34 CCS Voucher Feature Nodes
This chapter describes the Oracle Communications Network Charging and Control (NCC) CCS Voucher feature nodes.
This chapter contains the following topics.
Play Voucher Redeemed Info
Recharge Menu
Scratch Card Recharge
Scratch Card Recharge Alternate Subscriber
Select Voucher Scenario
Voucher Commit Revoke
Voucher Recharge
Voucher Redeemed
Voucher Reservation
Voucher Type Balance Information
Voucher Type Branching
Voucher Type Recharge
The Play Voucher Redeemed Info node plays the voucher balance to the subscriber. The node will generate and play a multi-part announcement that is built up from the response information from a successful voucher redeem. Is to be placed after a voucher redemption node (For example, Scratchcard or Voucher Redeem and plays out what the billing engine actually redeemed.
Node exits – Play Voucher Redeemed Info
This node has one entry and three exits. The number of exits cannot be changed.
Exit Cause Description
1 Success The caller received the voucher information.
2 Abandon The caller abandoned the call.
3 Unsupported Either error / failure or that the Domain being used does not support this feature node.
Configuration fields – Play Voucher Redeemed Info
This table describes the function of each field in the Configure Play Voucher Redeemed Info screen.
Field Description
Announcement Set List of all the available announcement sets.
Announcement Entry List of all the announcements belonging to the selected announcement set.
Note: You can set the node to use the system currency using the PAVRBalancesUseSystemCurrency parameter. For more information, see CCS Technical Guide.
Configuring the node – Play Voucher Redeemed Info
Follow these steps to configure the node.
  1. Use the drop down lists to select the pre-recorded announcements that are to be played as prompts to the caller.
    Select the specific Announcement Set to which the Announcement Entry belongs. Only valid announcements are available from the lists.
  2. Click Save.
    Note: This will be greyed out until all the announcement sets have been selected.
Recharge Menu
Warning: This feature node has now been deprecated and should no longer be used. This feature node will still function in existing control plans. For new control plans please use a combination of the Profile Branching and Selection Dependent Routing feature nodes.
The Recharge Menu feature node allows the caller to select a method of recharging an account.
Node exits – Recharge Menu
This node has one entry and six exits. The number of exits cannot be changed.
1 Unsupported Either, error / failure, the Domain being used does not support this feature node, or the number of menu retries has exceeded the limit.
2 Abandon The caller has terminated the call.
3 Escape The caller has selected the Escape option by entering *.
4 Voucher The caller has selected the Voucher Menu option by entering key 1.
5 Credit Card The caller has selected the Credit Card Menu option by entering key 2 when they have a PIN set. This exit is only available when the caller has previously made a credit card recharge.
6 First Credit Card The caller has selected the Credit Card Menu option by entering key 2, and has no PIN set. This exit is only available when the caller has never before made a credit card recharge.
Configuration fields – Recharge Menu
This table describes the function of each field in the Configure Recharge Menu node screen.
Field Description
Configuring the node – Recharge Menu
  1. For each relevant announcement, use the drop down lists to select the pre-recorded announcements that are to be played as prompts to the caller.
  2. Click Save.
The Scratch Card Recharge node enables a caller to use a scratch card to recharge their account, and to change the product type if required. The caller is prompted to enter their scratch card number.
The maximum number of consecutive times a caller can enter an invalid number is configured by the MaximumBadCodeRetries parameter in the ccsMacroNodes section of eserv.config. See CCS Technical Guide for details.
Note: If the Set Wallet Type feature node is used prior to the Scratch Card Recharge node, then the product type of the alternative wallet is changed when the voucher is redeemed.
Node exits – Scratch Card Recharge
This node has one entry and eight exits. The number of exits cannot be changed.
1 Success The caller has successfully exited the node or the wallet may not be recharged, or the voucher was successfully recharged but a product type swap request was unsuccessful.
2 Success Product Swap The caller has successfully exited the node and requested a product type swap.
3 Unsupported Either, error / failure, the Domain being used does not support this feature node, or the caller has not made an entry.
