |
WhyMissInputType |
complexType |
Table 7-18 describes the required fields for completeTaskRequest.
Table 7-18 Required Fields for completeTaskRequest
taskNumber |
long |
Task Number of the task to be completed. |
OrderKey |
OrderKey |
Document Number of the order where the task is assigned. |
whyMissReasonCode |
string |
Reason code for why the task was not completed on time. This field is only required when the task exceeds the actual completion date. |
The completeTaskRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful.Table 7-19 describes the returned information in the response.
Table 7-19 Payload Information for the Response
completeTaskRequestResponse |
element |
completeTaskProcedureResponse |
OrderAPI.wsdl |
element |
CompleteTaskProcedureResponse |
complexType |
mommekey |
mommekey |
element |
complexType |
metaSolvOrderKey |
metaSolvOrderKey |
element |
OrderKey |
OrderKey |
complexType |
Table 7-20 describes the error messages for the operation.
Table 7-20 Error Messages for the Operation
Task row not found for document number, task number. |
For the input document number and task number, the task could not be found in inventory. |
Check that the document number and task number exist for the document number/order. |
The task requires a why missed code before it can be completed. |
For the input task number, the why-missed code is not yet populated to complete the task. |
Populate the why-missed code for the task and then request the task completion again. |
createAttachment Operation
The createAttachment operation creates an attachment for the input order.
Request Structure: createAttachment
Response Structure: createAttachmentResponse
createAttachment
The createAttachment element contains the input information for the operation. Each row in Table 7-21 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-21 Payload Information for the Request
CreateAttachment |
element |
createAttachmentRequest |
OrderAPI.wsdl |
element |
CreateAttachmentRequestValue |
element |
CreateAttachmentType |
complexType |
Table 7-22 describes the required fields for createAttachment.
Table 7-22 Required Fields for createAttachment
attachmentKey |
string |
Valid PSR document number. |
attachmentName |
string |
Valid attachment name which appears in GUI. |
transformationName |
string |
Name of the XSL file stored in ms_attachment_transform table. |
attachmentType |
Enum |
ORDER is the valid enum value for attachment. |
The createAttachmentResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-23 describes the returned information in the response.
Table 7-23 Payload Information for the Response
createAttachmentResponse |
element |
momCreateAttachmentResponse |
OrderAPI.wsdl |
element |
Contains the CreateAttachmentResponseValue long |
createISROrderRequest Operation
This operation creates a new ISR order in the system and returns the new order key. A single OrderValue is the only value passed into the request. The state values in OrderValue are ignored; the state is initialized to STARTED by the system.
Request Structure: createISROrderRequest
Response Structure: createISROrderResponse
The createISROrderRequest element contains the input information for the operation. Each row in Table 7-24 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
This operation only supports the metaSolvISROrderValue schema in the request. For creating a PSR order using the metaSolvPSROrderValue schema, use the createOrderRequest and createPSROrderRequest operations.
Table 7-24 Payload Information for the Request
createISROrderRequest |
element |
createOrderByValueRequest |
OrderAPI.wsdl |
element |
Mommevalue |
Mommevalue |
element |
MetaSolvOrderValueChoice |
complexType |
complexType with a choice of type:
metaSolvISROrderValue |
complexType |
See Table 7-41 |
The complexType metaSolvISROrderValue for the create IRS order operation. metaSolvISROrderValue is a choice in the MetaSolvOrderValueChoice definition. The metaSolvISROrderValue element is mutually exclusive with the PSR order information metaSolvPSROrderValue.
Table 7-25 describes the required fields for ISROrderHeaderType.
Table 7-25 Required Fields for ISROrderHeaderType
externalOrderKey |
string |
External order key from the external system. |
requestType |
string |
Request type for the ISR order. |
activityCd |
string |
Activity code for the order. |
broadbandServiceCategory |
string |
Broad band service category if required. |
uniValue |
string |
UNI value for the order. |
organizationId |
string |
Organization ID for the order. |
userId |
string |
User ID for the order. |
desiredDueDate |
string |
Desired due date for the order that is planned. |
serviceOrderDate |
string |
Service order date for the order that is planned. |
servReqStatus |
int |
Service request status of the order. |
quantityUnit |
string |
Quantity on the order. |
quantityCircuitUnit |
int |
Quantity of circuit on the order. |
quantityVirtConnUnit |
int |
Quantity of virtual circuit on the order. |
activeInd |
string |
Active Indicator for the order. |
Table 7-26 describes the required fields for ISRContactType.
Table 7-26 Required Fields for ISRContactType
actionCd |
string |
Action code for the contact. |
orderKey |
int |
Document number of the order. |
companyContact |
string |
Company contact details of the order. |
assocContactName |
string |
Associate contact details. |
customerContactName |
string |
Customer contact details. |
Table 7-27 describes the required fields for ISRNoteValueType.
Table 7-27 Required Fields for ISRNoteValueType
noteKey |
int |
Note key value. |
actionCd |
string |
Action code for the note. |
noteText |
string |
Data to be entered on the note. |
circuitNoteInd |
string |
Note for the circuit. |
Table 7-28 describes the required fields for ISRLocationValueType.
Table 7-28 Required Fields for ISRLocationValueType
isTerminationPoint |
boolean |
Indicates if this is a termination point. |
netLocUse |
string |
Network location use code. |
Table 7-29 describes the required fields for ISRServiceValueType.
Table 7-29 Required Fields for ISRServiceValueType
actionCd |
string |
Action code for the service. |
activityCd |
string |
Activity code for the service. |
serviceItemKey |
string |
Service item id of the ISR order. |
orderKey |
int |
Table 7-30 describes the required fields for ISRRemarkType.
Table 7-30 Required Fields for ISRRemarkType
orderKey |
int |
formId |
string |
Form ID value. |
seqNumber |
int |
Sequence number of the order. |
remarkText |
string |
Remark that can be updated. |
The createISROrderResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-31 describes the returned information in the response.
Table 7-31 Payload Information for the Response
createISROrderResponse |
element |
createOrderByValueResponse |
OrderAPI.wsdl |
element |
mommekey |
mommekey |
element |
complexType |
metaSolvOrderKey |
metaSolvOrderKey |
element |
OrderKey |
OrderKey |
complexType |
createOrderRelationship Operation
This operation creates a relationship between two input order numbers. The input values are parent order ID and child order ID.
Request Structure: createOrderRelationship
Response Structure: createOrderRelationshipResponse
The createOrderRelationship element contains the input information for the operation. Each row in Table 7-32 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-32 Payload Information for the Request
createOrderRelationship |
element |
createOrderRelationshipRequest |
OrderAPI.wsdl |
complexType |
Contains the following:
Table 7-33 describes the required fields for createOrderRelationship.
Table 7-33 Required Fields for createOrderRelationship
parentOrderKey |
OrderKey |
Document number of the parent order of the relationship. |
childOrderKey |
OrderKey |
Document number of the child order of the relationship. |
The createOrderRelationshipResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-34 describes the returned information in the response.
Table 7-34 Payload Information for the Response
createOrderRelationshipResponse |
element |
Contains the momCreateOrderRelationshipResponse string |
OrderAPI.wsdl |
createOrderRequest Operation
The createOrderRequest operation enables external systems to create orders in MSS. You can request two different types of orders with this operation: PSR orders and ISR orders.
Request Structure: createOrderRequest
Response Structure: createOrderRequestResponse
createOrderRequest
The createOrderRequest element contains the input information for the operation. Each row in Table 7-35 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-35 Payload Information for the Request
createOrderRequest |
element |
OrderAPI.wsdl |
element |
mommevalue |
mommevalue |
element |
complexType |
metaSolvPSROrderValue |
complexType |
Described in Table 7-36 |
complexType |
Described in Table 7-41 |
Table 7-36 describes the metaSolvPSROrderValue definition information for the create PSR order operation. metaSolvPSROrderValue was referenced in Table 7-35 as a choice in the MetaSolvOrderValueChoice definition. The metaSolvPSROrderValue element is mutually exclusive with the ISR order information.
Table 7-36 metaSolvPSROrderValue Definition
element |
MetaSolvPSROrderValue |
complexType |
Extension of OrderValue OrderHeaderType metaSolvUserDataValue MetaSolvServiceValueChoice LineDirType |
OrderValue |
complexType |
Extension of ManagedEntityValue |
OrderHeaderType |
complexType |
complexType with a list of fields |
metaSolvUserDataValue |
complexType |
MetaSolvUserDataValueType |
MIPCommonEntities.xsd |
complexType |
UserDataValueType |
UserDataValueType |
complexType |
complexType with a list of fields BaseNameValueType |
MetaSolvServiceValueChoice |
complexType |
choice of metaSolvServiceValue |
ServiceEntities.xsd |
element |
MetaSolvServiceValue |
complexType |
Extension of ServiceValue and a list of fields |
ServiceValue |
complexType |
Extension of EntityValue complexType with a list of fields |
Service.xsd |
EntityValue |
complexType |
CBEManagedEntityValue |
Core.xsd |
LineDirType |
complexType |
lineDirectoryType |
lineDirectoryType |
complexType |
Table 7-37 describes the required fields for OrderValue.
Table 7-37 Required Fields for OrderValue
PrimaryKey |
OrderKey |
Value should be 0 if it is new or change order and the document number for update order. |
Table 7-38 describes the required fields for OrderHeaderType.
Table 7-38 Required Fields for OrderHeaderType
organizationId |
string |
Organization responsible for processing the order and providing service. |
servReqStatus |
Enum |
Valid values are defined in OrderStatusEnumType. Any new or change order created through an API should have osRECEIVED which refers as Electronically Received order. For update order, the corresponding order status should be passed. |
customerAccountKey |
integer |
Customer account key to associate to the order. |
orderedByFirstName |
string |
First name of the individual placing the order. |
orderedByLastName |
string |
Last name of the individual placing the order. |
orderedByTelephoneNr |
string |
Telephone number of the individual placing the order. |
desiredDueDate |
CbeDateTime |
Date that the customer desires the products to be installed and in-service. |
serviceOrderDate |
CbeDateTime |
Date the order is placed (entered). |
responsibleParty |
string |
Person responsible for the order, such as the customer care rep or the sales person. |
orderActivityCd |
Enum |
Valid values are oaNEW, oaCHANGE and oaDISCONNECT |
billActivationDate |
CbeDateTime |
Date for the customer invoice. |
suppType |
Enum |
Valid values are stcorrect, stcancell, stduedate and stnone. For a new order, this is always the value stnone and for update orders, this can be updated according to the requirement. |
Table 7-39 describes the required fields for UserDataValueType.
Table 7-39 Required Fields for UserDataValueType
tableNm |
string |
Table where the user data is stored. This table corresponds to where the user data was originally defined. |
keyColumnNm |
string |
Actual primary key column name of the product area. This is required so the user data row can be associated with one item. |
keyValue |
integer |
Actual value of the product area. |
Table 7-40 describes the required fields for BaseNameValueType.
