1 SDH Discovery Cartridge
This chapter provides information on the Oracle Communications Network Integrity SDH Discovery cartridge.
Overview
This chapter provides an overview of the Oracle Communications Network Integrity SDH Discovery cartridge.
About the SDH Discovery Cartridge
The SDH Discovery cartridge supports modeling of SDH connectivities such as Topological Link, Trail, and Tunnel. It supports modeling the service by managing these connectivities.
The SDH Discovery cartridge provides the following:
- Read and collect the data from files using FTP.
- Modeling and stitching of connectivities detected from the file.
- Perform Incremental Discovery on the notifications in database.
This cartridge supports logical discovery of the aforementioned entities. The logical hierarchy has a container (Links, Trails and Tunnels) for the device (connected on one of the ends) under which the connectivities are modeled along with the termination points of the connectivity. For trails and tunnels, the Primary and Secondary (if present) paths are modeled under the Trail/Tunnel. This path upon expansion will display all the links/trails present.
For the SDH Service entity, the modeling begins at the Service level and follows with the Service Configuration ("Main Config Item"). This Configuration is further divided into multiple configurations such as EndPoint_List, Properties_List, and so on.
About Cartridge Dependencies
This section provides information on dependencies that the SDH Discovery cartridge has on other entities.
Run-Time Dependencies
This cartridge requires the Address_Handlers cartridge be deployed to Network Integrity.
Design-Time Dependencies
The SDH Discovery cartridge has the following dependencies:
- Address_Handlers
- NetworkIntegritySDK
- ora_uim_model
- Optical_Model
- SDH_Service_Model
- ora_ni_uim_sdh_optical
- ora_uim_network_device
- ora_ni_uim_device
Opening the Cartridge Files in Design Studio
To review and extend the SDH Discovery cartridge, you must first download the Oracle Communications SDH Discovery cartridge software from the Oracle software delivery web site:https://edelivery.oracle.com.
The software contains the SDH Discovery cartridge ZIP file, which has the following structure:
- \UIM_Cartridge_Projects\
- \Network_Integrity_Cartridge_Projects\
- SDH-Discovery-Cartridge-R7_4_0.b0.iar
See Design Studio Online Help and Oracle Communications Network Integrity Developer's Guide for information about opening files in Design Studio.
About the Cartridge Components
This section provides information about the components of the Oracle Communications Network Integrity SDH Discovery cartridge.
The SDH Discovery cartridge contains the following actions:
- Discover SDH Connectivity and Service
The Discover SDH Connectivity and Service action collects the required input files over FTP or SFTP and processes them to model the connectivities and service.. This action creates paths that are covered by the connectivities.
Modeling is performed on various files as follows:
- Topological Link - XML file <vendor>-<circle>-NMS-TL.xml comprising of TL information
- Trail - Multiple CSV files and <vendor>-<circle>-NMS-TL.xml file
- <vendor>-<circle>-Trail.csv : Contains the device endpoints information, layer rate, protection, and other details of the trail
- <vendor>-<circle>-Trail_LegHasTrail_Relation.csv : Contains mapping between legs and trails
- <vendor>-<circle>-Trail-leg.csv : Contains the leg IDs present in NMS
- <vendor>-<circle>-Trail-ProtectionSegment.csv : Contains the protection segment ID, nature of protection, and endpoint devices information
- <vendor>-<circle>-Trail-ProtectionSegmentHasLegsRelation.csv : Contains the mapping between legs and protection segments
- <vendor>-<circle>-Trail-TrailMultiplexed.csv : Contains the relation between trail and other links and trails
- <vendor>-<circle>-Trail-TrailProtectedByProtectionSegment.csv : Contains the mapping between trail and protection segment
- <vendor>-<circle>-Trail-VC.csv : Contains the VCAT size and channel information for each TL in the trail
- Tunnel - Multiple CSV files, <vendor>-<circle>-NMS-TL.xml and
<vendor>-<circle>-Trail.csv files
- <vendor>-<circle>-Tunnel.csv : Contains the device endpoints information, layer rate, protection, and other details of the tunnel
- <vendor>-<circle>-Tunnel-Attributes.csv : Contains the characteristics details of the tunnel