4 Restricted Product The caller was unable to recharge the voucher because the caller's product type does not belong to the list of available product types for the voucher.
5 Abandon The caller has terminated the call.
6 Escape The caller has selected the Escape option.
7 Frozen The caller's account has been set to Frozen and therefore cannot use this node.
8 Blacklist The call has entered too many invalid scratch card numbers and has been Blacklisted.
Configuration fields – Scratch Card Recharge
This table describes the function of each field in the Configure Scratch Card Recharge node screen.
Field Description
Configuring the node – Scratch Card Recharge
  2. Click Save.
The Scratch Card Recharge Alternative Subscriber node enables a caller to use a scratch card to recharge another user's account, and to change the product type if required.
The caller is prompted to enter the MSISDN of the account, and re-enter for confirmation, that they wish to recharge. They are then prompted to enter the scratch card number. The caller has three attempts to enter a valid scratch card number.
Note: If the Set Wallet Type feature node is used prior to the Scratch Card Recharge - Alternate Subscriber node, then the product type of the alternative wallet is changed when the voucher is redeemed.
Node exits – Scratch Card Recharge Alternate Subscriber
1 Success The caller has successfully recharged the voucher and exited the node, but a product type swap, if requested, was unsuccessful.
7 Frozen The caller's account is Frozen and therefore cannot use this node.
Configuration fields – Scratch Card Recharge Alternate Subscriber
This table describes the function of each field in the Configure Scratch Card Recharge - Alternate Subscriber node screen.
Field Description
Configuring the node – Scratch Card Recharge Alternate Subscriber
  2. Click Save.
The Select Voucher Scenario node enables a subscriber to select from amongst the different ways the voucher can be redeemed, by choosing a particular scenario.
Note: It is possible for a scenario to increment a balance or extend the expiry date for the balance, or both. In addition, a scenario may also possibly change the overall account expiry date.
Node exits – Select Voucher Scenario
This node has one entry and five exits. The number of exits cannot be changed.
1 Success A scenario has been selected by the subscriber.
2 Failure
Any of a number of failures, for example:
  • Profile that should have contained the scenario list is missing or empty
  • Subscriber pressed escape
3 Unsupported An unknown response was received from Voucher Management.
4 Abandon The caller has hung up before completing the scenario selection.
5 Timeout The subscriber failed to respond within the configured timeout period
Configuring the node – Select Voucher Scenario
The configuration fields are used to establish the variable part message/announcement that the subscriber receives.
Review the examples before proceeding with the node configuration.
Follow these steps to configure the node configuration.
  1. Select the Scenario Data from the Data Type, Location and Field drop down lists.
    Note: This where the valid scenarios are located.
  2. Select the Interaction Method to use with the subscriber.
    Either of:
    • Voice
    • USSD, or
    • SMS
    Result: The lists and fields for the selected option are made available.
  3. Follow the relevant instructions for the method selected.
Voice or USSD method
  1. Select the announcement from each of the announcement Set and Entry drop down lists:
    • Initial Prompt: Select the first message.
    • Selection Choice: Select the scenario selection choices message.
    • Balance Expiry Ext: Select the balance expiry will be extended message.
    • No Bal Expiry Ext: Select the balance expiry will not be extended message.
    • Account Expiry Ext: Select the account expiry will be extended message.
    • No Account Exp Ext: Select the account expiry will not be extended message.
    • Account Type Change: Select the account type will be changed message.
    • Final Prompt: Select the last message to the subscriber.
  2. Select the Selected Scenario profile from the Data Type, Location and Field drop down lists.
    Note: This is where the scenario number to use for the voucher redemption will be saved.
  3. Click Save.
SMS method
  1. In the Text Notifications panel, enter the text fields which will be used to construct a short message to the subscriber.
    Type the text for the initial prompt to the subscriber in the Initial Prompt field.
  2. Type the text for the response choices available to the subscriber in the Selection Choice field.
  3. Type the text for any extension on account expiry available to the subscriber in the Acc Expiry Ext field.
  4. Type the text for no extension on account expiry available to the subscriber in the No Acc Expiry Ext field.
  5. Type the text for any account type change available to the subscriber in the Acc Type Change field.
  6. Select the Resultant Message profile from the Data Type, Location and Field drop down lists.
    Note: This is where the subscriber returned SMS containing the scenario number to use will be saved.
