5 About Cartridge Modeling
This chapter provides information on modeling the Network Integrity Generic SNMP cartridge.
Generic SNMP Cartridge UML Representation
Figure 5-1 displays a unified modeling language (UML) diagram depicting the object relationship being rendered.
Figure 5-1 Generic SNMP Cartridge UML Representation
Description of "Figure 5-1 Generic SNMP Cartridge UML Representation"
Hierarchy Mapping
The data sourced from RFC1213-MIB.mgmt.mib-2.system tables establishes and seeds the logical device object.
The media interface encapsulates the common information about an interface as a device is discovered. The device interface configuration captures the media type information that decorates the interface with media-specific parameters. These media-specific parameters define the behavior of the interface (Generic, ATM).
The media interfaces are established and seeded with data sourced from the following:
RFC1213-MIB.mgmt.mib-2.interfaces.ifTable
IF-MIB.mgmt.mib-2.ifMIB.ifMIBObjects.ifXTable.ifXEntry
IP-MIB.mgmt.mib-2.ip.ipAddressTable.ipAddressEntry
IF-MIB.mgmt.mib-2.ifMIB.ifMIBObjects.ifStackTable.ifStackEntry.ifStackStatus
IF-MIB.mgmt.mib-2.ifMIB.ifMIBObjects.ifStackTable.ifStackEntry.ifStackStatus establishes the interface hierarchy.
The generic media device interface configuration is established and seeded with data sourced from the following:
RFC1213-MIB.mgmt.mib-2.ip.ipAddrTable.ipAddrEntry
The ATM media device interface configuration is established and seeded with data sourced from the ATM-MIB. See "About Poll Lists".
Oracle Communications Information Model Information
All entities shown in Figure 5-1 (for example, physical device, logical device, media interface, and so on) are Oracle Communications Information Model 1.0-compliant for static fields. The dynamic fields (sometimes referred to as characteristics) are application-specific. You can customize application specific data with the device interface configuration mechanism.
The Generic SNMP cartridge supports the following configurations:
Generic Media
AtmMedia
For a listing of the Information Model fields, see "Logical Mapping" and "Physical Mapping".
Specifications
This section lists the specifications included in the ora_ni_uim_device cartridge for modeling Generic vendor devices.
You must first model inventory (UIM) specifications in an inventory cartridge using Design Studio, define the cartridge dependency such that the Network Integrity cartridge is dependent on the inventory cartridge, and then use the inventory cartridge specifications in the Network Integrity cartridge model.
Specifications shared with Oracle Communications Unified Inventory Management (UIM) are defined in the ora_ni_uim_device cartridge. These cartridges are used to directly deploy specifications to UIM.
PhysicalDevice
This specification models a physical device entity.
Table 5-1 shows the specifications for physical device.
Table 5-1 Physical Device Specifications
| Specification | Cartridge | Intended Usage |
| GenericPhysicalDeviceSpecification | ora_ni_uim_device | Used to model all types of generic devices. |
GenericPhysicalDeviceSpecification is available in ora_ni_uim_device and used to model all type of generic devices.
Table 5-2 shows the characteristics applied to physical device specifications.
Table 5-2 Physical Device Characteristics
| Characteristics | Field Type | Field Content |
mgmtIpAddress |
String |
Text |
modelName |
String |
Text |
discoveredModelNumber |
String |
Text |
discoveredPartNumber |
String |
Text |
discoveredVendorName |
String |
Text |
serialNumber |
String |
Text |
physicalLocation |
String |
Text |
hardwareRev |
String |
Text |
softwareRev |
String |
Text |
nativeEmsName |
String |
Text |
Equipment
Table 5-3 Equipment Specifications
| GenericEquipmentShelfSpecification | ora_ni_uim_device | Used to model shelf for all generic devices. |
| GenericEquipmentSpecification | ora_ni_uim_device | Used to model card for all generic devices. |
GenericEquipmentShelfSpecification and GenericEquipmentSpecification are available in ora_ni_uim_device and used to model generic devices.