- <vendor>-<circle>-Tunnel_LegHasTrail_Relation.csv : Contains mapping between legs and tunnels
- <vendor>-<circle>-Tunnel-legs.csv : Contains the leg IDs present in NMS
- <vendor>-<circle>-Tunnel-ProtectionSegment.csv : Contains the protection segment ID, nature of protection, and the endpoint devices information
- <vendor>-<circle>-Tunnel-ProtectionSegmentHasLegsRelation.csv : Contains the mapping between legs and protection segments
- <vendor>-<circle>-Tunnel-TrailMultiplexed.csv : Contains the relation between tunnel and other trails
- <vendor>-<circle>-Tunnel-TrailProtectedByProtectionSegment.csv : Contains the mapping between tunnel and protection segment
- Service - Multiple CSV files
- <vendor>-<circle>-Service.csv : Contains the service related information
- <vendor>-<circle>-ServiceEndpoints.csv : Contains the endpoint related information of the service
- <vendor>-<circle>-ServiceProperties.csv : Contains the properties information of the service
- <vendor>-<circle>-ServiceSupportByTrailRelation.csv : Contains the trails and tunnels information managed by the service
Scan Parameter Group
The Discover SDH Connectivity and Service action contains the following scan parameter groups:
- SDH File Parameters
- SDH Device Parameters
- Incremental Discovery Parameters
Table 1-1 SDH File Parameters
| Parameter | Default Value | Mandatory | Description |
| Password | N/A | No | The password to connect to the remote location. |
| Port | N/A | No | The port used to connect to the remote server. The default value is 21 for FTP and 22 for SFTP. |
| Rename Suffix | processed | No | The suffix to add to the source file if the source file management characteristic has the value Rename. |
| Session Timeout (sec) | 60 | No | The time in seconds before an idle connection is timed out. The valid range is from 1 to 3600. |
| Source File Management | Rename | No | Select the action to take on source files when the file transfer is complete. The available values are: Delete, Rename, and Nothing. |
| Transfer Type | SFTP | No | Select how files should be transferred: FTP, SFTP, Local. |
| User Name | N/A | No | The user name to connect to the remote location. |
Table 1-2 SDH Device Parameters
| Circle Name | N/A | Yes | The circle name of the OSS. |
| Vendor Name | N/A | Yes | The vendor name |
| Topological Link Name | N/A | No | To model and persist only the Topological Links with the names given in this input field. |
| Topological Link | N/A | No | Select the check box to model and persist Topological Links in this scan. |
| Trail ID | N/A | No | To model and persist only the Trails with the IDs given in this input field. |
| Trail | N/A | No | Select this check box to model and persist Trails in this scan. |
| Tunnel ID | N/A | No | To model and persist only the Tunnels with the IDs given in this input field. |
| Tunnel | N/A | No | Select this check box to model and persist Tunnels in this scan. |
| Service ID | N/A | No | To model and persist only the Services with the IDs given in this input field. |
| Service | N/A | No | Select this check box to model and persist Services in this scan. |
| Device Name | N/A | No | To model and persist only those connectivities whose both A and Z termination point devices (comma separated) are provided. |
Table 1-3 Incremental Discovery Parameters
| Incremental Discovery | N/A | No | Select this check box to perform Incremental Discovery in this scan. |
| Topological Link | N/A | No | Select this check box to model and persist Topological Links in this scan. |
| NMS Notification Count | N/A | No | The maximum number of NMS notifications to be processed. |
Conditions and Processors
The Discover SDH Connectivity and Service action contains the following conditions:
- IsTrailDiscoveryEnabled Condition
- IsTunnelDiscoveryEnabled Condition
- IsServiceDiscoveryEnabled Condition
The Discover SDH Connectivity and Service action contains the following processors run in the following order:
- Incremental Discovery Initializer Processor
- Notification Name Collector Processor
- Topological Link XML File Collector Processor
- Topological Link XML Parser Processor
- CSV Collector Processor
- Trail CSV Parser Processor
- Tunnel CSV Parser Processor
- Service CSV Parser Processor
- Update Notifications for Connectivities and Service Processor
The condition checks if Trail discovery or incremental discovery is selected in the scan parameters.