  7. Click Save.
Note: The list of data types is fixed at installation time for each feature node or screen.
Further reference:
  • For information about profile blocks (data type, location, and field) and how to use them, see Profile Blocks and Tags.
  • The primary tag lists are configured in the SMS > Services > ACS Service > Configuration > Profile Tag Details and Profile Tag Mapping tabs (see ACS User's Guide, Profile Tag Details for more information).
Example configuration values – Select Voucher Scenario
This table shows a textual example of the variable parts to be used when configuring the Voice and USSD announcement fields.
Announcement Example
Initial Prompt “Your voucher has several options, please select from the following”
Selection Choice “Press <choice> for”
Balance Expiry Ext “with an expiry extension of <days> days”
No Bal Expiry Ext “with no expiry”
Account Expiry Ext “with an extension to the account expiry of <days> days”
No Account Exp Ext "with no extension to the account expiry"
Account Type Change “with a change of Product Type to “
Note: The available balance types are configured on the Balance Type tab in CCS. The cost strings used to report balance values are configured on the Balance Type Translations tab in CCS. Refer to the Wallet Management chapter in the CCS User's Guide for details.
The above example allows the following announcement to be created:
“Your voucher has several options, please select from the following:
  • Press 1 for 10 sms with an expiry extension of 10 days.
  • Press 2 for 5 dollars and 5 sms with a change of Product Type to Platinum.
  • Press 3 for 20 sms with an expiry extension of 5 days.”
Example SMS values – Select Voucher Scenario
This table shows a textual example of the variable parts to be used when configuring the SMS Text Notifications fields.
SMS/Announcement Example
Selection Choice “Text <choice> for”
Acc Expiry Ext “with an extension to the account expiry of <days> days”
No Acc Expiry Ext "with no extension to the account expiry"
Acc Type Change “with a change of Product Type to “
The above example allows the following SMS to be created as a single message:
  • Text 1 for 10 sms with an extension to the account expiry of 10 days.
  • Text 2 for 5 dollars and 5 sms with a change of Product Type to Platinum.
  • Text 3 for 20 sms with an extension to the account expiry of 5 days.”
Warning: This may require careful use of the node in a Control Plan to split the options over several SMS messages to avoid the SMS length limitation.
Example use of node – Select Voucher Scenario
Voucher redeem options can be varied, for example:
  • Voucher redeems for 120 minutes of international calling (180 minutes during our “Talk-Fest July” promo special)
  • Voucher redeems for 200 short messages made within a 30 day period (300 SMS during our “Text-Fest August” promo special), or
  • Gold customers receive an additional 10% on top of their chosen option.
The potential scenarios are complex enough that CCS cannot be expected to know beforehand what scenarios apply, nor what the final values to the subscriber might be. There may be only one scenario that applies, or two, or three.
CCS requires some guidance from Voucher Management, as shown in the following example interaction for redeeming a voucher:
  1. Subscriber requests CCS to redeem a voucher for them.
  2. CCS passes request to Voucher Management, indicates no particular scenario.
  3. Voucher Management determines that this voucher has multiple scenarios, informing CCS that this is the case, along with some information to help prompt the subscriber.
  4. For Voice/USSD interactions:
    • CCS prompts the subscriber to choose the scenario they prefer.
    For SMS interactions:
    • CCS constructs a short message containing all the scenario options and sends this back to the subscriber.
  5. The subscriber re-requests CCS to redeem the same voucher and includes their preferred scenario option.
  6. CCS passes request to Voucher Management, this time with scenario selection information.
  7. Voucher Management performs redeem and updates balance values.
  8. CCS notifies subscriber of success, and announces updated balance values by using the Send Short Message Notification node.
    Note: If you recharge successfully on a UBE domain which has real-time wallet notifications configured for balance changes, CCS will send a notification for the balance change as well as the notification sent from the Send Short Message Notification node. For more information about the real-time wallet notifications, see Real-Time Wallet Notifications.
