7 About Design Studio Construction
This chapter provides information on the composition of the Oracle Communications Network Integrity Generic SNMP cartridge from the Oracle Communications Design Studio perspective.
Model Collections
Table 7-1 shows the MIB-II model collection used in the Generic SNMP cartridge.
Table 7-1 MIB-II Model Collection
| Specifications | Information Model Entity Type | Intended Usage/ Notes |
deviceGeneric |
LogicalDevice |
Represents any root object discovered on the network. |
interfaceGeneric |
MediaInterface |
Represents any interface discovered under deviceGeneric. |
GenericMedia |
DeviceInterfaceConfigurationItem |
Represents IpAddresses that are applied to an interfaceGeneric. |
IPAddresses |
Ip Addresses container. |
IPAddress |
Ip Address details container. |
Table 7-2 shows the Generic SNMP model collection.
Table 7-2 Generic SNMP Model Collection
| GenericPhysicalDeviceSpecification | PhysicalDevice | Represents any generic physical device discovered on the network. |
| GenericEquipmentHolderSpecification | EquipmentHolder | Represents any equipment container. |
| GenericEquipmentShelfSpecification | Equipment | Represents equipment shelf. |
| GenericEquipmentSpecification | Equipment | Represents equipment card. |
| GenericPhysicalPortSpecification | PhysicalPort | Represents any physical port. |
| AtmMedia | DeviceInterfaceConfigurationItem | Represents an ATM media configuration that can be applied to an interface or sub-interface. |
| VirtualChannelLink | DeviceInterfaceConfigurationItem | Represents a single Virtual Channel Link within an ATM Media configuration. |
| VPI | DeviceInterfaceConfigurationItem | Holds the VPI value and is contained within the Virtual Channel Link. |
| VCI | DeviceInterfaceConfigurationItem | Holds the VCI value and is contained within the Virtual Channel Link. |
| VirtualChannelLinkData | DeviceInterfaceConfigurationItem | Contains the Virtual Channel Link characteristics and is contained with the Virtual Channel Link. |
| AtmInterfaceConfigurationData | DeviceInterfaceConfigurationItem | Contains the ATM configuration applied to an interface. |
Logical Specification Lineage
Example 7-1 shows a logical specification lineage. This lineage shows the intended relationship between specifications.
Example 7-1 Logical Specification Lineage
deviceGeneric
[0..*] interfaceGeneric
[0..1] GenericMedia
[0..1] IP Addresses
[0..*] IpAddress
IpAddress (characteristic)
Prefix (characteristic)
IpVersion (characteristic)
[0..1] Atm Media
[0..1] IP Addresses
[0..*] IpAddress
[0..1] AtmInterfaceConfigurationData
[0..*] VirtualChannelLink
[0..1] VPI
[0..1] VCI
[0..1] VirtualChannelLinkData
Physical Specification Lineage
This section provides an example of a physical specification lineage.
Example 7-2 Physical Specification Lineage
[0..*]GenericEquipmentShelfSpecification
[0..*]GenericEquipmentHolderSpecification
[1]GenericEquipmentSpecification
[0..*]GenericPhysicalPortSpecification
Discovery Action
The Generic SNMP Cartridge supports the Discover Generic SNMP Device action. Table 7-3 shows the discovery action in the Generic SNMP cartridge.
Table 7-3 Discover Generic SNMP Action
| Result Category | AddressHandler | Scan Parameters | Model | Processors |
| Device | IPAddressHandler |
Note: These scan parameters must be added for the Create Scan web service request even if the values are left empty. |
Generic_SNMP_Cartridge |
Discovery Processors
Table 7-4 shows the processors of the Discover Generic SNMP action.
Table 7-4 Discovery Processors
| Processor Name | Variable |
| CPU Property Initializer |
Input: N/A Output: cpuProperties This class is used to initialize and set the default CPU value for the device. |
| Generic Device CPU Set Processor |
Input: Custom CPU Collector processor Response Output: N/A |
| CPU Utilization Compare Processor |
Input: cpuProperties This class is used to initialize and set the default CPU value for the device. Output: N/A |
| MIB-II PropertiesInitializer |
Input: N/A Output:
| DI Name remodel Initializer (inherited) |
Input:N/A Output: remodelerProperties Properties object contains device interface re-modeling information. |
| MIB II SNMP Collector |
Input: N/A Output: mibiisnmpCollectorResponseDocument (implicit) For more information about polled SNMP data, see "About Poll Lists". |
| MIB II SNMP Modeler |
Input:
Output:
| Generic SNMP Logical Collector |
Input: N/A Output: genericSNMPLogicalCollectorResponseDocument (implicit) For more information about polled SNMP data, see "About Poll Lists". |
Generic SNMP Logical Modeler
Input:
Output: genericLogicalDevice This is the logical device that was created in the Generic SNMP Logical Modeler. |
| DI Name Remodeler |
Input:
Output: N/A |
Generic SNMP Physical Collector
Input: N/A Output: genericSNMPPhysicalCollectorResponseDocument (implicit) For more information about polled SNMP data, see "About Poll Lists". |
Generic SNMP Physical Modeler
Input:
Output: physicalDevice This is the physical device that is created in this Generic SNMP Physical Modeler. |
Discrepancy Detection Action
The Detect Generic Device UIM Discrepancies action is used to perform discrepancy detection.
Table 7-5 Detect Generic Device UIM Discrepancies
| Result Category | Results Source | Scan Parameters | Model | Processors |
| All | Discover Generic SNMP Device | N/A | Generic_SNMP_Cartridge |
This action extends the Abstract Detect UIM Discrepancies action included in the UIM Integration cartridge. For more information, see "Overview" in Network Integrity UIM Integration Cartridge Guide. |
Discrepancy Resolution Action
The Resolve Generic Device in UIM action is used to perform discrepancy resolution.
Table 7-6 Resolve Generic Devices in UIM
| Result Category | Result Source | Processors |
| All | Discover Generic SNMP Device | This action extends the Abstract Resolve in UIM action included in the Network Integrity UIM Integration cartridge. For more information, see "Overview" in Network Integrity UIM Integration Cartridge Guide. |