Table 7-40 Required Fields for BaseNameValueType
column |
string |
Field is the user data column that is updated. |
value |
string |
Value entered into the defined column. |
dataType |
string |
Function of a user data field. Determines the kind of information a user can enter in a field on the User Data window. Valid values are Number, Decimal, VARCHAR2, Date, Dropdown. |
Table 7-41 describes the metaSolvISROrderValue definition information for the create IRS order operation. metaSolvISROrderValue was referenced in Table 7-35 as a choice in the MetaSolvOrderValueChoice definition. The metaSolvISROrderValue element is mutually exclusive with the PSR order information metaSolvPSROrderValue.
Table 7-41 metaSolvISROrderValue Definition
element |
MetaSolvISROrderValue |
complexType |
Extension of OrderValueISROrderHeaderType |
complexType |
complexType with a list of fields, contact, notes, locations, serviceValue, remarks, userData |
Contact |
element |
ISRContactType |
ISRContactType |
complexType |
notes |
element |
ISRNoteValueType |
ISRNoteValueType |
complexType |
locations |
element |
ISRLocation |
ISRLocation |
complexType |
locationValueA, locationValueB |
locationValueA |
element |
ISRLocationValueType |
locationValueB |
element |
complexType |
MetaSolvLocationKey |
serviceValue |
element |
ISRServiceValueType |
complexType |
remarks |
element |
ISRRemarkType |
ISRRemarkType |
complexType |
userData |
element |
UserDataValueType |
UserDataValueType |
complexType |
Table 7-42 describes the required fields for MetaSolvServiceValue.
Table 7-42 Required Fields for MetaSolvServiceValue
externalServiceKey |
string |
External service key value from the external system. |
activityCd |
Enum |
Valid values of ActivityCodeEnumType. Activity to be performed on this item. Pass the value based on the scenario. |
productGroup |
integer |
The name of the product grouping. This field should be zero if a value is not applicable. |
Table 7-43 describes the required fields for serviceKey and parentServiceKey.
Table 7-43 Required Fields for serviceKey and parentServiceKey
servicePrimaryKey |
string |
Field is required only for change orders and is populated using service item ID. For new orders, this value is 0. |
Table 7-44 describes the required fields for parentSpecKey and describingSpecificationKey.
Table 7-44 Required Fields for parentSpecKey and describingSpecificationKey
serviceSpecificationPrimaryKey |
string |
Field is populated using the product catalog ID which is added under the service structure. |
Table 7-45 describes the required fields for serviceLocationKey.
Table 7-45 Required Fields for serviceLocationKey
locationPrimaryKey |
string |
Value of the location ID where the product is assigned. This is populated for products which are under Service Location and is 0 for Global products. |
Table 7-46 describes the required fields for ipNumberInventoryKey and addressKey.
Table 7-46 Required Fields for ipNumberInventoryKey and addressKey
resourcePrimaryKey |
string |
Value of the address ID where the product is assigned. This is populated for products which are under Service Location and is 0 for Global products. |
Table 7-47 describes the required values for serviceItemValues.
Table 7-47 Required Values for serviceItemValues
label |
string |
Name or purpose of additional information that you want to capture for a service item. |
Value |
string |
Specific value for a given value label. Values can be lists of predefined choices, or text-entry fields. |
valueCd |
string |
Code used to identify a value, such as a shortened version of the value's “name" or a number. |
activityCd |
Enum |
assignedTelephoneNr
Table 7-48 defines assignedTelephoneNr information.
This tag applies for PSR orders which has products that require Telephone Numbers to be assigned.
Table 7-48 assignedTelephoneNr Definition
assignedTelNr |
element |
AssignedTelNrType |
AssignedTelNrType |
complexType |
Set of simple data types:
CnamType |
element |
psrCnam |
psrCnam |
element |
PsrCnamType |
PsrCnamType |
complexType |
LidbType |
element |
psrLidbType |
psrLidbType |
element |
PsrLidbType |
PsrLidbType |
complexType |
StructureFormatType |
complexType |
structureFormatComponents |
CustomerManagementData.xsd |
element |
StructureFormatComponentType |
complexType |
assignedTelNrRel |
element |
AssignedTelNrRelType |
complexType |
AssignedTelNrType |
complexType |
MetaSolvServiceKey |
element |
complexType |
servicePrimaryKey |
Table 7-49 describes the required fields for MetaSolvServiceKey.
Table 7-49 Required Fields for MetaSolvServiceKey
servicePrimaryKey |
string |
Field is required only for change orders and is populated using service item ID and for new orders, this is 0. |
Table 7-50 describes the required fields for assignedTelephoneNr.
Table 7-50 Required Fields for assignedTelephoneNr
relationshipType |
Enum |
Relationship between two telephone numbers. Valid values are rtRCF, rtPorted, rtPortedTo, rtTollfree and rtNone. |
Table 7-51 describes the required fields for AssignedTelNrType.
Table 7-51 Required Fields for AssignedTelNrType
telNrSuf |
string |
System tracks a number's history by assigning a suffix counter to each number. Each time the number is recalled into an Unassigned status, the counter increases by one. |
respOrg |
string |
Organization that owns the NPA NXX. |
telNrTypeCd |
Enum |
Telephone number type code and valid values are Valid values are tntINPOUT, tntRESALE, tntNPIN, tntTFWTN, tntTF, tntFORWTN, tntNPOUT, tntWTN, tntNone. |
activityCd |
Enum |
identityCd |
Enum |
Identify whether the telephone number as main telephone number or alternate. Valid values are: MPTN, ALT and NONE. |
locationId |
Long |
The location ID of the telephone number and if not mapped, it should be 0. |
btnInd |
Boolean |
Default is false and should be changed to true if the TN needs to set as billing telephone number. |
Table 7-52 describes the required fields for PsrCnamType.
Table 7-52 Required Fields for PsrCnamType
callingName |
string |
The name of the business or residential customer, as desired for the caller ID display. |
presentationInd |
Enum |
Valid values of PresentationIndEnumType. Indicates that caller ID name information is sent for calls made from this number. |
activityCode |
Enum |
Valid values of ActivityCodeEnumType. Activity to be performed on this item. |
manualIndicator |
Enum |
Valid values of IndicatorEnumType. Indicates that you do not want to send the CNAM information electronically to the gateway vendor. If you do not send the information electronically, you must send it manually. |
effectiveDateChg |
CbeDateTime |
Indicates a future date for any change to be effective, if it is not effective immediately. |
Table 7-53 describes the required fields for PsrLidbType.
Table 7-53 Required Fields for PsrLidbType
bnsCode |
Enum |
Valid values of BNSCodeEnumType. The Billed Number Screening Code is a code to indicate the type of screening, if any, applied to this number. |
marketInd |
Enum |
Valid values of MarketIndicatorEnumType. Indicates the type of market this number is assigned to. |
serviceClassCode |
Enum |
Valid values of ClassCodeEnumType. A code that describes how a service is used by a business, residential, or pay phone customer. Examples include business, residential, public coin, public non-coin, and semi-public coin. |
manualIndicator |
Enum |
Valid values of IndicatorEnumType. Indicates that you do not want to send the LIDB information electronically to the gateway vendor. If you do not send the information electronically, you must send it manually. |
activityCd |
Enum |
effectiveDateChg |
CbeDateTime |
Table 7-54 describes the required fields for StructureFormatType.
Table 7-54 Required Fields for StructureFormatType
sfType |
string |
Category that describes a structure. |
name |
string |
Name of a specific customizing of a structured format type. |
Table 7-55 describes the required fields for StructureFormatComponentType.
Table 7-55 Required Fields for StructureFormatComponentType
Id |
int |
ID of a component of a structured format. |
name |
string |
Name of a component of a structured format. |
componentType |
string |
Type of component, such as table-driven drop-down or valid value drop-down. |
Value |
string |
Name of a value for a component. |
Table 7-56 describes Access.
Table 7-56 Access Definition
Access |
element |
AccessType |
AccessType |
complexType |
AccessInformationType |
complexType |
Table 7-57 describes the required fields for AccessInformationType.
Table 7-57 Required Fields for AccessInformationType
Floor |
string |
The floor where the product is installed. |
Room |
string |
The room where the product is installed. |
jackCd |
string |
A standard code for the registered or non-registered jack used to terminate service at the service location. |
jackNr |
string |
If the jack is existing, the number associated with the jack. |
jackPosition |
integer |
The position of the circuit within the jack. |
jackStatus |
string |
Indicates whether the jack used to terminate service is new or existing. |
accessInfo |
string |
Special instructions regarding access to the service location and times that access is available. |
additionalLocationDetails |
string |
Specific details not included in the Additional Information field. |
locationIdSpot |
integer |
The CLLI code for the physical point of termination at the end user location. |
activityCd |
Enum |
Table 7-58 describes isdnTrunkGroup.
Table 7-58 isdnTrunkGroup Definition
isdnTrunkGroup |
element |
IsdnTrunkGroupType |
complexType |
isdnTrunkGroupInformation |
complexType |
IsdnTrunkGroupInformationType |
complexType |
Table 7-59 describes the required fields for IsdnTrunkGroupInformationType.
Table 7-59 Required Fields for IsdnTrunkGroupInformationType
bchanFunctionCd |
Enum |
Valid values of BchanFuncEnumType. Identifies the purpose of the bearer channels. |
nfasBkupDchanInd |
Enum |
Valid values of IndicatorWNAEnumType. Indicates if a backup D-Channel is used on a subsequent DS1 in a multiple DS1 trunk group. |
premierCallInd |
Enum |
Valid values of IndicatorEnumType. Identifies whether the premier calling features are available. |
nfasInd |
Enum |
Valid values of IndicatorEnumType. Indicates whether the DS1 circuits in the ISDN trunk group shares the same D channel for signaling. When NFAS is not used, each DS1 uses its own D channel. |
dialableGroup |
Enum |
Valid values of DialableGroupEnumType. The grouping method for the DS0 time slot (channel). |
dialableSearch |
Enum |
Valid values of DialableSrchEnumType. |
Table 7-60 defines trunkGroup.
Table 7-60 trunkGroup Definition
trunkGroup |
element |
TrunkGroupType |
TrunkGroupType |
complexType |
complexType |
complexType |
intoCO |
element |
IntoCOType |
outFromCO |
element |
OutFromCOType |
Table 7-61 describes the required fields TrunkGroupInformationType.
