4 About Cartridge Modeling
The Oracle Communications Network Integrity RAN and Microwave Discovery Cartridge models the collected data according to the Oracle Communications Information Model. The collected data is modeled into the following entities:
Equipment
EquipmentHolder
EquipmentEquipmentRel
EquipmentHolderEquipmentRel
LogicalDevice
MediaInterface
PhysicalDevice
PhysicalDeviceEquipmentRel
PhysicalPort
See Oracle Communications Information Model Reference for more information about the Information Model.
RAN and Microwave Discovery Cartridge Representation
Figure 4-1 displays a diagram depicting the object relationship rendered for RAN devices.
Figure 4-1 Object Relationship Rendered for RAN Devices
Figure 4-2 displays a diagram depicting the object relationship rendered for Microwave devices.
Figure 4-2 Object Relationship Rendered for Microwave Devices
Specifications
This section lists the specifications included in the ora_ni_uim_ran_microwave cartridge for devices.
You must first model the inventory (UIM) specifications in an inventory cartridge using Design Studio and define the cartridge dependency such that the Network Integrity cartridge is dependent on the inventory cartridge. Then you can use the inventory cartridge specifications in the Network Integrity cartridge model.
Specifications shared with Oracle Communications Unified Inventory Management (UIM) are defined in the ora_ni_uim_device cartridges. These cartridges are used to directly deploy specifications to UIM.
Physical Device
Table 4-1 shows the list of physical device specifications.
Table 4-1 Physical Device Specifications
| Specification | Cartridge | Intended Usage |
| GenericRANPD | ora_ni_uim_ran_microwave | Used to model RAN physical devices |
| GenericMWPD | ora_ni_uim_ran_microwave | Used to model Microwave physical devices |
Table 4-2 shows the characteristics applied to the physical device characteristics.
Table 4-2 Physical Device Characteristics
| Characteristics | Field Type | Field Content |
| areaId | string | Text |
| areaType | string | Text |
| btsType | string | Text |
| connectivityType | string | Text |
| description1 | string | Text |
| description2 | string | Text |
| fingerprint | string | Text |
| hardwareVersion | string | Text |
| hostServer | string | Text |
| ipAddress | string | Text |
| ipId | string | Text |
| ipName | string | Text |
| latestUnlockedPeriod | string | Text |
| leftUnlockedTime | string | Text |
| licenseState | string | Text |
| licenseType | string | Text |
| licenseValidity | string | Text |
| nativeEmsName | string | Text |
| neAcronym | string | Text |
| neAddedTime | string | Text |
| neAlias | string | Text |
| neGatewayIP | string | Text |
| neId | string | Text |
| neLastManagedUnmanagedTime | string | Text |
| neLastModifiedTime | string | Text |
| neLastStartedStoppedTime | string | Text |
| neLicensingMode | string | Text |
| neLocation | string | Text |
| neSiteId | string | Text |
| neSiteName | string | Text |
| neState | string | Text |
| neSubnetMask | string | Text |
| neType | string | Text |
| nodeType | string | Text |
| ntpServerIP | string | Text |
| ntpStatus | string | Text |
| operationalStatus | string | Text |
| operator | string | Text |
| ospfNetAddress | string | Text |
| ospfSubnetMask | string | Text |
| ossName | string | Text |
| parentBscId | string | Text |
| parentBscName | string | Text |
| parentRncId | string | Text |
| parentRncName | string | Text |
| productionDate | string | Text |
| RanCircle | string | Text |
| region | string | Text |
| rxPower | string | Text |
| serverName | string | Text |
| softwareVersion | string | Text |
| technology | string | Text |
| txPower | string | Text |
| unlockedReason | string | Text |
| Vendor | string | Text |
Equipment
Table 4-3 shows the list of equipment specifications.
Table 4-3 Equipment Specifications
| GenericRANCard | ora_ni_uim_ran_microwave | Used to model RAN card equipment |
| GenericRANRack | ora_ni_uim_ran_microwave | Used to model RAN rack equipment |
| GenericRANShelf | ora_ni_uim_ran_microwave | Used to model RAN shelf equipment |
| GenericMWCard | ora_ni_uim_ran_microwave | Used to model Microwave card equipment |
| GenericMWDirectCard | ora_ni_uim_ran_microwave | Used to model Microwave direct card equipment |
| GenericMWShelf | ora_ni_uim_ran_microwave | Used to model Microwave shelf equipment |
Table 4-4 shows the characteristics applied to the equipment characteristics.
Table 4-4 Equipment Characteristics
| activeSW | String | Text |
| biosVer | String | Text |
| bomCode | String | Text |
| hardwareVersion | String | Text |
| manufactureDate | String | Text |
| manufacturer | String | Text |
| minimumSWVersion | String | Text |
| numberOfPorts | String | Text |
| ossName | String | Text |
| partnumber | String | Text |
| productionDate | String | Text |
| RanCircle | String | Text |
| slotId | String | Text |
| swProductNumber | String | Text |
| technology | String | Text |
| unit | String | Text |
| Vendor | String | Text |
Equipment Holder
Table 4-5 shows the list of equipment holder specifications.
Table 4-5 Equipment Holder Specifications
| GenericRANEquipmentHolder | ora_ni_uim_ran_microwave | Used to model RAN equipment holders |
| GenericMWEquipmentHolder | ora_ni_uim_ran_microwave | Used to model Microwave equipment holders |
Table 4-6 shows the characteristics applied to the equipment holder characteristics.
Table 4-6 Equipment Holder Characteristics
| mountingPosition | String | Text |
Physical Port
Table 4-7 shows the list of physical port specifications.
Table 4-7 Physical Port Specifications
| GenericRANPort | ora_ni_uim_ran_microwave | Used to model RAN physical ports |
| GenericMWPort | ora_ni_uim_ran_microwave | Used to model Microwave physical ports |
Table 4-8 shows the characteristics applied to the physical port characteristics.
Table 4-8 Physical Port Characteristics
| bandwidth | String | Text |
| farEndNEIP | String | Text |
| farEndNEName | String | Text |
| farEndPort | String | Text |
| ifIndex | String | Text |
| ipAddress | String | Text |
| layerRate | String | Text |
| meId | String | Text |
| neId | String | Text |
| operationalStatus | String | Text |
| speed | String | Text |
| subnet | String | Text |
| type | String | Text |
Logical Device
Table 4-9 shows the list of logical device specifications.
Table 4-9 Logical Device Specifications
| GenericRANLD | ora_ni_uim_ran_microwave | Used to model RAN logical devices |
| GenericMWLD | ora_ni_uim_ran_microwave | Used to model Microwave logical devices |
Table 4-10 shows the characteristics applied to the logical device characteristics.
Table 4-10 Logical Device Characteristics
| nativeEmsName | String | Text |
| neSubnetMask | String | Text |
Device Interface
Table 4-11 shows the list of device interface specifications.
Table 4-11 Device Interface Specifications
| GenericRANInterface | ora_ni_uim_ran_microwave | Used to model RAN logical devices |
| GenericMWInterface | ora_ni_uim_ran_microwave | Used to model Microwave logical devices |
Table 4-12 shows the characteristics applied to the device interface characteristics.
Table 4-12 Device Interface Characteristics
| macAddress | String | Text |
| mtu | String | Text |