The condition checks if Tunnel discovery or incremental discovery is selected in the scan parameters.
The condition checks if Service discovery or incremental discovery is selected in the scan parameters.
The Incremental Discovery Initializer processor creates the required data structures for incremental discovery: tlNames, trailNames, tunnelNames and serviceNames
The Notification Name Collector processor populates the data structures prepared from the Incremental Discovery Initializer processor. If the incremental discovery option is enabled, the NMS Notification Manager fetches the required notification and populates the requisite data structure.
The Topological Link XML File Collector processor collects the XML files required for Topological Link discovery and places them in the topologicalLinkXMLFileCollectorFileCollection collection.
The Topological Link XML Parser processor iterates topologicalLinkXMLFileCollectorFileCollection to read the XML file and model the topological link based on the data. This data is filtered according to the device names, Link names from the scan parameter group, and tlNames (if incremental discovery is selected). The links are grouped according to container Links. This continues only if the Topological Link option is selected in the SDH Device Parameters or Incremental Discovery scan parameter group. The TL information is captured in the nameToTLBeanMap collection.
The CSV Collector processor collects the CSV files required for Trails, Tunnels, or Services discovery and places it in the csvCollectorFileCollection collection.
The Trail CSV Parser processor iterates the csvCollectorFileCollection collection to read the required CSV files for modeling trails. This data is filtered according to the device names, Trail IDs from the scan parameter group, and trailNames (if incremental discovery is selected). The trails are grouped according to the container Trails. This continues only if the Trail option is selected in the SDH Device Parameters/Incremental Discovery scan parameter group.
The Tunnel CSV Parser processor iterates the csvCollectorFileCollection collection to read the required CSV files for modeling tunnels. This data is filtered according to the device names, Tunnel IDs from the scan parameter group, and tunnelNames (if incremental discovery is selected). The tunnels are grouped according to the container Tunnels. This continues only if the Tunnel option is selected in the SDH Device Parameters or Incremental Discovery scan parameter group.
The Service CSV Parser processor iterates the csvCollectorFileCollection collection to read the required CSV files for modeling services. This data is filtered according to the Service IDs from the scan parameter group and serviceNames (if incremental discovery is selected). This continues only if the Service option is selected in the SDH Device Parameters or Incremental Discovery scan parameter group.
The Update Notifications for Connectivities and Service processor updates the NMS notification status to DISCOVERY_SUCCESSFUL for entries in tlNames, trailNames, tunnelNames, and serviceNames. It also creates empty containers for devices that are not attached to any connectivties
Using the Cartridge
This section provides instructions for using the Oracle Communications Network Integrity SDH Discovery cartridge in Network Integrity.
Creating a Discover SDH Connectivity and Service Scan
The Discover SDH Connectivity and Service scan discovers and models connectivities such as Topological Links, Trails, Tunnels, and Services.
To create a Discover SDH Connectivity and Service discovery scan:
Create a new scan.
See Network Integrity Online Help for more information.
On the General tab, do the following:
- From the Scan Action list, select Discover SDH Connectivity and
Service.
The Scan Type field displays Discovery.
- In the Scan Action Parameters section, SDH File Parameters is selected by default. Enter the FTP related parameters.
- Click on the Scan Action Parameters drop down and select SDH Device Parameters. Select the type of entities to model and the required filters such as Name, ID, Device Name, and so on.