Note: If there is only one scenario, then steps three to five can be skipped.
The voucher redemption process can be handled at a fine-grained level by using the Voucher Reserve and the Voucher Commit Revoke nodes. The Voucher Commit Revoke node takes the voucher identification information and commits or revokes a pre-existing voucher reservation that has been created via traversal of the Voucher Reserve node. When voucher commit is performed following a voucher reservation, then the voucher state is moved to used, and no wallet updates are done.
Node exits – Voucher Commit Revoke
This node has one entry and four exits.
1 Success The reservation that was opened on the voucher is removed. Where the node is set to be a revoke action, the state of the voucher is unchanged and the voucher can be reserved again. Otherwise, the node has performed a Commit action and the voucher state is set to Redeemed and the voucher finalized.
2 Unsupported
The Voucher Commit or Revoke action has not been successful for any of the following reasons:
  • Insufficient capabilities
  • Failed to validate configuration
3 Abandon
  • Call processing not allowed
  • Possible interface timeout
4 Failure
The Voucher Commit or Revoke action has not been successful and a specific failure is identified. If the state of the voucher was able to be retrieved, then it is returned. Otherwise, the state is set to Unknown. A failure code and failure text are set.
2001 - Voucher batch state not active
2002 - Invalid voucher value
2003 - Invalid serial number
2004 - Voucher not found
2005 - Reservation not found
3000 - System error
4000 - Service provider not found
4001 - Invalid voucher number length
4006 - Missing subscriber identifier
4007 - Missing voucher number
Configuring the node – Voucher Commit Revoke
  1. Select the source data for the recharged subscriber.
  2. Select the source data for the human readable voucher number (HRN)
  3. If you need to overide the service provider, check the Override provider checkbox. The result is that the next section becomes available to select the source data for the alternative service provider.
  4. If this is a revoke action (rather than a commit) then check the Revoke checkbox.
  5. Select the profile where the Voucher State shall get stored to.
  6. Select the profile where the Voucher Result Code shall get stored to.
  7. Select the profile where the Voucher Result Text shall get stored to.
  8. Click Save.
Result Codes– Voucher Commit Revoke
Success branch is always ResultCode of 0 and ResultText of Success.
The following tables describes the failure codes:
FOX (internal only) Enumerator (internal only) Code Description
NACK_VoucherBatchUnavailable failureUnavailable 2001 Voucher not found in batch
NACK_InvalidVoucherDigits failureInvalidVoucher 2002 Invalid voucher number
NACK_VoucherAuthFailed failureInvalidSerial 2003 Invalid serial number
NACK_UnknownVoucher failureUnknown 2004 Voucher not found
NACK_VoucherNoReservation failureNoReservation 2005 Reservation not found
NACK_SystemFailure (or other) systemError 3000 System error
N/A N/A 4000 Service provider not found
N/A N/A 4001 Invalid voucher number length
N/A N/A 4006 Missing subscriber identifier
N/A N/A 4007 Missing voucher number
The following tables lists the deprecated codes:
failed 2000 General error
communicationError 3001 Communication error
failureCreated 2011 Batch not active
Macro failures: - Do not continue processing control plan.
  • (ERROR) Unexpected message type received (x2)
  • (ERROR) Failed to retrieve nodePtr
  • (ERROR) Invalid action status
Unsupported Branch - Not able to start processing, or unable to store profile
  • Failed to validate config (various)
  • Failed to set voucher balances in profile (x num fields)
  • Failed to store in profile (x5)
Abandon Branch
  • Call processing not allowed (x2)
  • Possible interface timeout (x6)
SOAP Failure result codes:
  • 0 "",
  • 1 "No such subscriber",
  • 2 "No such service",
  • 3 "Missing parameter",
  • 4 "Mis-typed parameter",
  • 5 "System Error",
  • 6 "Operation does not exist",
  • 7 "Operation not available",
  • 8 "Invalid transaction type",
  • 9 "Transaction not found",
  • 10 "No response from ACS",
  • 11 "Too many transactions",
  • 12 "Duplicate tranaction",
  • 13 "Invalid SOAP or service key not found",
  • 14 "Operation disabled",
  • 15 "Service loader balance type mapping error",
  • 16 "Service loader profile data error",
  • 17 "Service loader balance conversion error",
  • 18 "Service loader balance type not present",
Voucher Recharge
The Voucher Recharge node allows the caller to recharge their account using a voucher number, and to change their product type if required.
