4 About Cartridge Modeling
The Oracle Communications Network Integrity Optical FTP Discovery Cartridge models the collected data according to Oracle Communications Information Model. The collected data is modeled into the following entities:
Equipment
EquipmentHolder
EquipmentEquipmentRel
EquipmentHolderEquipmentRel
LogicalDevice
PhysicalDevice
PhysicalDeviceEquipmentRel
PhysicalPort
DeviceInterfaceConfiguration
DeviceInterfaceConfigurationItem
See Oracle Communications Information Model Reference for more information about the Information Model.
Cartridge Representation
The following figure shows the object relationship being rendered for Optical Network Vendor Devices.
Hierarchy Mapping
When a device is discovered, the media interface encapsulates common information about that interface. The device interface configuration captures the media type information that decorates the interface with media-specific parameters that define its behavior (that is; Generic, ATM, Frame Relay or VLAN). This cartridge supports only Generic.
Oracle Communications Information Model Information
All entities (for example, physical device, logical device, media interface, and so on) are Oracle Communications Information Model 1.0-compliant for static fields. The dynamic fields (sometimes referred to as characteristics) are application specific. You can customize application-specific data with the device interface configuration mechanism.
The Optical FTP Discovery Cartridge supports the following configuration:
- Optical Generic Media
For the list of Information Model fields, see "Logical Mapping" and "Physical Mapping".
Specifications
This section lists the specifications included in the ora_ni_uim_device cartridge for Optical Network Vendor Devices.
You must first model inventory (UIM) specifications in an inventory cartridge using Design Studio, define the cartridge dependency such that the Network Integrity cartridge is dependent on the inventory cartridge, and then use the inventory cartridge specifications in the Network Integrity cartridge model.
Specifications shared with Oracle Communications Unified Inventory Management (UIM) are defined in the ora_ni_uim_device cartridge. These cartridges are used to directly deploy specifications to UIM.
Physical Device
The following table shows the list of physical device specifications.
Table 4-1 Physical Device Specifications
| Specification | Cartridge | Intended Usage |
| GenericPhysicalDeviceSpecification | ora_ni_uim_device | Used to model all types of Optical Network Vendor devices. |
GenericPhysicalDeviceSpecification is available in ora_ni_uim_device and used to model all types of supported devices.
The following table shows the characteristics applied to the physical device specifications.
Table 4-2 Physical Device Characteristics
| Characteristics | Field Type | Field Content |
| discoveredModelNumber | string | Text |
| discoveredPartNumber | string | Text |
| discoveredVendorName | string | Text |
| hardwareRev | string | Text |
| mgmtIpAddress | string | Text |
| nativeEmsName | string | Text |
| modelName | string | Text |
| owner | string | Text |
| softwareRev | string | Text |
| userLabel | string | Text |
Equipment
The following table shows the list of Equipment specifications.
Table 4-3 Equipment Specifications
| GenericEquipmentShelfSpecification | ora_ni_uim_device | Used to model all types of supported devices. |
| GenericEquipmentSpecification | ora_ni_uim_device | Used to model all types of supported devices. |
GenericEquipmentShelfSpecification and GenericEquipmentSpecification are available in ora_ni_uim_device and used to model all types of supported devices.
The following table shows the characteristics applied to the equipment specifications.
Table 4-4 Equipment Characteristics
| Charecteristics | Field Type | Field Content |
| discoveredModelNumber | String | Text |
| discoveredPartNumber | String | Text |
| discoveredVendorName | String | Text |
| hardwareRev | String | Text |
| softwareRev | String | Text |
| modelName | String | Text |
| nativeEmsName | String | Text |
| owner | String | Text |
| userLabel | String | Text |
Equipment Holder
The following table shows the list of Equipment Holder specifications.
Table 4-5 Equipment Holder Specifications
| GenericEquipmentHolderSpecification | ora_ni_uim_device | Used to model all types of Optical Network Vendor devices. |
GenericEquipmentHolderSpecification is available in ora_ni_uim_device and used to model all types of supported devices.
The following table shows the characteristics applied to the equipment holder specifications.
Table 4-6 Equipment Holder Characteristics
| direction | String | Text |
| edgePoint | String | Text |
| tpProtectionAssociation | String | Text |
Physical Port
The following table shows the list of Physical Port specifications.
