2 About the Cartridge Components
This chapter provides information about the components of the Oracle Communications Network Integrity Optical UIM Integration cartridge.
The Optical UIM Integration cartridge contains the following actions:
Discover Optical UIM Action
The Discover Optical UIM action discovers logical device hierarchies and models them as Network Device model hierarchies. This discovery action also remodels the physical device hierarchy into a Generic physical device hierarchy by changing the specification on the equipment objects from TMF814 specifications to Generic specifications.
This discovery action extends the Discover TMF814 action (from the Optical TMF814 CORBA cartridge) and inherits all its processors. For information about the inherited processors in this action, see Network Integrity Optical TMF814 CORBA Cartridge Guide.
This discovery action supports incremental discovery based on NMS notifications received by Network Integrity.
The Discover Optical UIM action contains the following processors run in the following order:
CORBA Property Initializer (inherited)
TMF814 CORBA Property Initializer (inherited)
CORBA Connection Manager (inherited)
TMF814 Property Initializer (inherited)
TMF814 Property Customizer (inherited)
Vendor Customizer
TMF814 Session Manager (inherited)
TMF814 Device Recorder Initializer (inherited)
TMF814 ME Collector (inherited)
TMF814 Updated ME Discoverer (inherited)
TMF814 MultiThread Device Modeler (inherited)
TMF814 Device Modeler (inherited)
TMF814 Equipment Collector (inherited)
TMF814 Equipment Modeler (inherited)
TMF814 PTP Collector (inherited)
TMF814 PTP Modeler (inherited)
TMF814 CPT Discoverer for PTP (inherited)
TMF814 FTP Collector (inherited)
TMF814 FTP Modeler (inherited)
TMF814 CTP Discoverer for FTP (inherited)
TMF814 Device Persister (inherited)
TMF814 Device Recorder Persister (inherited)
Update ME Notification Status (inherited)
TMF814 SNC Discoverer (inherited)
TMF814 Cross-Connect Discoverer (inherited)
TMF814 SNC CC Discoverer (inherited)
Update SNC Notification Status (inherited)
TMF814 Topological Link Config Initializer (inherited)
TMF814 Topological Link Collector (inherited)
TMF814 Updated Topological Link Collector (inherited)
TMF814 MultiThread TL Modeler (inherited)
TMF814 Topological Link Modeler (inherited)
TMF814 Pipe Persister (inherited)
Update TL Notification Status (inherited)
Figure 2-1 illustrates the processor workflow of the Discover Optical UIM action.
Figure 2-1 Discover Optical UIM Action Processor Workflow
The Abstract TMF814 action is configured with the isIncrementalScanEnabled condition. When this condition is met, the corresponding processors will run.
Logical Device Remodeler
This processor remodels the TMF814 discovery results into logical device hierarchies.
Optical UIM TMF814 MultiThread Device Modeler
This processor models logical and physical device entities, collects and models equipments, collects and models PTPs and respective CTPs, and collects and models FTPs and respective CTPs. It creates the logical and physical device entities and persists to the result.
This processor verifies whether a scan is configured with the Parallel Process option enabled. If not enabled, it skips the process.
This processor uses WebLogic's ManagedExecutorService work-manager concept to process it in parallel. For more information, see Parallel Process in Installation Guide.
Discover Enhanced TMF814 Action
The Discover Enhanced TMF814 action discovers logical device hierarchies and remodels them as Network Device model hierarchies.
The Discover Enhanced TMF814 action contains the following processors run in the following order:
Figure 2-2 illustrates the processor workflow of the Discover Enhanced TMF814 action.
Figure 2-2 Discover Enhanced TMF814 Action Processor Workflow
Enhanced TMF814 Property Customizer
This processor sets the modeler processors to model only the logical device tree and not to model the physical device tree.
Logical Network Device Remodeler
This processor remodels the logical device hierarchies from the TMF814 discovery results. This processor removes the TMF814 TPLayer Generic objects from the logical device tree from each DeviceInterface entity and then remaps specifications and attributes. This processor also corrects VC3/VC12 layers.
TMF814 MultiThread Enhanced Device Modeler
This processor uses WebLogic's ManagedExecutorService work-manager concept to process it in parallel. For more information, see Working with Application Context Work-Managers section in Developer's Guide.