Table 5-4 GenericEquipmentShelfSpecification Characteristics
| discoveredModelNumber | String | Text |
| discoveredPartNumber | String | Text |
| discoveredVendorName | String | Text |
| hardwareRev | String | Text |
| softwareRev | String | Text |
| modelName | String | Text |
| nativeEmsName | String | Text |
| owner | String | Text |
| userLabel | String | Text |
Table 5-5 GenericEquipmentSpecification Characteristics
Equipment Holder
Table 5-7 shows the characteristics applied to the EquipmentHolder specifications.
Table 5-6 Equipment Holder Specifications
| GenericEquipmentHolderSpecification | ora_ni_uim_device | Used to model all types of Generic Vendor devices. |
GenericEquipmentHolderSpecification is available in ora_ni_uim_device and used to model Generic Vendor devices.
Table 5-7 EquipmentHolder Characteristics
modelName |
String |
Text |
| nativeEmsName |
String |
Text |
String |
Text |
String |
Text |
String |
Text |
hardwareRev |
String |
Text |
softwareRev |
String |
Text |
Physical Port
Table 5-8 shows the characteristics applied to physical port specifications.
Table 5-8 Physical Port Characteristics
modelName |
String |
Text |
String |
Text |
String |
Text |
String |
Text |
serialNumber |
String |
Text |
physicalLocation |
String |
Text |
hardwareRev |
String |
Text |
softwareRev |
String |
Text |
nativeEmsName |
String |
Text |
physicalAddress |
String |
Text |
Table 5-9 Physical Port Characteristics
| direction | String | Text |
| edgePoint | String | Text |
| tpProtectionAssociation | String | Text |
| portLevel | String | Text |
| portType | String | Text |
Logical Device
For logical device and device interface specification details, see "Overview" in Network Integrity MIB-II SNMP Cartridge Guide.
Specification Cardinality
The cardinality of all specification parent-child relationships is included in the software code so that min= 0 and max= n. This approach allows Network Integrity to programmatically instantiate all objects on demand as they are discovered using the web service.
Field Mapping
The Generic SNMP cartridge supports the following field mappings:
Text: Implies Text [255]
static: Information Model 1.0 defines this field to be static on the entity specification. The specification provides getters and setters for this field.
dynamic: This is a dynamic field where the entity specification treats the field as a name and value pair. The specification does not provide getters and setters but generically has get and set characteristics method holding a HashSet of entries.
Logical Mapping
The Generic SNMP cartridge supports the following logical mappings:
LogicalDevice
Table 5-10 shows characteristics for the LogicalDevice specification.
Table 5-10 LogicalDevice Characteristics
| Characteristics (LogicalDevice) | Information Model Support | MIB Object | Field Type | Intended Usage |
Id |
static |
N/A |
Text |
Programmatically generated as MgmtIPAddress::sysName::"LogicalDevice" |
Name |
static |
sysName |
Text |
N/A |
Description |
static |
sysDescr |
Text |
N/A |
Specification |
static |
N/A |
N/A |
Programmatically applies deviceGeneric specification |
nativeEmsAdminServiceState |
static |
N/A |
Enum with the following values:
Nothing available to source the field |
nativeEmsName |
static |
sysName |
Text |
N/A |
nativeEmsServiceState |
static |
N/A |
mgmtIpAddress |
dynamic |
N/A |
Text |
discoveryAddress |
sysObjectId |
dynamic |
sysObjectId |
Text |
Support legacy systems |
MediaInterface
Table 5-11 shows characteristics for the MediaInterface specification.