Table 4-7 Physical Port Specifications
| GenericPhysicalPortSpecification | ora_ni_uim_device | Used to model all types of Optical Network Vendor devices. |
GenericPhysicalPortSpecification is available in ora_ni_uim_device and used to model all type of supported devices.
The following table shows the characteristics applied to the Physical Port specifications.
Table 4-8 Physical Port Characteristics
| Port Type | String | Text |
| Port Level | String | Text |
Logical Device
The following table shows the list of Logical Device specifications.
Table 4-9 Logical Device Specifications
| GenericLogicalDeviceSpecification | ora_ni_uim_device | Used to model all types of Optical Network Vendor devices. |
GenericLogicalDeviceSpecification is available in ora_ni_uim_device and used to model all type of supported devices.
The following table shows the characteristics applied to the GenericLogicalDeviceSpecification.
Table 4-10 Logical Device Characteristics for GenericLogicalDeviceSpecification
| mgmtIPAddress | String | Text |
| nativeEmsAdminServiceState | String | Text |
| nativeEmsServiceState | String | Text |
| sysObjectId | String | Text |
Device Interface
The following table shows the list of Device Interface specifications.
Table 4-11 Device Interface Specifications
| GenericInterfaceSpecification | ora_ni_uim_device | Used to model all types of Optical Network Vendor devices. |
GenericInterfaceSpecification is available in ora_ni_uim_device and used to model all type of supported devices.
The following table shows the characteristics applied to the GenericInterfaceSpecification specification.
Table 4-12 Device Interface Characteristics for GenericInterfaceSpecification Specification
| Characteristics | Field Type | Filed Content |
| ifAlias | String | Text |
| ifName | String | Text |
| direction | String | N/A |
| edgePoint | Boolean | N/A |
| ifPromiscuousMode | Boolean | N/A |
| mtuCurrent | Long | N/A |
| mtuSupported | Long | N/A |
| nativeEmsConnectorPresent | Boolean | N/A |
| physicalAddress | String | Text |
Specification Cardinality
The cardinality of all specification parent-child relationships is included in the software code so that min= 0 and max= n conditions are met. This approach allows Network Integrity to programmatically instantiate all objects on demand as they are discovered using the web service.
Equipment Visual Specifications
The visual facility on the Equipment specifications is not used. You can decide to upgrade the technology pack to provide visual effects to the UIM GUI for a given equipment entity.
Field Mapping
The Optical FTP Discovery Cartridge supports the following field mappings:
- Text: Implies
Text [255]. - static: Information Model 1.0 defines this field to be static on the entity specification. The specification provides getters and setters for this field.
- dynamic: This is a dynamic field where the entity specification considers the field as a name and value pair. The specification does not provide getters and setters but has a get and set characteristics method holding a HashSet of entries.
- For Optical Network Device FTP, all characteristics are configured using the data retrieved from collected Files.
Logical Mapping
The Optical FTP Discovery Cartridge supports the following logical mappings:
- Logical Device
- Media Interface
- Device Interface Configuration Item Mapping (Optical Generic Media)
Logical Device Mapping
The following table shows Logical Device Mapping.
Table 4-13 Logical Device Mapping
| Characteristic | Information Model Support | Value | Field Type |
| Description | static | NeSubrackType(NE_REPORT) | Text |
| id | static | Programmatically generated as
Text |
| Name | static | Name(NE_REPORT) | Text |
| NativeEMSName | static | Name(NE_REPORT) | Text |
Media Interface Mapping
The following table shows Media Interface Mapping.