Assimilate SDH Optical Circuits Action
The Assimilate SDH Optical Circuits action assimilates the results from the Discover Optical UIM action and forms end-to-end synchronous digital hierarchy (SDH) circuits.
This assimilation action extends the Assimilate Optical Circuits action (from the Optical Circuit Assimilation cartridge) and inherits all its processors. For information about the inherited processors, see Network Integrity Optical Circuit Assimilation Cartridge Guide.
The Assimilate SDH Optical Circuits action contains the following processors run in the following order:
Layer Rate Initializer (inherited)
Optical Assimilation Initializer (inherited)
Optical VC4 HOT HOP Assimilator (inherited)
Optical VC3 LOT LOP Assimilator (inherited)
Optical VC12 LOT LOP Assimilator (inherited)
Optical Assimilation Circuit Matcher (inherited)
Page Initialization for Circuit (inherited)
Optical Assimilation Modeler (inherited)
Optical Assimilation Persister (inherited)
Link Persister (inherited)
Cleanup Processor (inherited)
Figure 2-3 illustrates the processor workflow of the Assimilate SDH Optical Circuits action.
Figure 2-3 Assimilate SDH Optical Circuits Action Processor Workflow
Description of "Figure 2-3 Assimilate SDH Optical Circuits Action Processor Workflow"
Optical Assimilation SDH Circuit Matcher
This processor matches assimilated data with your inventory system. Cross-connect and topological link object naming can often vary over a network. When this processor matches an assimilated circuit with an inventory circuit, it applies the inventory circuit name to the assimilated circuit.
The Assimilate Huawei Optical Circuits action is configured with the IsUIMHuaweiOpticalCircuit condition. When this condition is met, this processor is run and the inherited Optical Assimilation Circuit Matcher processor is not run.
This processor has the same functionality as the Optical Assimilation Circuit Matcher processor, but also contains logic to collect and model partially-protected circuits in the UIM model.
Import Logical Optical from UIM Action
The Import Logical Optical from UIM scan imports logical optical data entities from UIM and models them in the Network Logical Device Model. Also, this import action provides extensibility for features specific to SDH that you want to add.
Table 2-1 lists the values that are used when configuring the filters in the base class.
Table 2-1 Filter Values
| Filter | Value |
Query Physical Devices |
False |
Import Related Physical or Logical Device |
False |
Logical Device Specification |
Network Device |
This import action extends the Abstract Incremental Import from UIM action (from the UIM Integration cartridge) and inherits all its processors. For information about the processors inherited from the Abstract Incremental Import from UIM action, see Network Integrity UIM Integration Cartridge Guide.
The Import Logical Optical from UIM action contains the following processors run in the following order:
Import UIM Initializer (inherited)
ME Names Collector (inherited)
Logical Device UIM Finder (inherited)
Physical Device UIM Finder (inherited)
Logical Device UIM MultiThread Importer (inherited)
Physical Device UIM MultiThread Importer (inherited)
Logical Device UIM Importer (inherited)
Linked Physical Device UIM Importer (inherited)
Logical Device UIM Persister (inherited)
Linked Logical Device UIM Importer (inherited)
Physical Device UIM Persister (inherited)
Figure 2-4 illustrates the processor workflow of the Import Logical Optical from UIM action.
Figure 2-4 Import Logical Optical from UIM Action Processor Workflow
Import Optical from UIM Action
The Import Optical from UIM action imports physical devices, logical devices, and channelized connectivities from UIM. Channelized connectivities are modeled into the Network Integrity Model according to their rate code. For example, synchronous transport module (STM) connectivities are modeled as topological links; VC4 connectivities are modeled as transport circuits; E1, E3, and E4 connectivities are modeled as customer circuits. See Network Integrity Information Model Reference for more information on the Network Integrity model.
For each channelized connectivity, only the most recent design version with a status of COMPLETED is imported.
The Optical UIM Incremental Import Parameters scan parameter group allows Network Integrity users to specify the scope of the import scan at run time:
The Import Optical from UIM action contains the following processors run in the following order:
Figure 2-5 illustrates the processor workflow of the Import Optical from UIM action.
