6 PI Password Expiry
The Password Expiry tab of the PI Administration screen enables you to configure the number of days after which PI user’s password should expire. You can also disable password expiration from this tab.
Password Expiry fields
This table describes the function of each field.
| Field | Description |
| Duration(In days) | Number of days after which password should expire. |
| DisablePassword Expiry | Selecting this checkbox disables password expiry and password will never expire for PI users. |
Configuring password expiry
Follow these steps to configure password expiry for PI users.
- Click on the Password Expiry tab.
In the Duration(In days) field, enter the number of days after which the password should expire.
Select Disable Password Expiry checkbox if you do not want the PI user password to expire. -
Click Save.
Result: The password expiry configuration is saved.
Hard restart the PI. For details, see Hard PI Restart in PI User's and Technical Guide.
Result: The new configuration details are loaded by the PImanager.
Related topic
