6 About Model Correction
This chapter provides model correction information for the Oracle Communications Network Integrity Generic SNMP cartridge.
Model correction occurs when the SNMP information received through discovery from a generic device does not conform to the Information Model and therefore cannot be persisted as is within Network Integrity.
The Generic SNMP cartridge applies the following model corrections:
Multiple Equipment Occupying the Same Slot
In this scenario, multiple equipment report the same relative position within the context of the same parent. The Generic SNMP cartridge applies the algorithm detailed in "About the absRelativePosition Value". No hierarchical change is required.
Equipment Under Physical Port
For a discovered generic device hierarchy, such as the following:
Physical DeviceEquipment-ShelfEquipmentHolderEquipmentPhysical PortEquipment-Card
The Generic SNMP cartridge converts the PhysicalPort to an EquipmentHolder as follows:
Physical DevicesEquipment-ShelfEquipmentHolderEquipmentEquipmentHolderEquipment-Card
Physical Port Under EquipmentHolder
Physical DeviceEquipment-ShelfEquipmentHolderPhysical Port
The Generic SNMP cartridge inserts an artificial Equipment entity between the EquipmentHolder and the PhysicalPort as follows:
EquipmentHolder Under EquipmentHolder
Physical DeviceEquipment-ShelfEquipmentHolderEquipmentHolder
The Generic SNMP cartridge inserts an artificial Equipment entity between the two EquipmentHolders as follows:
Physical DeviceEquipment-ShelfEquipmentHolderEquipmentEquipmentHolder
EquipmentHolder Containing Multiple Equipment
The Generic SNMP cartridge inserts an artificial Equipment entity as the parent to the two equipments and each equipment will be put under a Equipment Holder as follows:
Physical DeviceEquipment-ShelfEquipmentHolderEquipmentEquipmentHolderEquipmentEquipmentHolderEquipment
EquipmentHolder Under Physical Port
Physical DeviceEquipment-ShelfEquipmentHolderEquipmentPhysical PortEquipmentHolder
The Generic SNMP cartridge converts the Physical Port to an Equipment as follows:
Physical DevicesEquipment-ShelfEquipmentHolderEquipmentEquipmentEquipmentHolder
Multiple Equipment Under Physical Port
Physical DeviceEquipment-ShelfEquipmentHolderEquipment-CardPhysical PortEquipmentEquipment
The Generic SNMP cartridge first converts the Physical Port to an EquipmentHolder, then inserts an artificial Equipment between the EquipmentHolder and the Equipment, The Equipment and each sub-equipment will then be put under a Equipment Holder as follows:
Physical Device
Equipment-Shelf
EquipmentHolder
Equipment-Card
EquipmentHolder
Equipment
EquipmentHolder
Equipment
EquipmentHolder
EquipmentNaming Pattern for Artificial Entities
Naming pattern for artificial entities are introduced through model corrections.
The following example shows the EquipmentHolder naming pattern.
EquipmentHolder-Artificial::entPhysicalParentRelPos
The following example shows the Equipment naming pattern.
Equipment-Artificial::entPhysicalParentRelPos