Table 7-61 Required Fields for TrunkGroupInformationType
coDirection |
string |
Describes the direction of the signals traveling along this trunk. |
interfaceType |
string |
Indicates whether the interface for the trunk group is digital or analog. |
glareAction |
string |
Indicates who has control of the trunks when both ends are seized at the same time for different uses or by different users. |
ncCd |
string |
Network Channel code - A code that identifies the type of service provided by the trunk. |
ncCdOption |
string |
Two optional characters further identify the performance specifications and transmission options of the trunk. |
nciCd |
string |
Network Channel Interface code - A code that identifies the electrical conditions of the trunk at the customer location. |
twoSixCd |
string |
A code that identifies the trunk group. The code consists of a two-character company code, followed by the six-digit serial number of the trunk. |
framing |
string |
The type of frame pattern used for DS1 service. |
lineCoding |
string |
The type of pulse code modulation (PCM) pattern used for DS1 service. |
trunkSegment |
string |
Suffix added to a trunk to make it unique. This suffix is created by a local telephone trunk service. |
selectionSequence |
string |
The method of selecting idle trunks in a trunk group during call processing. This field is required for all types of special trunk groups. |
Table 7-62 describes the required fields for IntoCOType.
Table 7-62 Required Fields for IntoCOType
digitsQty |
integer |
The number of digits that are to be received by the central office switch from the customer for a Direct Outward-Dial (DOD) trunk. |
maxDigit |
string |
The maximum number of digits that can be sent from a PBX, terminal equipment, or similar device to the central office switch. |
minDigit |
string |
The minimum number of digits that can be sent from a PBX, terminal equipment, or similar device to the central office switch. |
pulseType |
string |
The pulsing method used to send digits from a customer to a central office switch. |
startSignal |
string |
The timing or method used to start signaling from the customer to the central office switch. |
supervisionSignal |
string |
The type of signaling sent from a PBX, terminal equipment, or similar device to a central office switch. |
Table 7-63 describes the required fields for OutFromCOType.
Table 7-63 Required Fields for OutFromCOType
digitsQty |
integer |
The number of digits sent from the central office switch to the customer for a Direct In-Dial (DID) trunk. |
maxDigit |
string |
The actual digits that are inserted before the Digits Outpulsed and sent from the central office switch to the PBX, terminal equipment, or similar device. |
minDigit |
string |
The quantity of digits that are extracted from the Digits Outpulsed before they are sent from the central office switch to the PBX, terminal equipment, or similar device. |
pulseType |
string |
The pulsing method used to send digits from a central office switch to a customer. |
startSignal |
string |
supervisionSignal |
string |
Table 7-64 defines Circuit.
Table 7-64 Circuit Definition
circuit |
element |
CircuitType |
CircuitType |
complexType |
circuitInformation |
complexType |
CircuitInformationType |
complexType |
Table 7-65 describes the required fields for CircuitInformationType.
Table 7-65 Required Fields for CircuitInformationType
rateCd |
string |
Identifies the transmission rate of the requested circuit (measured in bits per second). |
aPot |
string |
The CLLI associated with the additional termination point of the circuit, if applicable. |
framing |
string |
framingAnsiInd |
Enum |
Valid values of IndicatorWNAEnumType. Only applicable if framing is used. |
lineCoding |
string |
ownedLeasedCd |
Enum |
Valid values of CktServiceTypeEnumType. Description of the service provided, broken down into Special Services (for IntraLATA/Boundary and LATA/Boundary Access), Switched Services, and Facility Services. |
serviceTypeExt |
string |
Service a circuit provides. The extension further defines a service type code. |
serviceTypeCd |
string |
Service type code. |
ncCd |
string |
Identifies performance and other technical specifications for the circuit. |
ncCdOption |
string |
Jurisdiction |
string |
Jurisdiction classification, which categorizes the circuit (for its originating/terminating end) for toll separation purposes. |
Table 7-66 defines circuitLocation.
Table 7-66 circuitLocation Definition
| Name | Defined As | Field Description | File Name |
circuitLocation |
element |
CircuitLocationType |
complexType |
circuitLocationInformation |
complexType |
CircuitLocationInformationType |
complexType |
primaryLocation |
element |
LocationType |
secondaryLocation |
element |
LocationType |
LocationType |
complexType |
CodedLocationType, EndUserLocationType |
CodedLocationType |
complexType |
locationKey |
locationKey |
element |
complexType |
jackInformation |
element |
JackInformationType |
complexType |
Table 7-67 describes the required fields for CodedLocationType.
Table 7-67 Required Fields for CodedLocationType
serviceLocationRef |
integer |
Relates to the Service Location field that appears for End User locations. |
clliCd |
string |
Only applicable for network locations. The network location for the circuit connection. This field is only applicable to network locations and is only required when the CodedLocationType is populated. |
nciCd |
string |
Network Channel Interface code that identifies the interface specifications associated with a circuit. |
cfa |
string |
Connecting Facility Assignment field. If applicable, the circuit on another provider's network where the ordered circuit is connected and the channel that it is assigned. |
activityCd |
Enum |
supervisionSignal |
string |
Type of signaling sent from a PBX, terminal equipment, or similar device to a central office switch. |
Table 7-68 describes the required fields for EndUserLocationType.
Table 7-68 Required Fields for EndUserLocationType
integer |
endUserClli |
Enum |
Valid values of MomLocationTypeEnumType. The network location for the circuit connection. |
nciCd |
string |
cfa |
string |
backboardSpace |
Enum |
Valid values of IndicatorWNAEnumType. This field is only required if the parent tag is populated. This field is applicable for private line (including LAN) connections. Indicates whether backboard space for equipment installation is available, not available, or not applicable at this location. |
offNetType |
Enum |
Valid values of NniUniCDEnumType. This field is only required if the parent tag is populated. This field is applicable for frame relay orders when the On Net Location box is not checked. |
equipSpace |
Enum |
Valid values of IndicatorWNAEnumType. Indicates whether equipment space is available, not available, or not applicable at this location. |
seperatlyFused |
Enum |
Valid values of IndicatorEnumType. Indicates whether the power available to this location is separately fused. |
buildingGround |
Enum |
Valid values of IndicatorEnumType. Indicates whether a building ground is available at this location. |
powerAvail |
Enum |
Valid values of IndicatorEnumType. Indicates whether power is available at this location. |
localLoop |
Enum |
Valid values of IndicatorEnumType. Indicates whether you need to order a local loop connection to this location. |
Muxing |
Enum |
Valid values of IndicatorEnumType. Indicates whether the customer requests multiplexing (muxing). |
onNetLoc |
Enum |
Valid values of IndicatorEnumType. Indicates whether your company currently serves this location. |
powerType |
Enum |
Valid values of PowerTypeEnumType. A description of the type of power available at this location. |
activityCd |
Enum |
Table 7-69 describes the required fields for JackInformationType.
Table 7-69 Required Fields for JackInformationType
jackCd |
string |
Standard code for the registered or non-registered jack used to terminate service at the service location. |
jackPosition |
integer |
Position of the circuit within the jack. |
jackNr |
string |
jackStatus |
Enum |
Valid values of JackStatusEnumType. Indicates whether the jack used to terminate service is new or existing. |
activityCd |
Enum |
Table 7-70 defines Connector.
Table 7-70 Connector Definition
connector |
element |
ConnectorType |
ConnectorType |
complexType |
connectorInformation |
complexType |
ConnectorInformationType |
complexType |
serviceLocationKeyA |
element |
serviceLocationKeyB |
element |
Table 7-71 describes the required fields for ConnectorInformationType.
Table 7-71 Required Fields for ConnectorInformationType
compTypeConId |
integer |
Type of connection on an order. |
rateCd |
string |
Framing |
string |
Type of frame pattern used for DS1 service. |
lineCoding |
string |
Type of pulse code modulation (PCM) pattern used for DS1 service. |
Jurisdiction |
string |
serviceLocationRefA |
integer |
Primary location for the circuit termination for A. |
addressKeyA |
integer |
Address key A value. |
serviceLocationRefB |
integer |
Primary location for the circuit termination for B. |
addressKeyB |
integer |
Address key B value. |
Table 7-72 defines caUsageInstance.
Table 7-72 caUsageInstance Definition
caUsageInstance |
element |
CaUsageInstanceType |
complexType |
caUsageValue |
caUsageValue |
element |
CaUsageValueType |
CaUsageValueType |
complexType |
Table 7-73 describes the required fields for CaUsageInstanceType.
Table 7-73 Required Fields for CaUsageInstanceType
caUsageKey |
integer |
Unique ID of custom attribute. |
caValueLabel |
string |
Label of custom attribute. |
Table 7-74 describes the required fields for CaUsageValueType.
Table 7-74 Required Fields for CaUsageValueType
caValueKey |
integer |
Key of valid value custom attribute. |
caValue |
string |
Value of custom attribute. |
caUom |
string |
Unit of measure. For example, meters, yards, or feet. |
caUsageVvKey |
integer |
Table 7-75 defines picInfo.
Table 7-75 picInfo Definition
picInfo |
element |
PicInfoType |
PicInfoType |
complexType |
Table 7-76 describes the required fields for PicInfoType.
Table 7-76 Required Fields for PicInfoType
Pic |
string |
A Primary Interexchange (or IntraLata) Carrier code or Carrier identification code (CIC) that represents an end user's toll provider. |
picTypeCd |
string |
Toll calling area of a PIC, including intraLATA/Boundary, interLATA/Boundary, and international. |
freezePic |
Enum |
Valid values of IndicatorType. Indicates the customer requested the freeze option on the PIC. The end user is specifying that the PIC can only be changed when authorized by the end user. |
partyName |
string |
Name for the given primary interexchange code. This field is information only not used in business logic for create or update transactions. |
activityCd |
Enum |
Table 7-77 defines orderItemPrice.
Table 7-77 orderItemPrice Definition
orderItemPrice |
element |
PSROrderItemPriceType |
complexType |
psrOrderItemPrice |
psrOrderItemPrice |
complexType |
MomPsrOrderItemPriceType |
complexType |
Table 7-78 describes the required fields for MomPsrOrderItemPriceType.
Table 7-78 Required Fields for MomPsrOrderItemPriceType
priceID |
integer |
ID for the price. |
basePriceSeq |
string |
Base price sequence. |
priceVarSeq |
string |
Price variation sequence. |
priceOverride |
Float |
Indicator on whether to override the price. |
activityCD |
Enum |
Table 7-79 defines EmailInfo.
Table 7-79 EmailInfo Definition
EmailInfo |
element |
EmailInfoType |
EmailInfoType |
complexType |
internetEmailInformation |
complexType |
InternetEmailInformationType |
complexType |
Table 7-80 describes the required fields for InternetEmailInformationType.
Table 7-80 Required Fields for InternetEmailInformationType
emailName |
string |
Email that is used by the customer. |
Domain |
string |
Domain name. |
domainSuffix |
string |
Suffix for the domain name. |
Table 7-81 defines DialupInfo.
