2 Network Integrity System Requirements
This chapter describes the hardware, operating system, software, server, and database requirements for installing Oracle Communications Network Integrity.
Software Requirements
Network Integrity consists of a base application that is installed on an Oracle WebLogic server domain. It connects with an Oracle database to store all relevant information, and can connect to a report publishing tool if you require reports to be published. You must install and connect all required software with Network Integrity for optimal performance.
Supported Operating Systems
Table 2-1 lists operating systems that support the Network Integrity server. Use the My Oracle Support Certifications tab to access the latest software platform support information. See knowledge article 1491004.1 or the My Oracle Support Help on the My Oracle Support Web site for additional information:
Table 2-1 Supported Server-Side Operating Systems
| Product | Version |
Oracle Linux on x86 (64-bit) |
Linux 8.x or higher (with the latest available updates) Linux 9.x or higher (with the latest available updates) |
When installing Network Integrity in a multi-host shared-disk cluster environment, you must have full permissions on the NI_Home, MW_Home, WL_Home, and Domain_Home directories.
Refer to "Directory Placeholders Used in This Guide" for information on these directories.
Required Software
Table 2-2 lists software required on the server for installing and running Network Integrity.
Table 2-2 Required Server-Side Software
| Product | Version |
Oracle WebLogic Server Enterprise Edition (included with the Oracle Fusion Middleware WebLogic Server and Coherence distribution in the Oracle Fusion Middleware 12c software) |
12c (12.2.1.4) |
Oracle Fusion Middleware Application Development Runtime, including Enterprise Manager and Repository Creation Utility (included with the Oracle Fusion Middleware Infrastructure distribution in the Oracle Fusion Middleware 12c software) |
12c (12.2.1.4) |
Oracle Fusion Middleware Repository Creation Utility (RCU) for Linux (included with Oracle Data Integrator) |
12c (12.2.1.4) |
Oracle Java SE Development Kit (JDK) for Linux |
Java 8 with latest critical patch update |
Oracle Database Enterprise Edition |
19c (19.25) |
Oracle Access Manager (OAM), included with Oracle Identity and Access Management |
12c (12.2.1.4.0) |
The Network Integrity Installer checks for all required software and displays errors if it detects any missing or unavailable components, or if there are any connectivity related issues.
Table 2-3 lists software required to access the Network Integrity UI.
Table 2-3 Required Client-Side Software
| Product | Version |
Operating System |
Microsoft Windows 10, 11 (Windows is for development only) |
Java Runtime Environment (JRE) |
Web Browser |
Google Chrome 131.x or later Mozilla Firefox 132.0 or later |
Oracle Communications Service Catalog and Design |
See "Service Catalog and Design Compatibility" in SCD Compatibility Matrix (included in the Design Studio documentation) for Design Studio compatibility information. |
Oracle Fusion Middleware JDeveloper Studio Generic |
12c (12.2.1.4.0) |
Design Studio is required for developing cartridges that extend Network Integrity. Install Design Studio on a computer with network access to the Network Integrity server.
For Oracle Communications Service Catalog and Design - Design Studio plug-in installation information, see "Design Studio Installation Overview (1)" in Design Studio Installation Guide.
Supported Software
Table 2-4 lists additional software that is supported by Network Integrity.
Table 2-4 Supported Software
| Product | Version |
Oracle Analytics Publisher |
6.4.0 Oracle Analytics Publisher is required to use the reporting templates included with Network Integrity. |
Oracle Communications Unified Inventory Management (UIM) |
7.7.0.0.0 |
Oracle Communications MetaSolv Solution (MSS) |
6.3 |
Oracle Internet Directory |
12.2.1.4 or higher |
Supported software is installed and licensed separately from Network Integrity.
Hardware Requirements
The number and configuration of the systems that you employ for your Network Integrity installation depends on the scale and the kind of deployment you have planned according to your network(s).
The sizing estimates contained in this section are based on the assumptions of proper application configuration and tuning, in a manner consistent with leading practices of Oracle Communications consulting and performance engineering. This information is provided for informational purposes only and is not intended to be, nor shall it be construed as a commitment to deliver Oracle programs or services. This document shall not form the basis for any type of binding representation by Oracle and shall not be construed as containing express or implied warranties of any kind. You understand that information contained in this document will not be a part of any agreement for Oracle programs and services. Business parameters and operating environments vary substantially from customer to customer and as such not all factors, which may impact sizing, have been accounted for in this documentation.
Table 2-5 provides the minimal hardware requirement for Network Integrity installed on a single managed server in a WebLogic domain.
Table 2-5 Network Integrity Minimum Hardware Requirements
| Component | Requirement |
Hard disk |
Minimum 150 GB on each managed server. |
Processor |
Oracle recommends using a minimum of 4 OCPUs on each managed server. |
Memory |
Minimum 32 GB physical memory on each managed server. |
Temporary disc space |
Minimum 20 GB. The Network Integrity Installer uses a temporary directory to extract all installation files. |
Information Requirements
During Network Integrity installation, you must enter configuration values such as host names and port numbers. This section describes the information that you must provide during the installation process. You define some of these configuration values when you install and configure the Oracle database and WebLogic Server.
If you have already installed other Oracle Communications products, the installer reads the values from the existing Oracle Communications products and uses them as default values. If no existing Oracle Communications products are installed, the installer proposes default values.
WebLogic Connection Information
Table 2-6 lists WebLogic Server and domain connection details that you are required to provide during installation.