- Enter the Circle Name and Vendor name.
- If Incremental Discovery is to be performed, select Incremental Discovery from the Scan Action Parameters drop down.
- Select Incremental Discovery and the type of entities to be modeled and the number of notifications to be processed in this scan.
Service.
On the Scope tab, specify path to the file directory.
Save and run the scan.
About Cartridge Modeling
The Oracle Communications Network Integrity SDH Discovery cartridge models collected data according to the Oracle Communications Information Model. The collected data is modeled into the following entities:
Pipe
PipePipeTPRel
PipeTerminationPoint
TrailPath
TrailPipeRel
- TrailPipeRelTrailPathRel
Service
ServiceConfigurationItem
See Oracle Communications Information Model Reference for more information about the Information Model.
Specifications
This section lists the specifications included in the Optical_Model and SDH_Service models.
Pipe
Table 1-4 Pipe Specifications
| Specification | Cartridge |
| EthTunnel | Optical_Model |
| Optical Trail Pipe | Optical_Model |
| Topological Link | Optical_Model |
| VC3Circuit | Optical_Model |
| VC4Circuit | Optical_Model |
| VC12Circuit | Optical_Model |
Pipe Termination Point
Table 1-5 Pipe Termination Point Specifications
| Port Termination Point | Optical_Model |
Service
Table 1-6 Service Specifications
| SDH_Service | SDH_Service_Model |
Table 1-7 Service Configuration Specifications
| SDH_Service_Configuration | SDH_Service_Model |
About Design Studio Construction
This section provides information on the composition of the Oracle Communications Network Integrity Discovery SDH cartridge from the Oracle Communications Design Studio perspective.
Model Collections
Table 1-8 Discovery SDH Cartridge Model Collection
| Specification | Information Model Entity Type | Description |
| Topological Link | Pipe | Represents Topological Link connectivity |
| Optical Trail Pipe | Pipe | Represents Optical Trail Pipe which forms the segments of an optical path |
| VC12Circuit | Pipe | Represents VC12 type of trail connectivity |
| VC3Circuit | Pipe | Represents VC3 type of trail connectivity |
| VC4Circuit | Pipe | Represents VC4 type of trail connectivity |
| EthTunnel | Pipe | Represents EthTunnel type of tunnel connectivity |
| Port Termination Point | Pipe Termination Point | Represents Port Termination Point which acts as a device end |
| SDH_Service | Service | Represents SDH_Service that manages the network |
| SDH_Service_Configuration | Service Configuration | Represents SDH_Service_Configuration |
Discovery Action
The SDH Discovery cartridge supports the Discover SDH Connectivity and Service action.
The following table shows the discovery action in the SDH Discovery cartridge.
Table 1-9 Discover SDH Connectivity and Service
| Result Category | Address Handler | Scan Parameters | Model | Processors |
FileTransferAddressHandler |
Note: You must add these scan parameters to the Create Scan web service request even if the values are left empty. |
SDH_Discovery_Cartridge |
Discovery Processors
The following table shows the discovery processors in the SDH Discovery cartridge.
Table 1-10 Discover SDH Connectivity and Service Action Processors
| Processor Name | Variable |
| Incremental Discovery Initializer |
Input: N/A Output:
Collections of IDs and names on which the incremental discovery is performed.
| Notification Name Collector |
Input:
Collections of IDs and names on which the incremental discovery is performed. Output: N/A |
| Topological Link XML File Collector |
Input: N/A Output:
| Topological Link XML Parser |
Input:
Output:
| CSV Collector |
Input: N/A Output:
| Trail CSV Parser |
Input:
Output:
| Tunnel CSV Parser |
Input:
Output:
| Service CSV Parser |
Input:
Collection of service IDs on which the incremental discovery is performed. Output: N/A |
| Update Notifications for Connectivities and Service |
Input:
Output: N/A |
