B Oracle Communications MetaSolv Solution Components
Table B-1 shows which software components are included in the Oracle Communications MetaSolv Solution (MSS) core product, which are separate software options, and which are separate applications included with MSS.
Table B-1 MSS Components Included In This Release
| Component | Core component, software option, or separate application | Where installed |
Engineering |
AutoDesign |
Software option |
Client |
Diversity |
Software option |
Client |
Equipment |
Core |
Client |
Groom Tool |
Core |
Client |
Network Design Canvas |
Core |
Client |
Ownership of Inventory |
Core |
Client |
Path Analysis |
Core |
Client |
Plant Administration Module |
Software option |
Client |
Provisioning Assistant |
Core |
Client |
OSS Gateways and APIs |
ASR API |
Software option |
Application server |
End User Billing API |
Software option |
Internet Services API |
Software option |
Inventory and Capacity Management API |
Software option |
Plant API |
Software option |
PSR End User Order Entry API |
Software option |
Switch Provisioning Activation API |
Software option |
Transportation Provisioning Activation API |
Software option |
Trouble Management API |
Software option |
Work Management API |
Software option |
Service Requests |
ASR |
Software option |
ASR and ISR using templates |
Core |
Client |
Customer Management Module |
Software option |
Client |
Engineering Work Order (EWO) |
Software option |
Client |
Generate ASR (PSR to ASR mapping) |
Software option |
Client |
Internal Service Request (ISR) |
Software option |
Client |
Product Catalog Module |
Software option |
Client |
Product Service Request (PSR) |
Software option |
Client |
Service Request Worksheet Module |
Software option |
Client |
USO |
Software option |
Client |
Technology Modules |
ATM/Frame Relay Technology Module |
Software option |
Client |
Digital Loop Carrier Technology Module |
Software option |
Client |
DSL Technology Module |
Software option |
Client |
Ethernet Technology Module |
Software option |
Client |
IP Technology Module |
Software option |
Client |
MPLS Technology Module |
Software option |
Client |
Optical/TDM Technology Module |
Software option |
Client |
SONET Technology Module |
Software option |
Client |
Wireless Technology Module |
Software option |
Client |
Trouble Management |
Notifications |
Core |
Client |
Trouble Management Subsystem |
Software option |
Client |
Utilities |
Background Processor |
Core Separate application |
Separate machine |
Location and Routing Gateway |
Software option Separate application |
Client |
MetaSolv Solution Utilities |
Core Separate applications |
Client |
NPA Split Utility |
Software option |
Client |
Web Service |
MSS WebService |
Core |
Work Management |
Provisioning Plans |
Core |
Client |
Rules and Behaviors for all areas |
Core |
Client |
Work Queues |
Core |
Client |
