1 The RCA Configuration Screens
This chapter explains how to configure the RCA on the SMS using the RCA screens.
To configure RCA in the the database the following items must be defined:
Optionally the following items may also be defined:
This chapter contains the following topics.
Billing Type Prefix
You use the Billing Type Prefix tab to configure different billing types (volume or duration) for particular CLI prefixes.
To maintain Billing Type Prefixes, see the relevant option:
Adding a billing type prefix
Follow these steps to Add a new billing type prefix.
On the Billing Type Prefix tab in the Radius Control Agent Screen - Find mode, click New.
Result: You see the tab in New mode.
In the Prefix field, enter the CLI prefix you want to assign a billing type to.
From the Billing Type drop down box, select the billing type to use for billing calls that match the CLI prefix.
In the Remark field, enter a comment if required.
Click Save.
Repeat steps 2 through 5 for all the required Billing Type Prefixes.
Note: When you click Save, the saved values remain on the screen. You can create another new record by typing over these values and clicking Save again.
Click Return to go back to the previous screen.
Related topic
Editing a billing type prefix
Follow these steps to edit a billing type prefix.
In Find mode on the Billing Type Prefix tab, enter selection criteria in one or more query fields.
Note: If a field is left empty, then the search will retrieve all instances of that field.
Click Find.
Result: The query returns the first 100 records that begin with the selection criteria. For example, if you enter 123 in a query field, the system will return records such as 123, 1234, 12345.
The results appear in the table on the Find result mode screen for the type of record you are querying. See Using the Find Screens.
Click on the record to edit.
Click Select.
Result: The selected record appears in Update mode on the tab.
Edit the details as described in Adding a billing type prefix.
Click Save, and then Return, to save your changes and return to the previous screen.
Related topic
Deleting a billing type prefix
Follow these steps to delete an RCA billing type prefix.
Click Find.
Click on the record to delete.
Click Delete.
Result: The Confirm Delete Record screen appears.
Click Yes to confirm.
Click Return to return to the previous screen.
Related topic
Release Message
The Release Message tab allows you to specify the RADIUS release message to send, corresponding to the release codes received from the IN, if the IN releases instead of connecting the call.
To maintain global configurations, see the relevant option:
Adding a release message
Follow these steps to Add a new release message.
On the Release Message tab in the Radius Control Agent Screen - Find mode, click New.
In the Release Cause field, enter the code corresponding to the release cause from the destination application (either ACS or CCS).
In the Name field, enter the name to assign to the release cause.
In the Message field, enter the RADIUS release message to send when a call is disconnected with this release cause.
Click Save.
Repeat steps 2 through 6 for all the required release messages.
Related topic
Editing a release message
Follow these steps to edit an RCA release message.
In Find mode on the Release Message tab, enter selection criteria in one or more query fields.
Click Find.
Click Select.
Edit the details as described in Adding a release message.
Related topic
Deleting a release message
Follow these steps to delete an RCA release message.
Click Find.
Click Delete.
Related topic
Service Option
The RCA Service Option tabs let you configure the available service options for a service provided by the PDSN.
Service Options must be defined in the following order:
Define the available service options on the Service Option tab. See Adding a service option.
Create the service option list on the Service Option List tab. See Adding a service option entry.
On the Service Option Entry tab, assign the service options you have defined to the service option list. See Adding a service option entry.
Follow these steps to Add a new service option.
On the Service Option tab in the Radius Control Agent Screen in Find mode, click New.
In the ID field, enter the ID corresponding to the PDSN ID for the service option. This is an integer which must be in the range 0-255.
In the Name field, enter the service option name. You may use up to 30 characters.
In the Remark field, enter any comments.
Click Save.
Repeat steps 2 through 5 for all the required service options.
Related topic
Editing a service option
Follow these steps to edit a service option.
In Find mode on the Service Option tab, enter selection criteria in one or more query fields.
Click Find.
Click Select.
Edit the details as described in Adding a service option.
Related topic
Deleting a service option
Follow these steps to delete a service option in the RCA.
Click Find.
Click Delete.
Result: The Confirm Delete Record screen appears:
Result: The record is removed from the database.
Related topic
Service Option List
Create the service option list on the Service Option List tab. See Adding a service option list.
Maintaining service option lists
To maintain service option list configurations, see the relevant option:
Follow these steps to Add a new Service Option List.
On the Service Option List tab in the Radius Control Agent Screen in Find mode, click New.
In the Name field, enter the service option list name. This can be up to 30 characters long.
Click Save.
Repeat steps 2 through 4 for all the required service option lists.
