19 Subscriber Profile Manager Screen Layout
This chapter explains how to configure the screen layout for the Prepaid Charging Edit Subscriber screen and for the panels in the CCP Dashboard screen using Oracle Communications Network Charging and Control Subscriber Profile Manager.
The SPM provides the facility to define which fields will be displayed, and how they will be laid out in the screen. To configure a new panel you need to:
  1. Assign groups to the node on a tab.
  2. Configure the fields in the group which will be used on the screen
  3. Configure the option which the fields will be displayed on
Details of these tasks are covered in this chapter.
This chapter contains the following topics.
Assigning Groups to Config
Field Type Definition and Layout
Field Type
Layout Details
Screen Preview
This topic describes how to:
Config tabs where you can assign groups
You can assign groups, or edit assignment of groups, on the following tabs on the Subscriber Profile Manager screen.
  • Subscriber Config - to define the screen layout of the Prepaid Charging Edit Subscriber screen. For specific details, see Subscriber Panels.
  • Product Type Config - to define the screen layout for profile tag fields in the Prepaid Charging Edit Product Type screen. For specific details, see Product Type Panels.
  • Sub-group Configuration. For specific details, see Sub-Groups.
Note: Groups are configured on the Group Configuration tab of the Subscriber Profile Manager screen.
Assigning a group to a node
Follow these steps to assign a group to a node in a Config tree.
  1. On the Subscriber Profile Manager screen, select the Service Provider and Product Type from the drop down lists.
  2. Select the tab on which to assign a group. Tabs are listed in the Config tabs where you can assign groups topic.
  3. Select the folder on the config tree on the left-hand side of the screen, for example:
    .Description of spmsubscriberprofilemanagersubscriberconfigsubscriberpanels-nodeselected-ncc4-4.jpg follows
    Description of the illustration spmsubscriberprofilemanagersubscriberconfigsubscriberpanels-nodeselected-ncc4-4.jpg
    Result: The grid will display the groups which have been configured for the Config tree.
  4. Click New.
    Result: You see the Assign Group Dialog screen.
  5. From the Group Name drop down list, select the group you want to assign to the Config tree.
    Note: This field is populated with the relevant Group Type defined on the Group Configuration tab.
  6. In the Group Order field type the order number for the group. This determines the position of the group on the node in the Config tree and in the screen you are configuring.
    Note: Groups with the same order number are ordered alphabetically.
  7. Click Save.
Editing a group assignment
Follow these steps to edit the assignment of a group to a node in a Config tree.
  1. In the Subscriber Profile Manager screen, select the Service Provider and Product Type you require from the drop down lists.
  3. Select the folder on the config tree on the left-hand side of the screen.
  4. Select the group to change in the grid.
  5. Click Edit.
  6. If required, select a different Group Name from the drop down list.
  7. If required, in the Group Order field edit the order number for the group. This determines the position of the group on the node in the Subscriber Config tree and in the Edit Subscriber screen.
  8. Click Save.
Deleting a group
Follow these steps to delete a group from a Config tree.
Warning: You cannot delete a group that has had fields added to it. Any fields included in the group must be removed from the group before you attempt to delete it.
  2. Select the tab on which the assigned group to delete is located. Tabs are listed in the Config tabs where you can assign groups topic.
  4. Select the group to delete in the grid.
  5. Click Delete.
    Result: You see the Delete Confirmation prompt.
  6. Click OK.
The Subscriber Profile Manager allows you to define which fields will be displayed on some Prepaid Charging and CCP Dashboard screens. You can perform the following actions:
Config tabs where you can define fields for groups
You can add fields to groups, or edit fields from groups, on the following tabs on the Subscriber Profile Manager screen.
  • Subscriber Config - to define the screen layout of the Prepaid Charging Edit Subscriber screen. For specific details, see Subscriber Group Field Configuration.
  • Product Type Config - to define the screen layout for profile tag fields in the Prepaid Charging Edit Product Type screen. For specific details, see Product Type Field Configuration.
  • CCP Dashboard Config - to define the screen layout for the Quick View in the CCP Dashboard. For specific details, see Quick View.
  • Sub-group Configuration. For specific details, see Sub-Group Field Configuration.
Adding a new field for group
Follow these steps to add a field for a group.
Tip: You can create a basic layout for a field by specifying values only in the Field Type, Display Name, and Grid Position fields.
  1. In the Subscriber Profile Manager screen, select the required Service Provider and Product Type from the drop down lists.
  2. Select the tab where the group to add a field to is configured. Tabs are listed in the Config tabs where you can define fields for groups topic.
  3. In the panel on the left, select the required group.
    Tip: If the group is not currently visible, double click on its node.
  4. Click New.
    Result: You see the New Field for Group screen. The name of the currently selected group is appended to the screen title bar.