Note: When a voucher recharge attempt is made, the voucher's redeemed date is set to the current system date and time. The redeemed field for the voucher is set to one of:
  • True for successful attempts
  • False for unsuccessful attempts
This allows you to check if a voucher has been redeemed, or if a failed redeem attempt has been made.
Node exits – Voucher Recharge
This node has one entry and ten exits. The number of exits cannot be changed.
1 Success The voucher recharge has been successful and the caller's account has been credited.
3 Unsupported
The recharge has not been successful for any of the following reasons:
  • The Domain being used does not support this feature node
  • The number of menu retries has exceeded the limit
  • Information routing error
  • Timeout
  • Recharge Interface Not Found
  • Interface can not be used to recharge this voucher
  • Any other failure or error condition not listed for the other exits.
5 Abandon
This exit is used for many error conditions, including the following:
  • Customer/Retailer (to be recharged/credited) was not found
  • Customer/Retailer (to be recharged/credited) is not initialized
  • Customer/Retailer (to be recharged/credited) is deactivated
  • Customer/Retailer (to be recharged/credited) is suspended on IN
  • Customer/Retailer (to be recharged/credited) is suspended on Voucher Management
  • Limit of number of recharge is reached
  • Bad customer state
  • Product is not rechargeable
  • Invalid error code for a recharge subscriber update
  • No recharge part for this subscriber
  • One of balances involved in recharge is deactivated
  • One of balances involved in recharge is missing
  • Subscriber is locked from Voucher Management
  • Customer/Retailer credit is too large
  • The value minimum of the transaction is not reached
  • The value maximum of the transaction value reached
  • Recharge value is out of range
  • Credit out of range
  • Voucher not found
7 Frozen The caller's account status is Frozen, and they are therefore forbidden to use a voucher recharge.
8 Need Scenario Info This voucher has several potential ways to be recharged. This exit is used to find out which one to use. Must always exit to a Select Voucher Scenario node.
9 Voucher Invalid
The voucher number is invalid, for any of the following reasons:
  • Not enough digits in the source buffer
  • Unexisting recharge properties
  • Voucher Bad Found
  • Tariff Plan Not Exist For This Pack
  • Bad Voucher Type
  • Voucher is in pending state
  • Voucher is in frozen state
  • Voucher is blocked
  • Voucher has expired
  • Voucher is disabled
  • Voucher type is not applicable
  • Voucher has a bad brand Id
10 Already Redeemed The voucher number has already been redeemed.
Configuring the node – Voucher Recharge
  1. Select the Source for the voucher recharge. Either of:
    • Interactive, or
    • Stored.
    Result: The related source fields for the selected option become available.
  2. Select the Get voucher number options:
    • If Interactive: Select from the announcement drop down lists the announcement to play to prompt the subscriber for the voucher number.
    • If Stored: Select from the profile Data Type, Location and Field drop down lists containing the voucher number.
  3. If Interactive: Select the from the Announcement drop down lists the various announcements to play to the subscriber:
    • Thankyou announcement to play when the redeem process is concluded.
    • Account Locked announcement to play when the subscriber either is currently frozen, or has become frozen as a result of the voucher redeem.
    • Invalid Attempt - Created announcement to play when the voucher being redeemed has been created, but is not yet available for redemption.
    • Invalid Attempt - Used announcement to play when the voucher being redeemed has already been redeemed.
    • Invalid Attempt - Unavailable announcement to play when the voucher being redeemed is no longer available (i.e. has been stopped by the telco, or expired).
    • Invalid Attempt - Invalid Number announcement to play when the subscriber has provided an incorrect voucher number.
    • Maximum Iterations Reached announcement to play when the number of retries a subscriber is allowed has been reached.