Figure 2-5 Import Optical from UIM Action Processor Workflow
Scan Params Physical Optical UIM Init
This processor initializes the scan parameters configured by the Network Integrity user.
STM Link UIM Importer
This processor imports channelized connectivities with the STM rate code for each logical device.
STM Link UIM Persister
This processor takes each STM channelized connectivity and models it in the Optical Model as an optical link. The modeled connectivities are then saved to the device result category.
VC4HOT UIM Importer
This processor imports channelized connectivities with the VC4 rate code for each logical device.
VC4HOT UIM Persister
This processor takes each VC4 channelized connectivity and models it in the Optical Model as a VC4 HOT transport circuit. The modeled connectivities are then saved to the device result category.
Circuit UIM Importer
This processor imports E1, E3, and E4 rate code channelized connectivities from UIM for each logical device. When the circuit originates on one device and terminates on another, the circuit is made the child of the first device in alphabetical order.
Circuit UIM Persister
This processor takes each channelized connectivity and models it in the Optical Model as a circuit. The modeled circuits are then saved to the device result category.
Circuits with one path are modeled as primary path circuits. Circuits with multiple paths are modeled with numbered path values (for example, path 1, path 2, path 3, and so on).
Optical UIM Multithread Importer
This processor uses the filters, uimImportContext, uimLogicalDeviceIDs, and uimPhysicalDeviceIDs as input parameters and imports and models the specified device(s) and stores results in Network Integrity. Instead of using the hardcoded specifications for logical device and device interface, the UIM specification name is mapped to a Network Integrity specification name. When creating a device interface, this processor instantiates either DeviceInterface or MediaInterface based on the type received from UIM. Instead of using the hardcoded specifications for physical entities, the UIM specification name is mapped to a Network Integrity specification name.
This processor uses WebLogic's Managed Executor Service work-manager concept to process it in parallel. For more information, see the Working with Application Context Work-Managers section in Developer's Guide.
UIM Detect Optical Device Discrepancies Action
The UIM Detect Optical Device Discrepancies action detects device-level physical and logical discrepancies while filtering and removing unused attributes and characteristics from the logical and physical device models.
This discrepancy detection action extends the Abstract Detect UIM Discrepancies action (from the Network Integrity UIM Integration cartridge) and inherits all its processors. For information about the processors inherited from the Abstract Detect UIM Discrepancies action, see Network Integrity UIM Integration Cartridge Guide.
This action also extends the Auto Resolve Discrepancies action (from the NetworkIntegritySDK cartridge) to provide automatic discrepancy resolution. For information about the processors inherited from the Auto Resolve Discrepancies action, see Network Integrity Developer's Guide.
The UIM Detect Optical Device Discrepancies action contains the following processors run in the following order:
UIM Discrepancies Filter Initializer (inherited)
Discrepancy Detector (inherited)
Check Auto Resolution Selected (inherited)
Identify Auto Resolving Discrepancies (inherited)
Prepare Resolving Discrepancies (inherited)
Figure 2-6 illustrates the processor workflow of the UIM Detect Optical Device Discrepancies action.
Figure 2-6 UIM Detect Optical Device Discrepancies Action Processor Workflow
Optical UIM DD Filters
This processor applies filters to ignore the following types of discrepancies:
Missing equipment holder
Missing physical port
Missing physical device with a TMF814 specification
Missing equipment card with a TMF814 specification
Missing cross-connects
Missing topological links
UIM Auto Resolve Selected Discrepancies
This processor contains the automatic resolution Java class. The Java implementation class determines the types of discrepancies to be automatically resolved and the resolution logic.
See Network Integrity Developer's Guide for more information about completing the Java implementation class.
UIM Detect Optical Circuit Discrepancies Action
The UIM Detect Optical Circuit Discrepancies action detects discrepancies between assimilated circuits and imported channelized connectivities and circuits from UIM.
The name-matching logic compares assimilated circuit paths with imported circuit paths. When it finds a match, the name given during circuit assimilation is discarded and the imported circuit path name is used.
This discrepancy detection action extends the Abstract Optical Circuit Discrepancy Detection action (from the Network Integrity Optical Circuit Assimilation cartridge) and inherits all its processors. For information about the inherited processors in this action, see Network Integrity Optical Circuit Assimilation Cartridge Guide.