    For an example screen, see New Field for Group screen.
  5. Select the Field Type from the drop down box.
    Result: You see the field configuration options for the selected field type in the panel below.
  6. Specify the Field Type details. For more information, see Field Type fields.
  7. Specify the Layout Details for the field. This will determine where the field will appear on the screen.
    For more information on the layout details options, refer to Layout Details.
  8. Click Save.
Editing a field from a group
Follow these steps to edit a field included in a group in a Config tree.
  2. Select the tab where the group to edit a field from is configured. The relevant tabs are:
    • Subscriber Config
  4. Select the field on the grid and click Edit.
    Result: You see the Editing Field from Group screen. The name of the currently selected group is appended to the screen name.
    For an example screen, see Editing Field from Group screen.
  5. Edit the fields to reflect the changes you need to make. For more information, see:
  6. Click Save.
Field Type
Each field used on a screen has a Field Type. The field type defines the features of the field, such as:
  • What actions a user can take with the field
  • Some elements of the field's appearance (such as whether it is a data entry field or a button)
Field Type fields
This table describes the fields in the field type area of the New/Edit Field for Group screen.
Note: Most of these fields will only be displayed for a specific Field Type.
Field Description
Field Type
Defines the functions and appearance of the field.
For more information about the different types of field which are available, see Field Types.
BPL
The BPL task to attach to this field. This drop down list is populated by records from the Task Management screen.
Note: Only available if the Field Type is Business Process Logic.
Display Name
This is the label that will appear next to the field when the Auto Create Label check box is ticked. It is also used as part of the name of the access permission for this field. Access permissions are controlled in the SMS User Management screen. For more information about access permissions, see NCCService Management System User's Guide.
Note: This field is required for all field types except Business Process Logic.
Profile Tag Name
The profile tag this field will provide access to. The list of available profile tags is populated by records configured in the ACS Configuration screen. For more information about profile tags, see Profile Tag Fields.
Note: Only available if the Field Type value is Profile Tag Field.
Date Type
Defines whether or not a profile tag date field includes a time element.
Note: Only available if the Field Type value is Profile Tag Field, and the Profile Tag Name displays a date type profile field.
Field
This will be either a database field or a search key field depending on the selected field type.
Note: Only available if the Field Type value is Database Field or Search Key Field.
Type
A predefined list of display options for the field. This information is used to define how to display a field in the Preview screen.
Custom Type
A predefined group of fields.
Note: Only available if the Field Type is Custom Field or Custom Profile Field.
Sub-Group
A group of fields included in a Sub-Group on the Subscriber Config tree. This drop down list is populated by sub-group records from the Group Configuration tab.
Note: Only available if the Field Type value is Sub-Group.
Periodic Charge
The periodic charge to associate with this field. This list of available periodic charges is populated by the records on the Periodic Charge tab on the Wallet Management screen. For more information about periodic charges, see NCCCharging Control Services User's Guide.
Note: Only available if the Field Type value is Periodic Charge Field.
Show Date Fields
Whether or not the three date fields should be displayed as part of this field.
Promotion
The promotions to associate with this field. The list is populated by the promotions defined in the Promotion Manager screen for the current service provider.
Note: Only available in the Field Type is Promotion Info Field.
Show Expiry Date
Whether or not to display the promotion expiry date as part of this field.
Note: Only available if the Field Type is Promotion Info Field.
Field Types
This table describes the function of the available fields for the different Field Types.
Field Type Description Screen
Provides a button which executes a BPL task.
For more information about BPL task configuration, see NCC Charging Control Services User's Guide.
CCP Dashboard (Common Tasks option)
Edit Subscriber
Profile Tag
Profile tags are flexible data fields which can be defined for subscribers or product types. Profile tags have different types depending on the type of data they store.
For more information about profile tag configuration, see NCC Advanced Control Services User's Guide.
Edit Subscriber
Edit Product Type
Database Field A field which is specifically related to CCS functionality. These are usually predefined Profile Tags.
CCP Dashboard (Quick View and Vouchers options)
Edit Subscriber
Search Key Field A field on the CCP Dashboard which is used to search the SMF database.
CCP Dashboard
(Quick View option)
Sub-Group A group of fields of other types.
CCP Dashboard (Quick View option)
Edit Subscriber
A field which displays the status of a subscriber's subscription to a periodic charge.
Notes:
  • To change the status of a subscriber's periodic charge subscription, you must use a BPL task which uses a Periodic Charge Subscription node.
  • This option is only available if the periodic charge license is activated.
For more information about periodic charges and periodic charge groups, see NCC Charging Control Services User's Guide.
Edit Subscriber
A field which displays a predefined list of promotion data including the promotion:
  • name
  • status
  • tracker balance value, and
  • limited liability balance and status information.