    • Redeem System Error : Please try later announcement to play when the voucher redeem system is unavailable.
    • Limited Product Type Failure announcement to play when the subscriber product type is invalid for, or would become invalid due to, the voucher recharge.
    Note: If Stored selected, these options are all grayed out.
  4. If the voucher redeem scenario is known, tick the Have scenario selection check box.
    Result: The Selected Scenario profile fields become available.
  5. If available, from the Selected ScenarioData Type, Location and Field drop down lists, select the profile containing the scenario number to use for the voucher redemption.
  6. From the Scenario DataData Type, Location and Field drop down lists, select the profile containing the currently available scenarios for voucher redemption.
  7. Click Save.
    Note: This will be greyed out until all the required fields have been completed.
Further reference:
Voucher Redeemed
Warning: This feature node has now been deprecated and should no longer be used. This feature node will still function in existing control plans. For new control plans please use the Voucher Recharge feature node.
The Voucher Redeemed feature node retrieves a voucher number from the specified location.
The number of redeem attempts is only used to determine how the feature node should branch.
The number of attempts will be recorded each time the control plan passes through the feature node. Each time the control plan runs the feature node, the feature node will attempt only one redemption.
Node exits – Voucher Redeemed
The node has one entry and ten exits. The number of exits cannot be changed.
Note: These exit descriptions are specific to the responses received from an Oracle VWS. For specific information about how responses from other billing engines map to these exits, see the technical guide for the interface for billing engine being used.
1 Success Voucher redeemed and subscriber account updated successfully.
2 Success Product Swap Voucher redeemed and subscriber product type swapped.
3 Restricted Product Voucher has a restricted product redemption list.
4 Unknown Wallet Wallet has been deleted, not replicated correctly or some other wallet error.
5 Invalid wallet State Subscriber account has been frozen.
6 Invalid Serial Voucher number is invalid.
7 Already Redeemed The voucher number has already been redeemed.
8 Voucher Invalid The voucher number is invalid (includes not enough digits in the source buffer).
9 Retry Exceeded The number of redeem attempts has been exceeded (as defined by the Redeem Attempts node parameter).
10 Unsupported Either error / failure or that the Domain being used does not support this feature node.
Configuration fields – Voucher Redeemed
This table describes the function of each field in the Configure Voucher Redeemed node screen.
Field Description
Number Source The ACS number buffer containing the voucher number.
Redeem Attempts Maximum number of voucher number attempts before taking the retry exceed branch.
Number of Digits The number of digits to remove from the front of the voucher number prior to redemption.
Configuring the node – Voucher Redeemed
  1. Select the ACS buffer that contains the voucher number digits from the Number Source drop down list.
  2. Type the maximum number of voucher number entry retries in the Redeem Attempts field.
  3. Type the number of digits to remove from the front of the voucher digits before attempting to redeem in the Number of Digits field.
  4. Click Save.
Voucher Reservation
The voucher reservation process can be handled at a fine-grained level by using the Voucher Reserve node. The Voucher Reserve node takes the voucher identification information, retrieves the set of information that is required to make wallet updates, and sets aside a voucher reservation to wait for a commit or revoke action to occur. This prevents the voucher from being used again until either the commit or revoke action is received or a timeout occurs and the voucher is either indefinitely held, or committed or revoked automatically based on the configuration. A revoked voucher enables a voucher redemption to be attempted again.
Node exits – Voucher Reservation
1 Success A voucher reservation has been created and the information needed to be able to credit a caller's account has been retrieved.
2 Unsupported
The voucher reserve action has not been successful for any of the following reasons:
3 Abandon
4 Failure
The voucher reserve action has not been successful and a specific failure is identified. If the state of the voucher was able to be retrieved, then it is returned. Otherwise, the state is set to Unknown. A failure code and failure text are set.