Table 7-81 DialupInfo Definition
DialupInfo |
element |
DialupInfoType |
DialupInfoType |
complexType |
internetDialupInformation |
complexType |
InternetDialupInformationType |
complexType |
Table 7-82 describes the required fields for InternetDialupInformationType.
Table 7-82 Required Fields for InternetDialupInformationType
url |
string |
URL for the dial up. |
Domain |
string |
Domain name. |
domainSuffix |
string |
userId |
string |
User ID for the dial up. |
accessTnNbrInvId |
integer |
Associated Number inventory ID. |
Table 7-83 defines TemplateInfo.
Table 7-83 TemplateInfo Definition
TemplateInfo |
element |
TemplateInfoType |
TemplateInfoType |
complexType |
templateInformation |
complexType |
TemplateInformationType |
complexType |
Table 7-84 describes the required fields for TemplateInformationType.
Table 7-84 Required Fields for TemplateInformationType
| Field Name | Data Type | Field Decription |
configTypeId |
integer |
Config type ID. |
shortName |
string |
Short name that is going to be defined for the template product. |
longName |
string |
Long name that is going to be defined for the template product. |
providerId |
string |
Provider ID of the template. |
customerId |
string |
Customer ID that is assigned to this template. |
Table 7-85 defines ElementInfo.
Table 7-85 ElementInfo Definition
ElementInfo |
element |
ElementInfoType |
ElementInfoType |
complexType |
elementInformation |
complexType |
ElementInformationType |
complexType |
Table 7-86 describes the required fields for ElementInformationType.
Table 7-86 Required Fields for ElementInformationType
configTypeId |
integer |
Config type ID. |
elementType |
string |
Type of element that is used. |
elementNbr |
integer |
Element number. |
elementNm |
string |
Element name that is used. |
networkElementId |
string |
Network element ID that is assigned. |
locationId |
string |
Location ID that is assigned. |
addressId |
string |
Address ID that is assigned. |
Table 7-87 defines EquipmentInfo.
Table 7-87 EquipmentInfo Definition
EquipmentInfo |
element |
EquipmentInfoType |
EquipmentInfoType |
complexType |
equipmentInformation |
complexType |
EquipmentInformationType |
complexType |
Table 7-88 describes the required fields for EquipmentInformationType.
Table 7-88 Required Fields for EquipmentInformationType
equipmentSpecId |
integer |
Equipment specification ID that is assigned to this order. |
equipmentId |
integer |
Equipment id that is assigned to this order. |
Table 7-89 defines PSRDirServ.
Table 7-89 PSRDirServ Definition
PSRDirServ |
element |
PSRDirServType |
PSRDirServType |
complexType |
directoryServiceRequest |
complexType |
directoryServiceType |
complexType |
BANUsageOne |
element |
PSRBillingAccountNumberUsageType |
BANUsageTwo |
element |
complexType |
ACNAInfo |
element |
PSRDirServReqACNAType |
complexType |
Table 7-90 describes the required fields for directoryServiceType.
Table 7-90 Required Fields for directoryServiceType
serviceCenter1 |
string |
Service center 1 details. |
serviceCenter2 |
string |
Service center 2 details. |
accountNumber |
string |
Identifies the main account number assigned by the NSP. |
accountTelNbr |
string |
Identifies the account telephone number assigned by the NSP. |
TOSTYPE |
Enum |
Valid values of TypeOfServiceEnumType. Type of Service identifies the type of service or the line ordered. Byte 1 of 4-byte field. |
TOSPROD |
Enum |
Valid values of TypeOfServiceProdEnumType. Type of Service identifies the type of service for the line ordered. Byte 2 of 4-byte field. |
TOSCLASS |
Enum |
Valid values of TypeOfServiceClassEnumType. Type of Service identifies the type of service or the line ordered. Byte 3 of 4-byte field. |
TOSCHAR |
Enum |
Valid values of TypeOfServiceClassEnumType. Type of Service identifies the type of service or the line ordered. Byte 4 of 4-byte field. |
Table 7-91 describes the required fields for PSRBillingAccountNumberUsageType.
Table 7-91 Required Fields for PSRBillingAccountNumberUsageType
billingAcctNbr |
string |
Identifies the billing account number for the recurring and non-recurring charges for this request. |
banSvcCat |
Enum |
Valid values of BanServiceTypeEnumType. Identifies the type of billing account number. |
Table 7-92 describes the required fields for PSRDirServReqACNAType.
Table 7-92 Required Fields for PSRDirServReqACNAType
Acna |
string |
ACNA value. |
partyPrimaryName |
string |
Primary name of the party. |
partySecondaryName |
string |
Secondary name of the party. |
Table 7-93 defines PSRDirListing.
Table 7-93 PSRDirListing Definition
PSRDirListing |
element |
PSRDirListingType |
PSRDirListingType |
complexType |
directoryListing |
directoryListing |
complexType |
directoryListingType |
complexType |
Address |
element |
PSRDirectoryListingAddress |
complexType |
telNbr |
element |
PSRDirectoryListingTelephoneNumber |
complexType |
delivery |
element |
PSRDirectoryListingDeliveryLocation |
complexType |
Contains a list of fields PSRDirectoryListingDirectoryTypeSegments |
addlInfo |
element |
PSRDirectoryListingAdditionalInformation |
complexType |
Text |
element |
PSRDirectoryListingLinesOfText |
complexType |
complexType |
Table 7-94 describes the required fields for directoryListingType
Table 7-94 Required Fields for directoryListingType
ALICd |
string |
Uniquely identifies each listing for an account number. |
listingType |
Enum |
Valid values of listingType. For DSR, identifies the type of listing being submitted for the publication and directory assistance (DA) appearance rules. |
listAcctType |
Enum |
Valid values of TypeOfAccountEnum. Identifies the type of account for this listing and determines the placement of the listing in split directories and directory assistance. |
styleCd |
Enum |
Valid values of StyleCodeEnum. Identifies if the listing is a straight line, caption header. |
Yphdgcd |
string |
Identifies the heading under which a business listing should appear in the Yellow Pages Directory. |
Yphdgverbiage |
string |
Identifies the heading under which a business listing should appear in the Yellow Pages. |
placeListingAs |
string |
When a customer wishes to override the normal sequencing, the special filing words that are used rather than using the listed name. |
dirName |
string |
Identifies the name of the directory in which the listing is to be placed. |
listedNmAddrAddl |
string |
This is a twelve-character alphaNumeric field. |
listedNmLineageDual |
Enum |
Valid values of LineageNameEnum. |
listedNmAddrDual |
Enum |
Valid values of AddressNameEnum. |
Table 7-95 describes the required fields for PSRDirectoryListingAddress.
Table 7-95 Required Fields for PSRDirectoryListingAddress
listedNmLineage |
Enum |
listedNmLast |
string |
Last name for the listing. |
listedNmFirst |
string |
First name for the listing. |
houseNbrPref |
string |
Identifies the prefix for the house number. |
houseNbr |
string |
The number of the street address, not including extensions such as 1/2, A, D. |
streetNm |
string |
Name of the road of the address. |
City |
string |
Community of the street name/house number as designated by the Master Street Address Guide, MSAG. |
stateCd |
string |
A two-character abbreviation for the State associated with the address. |
zipCode |
string |
Zip code of the address. |
omitAddr |
Enum |
Valid values of CheckBoxOptionEnum. |
omitTelNbr |
Enum |
Table 7-96 describes the required fields for PSRDirectoryListingTelephoneNumber.
Table 7-96 Required Fields for PSRDirectoryListingTelephoneNumber
Listingtelnbr |
string |
Indicates the telephone number to be placed in the directory and quoted in Directory Assistance (DA) as appropriate based on LTY, RTY, and STYC field entries. |
mainTelNbr |
string |
Field identifies the main telephone number used to link the main listing with any other associated listings. |
Telnbrnpa |
string |
Area code (NPA) portion of the telephone number. The first three digits of a ten-digit phone number. |
Telnbrnxx |
string |
Central Office, or Exchange, portion of the phone number. The first three digits of a seven-digit telephone number, and the fourth through sixth digits of a ten-digit phone number. |
Telnbrlinerange |
string |
Line number of the telephone. This is the last four digits a ten-digit telephone number, and the last four digits of a seven-digit number. |
Telnbrsuf |
string |
Suffix or PIN used to differentiate between two otherwise identical telephone numbers. |
Table 7-97 describes the required fields for PSRDirectoryListingDeliveryLocation.
Table 7-97 Required Fields for PSRDirectoryListingDeliveryLocation
dirDirectoryDeliveryId |
integer |
Oracle sequence uniquely identifies the delivery location information. |
delRefNbr |
string |
Identifies the delivery address/information segment and each additional delivery address/information segment with a unique number. |
delAddressType |
Enum |
Valid values of deliveryAddTypeEnum. Identifies a delivery address segment as being valid for hand delivery, postal delivery or both. (Represents the DATY field on the DL Form.). |
endUserName |
string |
Recipient name for the delivery address. |
houseNbrPref |
string |
houseNbr |
string |
Number of the street address, not including extensions such as 1/2, A, D. |
streetnm |
string |
City |
string |
stateCd |
string |
Two-character abbreviation for the State associated with the address. |
zipCd |
string |
Table 7-98 describes the required fields for PSRDirectoryListingAdditionalInformation.
Table 7-98 Required Fields for PSRDirectoryListingAdditionalInformation
ttyttdCd |
Enum |
Valid values of TTYTDDEnum. Identifies that this listing should include a special TTY or TDD phrase and which phrase should be included. |
localNpaNxx |
string |
The telephone number being listed is not local to the service address and this column indicates the provider's local NPA NXX. Examples of when this might be used include foreign exchange numbers and ported numbers. |
noSoliciationCd |
Enum |
listedNmPlacement |
Enum |
omitStAddr |
Enum |
Valid values of CheckBoxOptionEnum. Identifies if this listing is to be omitted from the street address (reverse) directory. |
omitDirectMail |
Enum |
Valid values of CheckBoxOptionEnum. Indicates whether this listing is to be omitted from any direct mail lists. |
omitTeleMktg |
Enum |
Valid values of CheckBoxOptionEnum. Indicates that this listing is to be omitted from any telemarketing lists. |
placementOverrideCd |
Enum |
Valid values of OverrideCodeEnum. Identifies an override of the normal placement of business or residence listings. |
profList |
Enum |
Valid values of CheckBoxOptionEnum. Indicates that this is a professional listing. |
doNotAbbrev |
Enum |
Valid values of doNotAbbrevEnum. Identifies that data in specific fields must not be abbreviated. |
existingAdvert |
Enum |
Valid values of ExistingAdvertisingEnum. Identifies the end user's directory advertising status. |
Table 7-99 describes the required fields for PSRDirectoryListingDirectoryTypeSegments.
