3 Using Debug Tool
The Debug Tool provides third-party troubleshooting tools for debugging the runtime issues for the lab and production environment. The following tools are available for OCNWDAF debugging:
  • tcpdump
  • ip
  • netstat
  • curl
  • ping
  • nmap
  • dig
Preconfiguration Steps
This section explains the preconfiguration steps for using the debug tool:
  1. Configuration in CNE
    The following configurations must be performed in the Bastion Host.
    PodSecurityPolicy (PSP) Creation
    1. Log in to the Bastion Host.
    2. Create a new PSP by running the following command from the bastion host. The parameters readOnlyRootFileSystem, allowPrivilegeEscalation, allowedCapabilities are required by debug container.
    Other parameters are mandatory for PSP creation and can be customized as per the CNE environment. Default values are recommended.
    $ kubectl apply -f - <<EOF
    apiVersion: policy/v1beta1
    kind: PodSecurityPolicy
    metadata:
    spec:
      readOnlyRootFilesystem: false
      allowPrivilegeEscalation: true
      allowedCapabilities:
      - NET_ADMIN
      - NET_RAW
      fsGroup:
        ranges:
        - max: 65535
          min: 1
        rule: MustRunAs
      runAsUser:
        rule: MustRunAsNonRoot
      seLinux:
        rule: RunAsAny
      supplementalGroups:
        rule: RunAsAny
      volumes:
      - configMap
      - downwardAPI
      - emptyDir
      - persistentVolumeClaim
      - projected
      - secret
    EOF
    Role Creation
    Run the following command to create a role for the PSP:
    apiVersion: rbac.authorization.k8s.io/v1
    kind: Role
    metadata:
      namespace: cncc
    rules:
    - apiGroups:
      - policy
      resources:
      - podsecuritypolicies
      verbs:
      - use
      resourceNames:
      - debug-tool-psp
    EOF
    RoleBinding Creation
    Run the following command to attach the service account for your NF namespace with the role created for the tool PSP:
    kind: RoleBinding
    metadata:
      namespace: ocnef
    roleRef:
      apiGroup: rbac.authorization.k8s.io
      kind: Role
    subjects:
    - kind: Group
    EOF
  2. Configuration in NF specific Helm
    Following updates must be performed in custom_values.yaml file.
    1. Log in to the NF server.
    2. Open the custom_values file:
      $ vim <custom_values file>
    3. Under global configuration, add the following:
      # Allowed Values: DISABLED, ENABLED
      extraContainers: DISABLED
      extraContainersTpl: |
          - command:
              - /bin/sleep
              - infinity
            image: <image-name>:<image-tag>
            imagePullPolicy: Always
            resources:
              requests:
                ephemeral-storage: "2Gi"
                cpu: "0.5"
                memory: "1Gi"
              limits:
                ephemeral-storage: "4Gi"
                cpu: "1"
                memory: "2Gi"
            securityContext:
              capabilities:
                drop:
                - ALL
                add:
                - NET_RAW
                - NET_ADMIN
              runAsUser: <user>
      • Debug Tool Container comes up with the default user ID - 7000. If the operator wants to override this default value, it can be done using the `runAsUser` field, otherwise, the field can be skipped.
        Default value: uid=7000(debugtool) gid=7000(debugtool) groups=7000(debugtool)
      • In case you want to customize the container name, replace the `name` field in the above values.yaml with the following:
        name: {{ printf "%s-tools-%s" (include "getprefix" .) (include "getsuffix" .) | trunc 63 | trimPrefix "-" | trimSuffix "-"  }}
        This will ensure that the container name is prefixed and suffixed with the necessary values.
    4. Under service specific configurations for which debugging is required, add the following:
      # Allowed Values: DISABLED, ENABLED, USE_GLOBAL_VALUE
      extraContainers: USE_GLOBAL_VALUE
        • At the global level, extraContainers flag can be used to enable/disable injecting extra containers globally. This ensures that all the services that use this global value have extra containers enabled/disabled using a single flag.
        • At the service level, extraContainers flag determines whether to use the extra container configuration from the global level or enable/disable injecting extra containers for the specific service.
Run the Debug Tool
Following is the procedure to run Debug Tool.