2007 - Limited voucher product match
2008 - Scenario required
2009 - Voucher already redeemed
2010 - Voucher already reserved
2012 - Voucher in frozen state
2013 - Voucher in deleted state
3000 - System error
4002 - Incorrect voucher balances tag count
4003 - Incorrect voucher balances tag type
4004 - No voucher balances
4005 - Invalid scenario number
Configuring the node – Voucher Reservation
  1. Select the source for the recharged subscriber.
  2. Select the source data for the human readable voucher number (HRN).
  3. If you need to override the service provider, select the Override provider checkbox.
    Result: The next section becomes available to select the source data for the alternative service provider.
  4. If you need to provide a scenario number, select the Have scenario checkbox.
    Result: The next section becomes available to select the source data for a scenario number.
  5. Select the profile where the per balance Voucher Info shall get stored to.
  6. Select the profile where the Voucher State shall get stored to.
  7. Select the profile where the Voucher Serial Number shall get stored to.
  8. Select the profile where the Voucher Result Code shall get stored to.
  9. Select the profile where the Voucher Result Text shall get stored to.
  10. Select the profile where the Voucher Recharge Classification shall get stored to.
  11. Click Save.
Result Codes – Voucher Reservation
NACK_AlreadyReserved failureReserved 2010 Voucher already reserved
NACK_AlreadyRedeemed failureUsed 2009 Voucher already redeemed
NACK_VoucherBatchUnavailable failureUnavailable 2001 Voucher batch state not active
NACK_BadVoucherValue,NACK_InvalidVoucherDigits failureInvalidVoucherValue 2006 Invalid voucher value
NACK_VoucherCreated failureVoucherCreated 2011 Voucher in created state
NACK_VoucherFrozen failureVoucherFrozen 2012 Voucher in frozen state
NACK_VoucherDeleted failureVoucherDeleted 2013 Voucher in deleted state
NACK_LimitedVoucher failureLimitedVoucher 2007 Limited voucher product match
NACK_BadScenario failureScenarioRequired 2008 Scenario required
NACK_UnknownVoucher,NACK_AmbiguousVoucher failureUnknown 2004 Voucher not found
N/A N/A 4002 Incorrect voucher balances tag count
N/A N/A 4003 Incorrect voucher balances tag type
N/A N/A 4004 No voucher balances
N/A N/A 4005 Invalid scenario number
N/A N/A 4006 Missing subscriber identifier (ERROR)
N/A N/A 4007 Missing voucher number (ERROR)
Abandon Branch
  • 0 "",
  • 5 "System Error",
The Voucher Type Balance Information node retrieves the balances associated with a Voucher Type and stores them in a selected profile.
Node exits – Voucher Type Balance Information
This node has one entry and two exits. The number of exits cannot be changed.
1 Success The voucher type balance information has been successfully stored in a profile.
2 Error The voucher type could not be found or the balance information could not be extracted.
Configuration fields – Voucher Type Balance Information
This table describes the function of each field in the Configure Voucher Type Balance Information node screen.
Field Description
Voucher Type Source options Controls what the voucher source will be:
Select Voucher Type From area
Either:
  • Specifies the profile to use when From Profile is selected, or
  • The voucher type that balance information will be retrieved for when Manual Definition is selected.
Voucher Scenario Source options Controls what the voucher scenario source will be:
Select Voucher Scenario From area
Either:
  • The default voucher scenario will be used when None is selected, or
  • Specifies the profile to use when From Profile is selected.
Store Balance In area Specifies the profile to use to store the balance information.
Configuring the node – Voucher Type Balance Information
Note: For more information on the Voucher Type Balance Information node configuration fields see Configuration fields – Voucher Type Balance Information.
  1. In the Voucher Type Source area select either:
    • From Profile, or
    • Manual Definition.
  2. Select the Voucher Type for which balance information will be retrieved. If you selected:
    • From Profile, select from the profile Data Type, Location and Field drop down lists that contains the Voucher Type you want, or
    • Manual Definition, select the voucher type from the Voucher Type drop down list.
  3. In the Voucher Scenario Source area select either:
    • None, or
    • From Profile.
  4. If you selected From Profile, in the Select Voucher Scenario From area, select the profile Data Type, Location and Field drop down lists that contains the Voucher Scenario you want.
  5. In the Store Balances In area select the profile Data Type, Location and Field drop down lists where the balance information will be stored.