Table 7-99 Required Fields for PSRDirectoryListingDirectoryTypeSegments
dirTypeCd |
Enum |
Valid values of DirectoryTypeEnum. Identifies the type of directory to be delivered. |
dirAnnualQty |
integer |
Identifies the number of directories to be delivered on an annual basis. |
dirNCQty |
integer |
Identifies the number of directories to be delivered at the time of new connection. |
dirDelCd |
integer |
Identifies the directory code of the book to be delivered. |
dirName |
string |
Table 7-100 defines AuthCDUsage.
Table 7-100 AuthCDUsage Definition
AuthCDUsage |
element |
AuthCDUsageType |
AuthCDUsageType |
complexType |
authCodeUsage |
authCodeUsage |
complexType |
AuthCodeUsageType |
AuthCodeUsageType |
complexType |
Table 7-101 describes the required fields for AuthCodeUsageType.
Table 7-101 Required Fields for AuthCodeUsageType
authTypeCD |
string |
User recognizable code for the auth type being defined. |
authCD |
string |
Actual code assigned to the service item. |
Translation |
string |
For a verified auth code, you must enter a verbal translation which is the response to the telephone user after the user enters the verified auth code correctly. |
authCDName |
string |
Describes who is using an auth code. This name can be used on the bill format. |
fromEffectiveDateTime |
CbeDateTime |
The date the entity became effective. |
toEffectiveDateTime |
CbeDateTime |
Date product became inactive. This field must be non-null. It may have a zero date value. |
activityCD |
Enum |
Valid values of ActivityCodeEnumType. An enumerated type describing the activity for this item. Set this type to indicate how the operation processes this structure. |
Table 7-102 defines huntGroup.
Table 7-102 huntGroup Definition
huntGroup |
element |
HuntGroupType |
HuntGroupType |
complexType |
huntGroupToFrom |
huntGroupToFrom |
element |
HuntToFromType |
HuntToFromType |
complexType |
huntToServItemKey, huntFromServItemKey |
huntToServItemKey |
element |
element |
Table 7-103 describes the required fields for HuntGroupType.
Table 7-103 Required Fields for HuntGroupType
huntKey |
integer |
Unique Key that identifies a hunt group in the database. |
huntType |
string |
Hunt Type of hunting requested. |
huntName |
string |
Hunt Group Name |
huntNumber |
string |
Number of members in the hunt group. |
activityCd |
Enum |
Table 7-104 describes the required fields for HuntToFromType.
Table 7-104 Required Fields for HuntToFromType
activityCd |
Enum |
Table 7-105 defines lineDirectoryType.
Table 7-105 lineDirectoryType Definition
lineDirectoryType |
complexType |
Address |
element |
complexType |
telNbr |
element |
complexType |
delivery |
element |
complexType |
addlInfo |
element |
complexType |
Text |
element |
complexType |
complexType |
Table 7-106 describes the required fields for lineDirectoryType.
Table 7-106 Required Fields for lineDirectoryType
rcdType |
Enum |
Valid values of RecordTypeEnum |
rcdTypeArea |
Enum |
Valid values of RecordTypeAreaEnum |
referenceNumber |
string |
A number that uniquely identifies a delivery location. |
listingType |
Enum |
Valid values of ListingTypeEnum. For DSR, identifies the type of listing being submitted for the publication and directory assistance (DA) appearance rules. |
styleCd |
Enum |
listAcctType |
Enum |
degreeofIdent |
Long |
Identifies the degree of indention for this listing. |
Enum |
Valid values of LineageNameEnum |
listedNmAddrDual |
Enum |
Valid values of AddressNameEnum |
ALICd |
string |
Uniquely identifies each listing for an account number |
Yphdgcd |
string |
Yphdgverbiage |
string |
sicCode |
string |
Industry code to identify yellow page heading. |
The createOrderRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-107 describes the returned information in the response.
Table 7-107 Payload Information for the Response
createOrderRequestResponse |
element |
OrderAPI.wsdl |
element |
mommekey |
mommekey |
element |
complexType |
metaSolvOrderKey |
createPSROrderRequest Operation
This operation creates a new PSR order in the system and returns the key for the new order created. A single OrderValue is the only value passed into the request. The state values in OrderValue are ignored; the state is initialized to STARTED by the system.
The following are the request and response structures:
Request Structure: createPSROrderRequest
Response Structure: createPSROrderRequestResponse
The createPSROrderRequest element contains the input information for the operation. Each row in Table 7-108 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-108 Payload Information for the Request
| Name | Defined As | Type Description | File Name |
createPSROrderRequest |
element |
OrderAPI.wsdl |
element |
Mommevalue |
OrderManagementAPI.xsd |
Mommevalue |
element |
complexType |
Contains a choice of types:
OrderManagementEntities.xsd |
complexType |
The createPSROrderRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-109 describes the returned information in the response.
Table 7-109 Payload Information for the Response
createPSROrderRequestResponse |
element |
OrderAPI.wsdl |
element |
mommekey |
mommekey |
element |
complexType |
metaSolvOrderKey |
metaSolvOrderKey |
element |
OrderKey |
OrderKey |
complexType |
Table 7-110 describes the error messages for the operation.
Table 7-110 Error Messages for the Operation
Miscellaneous Error: Telephone Number already exists in inventory and has status of statusValue. |
The telephone number you specified already exists in the database. |
Provide a new telephone number. |
Telephone Number already exists in inventory with a different telephone number type. |
The telephone number type you specified does not match the type in the database or the telephone number already exists. |
Retrieve the type for the telephone number and provide the matching type or provide a new telephone number. |
Unable to copy item valueForItem to the order as the Service Item is on another open PSR Order. The Preference to Copy Pending PSR Items is set to No. |
You requested a copy of a service item that is on an open PSR. |
Remove the request to copy the item or change the preference for the Copy Pending PSR Items to Yes. |
getCnamData Operation
This operation retrieves the Calling Name (CNAM) records. This operation provides the extract sequence for updating the Calling Name information.
Request Structure: getCnamData
Response Structure: getCnamDataResponse
getCnamData
The getCnamData element contains the input information for the operation. Each row in Table 7-111 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-111 Payload Information for the Request
getCnamData |
element |
getCNAMDataRequest |
OrderAPI.wsdl |
getCnamDataResponse
The getCnamDataResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-112 describes the returned information in the response.
Table 7-112 Payload Information for the Response
| Name | Defined As | Type Descriptions | File Name |
getCnamDataResponse |
element |
momGetCNAMDataResponse |
OrderAPI.wsdl |
element |
CNAMDataValue |
CNAMDataValue |
element |
CNAMDataType |
CNAMDataType |
complexType |
CNAMRecords |
CNAMRecords |
element |
CNAMRecordType |
CNAMRecordType |
complexType |
OrderAncillaryManagementData.xsd |
getE911Data Operation
This operation retrieves the E911 records. This operation provides the extract sequence for updating the E911 information.
Request Structure: getE911Data
Response Structure: getE911DataResponse
getE911Data
The getE911Data element contains the input information for the operation. Each row in Table 7-113 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-113 Payload Information for the Request
getE911Data |
element |
getE911DataRequest |
OrderAPI.wsdl |
getE911DataResponse
The getE911DataResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-114 describes the returned information in the response.
Table 7-114 Payload Information for the Response
getE911DataResponse |
element |
momGetE911DataResponse |
OrderAPI.wsdl |
element |
e911DataValue |
e911DataValue |
element |
E911DataType |
E911DataType |
complexType |
e911Records |
e911Records |
element |
E911RecordType |
E911RecordType |
complexType |
getLidbData Operation
This operation retrieves the Line Database (LIDB) records. This operation provides the extract sequence used for updating the Line Database details.
Request Structure: getLidbData
Response Structure: getLidbDataResponse
getLidbData
The getLidbData element contains the input information for the operation. Each row in Table 7-115 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-115 Payload Information for the Request
getLidbData |
element |
getLIDBDataRequest |
OrderAPI.wsdl |
getLidbDataResponse
The getLidbDataResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-116 describes the returned information in the response.
Table 7-116 Payload Information for the Response
getLidbDataResponse |
element |
momGetLIDBDataResponse |
OrderAPI.wsdl |
element |
LIDBDataValue |
LIDBDataValue |
element |
LIDBDataType |
LIDBDataType |
complexType |
LIDBRecords |
LIDBRecords |
element |
LIDBRecordType |
LIDBRecordType |
complexType |
Contains a list of fields |
getOrderByKey Operation
This operation retrieves the order details given an input order number (document number of the order). The output consists of order header, user data, and services information.
Request Structure: getOrderByKey
Response Structure: getOrderByKeyResponse
getOrderByKey
The getOrderByKey element contains the input information for the operation. Each row in Table 7-117 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-117 Payload Information for the Request
getOrderByKey |
element |
momGetOrderByKeyRequest |
OrderAPI.wsdl |
element |
mommekey |
Mommekey |
element |
MetaSolvOrderKeyChoice |
complexType |
metaSolvOrderKey |
metaSolvOrderKey |
element |
OrderKey |
OrderKey |
complexType |
primaryKey |
Table 7-118 describes the required fields for getOrderByKey.
Table 7-118 Required Fields for getOrderByKey
| Field Name | Data Type | Field Description |
PrimaryKey |
string |
Document number of the order where the details are required. |
The getOrderByKeyResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-119 describes the returned information in the response.
Table 7-119 Payload Information for the Response
getOrderByKeyResponse |
element |
momGetOrderByKeyResponse |
OrderAPI.wsdl |
element |
Mommevalue |
mommevalue |
element |
complexType |
complexType |
complexType |
getPSROrderByTN Operation
This operation retrieves the PSR order details given the input telephone number and TN format. The output includes the order header, user data and service details.
Request Structure: getPSROrderByTN
getPSROrderByTN
The getPSROrderByTN element contains the input information for the operation. Each row in Table 7-120 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-120 Payload Information for the Request
getPSROrderByTN |
element |
getPSROrderByTNRequest |
OrderAPI.wsdl |
element |
GetPSROrderByTNRequestValue |
element |
GetPSROrderByTNRequestValueType |
complexType |
OrderManagementData.xsd |
Table 7-121 describes the required fields for getPSROrderByTN.
Table 7-121 Required Fields for getPSROrderByTN
TelephoneNbr |
string |
Element is used to pass the telephone number and the details are required. |
TelephoneNbrFormat |
string |
Element is used to specify the format of the telephone number. For example in case of US format i.e NPA-NXX-LINE the format is 'xxx-xxx-xxxx'. |
getPSROrderByTNResponse
The getPSROrderByTNResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-122 describes the returned information in the response.
Table 7-122 Payload Information for the Response
getPSROrderByTNResponse |
element |
momGetPSROrderByTNResponse |
OrderAPI.wsdl |
element |
mommevalue |
mommevalue |
element |
complexType |
complexType |
complexType |
processSuppOrderRequest Operation
This operation requests a supplement to the order. It takes in the supplement type, and order number. You have the option to reopen tasks and gateway events attached to the order.