Table 4-14 Media Interface Mapping
| id | static | Programmatically generated as Id::Name::InterfaceName::ShelfNumber::SlotNumber::PortNumber | Text |
| Name | static | Interface Name (Interface_Resource_Report) | Text |
| description | static | Interface Description (Interface_Resource_Report) | Text |
| specification | static | Programmatically applies specification "GenericInterfaceSpecification". | N/A |
| interfaceNumber | static | N/A | Text |
| customerInterfaceNumber | static | N/A | Text |
| vendorInterfaceNumber | static | N/A | Text |
| nativeEmsName | static |
Text |
| nativeEmsAdminServiceState | static | N/A |
Enum with the following values:
| nativeEmsServiceState | static | Status (Interface_Resource_Report) |
| ifType | dynamic | Interface Type (Interface_Resource_Report) | Text |
| mtuSupported | static | N/A | Float |
| mtuCurrent | static | mtuCurrent (Interface_Resource_Report) | Float |
| physicalAddress | static | N/A | Text |
| physicalLocation | static | N/A | Text |
| minSpeed | static | N/A | Float |
| maxSpeed | static | N/A | Float |
| nominalSpeed | static | Speed (Interface_Resource_Report) | Float |
| ifAlias | dynamic | N/A | Text |
| ifName | dynamic | N/A | Text |
The following table shows Device Interface Configuration Item Mapping.
Table 4-15 Device Configuration Item (IPv4) Mapping
| Characteristic (Generic Media) | Information Model Support | Value | Field Type |
| ipAddress | dynamic | IPv4Address (Interface_Resource_Report) | Text |
| prefix | dynamic | N/A | Text |
| ipVersion | dynamic | Programmatically Generated as IPv4 |
Enum
| specification | static | Programmatically applies Optical GenericMedia specification | N/A |
Table 4-16 Device Configuration Item (IPv6) Mapping
| ipAddress | dynamic | IPv6Address (Interface_Resource_Report) | Text |
| ipVersion | dynamic | Programmatically Generated as IPV6 |
Enum
Physical Mapping
The Optical FTP Discovery Cartridge supports the following physical mappings:
- Physical Device
- Equipment Shelf
- Equipment Holder
- Equipment Card
- Physical Port
Physical Device Mapping
The following table shows Physical Device mapping.
Table 4-17 Physical Device Mapping
| Characteristic (Generic Physical Device Specification) | Information Model Support | Value | Field Type |
| SoftwareRev | dynamic | SoftwareRev(NE_REPORT) | Text |
| PhysicalLocation | static | Location(PHYSICAL_LOCATION_FILE) | Text |
| ModelName | dynamic | NeType(NE_REPORT) | Text |
| id | static |
Programmatically generated as Id::Name::"PhysicalDevice" |
Text |
| DiscoveredVendorName | dynamic | Set to "opticalVendor" | Text |
Equipment Shelf Mapping
The following table shows Equipment Shelf mapping.
Table 4-18 Equipment Shelf Mapping
| Characteristic (GenericEquipmentSheflSpecification) | Information Model Support | Value | Field Type |
| id | static |
Programmatically generated as Type(SUBRACK_REPORT) |
Text |
| Name | static |
Text |
| Description | static | Description(SUBRACK_REPORT) | Subnet(SUBRACK_REPORT) | Text |
| NativeEmsName | static |
Text |
| PhysicalLocation | static | PhysicalLocation(PHYSICAL_LOCATION_FILE) | Text |
| ModelName | dynamic | Set to "OPTICAL-SHELF" | Text |
| DiscoveredPartNumber | dynamic |
Text |
Equipment Holder Mapping
The following table shows Equipment Holder mapping.
Table 4-19 Equipment Holder Mapping
| Characteristic (GenericEquipmentHolderSpecification) | Information Model Support | Value | Field Type |
| id | static | Programmatically generated | Text |
| Name | static |
Programmatically generated as |
Text |
| NativeEMSName | static | Programmatically generated | Text |
| Owner | dynamic | Set to "opticalVendor" | Text |
Equipment Card Mapping
The following table shows Equipment Card mapping.
Table 4-20 Equipment Card Mapping
| Characteristic (GenericEquipmentCardSpecification) | Information Model Support | Value | Field Type |
| Name | static | Name (BOARD_REPORT) | Text |
| Description | static | Description (BOARD_REPORT) | Text |
| SerialNumber | static |
Programmatically generated using SerialNo (BOARD_REPORT) |
Text |
| ModelName | dynamic | Set to "OPTICAL-CARD" | Text |
| DiscoveredPartNumber | dynamic | Type (BOARD_REPORT) | Text |
| HardwareRev | dynamic | HardwareRev (BOARD_REPORT) | Text |
Physical Port Mapping
The following table shows Physical Port mapping.