Table 5-11 MediaInterface Characteristics
| Characteristics (MediaInterface) | Information Model Support | MIB Object | Field Type | Intended Usage/ Notes |
Id |
static |
N/A |
Text |
Programmatically generated as MgmtIPAddress::sysName::ifDescr::"MediaInterface" |
Name |
static |
ifDescr |
Text |
N/A |
Description |
static |
ifDescr |
Text |
N/A |
Specification |
static |
N/A |
N/A |
Programmatically applies interfaceGeneric specification |
interfaceNumber |
static |
N/A |
Text |
Nothing available to source the field. |
customerInterfaceNumber |
static |
N/A |
Text |
vendorInterfaceNumber |
static |
ifName |
Text |
N/A |
nativeEmsName |
static |
ifDescr |
Text |
The field must be unique. ifDescr guarantees the uniqueness of a device. |
static |
ifAdminStatus |
Mapped, see Table 5-17. |
static |
ifOperStatus |
ifType |
dynamic |
ifType |
Text |
Mapped from IANA MIB using the snmpIfTypeMap properties file. Look up returning null results in a value of "n". |
mtuSupported |
static |
N/A |
Float |
Nothing available to source the field. Defaults to 0.0 |
mtuCurrent |
static |
ifMtu |
Float |
N/A |
physicalAddress |
static |
ifPhysAddress |
Text |
N/A |
physicalLocation |
static |
sysLocation |
Text |
N/A |
minSpeed |
static |
N/A |
Float |
maxSpeed |
static |
N/A |
Float |
Nothing available to source the field. Default to 0.0 |
nominalSpeed |
static |
ifSpeed | ifHighSpeed |
Float |
ifHighSpeed overrides ifSpeed when ifHighSpeed is available |
ifAlias |
dynamic |
ifAlias |
Text |
N/A |
ifName |
dynamic |
ifName |
Text |
DeviceInterfaceConfigurationItem Mapping (IPv4)
Table 5-12 shows characteristics for the DeviceInterfaceConfigurationItem (IPv4) specification.
Table 5-12 DeviceInterfaceConfigurationItem (IPv4) Characteristics
| Characteristics (Generic Media) | Information Model Support | MIB Object | Field Type | Intended Usage/ Notes |
ipAddress |
dynamic |
ipAdEntAddr |
Text |
N/A |
prefix |
dynamic |
ipAdEntNetMask |
Text |
N/A |
ipVersion |
dynamic |
ipAddressType |
Enum
Programmatically set to IPV4. |
Specification |
static |
N/A |
N/A |
Programmatically applies GenericMedia specification |
DeviceInterfaceConfigurationItem Mapping (IPv6)
Table 5-13 shows characteristics for the DeviceInterfaceConfigurationItem (IPv6) specification.
Table 5-13 Characteristics for the DeviceInterfaceConfigurationItem (IPv6) Specification
ipAddress |
dynamic |
ipAddressIfIndex |
Text |
For IPv6 addresses the actual IP is derived from the index since ipAddressAddr is not acceptable. |
prefix |
dynamic |
ipAddressPrefix |
Text |
N/A |
ipVersion |
dynamic |
ipAddressType |
Enum
Programmatically set to IPV6. |
Specification |
static |
N/A |
N/A |
DeviceInterfaceConfigurationItem Mapping (ATM Media)
Table 5-14 shows characteristics for the DeviceInterfaceConfigurationItem mapping (ATM media) specification.
Table 5-14 Characteristics for the DeviceInterfaceConfigurationItem (ATM media) Specification
| Characteristics (ATM Media) | Information Model Support | MIB Object | Field Type | Intended Usage/ Notes |
VPI |
dynamic |
Table index |
Text |
Parsed from the table index, which is in the format: <ifIndex>.<VPI>.<VCI> |
VCI |
dynamic |
Table index |
Text |
Table 5-15 shows characteristics for the DeviceInterfaceConfigurationItem Mapping (VirtualChannelLinkData) specification.
Table 5-15 Characteristics for the DeviceInterfaceConfigurationItem (VirtualChannelLinkData) Specification
| Characteristics (VirtualChannelLinkData) | Information Model Support | MIB Object | Field Type |
atmVccAal5EncapsType |
dynamic |
Text |
atmVccAalType |
dynamic |
atmVccAalType |
Text |
atmVclLastChange |
dynamic |
atmVclLastChange |
Text |
atmVclAdminStatus |
dynamic |
atmVclAdminStatus |
Text |
atmVclOperStatus |
dynamic |
atmVclOperStatus |
Text |
Table 5-16 shows characteristics for the DeviceInterfaceConfigurationItem Mapping (AtmInterfaceConfigurationData) specification.