Related topic
Editing a service option list
Follow these steps to edit a service option list name.
In Find mode on the Service Option List tab, enter selection criteria in one or more query fields.
Click Find.
Click Select.
Edit the details as described in Adding a service option list.
Related topic
Deleting a service option list
Follow these steps to delete an RCA service option list.
Click Find.
Click Delete.
Related topic
Maintaining service option entry
To maintain service option entry configurations, see the relevant option:
Follow these steps to Add a Service Option Entry to a Service Option List.
On the Service Option Entry tab in the Radius Control Agent Screen in Find mode, click New.
From the Service Option List drop down box, select the required service option list.
From the Service Option drop down box, select the service option to include in the list.
In the Max Num Instances enter the maximum number of simultaneous accesses to the service option, that the customer may have. This is an integer which must be in the range 0-255.
Click Save.
Related topic
Editing a service option entry
Follow these steps to Edit a Service Option Entry.
In Find mode on the Service Option Entry tab, enter selection criteria in one or more query fields.
Click Find.
The results appear in the grid on the Find result mode screen for the type of record you are querying. See Using the Find Screens.
Click Select.
Edit the details as described in Adding a service option entry.
Related topic
Deleting a service option entry
Follow these steps to delete an RCA Service Option Entry.
In Find mode on the Service option Entry tab, enter selection criteria in one or more query fields.
Click Find.
Click Delete.
Related topic
IP Address
The address tabs in the RCA allow you to configure lists of IP addresses for remote billing purposes (see X.S011 - 005 - C, cdma200 Wireless IP Network Standard: Accounting Services and3GPP2 RADIUS VSAs).
Note: It is the responsibility of the PDSN to perform the remote accounting, and not the RADIUS Control Agent.
Addresses in RCA need to be configured in the following order:
Define the IP addresses on the IP Address tab. See Adding an IP address.
Define IP address lists on the Address List tab. See Adding an address list.
Assign the IP addresses to an address list, on the Address List Entry tab. See Adding an address list entry.
Assign the address lists to CLI prefixes on the CLI Address List tab. See Adding a CLI address list.
Follow these steps to Add a new IP address.
On the IP Address tab in the Radius Control Agent Screen in Find mode, click New.
From the Address Type drop down list, select the address type.
Select the Qualifier check box if the IP address is exempt from billing.
Note: The exemption is subject to interpretation by the PDSN, and not the RADIUS Control Agent.
In the IP Address field, enter the IP address you want to add.
In the Mask or Prefix field, enter the mask or prefix for the IP address.
Note: This will depend on the Address Type. Enter a mask if the Address Type is IPv4, or a prefix if it is IPv6.
In the Description field enter a description for the IP address. This can be up to 50 characters long.
In the Remark field, enter a user comment if required.
Click Save.
Repeat steps 2 through 8 for all the required IP Addresses.
Note: When you click Save, the values from the previous entry remain on the screen. You can create another new record by typing over these values and clicking Save again.
Related topic
Editing an IP address
Follow these steps to edit an RCA IP address.
In Find mode on the IP Address tab, enter selection criteria in one or more query fields.
Click Find.
Click Select.
Edit the details as described in Adding an IP address.
Related topic
Deleting an IP address
Follow these steps to delete an RCA IP address.
Click Find.
Click Delete.
Related topic
Address List
Follow these steps to Add a new address list.
On the Address List tab in the Radius Control Agent Screen in Find mode, click New.
In the Name field, enter the name of the address list to add.
Click Save.
Repeat steps 2 through 5 for all the required address lists.
Related topic
Editing an address list
Follow these steps to edit an RCA address list.
In Find mode on the Address List tab, enter selection criteria in one or more query fields.
Click Find.
Click Select.
Edit the details as described in Adding an address list.
Related topic
Deleting an address list
Follow these steps to delete an RCA address list.
Click Find.
Click Delete.
Related topic
Address List Entry
Maintaining address list entry
To maintain address list entry configurations, see the relevant option:
On the Address List Entry tab in the Radius Control Agent Screen in Find mode, click New.
From the Address List drop down box, select the name of the address list to add an IP address to.
From the IP Address drop down box, select the IP address to add.
Click Save.
Related topic
Editing an address list entry
Follow these steps to edit an RCA address list entry.
In Find mode on the Address List Entry tab, enter selection criteria in one or more query fields.
Click Find.
Click Select.
Edit the details as described in Adding an address list entry.
Related topic
Deleting an address list entry
Follow these steps to delete an RCA address list entry.
Click Find.
Click Delete.
Related topic
CLI Address List
Follow these steps to add a new CLI address list.