Request Structure: processSuppOrderRequest
Response Structure: assignProvPlanRequestResponse
The processSuppOrderRequest element contains the input information for the operation. Each row in Table 7-123 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-123 Payload Information for the Request
processSuppOrderRequest |
element |
momProcessSuppOrderRequest |
OrderAPI.wsdl |
element |
ProcessSuppOrderRequestValueType |
complexType |
orderKey |
orderKey |
element |
OrderKey |
OrderKey |
complexType |
Table 7-124 describes the required fields for processSuppOrderRequest.
Table 7-124 Required Fields for processSuppOrderRequest
suppType |
Enum |
Valid values of SuppTypeEnumType. This field indicates the reason that the order is being supplemented, or changed. |
reopenTasksIndicator |
boolean |
Indicates whether the found tasks need to be re-opened for later processing. |
reopenGatewayEventsIndicator |
boolean |
Indicates whether the found Gateway Events need to re-opened for later processing. |
Table 7-125 describes the required fields for OrderKey.
Table 7-125 Required Fields for OrderKey
PrimaryKey |
string |
processSuppOrderRequestResponse
The processSuppOrderRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-126 describes the returned information in the response.
Table 7-126 Payload Information for the Response
processSuppOrderRequestResponse |
element |
processSuppOrderResponse |
OrderAPI.wsdl |
queryOrderManagementRequest Operation
This operation retrieves the order management information for:
validateOrderQueryValue
getTaskGWEventQueryValue
getServReqTasksQueryValue
getServiceRequestDLRsValue
getDLRInfosByOrderAndServiceItemIdValue
getDLRInfosByServiceItemIdInServiceValue
getServItemReferenceValue
getServItemsValue
Request Structure: queryOrderManagementRequest
Response Structure: queryOrderManagementRequestResponse
The queryOrderManagementRequest element contains the input information for the operation. Each row in Table 7-127 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-127 Payload Information for the Request
queryOrderManagementRequest |
element |
momQueryOrderManagementRequest |
OrderAPI.wsdl |
element |
queryValue |
queryValue |
element |
MetaSolvQueryValueChoice |
complexType |
Contains a choice of:
Table 7-128 defines getTaskGWEventQueryValue.
Table 7-128 getTaskGWEventQueryValue Definition
getTaskGWEventQueryValue |
complexType |
Extension of MomQueryValue Contains the following:
orderKey |
element |
OrderKey |
taskKey |
element |
TaskKey |
Table 7-129 describes the required fields for getTaskGWEventQueryValue.
Table 7-129 Required Fields for getTaskGWEventQueryValue
requestId |
short |
Request ID for get task gateway event query. |
Table 7-130 describes the required fields for orderKey.
Table 7-130 Required Fields for OrderKey
primaryKey |
string |
Document number of the order in the OrderKey type. |
Table 7-131 describes the required fields for TaskKey.
Table 7-131 Required Fields for TaskKey
taskPrimaryKey |
string |
Task number of the order. |
Table 7-132 defines getServReqTasksQueryValue.
Table 7-132 getServReqTasksQueryValue Definition
getServReqTasksQueryValue |
complexType |
Extension of MomQueryValue mommekey |
mommekey |
element |
mommekey |
Mommekey |
element |
element |
metaSolvOrderKey |
metaSolvOrderKey |
element |
OrderKey |
Table 7-133 describes the required fields for getServTasksQueryValue.
Table 7-133 Required Fields for getServReqTasksQueryValue
timeZone |
string |
Time zone. |
Table 7-134 defines getServiceRequestDLRsValue.
Table 7-134 getServiceRequestDLRsValue Definition
getServiceRequestDLRsValue |
element |
GetServiceRequestDLRsValue |
complexType |
Extension of MomQueryValue orderKey |
orderKey |
element |
OrderKey |
Table 7-135 defines getDLRInfosByOrderAndServiceItemIdValue.
Table 7-135 getDLRInfosByOrderAndServiceItemIdValue Definition
getDLRInfosByOrderAndServiceItemIdValue |
complexType |
orderKey |
element |
OrderKey |
Table 7-136 describes the required fields for getDLRInfosByOrderAndServiceItemIdValue.
Table 7-136 Required Fields for getDLRInfosByOrderAndServiceItemIdValue
serviceItemId |
long |
Service item ID of the product where the DLR information is retrieved. |
Table 7-137 defines getServItemReferenceValue.
Table 7-137 getServItemReferenceValue Definition
| Name | Defined As | Type Definition | File Name |
getServItemReferenceValue |
complexType |
orderKey |
element |
OrderKey |
Table 7-138 describes the required fields for getServItemReferenceValue.
Table 7-138 Required Fields for getServItemReferenceValue.
serviceItemId |
long |
The service item ID of the product where the DLR information is retrieved. |
Table 7-139 defines getProductCatalog.
Table 7-139 getProductCatalog Definition
getProductCatalog |
complexType |
productCatalogPolicy |
element |
criteria |
element |
CatalogExportCriteria |
complexType |
specificationKey |
element |
MetaSolvServiceSpecificationKey |
complexType |
Table 7-140 defines CatalogExportCriteria.
Table 7-140 CatalogExportCriteria Definition
complexType |
specificationKey |
element |
complexType |
Table 7-141 describes the required fields for productCatalogPolicy.
Table 7-141 Required Fields for productCatalogPolicy
customAttribute |
boolean |
Specifies whether the custom attribute should be included with the product catalog. |
Table 7-142 describes the required fields for CatalogExportCriteria.
Table 7-142 Required Fields for CatalogExportCriteria
exportInd |
boolean |
Indicates if you only want level one products. |
applicationUseCode |
string |
Application use code indicates which module uses the product catalog item created. If the application use code is Global the product catalog item is used by a PSR order. |
Table 7-143 describes the required fields for MetaSolvServiceSpecificationKey.
Table 7-143 Required Fields for MetaSolvServiceSpecificationKey
string |
Product specification ID of the product |
Table 7-144 defines getOrderStatus.
Table 7-144 getOrderStatus Definition
getOrderStatus |
complexType |
orderKey |
element |
OrderKey |
The queryOrderManagementRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-145 describes the returned information in the response.
Table 7-145 Payload Information for the Response
queryOrderManagementRequestResponse |
element |
queryOrderManagementResponse |
OrderAPI.wsdl |
element |
queryResponse |
queryResponse |
element |
MetaSolvQueryResponseChoice |
complexType |
Contains a choice of the following:
Table 7-146 defines getTaskGWEventQueryResponse.
Table 7-146 getTaskGWEventQueryResponse Definition
getTaskGWEventQueryResponse |
complexType |
gWEventTypes |
element |
MetaSolvGatewayEventValue |
element |
GatewayEventType |
GatewayEventType |
complexType |
OrderManagementEvents.xsd |
gatewayEventKey |
element |
GatewayEventKey |
taskKeyPredecessor |
element |
TaskKey |
Table 7-147 defines GetServReqTasksQueryResponse.
Table 7-147 GetServReqTasksQueryResponse Definition
GetServReqTasksQueryResponse |
complexType |
predFollows |
element |
PredFollowType |
PredFollowType |
complexType |
taskKey |
element |
TaskKey |
orderKey |
element |
OrderKey |
Table 7-148 defines getDLRInfosByOrderAndServiceItemIdResponse.
Table 7-148 getDLRInfosByOrderAndServiceItemIdResponse Definition
getDLRInfosByOrderAndServiceItemIdResponse |
complexType |
orderKey |
element |
OrderKey |
dlrInfos |
element |
DLRInfo |
DLRInfo |
complexType |
Table 7-149 defines getDLRInfosByServiceItemIdInServiceResponse.
Table 7-149 getDLRInfosByServiceItemIdInServiceResponse Definition
getDLRInfosByServiceItemIdInServiceResponse |
complexType |
orderKey |
element |
OrderKey |
dlrInfos |
element |
DLRInfo |
DLRInfo |
complexType |
Table 7-150 defines getServItemReferenceResponse.
Table 7-150 getServItemReferenceResponse Definition
getServItemReferenceResponse |
complexType |
orderKey |
element |
OrderKey |
serviceItemAlias |
string |
numberKey |
element |
MetaSolvResourceKey |
Table 7-151 defines getServItemsResponse.
Table 7-151 getServItemsResponse Definition
getServItemsResponse |
complexType |
element |
complexType |
serviceKey |
element |
parentSpecKey |
element |
describingSpecificationKey |
element |
parentServiceKey |
element |
serviceLocationKey |
element |
addressKey |
element |
ipNumberInventoryKey |
element |
serviceItemValues |
element |
ServiceItemValueType |
assignedTelephoneNr |
element |
AssignedTelephoneNrType |
Access |
element |
AccessType |
isdnTrunkGroup |
element |
trunkGroup |
element |
TrunkGroupType |
Circuit |
element |
CircuitType |
circuitLocation |
element |
Connector |
element |
ConnectorType |
caUsageInstance |
element |
picInfo |
element |
PicInfoType |
orderItemPrice |
element |
EmailInfo |
element |
EmailInfoType |
DialupInfo |
element |
DialupInfoType |
TemplateInfo |
element |
TemplateInfoType |
ElementInfo |
element |
ElementInfoType |
EquipmentInfo |
element |
EquipmentInfoType |
PSRDirServ |
element |
PSRDirServType |
PSRDirListing |
element |
PSRDirListingType |
AuthCDUsage |
element |
AuthCDUsageType |
huntGroup |
element |
HuntGroupType |
Table 7-152 defines getProductCatalogResponse.
Table 7-152 getProductCatalogResponse Definition
getProductCatalogResponse |
complexType |
productSpecification |
element |
pSRSpecItemType |
element |
pSRSpecItemType |
pSRSpecItemType |
complexType |
specificationKey |
element |
levelOneSpecKey |
element |
LevelOneSpecKey |
parentSpecId |
element |
parentSpecId |
Netarea |
element |
NetworkAreaType |
Prices |
element |
PSRSpecItemPriceType |
Labels |
element |
PSRDefaultValueType |
levelOne |
element |
LevelOneUnionType |
Standard |
element |
IndicatorEnumType |
Required |
element |
IndicatorEnumType |
global |
element |
IndicatorEnumType |
guideInd |
element |
IndicatorEnumType |
softProvInd |
element |
IndicatorEnumType |
CaUsages |
element |
CaUsageType |
partyRoles |
element |
PSRSpecItemPartyRoleType |
Table 7-153 defines getOrderStatusResponse.
Table 7-153 getOrderStatusResponse Definition
getOrderStatusResponse |
complexType |
orderStatus |
orderStatus |
element |
OrderStatusEnumType |
reopenTaskRequest Operation
This operation requests a task to be reopened. This is for a task that is already completed. This operation takes an input order number and task number.