Table 5-16 Characteristics for the DeviceInterfaceConfigurationItem (AtmInterfaceConfigurationData) Specification
| Characteristics (AtmInterfaceConfigurationData) | Information Model Support | MIB Object | Field Type |
atmInterfaceMaxVpcs |
dynamic |
Text |
atmInterfaceMaxVccs |
dynamic |
Text |
atmInterfaceMaxActiveVpiBits |
dynamic |
Text |
atmInterfaceMaxActiveVciBits |
dynamic |
Text |
atmInterfaceIlmiVpi |
dynamic |
Text |
atmInterfaceIlmiVci |
dynamic |
Text |
atmInterfaceAddressType |
dynamic |
Text |
atmInterfaceAdminAddress |
dynamic |
Text |
Mapping Table
Table 5-17 shows a mapping table.
Table 5-17 Mapping Table
| ifOperStatus | ifAdminStatus | nativeEmsServiceState nativeEmsAdminState |
4: unknown, 6: notPresent |
N/A |
UNKNOWN |
1: up |
1: up |
IN_SERVICE |
2: down, 5: dormant, 7: lowerLayerDown |
2: down |
Programmatically set to OUT_OF_SERVICE. |
3: testing |
3: testing |
TESTING |
N/A |
N/A |
IN_MAINTENANCE |
Physical Mapping
This cartridge support the following physical mappings:
Information Model Nomenclature Mapping
Information Model mapping helps in classification of physical components. For example, if an equipment is classified as "Power Supply," this cartridge maps the SNMP data into the Information Model entity type Equipment. Table 5-18 lists the various physical classes and the Information Model entity type they are mapped to.
Table 5-18 Information Model Nomenclature Mapping
| entPhysicalClass | Information Model |
root |
Physical Device |
Other (1) |
Unsupported |
Unknown (2) |
Unsupported |
Chassis (3) |
Equipment-Shelf |
Backplane (4) |
Equipment-Shelf |
Container (5) |
Equipment-Holder |
Power supply (6) |
Equipment |
Fan (7) |
Equipment |
Sensor (8) |
Equipment |
Module (9) |
Equipment-Card |
Port (10) |
Physical Port |
Stack (11) |
Unsupported |
PhysicalDevice
Table 5-19 shows the characteristics for the PhysicalDevice specification.
Table 5-19 PhysicalDevice Characteristics
| Characteristics (Physical Device) | Information Model Support | MIB Object | Field Type | Intended Usage/ Notes |
Id |
static |
N/A |
Text |
Programmatically generated as MgmtIPAddress::sysName::0::"PhysicalDevice". |
Name |
static |
sysName |
Text |
N/A |
Description |
static |
sysDescr |
Text |
N/A |
Specification |
static |
N/A |
Text |
Programmatically applies GenericPhysicalDeviceSpecification specification. |
dynamic |
sysObjectId |
Text |
N/A |
dynamic |
N/A |
Text |
Set to "Network Vendor". |
serialNumber |
static |
N/A |
Text |
N/A |
physicalLocation |
N/A |
location |
Text |
N/A |
dynamic |
N/A |
Text |
N/A |
hardwareRev |
dynamic |
N/A |
Text |
N/A |
softwareRev |
dynamic |
N/A |
Text |
N/A |
ModelName |
dynamic |
N/A |
Text |
Set to "Network Equipment Type". |
mgmtIpAddress |
dynamic |
N/A |
Text |
discoveryAddress |
nativeEmsName |
static |
sysName |
Text |
N/A |
Equipment
Table 5-20 shows characteristics for the Equipment specification.