Table 2-6 Application Server Connection Information
| Information Type | Description |
Host name |
The host name for the particular WebLogic server instance to define it uniquely for the specific purpose of installing, and working with, Network Integrity. |
Port number |
This is the number assigned to this specific service. Port numbers are usually pre-defined and you can accept the provided default value. |
User name |
Your WebLogic Server user name. You define this name when you install Oracle WebLogic Server. |
Password |
Your password to connect to the WebLogic server as the user for which you provided the user name. You define this password along with the user name during the Oracle WebLogic Server installation. |
Database Connection Information
Table 2-7 lists database connection details that you are required to provide during installation.
Table 2-7 Database Connection Information
Host name |
Host name or IP address of the Oracle Database server for Network Integrity. |
Port number |
User name |
Your database user name. You define the user name when you install the database. |
Password |
Your password to connect to the database as the user for which you provided the user name. You define this password along with the user name during database installation. |
Service name |
This is the name of the database service or instance to remotely connect to the database. For example, oracle.com. |
Database Connection Information for Real Application Cluster Database
Table 2-8 lists database connection details for an Oracle Real Application Cluster (RAC) database that you are required to provide during installation.
Table 2-8 Database Connection Information for Oracle RAC Database
Oracle RAC database connection string |
The information string that is used to connect to the Oracle RAC database. For example, HOST NAME1:PORT1:SERVICE NAME1, HOST NAME2:PORT2:SERVICE NAME2. |
User name |
A database user name with SYS privileges. You define the user name when you install the database. |
Password |
Schema User Name Information
Table 2-9 lists schema user details that you are required to provide during installation.
Table 2-9 Schema user Information
Schema user name |
Your schema user name that you use to access the Network Integrity schema. |
Schema user password |
The password to access the Network Integrity schema for the schema user you defined. |
Hardware Sizing Considerations
Use Table 2-10, Table 2-11, and Table 2-12 as a general guideline when planning the hardware for your Network Integrity system.
The information in this section is meant as a guideline only. The values in this section are approximate. Accurate sizing for a production system requires a detailed analysis of the proposed business requirements. The guidelines do not account for High Availability, Disaster Recovery environments or lower test and dev environments.
- The below sizing information for each network domain is mutually exclusive and is considered at 70% CPU utilization. In case multiple domains need to be supported, it is necessary to add suggested sizing per domain and procure the resulting total.
- Additionally, 4 OCPUs are required on the Inventory system (UIM) during the reconciliation and import process to ensure no impact on ongoing inventory/UIM system processing.
Table 2-10 Network Integrity Hardware Planning Guideline
| Product Cartridge | Network Domain | Protocol | NI Actions benchmarked | Network Resources |
TMF814Discovery_Cartridge Optical_UIM_Cartridge |
Optical (SDH/DWDM/ SONET) |
CORBA | Discovery, Discrepancy Detection, Reconciliation, Import | Physical Network Resources (Node, Equipment, Slot, Card, Port and Interface) |
SDH_Discovery_Cartridge SDH_UIM_Cartridge |
SDH | FTP | Discovery, Discrepancy Detection, Reconciliation, Import | Logical Network Resources (Topological links, Trails, Tunnels and Services) |
DWDM_Logical_Discovery_Cartridge DWDM_Logical_Assimilation_Cartridge |
DWDM | CORBA | Discovery, Discrepancy Detection, Reconciliation, Import | Logical Network Resources (Services, ODU, OTU, OCH, OMS and OTS) |
Generic_SNMP_Cartridge UIM_Integration_Cartridge |
IP | SNMP | Discovery, Discrepancy Detection, Reconciliation, Import | Physical Network Resources (Node, Equipment, Slot, Card, Port and Interface) |
Table 2-11 Network Integrity Hardware Planning Guideline
| Network Domain | Supported chunk size in single scan | Minimum Required Resources | Oracle Cloud Infrastructure Equivalent |
5k Devices |
NI 4*4 OCPU and 128 GB RAM (4 MS each with 4 OCPUs and 32 GB RAM) |
4 * VM.Standard3.Flex |
| SDH assimilated topology | 100k Resources |
| DWDM assimilated topology | 100k SNCs |
| IP | 2k Devices |
Example: NI 4*4 OCPU and 128 GB RAM
- NI Admin Server → Machine 1 → 4 OCPU → 2 GB RAM
- NI Proxy → Machine 1 → 4 OCPU → 2 GB RAM
- NI MS1→ Machine 1 → 4 OCPU → 24 GB RAM
- NI MS2 → Machine 2 → 4 OCPU → 28 GB RAM
- NI MS3 → Machine 3 → 4 OCPU → 28 GB RAM
- NI MS4 → Machine 4 → 4 OCPU → 28 GB RAM
It is recommended to reserve approximately 4 GB of RAM accessible for Linux utility tasks rather than using the entire 32 GB of RAM of the system for NI application processes.
Table 2-12 Hardware Sizing Guideline for Network Integrity Deployment
| System Size and Range | Linux | Oracle Database Server | Sample Scan Configuration |
Small
Up to 20k device
Up to 50k assimilated topology
Medium
Up to 50k device
Up to 100k assimilated topology
Large
Up to 75k device
Up to 200k assimilated topology
Extra-large
Up to 200k device
Up to 400k assimilated topology
Tablespace needs to be increased periodically, based on the scan's frequency and data volume.