Table 4-21 Physical Port Mapping
| Characteristic (GenericPhysicalPortSpecification) | Information Model Support | Value | Field Type |
| Name | static | Name (PORT_REPORT) | Text |
| Description | static | PortNeType (PORT_REPORT) | Text |
| VendorPortName | static | Name (PORT_REPORT) | Text |
| PortNumber | static | PortNum (PORT_REPORT) | Text |
| Direction | dynamic | Set to "Bidirectional" | Text |
| EdgePoint | dynamic | Set to "true" | Text |
| Port Type | dynamic | Port Type (PORT_REPORT) | Text |
| Port Level | dynamic | Port Level (PORT_REPORT) | Text |
About Design Studio Construction
This chapter provides information on the composition of the Oracle Communications Network Integrity Optical FTP Discovery Cartridge from the Oracle Communications Design Studio perspective.
The following table shows the Optical_FTP_Discovery_Cartridge model collection used in the Optical FTP Discovery cartridge.
Table 4-22 Optical_FTP_Discovery_Cartridge Model Collection
| Specification | Information Model Entity Type | Intended Usage |
| GenericLogicalDeviceSpecification | LogicalDevice | Represents the root object discovered on the network for the devices. Logical Device Modeler models logical devices into GenericLogicalDeviceSpecification. |
| GenericPhysicalDeviceSpecification | PhysicalDevice | Represents any Optical Network Vendor Device discovered using FTP protocol. |
| GenericEquipmentHolderSpecification | EquipmentHolder | Represents any equipment container. |
| GenericEquipmentShelfSpecification | Equipment | Represents Chassis piece of equipment. |
| GenericEquipmentSpecification | Equipment | Represents Module piece of equipment. |
| GenericPhysicalPortSpecification | PhysicalPort | Represents any physical port. |
| GenericInterfaceSpecification | DeviceInterface | Represents interface discovered under GenericLogicalDeviceSpecification. |
Logical Specification Lineage
The following example shows a logical specification lineage for Devices. This lineage shows the intended relationship between specifications.
Example 4-1 Logical Specification Lineage
[0..*] GenericInterfaceSpecification
[0..1] Optical Generic Media Configuration Item
[0..1] Optical IP Addresses
[0..*] Optical IP Address
Physical Specification Lineage
The following example shows a physical specification lineage for Devices. This lineage shows the intended relationship between specifications.
Example 4-2 Physical Specification Lineage
[0..*] GenericEquipmentHolderSpecification
[0..1] GenericEquipmentSpecification
[0..1] GenericPhysicalPortSpecification
Discovery Action
Optical FTP Discovery Cartridge supports discovery action Discover optical Devices FTP.
The following table shows the discovery actions in the Optical FTP Discovery Cartridge.
Table 4-23 Discover optical Devices FTP
| Result Category | Address Handler | Scan Parameters | Model | Processors |
| Device | FileTransferAddressHandler |
Note: These scan parameters must be added for the Create Scan web service request even when the values are left empty. |
Optical_FTP_Discovery_Cartridge |
Discovery Processors
Table 4-24 Discover Optical Devices FTP Scan Action Processors
| Processor Name | Variable |
| Optical File Transfer Collector |
Input: N/A Output:
Collection of files read from the scope provided. |
| Optical File Transfer Parser |
Input:
Output:
| Optical File Transfer Device Modeler |
Input: neObjects Output: N/A |
Discrepancy Detection Action
Detect Optical Device UIM Discrepancies is the action used to perform Discrepancy detection.
Table 4-25 Detect Optical Device UIM Discrepancies
| Result Category | Results Score | Scan Parameters | Model | Processors |
| All | Discover optical Devices FTP | N/A | Optical_FTP_Discovery_Cartridge | This action extends the Abstract Detect UIM Discrepancies action included in the UIM Integration cartridge. See "Abstract Detect UIM Discrepancies Action" in Network Integrity UIM Integration Cartridge Guide for more information. |
Discrepancy Resolution Action
Resolve Optical Device in UIM is the action used to perform Discrepancy Resolution.
Table 4-26 Resolve Optical Device in UIM
| Result Category | Result Score | Processor |
| All | Discover optical Devices FTP | This action extends the Abstract Resolve in UIM action included in the Network Integrity UIM Integration cartridge. See "Abstract Resolve in UIM Action" in Network Integrity UIM Integration Cartridge Guide for more information. |