Table 5-20 Equipment Characteristics
| Characteristics (Equipment) | Information Model Support | MIB Object | Field Type | Intended Usage/ Notes |
Id |
static |
N/A |
Text |
Programmatically set to MgmtIPAddress::sysName:: [absRelativePosition]::"Equipment.Rack|Shelf|Card". See "About the absRelativePosition Value". |
Name |
static |
entPhysicalDescr |
Text |
N/A |
Description |
static |
entPhysicalDescr |
Text |
N/A |
Specification |
static |
N/A |
Text |
Programmatically applies GenericEquipmentShelfSpecification or GenericEquipmentSpecification based on device type (shelf/card). |
dynamic |
entPhysicalVendorType |
Text |
N/A |
dynamic |
entPhysicalMfgName |
Text |
N/A |
serialNumber |
static |
entPhysicalSerialNum |
Text |
N/A |
physicalLocation |
static |
location |
Text |
N/A |
dynamic |
entPhysicalModelName |
Text |
N/A |
hardwareRev |
dynamic |
entPhysicalHardwareRev |
Text |
N/A |
softwareRev |
dynamic |
entPhysicalSoftwareRev |
Text |
N/A |
ModelName |
dynamic |
N/A |
Text |
Programmatically applies based on entPhysicalDescr or entPhysicalModelName. |
nativeEmsName |
static |
entPhysicalDescr and absRelativePosition |
Text |
N/A |
EquipmentHolder
Table 5-21 shows characteristics for the EquipmentHolder specification.
Table 5-21 EquipmentHolder Characteristics
| Characteristics (EquipmentHolder) | Information Model Support | MIB Object | Field Type | Intended Usage/ Notes |
Id |
static |
N/A |
Text |
Programmatically generated as MgmtIPAddress::sysName::[absRelativePosition]::"EquipmentHolder". See "About the absRelativePosition Value". |
Name |
static |
entPhysicalDescr and entPhysicalParentRelPos |
Text |
Programmatically generated as entPhysicalDescr::entPhysi calParentRelPos. |
Description |
static |
entPhysicalDescr |
Text |
N/A |
Specification |
static |
N/A |
Text |
Programmatically applies GenericEquipmentHolderSpecification. |
dynamic |
Text |
N/A |
dynamic |
Text |
N/A |
serialNumber |
static |
Text |
N/A |
physicalLocation |
static |
location |
Text |
N/A |
dynamic |
Text |
N/A |
hardwareRev |
dynamic |
Text |
N/A |
softwareRev |
dynamic |
Text |
N/A |
ModelName |
dynamic |
entPhysicalDescr or entPhysicalModelName |
Text |
Programmatically applies based on entPhysicalDescr or entPhysicalModelName |
nativeEmsName |
static |
Text |
N/A |
PhysicalPort
Table 5-22 shows characteristics for the PhysicalPort specification.
Table 5-22 PhysicalPort Characteristics
| Characteristics (PhysicalPort) | Information Model Support | MIB Object | Field Type | Intended Usage/ Notes |
Id |
static |
N/A |
Text |
Programmatically generated as MgmtIPAddress::sysName::[absRelativePosition]::"PhysicalPort". See "About the absRelativePosition Value". |
Name |
static |
Text |
Programmatically generated as entPhysicalDescr::entPhysicalParentRelPos. |
Description |
static |
entPhysicalName |
Text |
N/A |
Specification |
static |
N/A |
Text |
Programmatically applies GenericPhysicalPortSpecification. |
dynamic |
Text |
N/A |
portNumber |
static |
Int |
N/A |
customerPortName |
static |
Text |
N/A |
vendorPortName |
static |
N/A |
Text |
N/A |
dynamic |
Text |
N/A |
serialNumber |
static |
Text |
N/A |
physicalLocation |
static |
location |
Text |
N/A |
dynamic |
Text |
N/A |
hardwareRev |
dynamic |
Text |
N/A |
softwareRev |
dynamic |
Text |
N/A |
| ModelName | dynamic | entPhysicalDescr or entPhysicalModelName | Text | Programmatically applies based on entPhysicalDescr or entPhysicalModelName |
nativeEmsName |
static |
Text |
N/A |