On the CLI Address List tab in the Radius Control Agent Screen in Find mode, click New.
In the Prefix field, enter the CLI prefix to assign an address list to.
From the Address List drop down box, select the address list.
Click Save.
Repeat steps 2 through 5 for all the address lists to assign to a CLI.
Related topic
Editing a CLI address list
Follow these steps to edit an RCA CLI address list.
In Find mode on the CLI Address List tab, enter selection criteria in one or more query fields.
Click Find.
Click Select.
Edit the details as described in Adding a CLI address list.
Related topic
Deleting a CLI address list
Follow these steps to delete an RCA CLI address list.
Click Find.
Click Delete.
Related topic
Global Config
The Global Config tab allows you to specify the global default values for the RCA service.
Adding a global configuration
Follow these steps to add a new global configuration for the RCA.
On the Global Config tab in the Radius Control Agent Screen in Find mode, click New.
Result: The Global Config tab redisplays in New mode.
In the Name field, enter the name for the global configuration.
Note: This name corresponds to the
ConfigNameparameter in the eserv.config file. This tells the Radius Gateway which database configuration to load at startup. -
From the Service Option List drop down box, select the service option list. This will have been previously defined on the Service Option List tab.
Note: This is intended for volume-based billing; for duration-based billing leave blank or none.
In the Max Service Instances field, enter the maximum number of external services that can be accessed at one time.
Note: This is related to service options; for duration-based billing leave blank.
In the Session Timeout field, enter the maximum length of time for a session before it is disconnected (regardless of the activity of the session).
Note: Leave blank or 0 for no timeout.
In the Idle Timeout field, enter the length of time the session can be inactive before it is disconnected. To ensure that calls can be billed correctly, you must enter a value for Idle Timeout that is:
Greater than zero (0). If you set Idle Timeout to zero or leave this field blank, the timer is disabled.
Greater than the largest reservation chunk that will be returned by the billing engine. This will prevent the RCA from timing out sessions that are still active.
Less than the billing engine timeout value that is set in the Session Timeout field; if the billing engine times out first, it will release the
reservation, so the call will not be billed.
Note: When the idle timer expires, RCA sends an ApplyChargingReport to ACS, signaling that the call has ended, and billing for the call.
From the Billing Type drop down list, select the default billing type for incoming calls. Select one of:
Duration
Volume
None
Note: If you select
None, then you must select a value in the Release field. If the CLI for an incoming call does not match any prefix configured in the Billing Type Prefix tab then the incoming call is released using the release code configured here. -
Select the Write UDR check box if you want to write usage data records.
Note: This should be left unselected, Oracle applications write EDRs generated by Prepaid Charging.
In the Internal Error field, enter the RADIUS error message to send for any errors occurring that are not related to releasing the call.
In the Max Volume Quota field, enter the maximum amount of data (in octets) that can be used.
Note: This is used for volume-based billing; for duration-based billing leave blank or 0.
In the Max Duration Quota field, enter the maximum length of time (in seconds) that the user can be connected when no billing is being performed. For example, if RCA receives a Connect/Continue from the IN without an ApplyCharging.
Note: This is used for duration-based billing;for volume-based billing leave blank or 0.
In the Shared Secret field, enter the key used for encryption/decryption between RCA and the RADIUS client.
Click Save.
Repeat steps 2 through 14 for all global configuration records to define.
Note: When you click Save, the values from the previous entry remain on the screen. You can then create another new record by typing over these values.
Related topic
Editing a global configuration
Follow these steps to edit an RCA global configuration.
In Find mode on the Global Config tab, enter selection criteria in one or more query fields.
Click Find.
Click Select.
Edit the details as described in Adding a global configuration.
Related topic
Deleting a global configuration
Follow these steps to delete an RCA global configuration.
Click Find.
Click Delete.
Related topic
A find screen enables you to find records that match the selection criteria. All RCA find screens contain the following:
Buttons
Query fields
Find result mode buttons
The table below describes the function of each button displayed at the bottom of the RADIUS Control Agent Screens in Find result mode.
| Button | Function |
| Previous | Goes back to the previous set of records in the table, if you have used the Next button to display more records. |
| Next | Displays the next set of records, if all the Find results cannot be displayed in the table at one time. |
| Select | Selects the record highlighted in the table and displays it on the tab in Update mode. |
| Modify All | Modifies a group of records. |
| Delete All | Deletes a group of records. |
| Export | Exports the Find results to a file. |
| Prints the Find results. | |
| Return | Returns you to the RADIUS Control Agent Screen in Find mode for the tab. |