Request Structure: reopenTaskRequest
Response Structure: reopenTaskRequestResponse
reopenTaskRequest
The reopenTaskRequest element contains the input information for the operation. Each row in Table 7-154 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-154 Payload Information for the Request
reopenTaskRequest |
element |
momReopenTaskRequest |
OrderAPI.wsdl |
element |
reopenTaskValue |
reopenTaskValue |
element |
ReopenTaskValueType |
complexType |
orderNumber |
element |
OrderKey |
taskNumber |
element |
TaskKey |
The reopenTaskRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-155 describes the returned information in the response.
Table 7-155 Payload Information for the Response
reopenTaskRequestResponse |
element |
reopenTaskResponse |
OrderAPI.wsdl |
element |
orderKey |
orderKey |
element |
OrderKey |
OrderKey |
complexType |
rejectTaskRequest Operation
This operation rejects a completed predecessor task. It takes an input order number, task number, new work queue id, and reject reason.
Request Structure: rejectTaskRequest
Response Structure: rejectTaskRequestResponse
rejectTaskRequest
The rejectTaskRequest element contains the input information for the operation. Each row in Table 7-156 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-156 Payload Information for the Request
rejectTaskRequest |
element |
momRejectTaskRequest |
OrderAPI.wsdl |
element |
rejectTaskValue |
rejectTaskValue |
element |
RejectTaskValueType |
complexType |
orderNumber |
element |
OrderKey |
taskNumber |
element |
TaskKey |
newWorkQueueId |
element |
string |
rejectReason |
element |
string |
The rejectTaskRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-157 describes the returned information in the response.
Table 7-157 Payload Information for the Response
rejectTaskRequestResponse |
element |
rejectTaskResponse |
OrderAPI.wsdl |
element |
orderKey |
orderKey |
element |
OrderKey |
OrderKey |
complexType |
startOrderRequest Operation
This operation validates the order along with a finish order option request. This operation takes an input document number (order number).
Request Structure: startOrderRequest
Response Structure: startOrderRequestResponse
startOrderRequest
The startOrderRequest element contains the input information for the operation. Each row in Table 7-158 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-158 Payload Information for the Request
startOrderRequest |
element |
startOrderByKeyRequest |
OrderAPI.wsdl |
element |
mommekey |
Mommekey |
element |
complexType |
metaSolvOrderKey |
metaSolvOrderKey |
element |
OrderKey |
OrderKey |
complexType |
The startOrderRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-159 describes the returned information in the response.
Table 7-159 Payload Information for the Response
startOrderRequestResponse |
element |
startOrderByKeyResponse |
OrderAPI.wsdl |
element |
mommekey |
mommekey |
element |
complexType |
metaSolvOrderKey |
metaSolvOrderKey |
element |
OrderKey |
OrderKey |
complexType |
Table 7-160 describes the error messages for the operation.
Table 7-160 Error Messages for the Operation
| Error Message | Cause | Resolution |
The Broadband Service Category is missing for this bandwidth circuit. Please add a Broadband Service Category value to this order. |
This order cannot be started until the Broadband Service Category is added. |
Add the Broadband Service Category to this circuit. |
Error: This service item has required labels with no values. Please add values. |
You have requested a start order but values are missing from a service item. |
Put in values for the required labels on the service items. |
TaskJeopardyRequest Operation
This operation adds task jeopardy information for the input task number.
Request Structure: TaskJeopardyRequest
Response Structure: TaskRequestResponse
TaskJeopardyRequest
The TaskJeopardyRequest element contains the input information for the operation. Each row in Table 7-161 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-161 Payload Information for the Request
TaskJeopardyRequest |
element |
getTaskJeopardyRequest |
OrderAPI.wsdl |
element |
GetTaskJeopardyRequestValue |
element |
GetTaskJeopardyRequestValueType |
element |
orderKey |
element |
OrderKey |
taskKey |
element |
TaskKey |
Table 7-162 describes the required fields for TaskJeopardyRequest.
Table 7-162 Required Fields for TaskJeopardyRequest
circuitId |
string |
Circuit ID assigned to the order. |
timeZone |
string |
Time zone. |
TaskJeopardyRequestResponse
The TaskJeopardyRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-163 describes the returned information in the response.
Table 7-163 Payload Information for the Response
TaskJeopardyRequestResponse |
element |
getTaskJeopardyResponse |
OrderAPI.wsdl |
element |
getTaskJeopardyReponseValue |
element |
GetTaskJeopardyResponseValueType |
complexType |
orderKey |
element |
OrderKey |
taskKey |
element |
TaskKey |
This operation retrieves task details for the input task number and document number.
Request Structure: TaskRequest
TaskRequest
The TaskRequest element contains the input information for the operation. Each row in Table 7-164 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-164 Payload Information for the Request
TaskRequest |
element |
getTaskDetailRequest |
OrderAPI.wsdl |
element |
getTaskDetailValue |
element |
getTaskDetailRequestValueType |
complexType |
orderKey |
element |
OrderKey |
taskKey |
element |
TaskKey |
Table 7-165 describes the required fields for getTaskDetailRequestValueType.
Table 7-165 Required Fields for getTaskDetailRequestValueType
timeZone |
string |
Time zone. |
TaskRequestResponse
The TaskRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-166 describes the returned information in the response.
Table 7-166 Payload Information for the Response
element |
getTaskDetailResponse |
OrderAPI.wsdl |
element |
TaskDetailResponseValue |
element |
getTaskDetailResponseValueType |
complexType |
orderKey |
element |
OrderKey |
taskKey |
element |
TaskKey |
transferTaskRequest Operation
This operation transfers tasks from one work queue to another work queue.
Request Structure: transferTaskRequest
Response Structure: transferTaskRequestResponse
transferTaskRequest
The transferTaskRequest element contains the input information for the operation. Each row in Table 7-167 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-167 Payload Information for the Request
transferTaskRequest |
element |
momTransferTaskRequest |
OrderAPI.wsdl |
element |
transferTaskValue |
transferTaskValue |
element |
TransferTaskValueType |
complexType |
orderKey |
orderKey |
element |
OrderKey |
Table 7-168 describes the required fields for TransferTaskValueType.
Table 7-168 Required Fields for TransferTaskValueType
taskNumber |
long |
Task that is being transferred. |
currentWorkQueue |
string |
Work queue where a task is currently assigned. |
newWorkQueue |
string |
Work queue where you are transferring a task. |
The transferTaskRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-169 describes the returned information in the response.
Table 7-169 Payload Information for the Response
transferTaskRequestResponse |
element |
transferTaskResponse |
OrderAPI.wsdl |
element |
orderKey |
orderKey |
element |
OrderKey |
Table 7-170 describes the error messages for the operation.
Table 7-170 Error Messages for the Operation
The Transfer TO Work Queue is an invalid work queue. |
For the input task, the provided work queue to transfer the task, does not exist in the database. |
Populate the transfer to work queue with a valid input value that exists in the database. |
updateCnamData Operation
This operation updates the details of CNAM records.
Request Structure: updateCnamData
Response Structure: updateCnamDataResponse
updateCnamData
The updateCnamData element contains the input information for the operation. Each row in Table 7-171 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-171 Payload Information for the Request
updateCnamData |
element |
updateCNAMDataRequest |
OrderAPI.wsdl |
element |
CNAMDataValue |
CNAMDataValue |
element |
CNAMDataType |
CNAMDataType |
complexType |
CNAMRecords |
CNAMRecords |
element |
CNAMRecordType |
CNAMRecordType |
complexType |
Table 7-172 describes the required fields for CNAMDataType.
Table 7-172 Required Fields for CNAMDataType
extractSequence |
long |
Oracle-generated sequence that identifies a group of CNAM records returned from a call to getCNAMDataRequest. You must pass back the same extractSequence value for the corresponding set of extract records in the call to updateCNAMDataRequest. |
Table 7-173 describes the required fields for CNAMRecordType.
Table 7-173 Required Fields for CNAMRecordType
bsp |
string |
Billing service provider. |
callingNm |
string |
Name that is shown on the called party's caller ID. |
Line |
string |
Line portion of the telephone number. Valid values are a 4-digit number created using numeric characters (0-9). |
Npa |
string |
Numbering plan area of the telephone number. Valid values are a 3-digit number created using numeric characters (0-9). |
Nxx |
string |
Exchange portion of the telephone number. NXX is also known as the central office (CO) prefix or code. Valid values are a 3-digit number created using numeric characters (0-9). |
ocn |
string |
Number assigned to a local exchange carrier or an interexchange carrier. This field is also referred to as the company code (CC). |
presCd |
CharType |
Code that indicates if the name should be presented when the called party has caller ID. Valid values are ALLOW and RESTRICT. |
rao |
string |
Revenue accounting office (RAO) associated with the NPA NXX. The RAO processes message usage in the form of automatic message accounting (AMA). |
transCd |
CharType |
Indicates the action taken by the database provider. Valid values are ADD, MODIFY, and DELETE. |
Date |
string |
The effective date of the CNAM update. This date field is only recorded to resolve discrepancies. Format: YYYY-MM-DD. Example: 2015-06-01. |
entrySrc |
CharType |
Identifies the mechanism used to send information to the LIDB/CNAM database provider. |
The updateCnamDataResponse elementelementelement contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-174 describes the returned information in the response.
Table 7-174 Payload Information for the Response
updateCnamDataResponse |
element |
updateCNAMDataReponse |
OrderAPI.wsdl |
element |
status |
updateE911DataRequest Operation
This operation updates the status of E911 records.
Request Structure: updateE911DataRequest
Response Structure: updateE911DataRequestResponse
The updateE911DataRequest element contains the input information for the operation. Each row in Table 7-175 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-175 Payload Information for the Request
updateE911DataRequest |
element |
momUpdateE911DataRequest |
OrderAPI.wsdl |
element |
e911DataValue |
e911DataValue |
element |
E911DataType |
E911DataType |
complexType |
e911Records |
e911Records |
element |
E911RecordType |
E911RecordType |
complexType |
E911ErrorType |
complexType |
e911ErrorStruc |
e911ErrorStruc |
element |
E911ErrorStruc |
E911ErrorStruc |
complexType |
Table 7-176 describes the required fields for E911DataType.
Table 7-176 Required Fields for E911DataType
extractSequence |
long |
Oracle-generated sequence that identifies a group of E911 records returned from a call to getE911DataRequest. You must pass back the same extractSequence value for the corresponding set of extract records in the call to updateE911DataRequest. |
Table 7-177 describes the required fields for E911RecordType.