Further reference:
The Voucher Type Branching feature node branches based on the voucher type of the voucher retrieved from one of:
  • The context within the control plan. For example, this would be the redeemed voucher if the Voucher Type Branching feature node is placed immediately after a Voucher Recharge feature node
  • A profile field containing the voucher number
This feature node has three default branches. You can add up to twenty additional branches that you use to specify the voucher type branching rules.
The fast key for the Voucher Type Branching feature node is VTYB. You can use this value to search for the Voucher Type Branching feature node in your control plans.
Node exits – Voucher Type Branching
The Voucher Type Branching feature node has 3 to 23 exits. You can configure the number of exits within this range as required, using the Edit Node Exits option on the shortcut menu. See Editing node exits.
1 Not found The voucher does not exist.
2 Unsupported/Error Indicates an internal or general system error.
3 Default The voucher type does not correspond to a configured branch.
4 to 23 Matched The voucher type matches one of the branches.
Configuration fields – Voucher Type Branching
This table describes the function of each field.
Field Description
Context Select to branch based on the voucher type of the voucher retrieved from the control plan context.
Profile Select to branch based on the voucher type of the voucher retrieved from the specified profile location.
Voucher Number Data Type Specifies the data type of the voucher number profile block.
Voucher Number Location Specifies the profile block that contains the voucher number profile field.
Voucher Number Field Specifies the profile field where the voucher number is stored. Must be a STRING, NSTRING, or LNSTRING profile field type.
All Voucher Types Lists all the voucher types defined in the Voucher Management > Voucher Type screens for the current service provider.
Branch Voucher Types Displays the branch number being configured and the associated voucher types.
Not Found Provides the branch to take when the voucher number from the profile location does not exist.
Unsupported/Error Provides the branch to take when an internal error occurs.
Default Branch Provides the branch to take when the voucher type of the retrieved voucher is not included in any of the branch voucher type rules.
Configuring the node – Voucher Type Branching
Follow these steps to configure the Voucher Type Branching feature node.
  1. Configure the required number of additional exits. The maximum number of additional exits is 20. See Editing node exits.
  2. In the Configure Voucher Type Branching window, select the source for the voucher number on which to base branching. Select:
    • Context to branch based on the voucher type of the voucher number in the control plan context.
    • Profile to branch based on the voucher type of the voucher number in the specified profile field.
  3. If you selected Profile in step 2, select the profile field location where the voucher number is stored from the Voucher Number Data Type, Voucher Number Location, and Voucher Number Field lists.
  4. In the Branch Voucher Types area, use the Number up and down arrows to select the exit branch to configure.
    The voucher types configured for the selected branch appear in the panel below.
  5. Add the required voucher types to the selected branch by selecting the voucher types in the All Voucher Types area, and clicking Move to branch >>.
  6. To remove a voucher type from the selected branch; for example if you want to make the voucher type available to another branch, select the voucher type and then click << Replace in set.
  7. Repeat steps 4 to 6 for each branch.
  8. Click Save.
The Voucher Type Recharge node invokes the voucher type recharge billing engine action using the configured name of the voucher type. See CCS User's Guide for details on configuring voucher type recharges.
Node exits – Voucher Type Recharge
1 Success The billing engine returned a successful voucher type recharge indication.
2 Error The billing engine returned a failed voucher type recharge indication.
3 Unsupported The voucher type recharge capability is not supported.
Configuring the node – Voucher Type Recharge
Follow these steps to configure the Voucher Type Recharge feature node.
  1. In the Voucher Type Source area select one of:
    • From Profile
    • Manual Definition
  2. Select the voucher type to be recharged. If you selected:
    • From Profile, select the profile field that holds the voucher type from the Data Type, Location and Field lists.
    • Manual Definition, select the name of the voucher type to recharge from the Voucher Type list.
    Note: The feature node always recharges vouchers against the default scenario for the voucher type.
  3. Click Save.
For more information about profile blocks (data type, location, and field) and how to use them, see Profile Blocks and Fields.
For more information about profile field configuration, see the discussion on profile tag configuration in NCC Advanced Control Services User's Guide.