The UIM Detect Optical Circuit Discrepancies action contains the following processors run in the following order:
Circuit Discrepancy Name Filter Initializer (inherited)
Missing Entity Filter Initializer (inherited)
Figure 2-7 illustrates the processor workflow of the UIM Detect Optical Circuit Discrepancies action.
Figure 2-7 UIM Detect Optical Circuit Discrepancies Action Processor Workflow
Description of "Figure 2-7 UIM Detect Optical Circuit Discrepancies Action Processor Workflow"
Circuit Discrepancy Filters Initializer
This processor initializes the following discrepancy detection filters:
Attributes Filter: prevents discrepancy detection on the ID, physical location, description, rerouted, partial, sequence, aEnd, and zEnd attributes.
Channel Attribute Filter: changes the channel attribute mismatch discrepancy severity from minor to major.
Partial Circuit Filter: sets the status on partial circuit discrepancies to Ignore.
Ignore Container Level Discrepancy Filter: sets the status on container-level discrepancies to Ignore.
UIM Detect TMF814 Device Discrepancies Action
The UIM Detect TMF814 Device Discrepancies action detects discrepancies while filtering and removing unused attributes and characteristics from the logical and physical device models.
This discrepancy detection action extends the Abstract Detect UIM Discrepancies action (from the UIM Integration cartridge) and inherits all its processors. For information about the inherited processors in this action, see Network Integrity UIM Integration Cartridge Guide.
The UIM Detect TMF814 Device Discrepancies action contains the following processors run in the following order:
Figure 2-8 illustrates the processor workflow of the UIM Detect TMF814 Device Discrepancies action.
Figure 2-8 UIM Detect TMF814 Device Discrepancies Action Processor Workflow
Description of "Figure 2-8 UIM Detect TMF814 Device Discrepancies Action Processor Workflow"
Optical UIM TMF DD Filters
Missing device interface with a TMF814 specification
Media interface-specific attributes when comparing connection termination points. For physical termination point interfaces, it compares as a media interface.
Resolve Optical in UIM Action
The Resolve Optical in UIM action resolves logical and physical device and circuit discrepancies between discovered data and the data imported from UIM.
For each channelized connectivity, only the most recent design version is resolved:
When the design status is IN_PROGRESS, this action updates the intermediate segment with network trail paths and sets the status to COMPLETED.
When the design status is COMPLETED or CANCELLED, this action creates a new intermediate segment using network trail paths and sets the status to COMPLETED.
For new entities, this action creates the first design versions and sets the status to COMPLETED.
This discrepancy resolution action cannot delete channelized connectivities from UIM when there exists multiple versions with the COMPLETED or CANCELLED status. Therefore, to resolve Missing Entity discrepancies on channelized connectivities, this discrepancy resolution action creates a new design version with a COMPLETED status and clears all intermediate segments.
This discrepancy resolution action extends the Abstract Resolve in UIM action (from the UIM Integration cartridge) and inherits all its processors. For information about the inherited processors in this action, see Network Integrity UIM Integration Cartridge Guide.
This action contains the following processors run in the following order:
UIM Resolution Framework Initializer
UIM Resolution Initializer
UIM Resolution Framework Dispatcher
Figure 2-9 illustrates the processor workflow of the Resolve Optical in UIM action.
Figure 2-9 Resolve Optical in UIM Action Processor Workflow
Description of "Figure 2-9 Resolve Optical in UIM Action Processor Workflow"
About Recording Mode
You can configure the Optical UIM Integration cartridge to record all discovered managed elements (MEs), topological links, and cross-connects. The recorded files (ME_Name.me for MEs, EMS_Name.ems for topological links, and EMS_Name.cc for cross-connects) are saved to the Domain_Home/corbaData/Scan_Name/EMS_Name directory, where:
ME_Name is the name of the ME.
EMS_Name is the name of the element-management system (EMS).
Domain_Home is the Network Integrity WebLogic Server domain.
Scan_Name is the name of the scan.
If the TMF814 scan action type has been configured to not discover MEs, topological links, or cross-connects, the corresponding file is not generated.
The recording processor reads this file each time it is run.