For more information about promotions, see the NCC Promotion Manager User's Guide.
Edit Subscriber
Custom Type A predefined list of special fields.
Edit Subscriber
Custom Profile Field A predefined list of profile fields. Edit Product Type
Wallet Life Cycle Field
Provides the Display Name of a Wallet Life Cycle Period.
For more information about Wallet Life Cycle, see NCC Charging Control Services User's Guide.
Edit Subscriber
Note: The availability of Field Types will depend on the screen the group is defined for. For example, the Vouchers group on the CCP Dashboard can only contain database fields.
Layout Details
You specify how a field will be displayed in the Layout Details panel in the New Field for Group and Edit Field From Group screens. For each field you can define its:
  • Grid position
  • External padding
  • Auto resize option
  • Anchor position
  • Preferred size
  • Label settings
Grid position
The SPM uses a grid to determine where a field is located on the screen. The grid position for a field defines which column and row it will be displayed on. Care must be taken when specifying the grid position to ensure fields do not overlap and that enough space is given to group field types. For example, you need to allow 5 columns to display the fields in the Wallet Information group.
Note: Rows and columns are not uniformly sized. Row height and column width is allocated dynamically and depends on how all the fields appearing in the screen have been configured.
Grid position fields
This table describes the function of each field.
Field Description
Column
The column number defines which column the field will be displayed in. Valid column numbers are in the range 0 to 99, where '0' is the column furthest to the left of the screen.
Tips:
  • The width of each column is allocated dynamically and depends on the length of the longest item to appear in the column.
  • Fields with the same column number will appear in a vertical line.
Row
Defines which row the field will be displayed on. Valid row numbers are in the range 0 to 99.
Tip: It is a good idea to leave a gap between row numbers so that you can easily change a field's vertical position. This is especially important if you want to insert a new field or swap two fields around.
Width
Defines the number of columns required to display the field.
Note: The field label will use one column, therefore you must set the width to more than one if the Auto Create Label check box is ticked.
Height Defines the number of rows required to display the field.
External padding
You use the external padding fields to define the minimum amount of space between the field and the border of its display area. This helps to ensure that each of the fields displayed in the screen can be clearly identified.
Notes:
  • Values must be specified in pixels.
  • The display area is the whole cell in the grid.
Auto resize
You use the auto resize options to resize the field to fit the available display area.
Auto resize fields
Field Description
None The displayed field is not resized.
Horizontal The displayed field is stretched horizontally to fill the width of its display area.
Vertical The displayed field is stretched vertically to fill the height of its display area.
Both The displayed field is stretched horizontally and vertically to fill the available space.
Anchor position
The option you select for the Anchor position defines where the field will be placed within its display area. This feature is useful when the field you want to display is smaller than the display area specified for it.
Preferred size
You can override the default size used to display a field by setting a preferred size for it.
Note: The values specified for the preferred size may be ignored depending on which auto resizing option is selected.
Preferred size fields
Field Description
Height
Sets the display height for the field. Valid values are in the range 0 to 999 pixels.
Note: This value will be ignored when the Auto Resize option is set to Vertical or Both.
Width
Sets the display width for the field. Valid values are in the range 0 to 999 pixels.
Note: This value will be ignored when the Auto Resize option is set to Horizontal or Both.
Use Default Use the default size to display the field. The Height and Width options will be ignored.
Label options
You can display a label next to each field in the screen. The Label options let you define the type, color and size of the text used for the label.
Tip: BPLs and Custom fields (excluding Label/Separator fields) do not normally required a label.
Label fields
Field Description
Auto Create Label
When selected, the Display Name specified for the field will be used as a label.
Note: If selected you will need to allow an additional column for the label when specifying the Grid Position Width.
Text Type Sets the type of the text used for the label.
Text Size Sets the size of the text used for the label.
Text Colour Displays text in the selected color for the label.
Screen Preview
You can preview the screen layout for a group of fields. This will help you to see what adjustments are needed to improve the screen layout.
Note: The preview is only an approximation of the screen layout which may appear slightly different on the real screen.
Previewing a subscriber screen
Follow these steps to preview how a group of fields will look in the Edit Subscriber screen.
Tip: You can display the Preview panel while making changes to the screen layout. Then you can refresh it as required by clicking Refresh.
  1. In the Subscriber Profile Manager screen, select the Service Provider from the drop down box.
  2. On the Subscriber Config tab, select the Product Type from the drop down list.
  3. In the panel on the left select the group that you want to preview.
    Tip: Double click on the node to see the list of groups assigned to the node, if these are not currently in view.
  4. Click Preview.
    Result: You see the Previewing Panel for the selected group.
  5. When you have finished previewing, click Close.