Table 7-177 Required Fields for E911RecordType
Cls |
CharType |
Class of service. |
cpd |
string |
Completion date (YYYY-MM-DD) . |
Ctn |
string |
Calling telephone number. |
Exd |
string |
Extract Date YYYY-MM-DD |
Foc |
CharType |
Function code (function of change). |
Hno |
string |
House number of the service location for the calling telephone number. |
Nam |
string |
Customer name. |
Ord |
string |
Order number. |
Pcn |
string |
Postal community name of the service location for the calling telephone number. |
Sta |
string |
State/province of the service location for the calling telephone number. |
Stn |
string |
Street name of the service location for the calling telephone number. |
Table 7-178 describes the required fields for E911ErrorStruc.
Table 7-178 Required Fields for E911ErrorStruc
Code |
integer |
Error code. |
Reason |
string |
Reason for the error. |
The updateE911DataRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-179 describes the returned information in the response.
Table 7-179 Payload Information for the Response
updateE911DataRequestResponse |
element |
updateE911DataReponse |
OrderAPI.wsdl |
element |
status |
updateEstimationCompletedDateRequest Operation
This operation updates the estimated completion date for an input task. The request takes an input document number, task number and estimated completion date.
Request Structure: updateEstimationCompletedDateRequest
Response Structure: updateEstimationCompletedDateRequestResponse
The updateEstimationCompletedDateRequest element contains the input information for the operation. Each row in Table 7-180 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-180 Payload Information for the Request
updateEstimationCompletedDateRequest |
element |
updateEstimatedCompletionDateRequest |
OrderAPI.wsdl |
element |
updateEstimatedCompletionDateValue |
element |
UpdateEstimatedCompletionDateValueType |
complexType |
orderNumber |
element |
OrderKey |
taskNumber |
element |
TaskKey |
Table 7-181 describes the required fields for UpdateEstimatedCompletionDateValueType.
Table 7-181 Required Fields for UpdateEstimatedCompletionDateValueType
timeZone |
string |
Time zone associated with an NPA NXX/building location. |
estCompDateTime |
string |
Work queue owner's estimate of the task completion date and time. |
The updateEstimationCompletedDateRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-182 describes the returned information in the response.
Table 7-182 Payload Information for the Response
updateEstimationCompletedDateRequestResponse |
element |
updateEstimatedCompletionDateResponse |
OrderAPI.wsdl |
element |
status |
updateGWEventRequest Operation
This operation updates order management details for the following:
updateOrderTaskGWEventValue
completeTaskProcedureValue
updateOrderTaskEventProcedureValue
reopenTaskProcedureValue
updateServicesInOrderProcedureValue
Request Structure: updateGWEventRequest
Response Structure: updateGWEventRequestResponse
The updateGWEventRequest element contains the input information for the operation. Each row in Table 7-183 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-183 Payload Information for the Request
updateGWEventRequest |
element |
updateOrderManagementRequest |
OrderAPI.wsdl |
element |
updateValue |
updateValue |
element |
MetaSolvUpdateProcedureValueChoice |
complexType |
updateOrderTaskGWEventValue |
complexType |
metaSolvGatewayEventKey |
element |
GatewayEventKey |
GatewayEventKey |
complexType |
orderKey |
element |
OrderKey |
taskKey |
element |
TaskKey |
serviceKey |
element |
MetaSolvServiceKey |
ServiceEntities.xsd |
Table 7-184 describes the required fields for updateOrderTaskGWEventValue.
Table 7-184 Required Fields for updateOrderTaskGWEventValue
statusCode |
Enum |
Valid values of GatewayEventStatusEnumType. Current state of the gateway event. |
requestId |
short |
Request ID |
Table 7-185 describes the required fields for serviceKey.
Table 7-185 Required Fields for serviceKey
servicePrimaryKey |
string |
Service item ID of the product |
The updateGWEventRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-186 describes the returned information in the response.
Table 7-186 Payload Information for the Response
updateGWEventRequestResponse |
element |
updateOrderTaskGWEventResponse |
OrderAPI.wsdl |
element |
UpdateOrderTaskGWEventResponse |
complexType |
Extension of UpdateProcedureResponse metaSolvGatewayEventKey |
element |
GatewayEventKey |
GatewayEventKey |
complexType |
Extension of EventKey Contains the following:
EventKey |
complexType |
Extension of ManagedEntityKey |
orderKey |
element |
OrderKey |
taskKey |
element |
TaskKey |
serviceKey |
element |
updateLidbData Operation
This operation updates the details of LIDB records.
Request Structure: updateLidbData
Response Structure: updateLidbDataResponse
updateLidbData
The updateLidbData element contains the input information for the operation. Each row in Table 7-187 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-187 Payload Information for the Request
updateLidbData |
element |
updateLIDBDataRequest |
OrderAPI.wsdl |
element |
LIDBDataValue |
LIDBDataValue |
element |
LIDBDataType |
LIDBDataType |
complexType |
LIDBRecords |
LIDBRecords |
element |
LIDBRecordType |
LIDBRecordType |
complexType |
Table 7-188 describes the required fields for LIDBDataType.
Table 7-188 Required Fields for LIDBDataType
extractSequence |
long |
Oracle-generated sequence that identifies a group of LIDB records returned from a call to getLIDBDataRequest. You must pass back the same extractSequence value for the corresponding set of extract records in the call to updateLIDBDataRequest. |
Table 7-189 describes the required fields for LIDBRecordType.
Table 7-189 Required Fields for LIDBRecordType
bnsCd |
CharType |
Determines what kind of calls can be made from another telephone but billed to this number. |
busResCd |
CharType |
Indicates the type of market that this telephone number is intended. Valid values are B = BUSINESS, R = RESIDENCE. |
Line |
string |
Npa |
string |
Nxx |
string |
ocn |
string |
servClassCd |
string |
Class of Service code. Valid values are BUS = Business, RES = Residential, PBC = Public Coin, PBN = Public non-coin. |
transCd |
CharType |
Indicates the action taken by the database provider. Valid values are I = ADD, C = MODIFY, D = DELETE. |
entrySrc |
CharType |
Field identifies the mechanism used to send information to the LIDB/CNAM database provider. |
thirdNbrAcc |
CharType |
Third number acceptance indicator. Valid values are B = DENIED (This value prevents the PSR from go into Complete status), C = VERIFIED. |
collCallAcc |
CharType |
Collect call acceptance indicator. Valid values are B = DENIED, A = VERIFIED. |
The updateLidbDataResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-190 describes the returned information in the response.
Table 7-190 Payload Information for the Response
updateLidbDataResponse |
element |
updateLIDBDataReponse |
OrderAPI.wsdl |
element |
Success |
updateOrderRequest Operation
Request Structure: updateOrderRequest
Response Structure: updateOrderRequestResponse
updateOrderRequest
The updateOrderRequest element contains the input information for the operation. Each row in Table 7-191 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-191 Payload Information for the Request
updateOrderRequest |
element |
OrderAPI.wsdl |
element |
updateValue |
updateValue |
element |
complexType |
Table 7-192 defines UpdateServicesInOrderProcedureValue.
Table 7-192 UpDateServicesInOrderProcedureValue Definition
UpdateServicesInOrderProcedureValue |
element |
metaSolvPSROrderValue |
complexType |
Described in Table 7-36 |
Table 7-193 defines updateOrderTaskGWEventValue.
Table 7-193 updateOrderTaskGWEventValue Definition
element |
UpdateOrderTaskGWEventValue |
complexType |
metaSolvGatewayEventKey,statusCode |
element |
GatewayEventKey |
GatewayEventKey |
complexType |
Table 7-194 defines CompleteTaskProcedureValue
Table 7-194 CompleteTaskProcedureValue Definition
| Name | Defined As | File Description | File Name |
CompleteTaskProcedureValue |
complexType |
whyMissInputs |
element |
WhyMissInputType |
WhyMissInputType |
complexType |
Mommekey |
element |
element |
metaSolvOrderKey |
metaSolvOrderKey |
element |
OrderKey |
The updateOrderRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-195 describes the returned information in the response.
Table 7-195 updateOrderRequestResponse
updateOrderRequestResponse |
element |
updateOrderManagementResponse |
OrderAPI.wsdl |
element |
updateValueResponse |
element |
MetaSolvUpdateProcedureValueResponseChoice |
complexType |
updateServicesInOrderProcedureResponse |
element |
UpdateServicesInOrderProcedureResponse |
complexType |
Extension of UpdateProcedureResponse metaSolvOrderKey |
metaSolvOrderKey |
element |
OrderKey |
OrderKey |
complexType |
completeTaskProcedureResponse |
element |
CompleteTaskProcedureResponse |
complexType |
Extension of UpdateProcedureResponse mommekey |
mommekey |
element |
complexType |
metaSolvOrderKey |
metaSolvOrderKey |
element |
OrderKey |
OrderKey |
complexType |
element |
complexType |
element |
GatewayEventKey |
GatewayEventKey |
complexType |
EventKey |
complexType |
Extension of ManagedEntityKey Contains a list of fields |
orderKey |
element |
OrderKey |
OrderKey |
complexType |
taskKey |
element |
TaskKey |
TaskKey |
complexType |
serviceKey |
element |
complexType |
updatePSROrderRequest Operation
Request Structure: updatePSROrderRequest
Response Structure: updatePSROrderRequestResponse
The updatePSROrderRequest element contains the input information for the operation. Each row in Table 7-196 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-196 Payload Information for the Request
updatePSROrderRequest |
element |
OrderAPI.wsdl |
element |
updateValue |
updateValue |
element |
complexType |
Table 7-197 defines updateServicesInOrderProcedureValue.
Table 7-197 UpdateServicesInOrderProcedureValue
updateServicesInOrderProcedureValue |
element |
complexType |
Table 7-198 defines updateOrderTaskGWEventValue.
Table 7-198 updateOrderTaskGWEventValue
element |
complexType |
Extension of UpdateProcedureValue Contains a list of fields |
statusCode |
element |
GatewayEventStatusEnumType |
element |
GatewayEventKey |
GatewayEventKey |
complexType |
EventKey |
element |
eventPrimaryKey |
taskKey |
element |
taskKey |
orderKey |
element |
taskKey |
serviceKey |
element |
Table 7-199 defines CompleteTaskProcedureValue.
Table 7-199 CompleteTaskProcedureValue Definition
complexType |
whyMissInputs |
element |
WhyMissInputType |
WhyMissInputType |
complexType |
Mommekey |
element |
element |
metaSolvOrderKey |
metaSolvOrderKey |
element |
OrderKey |
OrderKey |
complexType |
The updatePSROrderRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-200 describes the returned information in the response.
Table 7-200 Payload Information for the Response
updatePSROrderRequestResponse |
element |
OrderAPI.wsdl |
element |
complexType |
metaSolvOrderKey |
element |
OrderKey |
OrderKey |
complexType |
Table 7-201 describes the error messages for the operation.
Table 7-201 Error Messages for the Operation
The telephone number type you specified does not match the type in the database or the telephone number is invalid. |