Run the following command to enter Debug Tool Container:
  1. Run the following command to retrieve the POD details:
    $ kubectl get pods -n <k8s namespace>
  2. Run the following command to enter Debug Tool Container:
    $ kubectl exec -it <pod name> -c <debug_container name> -n <namespace> –- bash
  3. Run the debug tools:
    bash -4.2$ <debug_tools>
  4. Copy the output files from container to host:
    $ kubectl cp -c <debug_container name> <pod name>:<file location in container> -n <namespace> <destination location>
3.1 Debug Tool Configuration Parameters
Following are the parameters used to configure debug tool.
OCCNE Parameters
Table 3-1 OCCNE Parameters
Parameter Description
apiVersion APIVersion defines the version schema of this representation of an object.
kind Kind is a string value representing the REST resource this object represents.
metadata Standard object's metadata.
metadata.name Name must be unique within a namespace.
spec spec defines the policy enforced.
spec.readOnlyRootFilesystem Controls whether the containers run with a read-only root filesystem (that is, no writable layer).
spec.allowPrivilegeEscalation Gates whether or not a user is allowed to set the security context of a container to allowPrivilegeEscalation=true.
spec.allowedCapabilities Provides a list of capabilities that are allowed to be added to a container.
spec.fsGroup Controls the supplemental group applied to some volumes. RunAsAny allows any fsGroup ID to be specified.
spec.runAsUser Controls which user ID the containers are run with. RunAsAny allows any runAsUser to be specified.
spec.seLinux RunAsAny allows any seLinuxOptions to be specified.
spec.supplementalGroups Controls which group IDs containers add. RunAsAny allows any supplementalGroups to be specified.
spec.volumes Provides a list of allowed volume types. The allowable values correspond to the volume sources that are defined when creating a volume.
Role Creation Parameters
Table 3-2 Role Creation
apiVersion APIVersion defines the versioned schema of this representation of an object.
metadata.namespace Namespace defines the space within which each name must be unique.
rules Rules holds all the PolicyRules for this Role
apiGroups APIGroups is the name of the APIGroup that contains the resources.
rules.resources Resources is a list of resources this rule applies to.
rules.verbs Verbs is a list of Verbs that apply to ALL the ResourceKinds and AttributeRestrictions contained in this rule.
rules.resourceNames ResourceNames is an optional allowed list of names that the rule applies to.
Role Binding Creation
Table 3-3 Role Binding Creation
roleRef RoleRef can reference a Role in the current namespace or a ClusterRole in the global namespace.
roleRef.apiGroup APIGroup is the group for the resource being referenced
roleRef.kind Kind is the type of resource being referenced
roleRef.name Name is the name of resource being referenced
subjects Subjects holds references to the objects the role applies to.
subjects.kind Kind of object being referenced. Values defined by this API group are "User", "Group", and "ServiceAccount".
subjects.apiGroup APIGroup holds the API group of the referenced subject.
subjects.name Name of the object being referenced.
Table 3-4 Debug Tool Configuration Parameters
command String array used for container command.
image Docker image name
imagePullPolicy Image Pull Policy
name Name of the container
resources Compute Resources required by this container
resources.limits Limits describes the maximum amount of compute resources allowed
resources.requests Requests describes the minimum amount of compute resources required
resources.limits.cpu CPU limits
resources.limits.memory Memory limits
resources.limits.ephemeral-storage Ephemeral Storage limits
resources.requests.cpu CPU requests
resources.requests.memory Memory requests
resources.requests.ephemeral-storage Ephemeral Storage requests
securityContext Security options the container should run with.
securityContext.allowPrivilegeEscalation AllowPrivilegeEscalation controls whether a process can gain more privileges than its parent process. This directly controls if the no_new_privs flag will be set on the container process
securityContext.readOnlyRootFilesystem Whether this container has a read-only root filesystem. Default is false.
securityContext.capabilities The capabilities to add/drop when running containers. Defaults to the default set of capabilities granted by the container runtime.
securityContext.capabilities.drop Removed capabilities
securityContext.capabilities.add Added capabilities
securityContext.runAsUser The UID to run the entrypoint of the container process.
