4 About Cartridge Modeling
This chapter provides information on modeling the Oracle Communications Network Integrity MIB-II UIM Integration cartridge.
For information about the following, see "About Cartridge Modeling" in Network Integrity MIB-II SNMP Cartridge Guide:
MIB-II UIM Integration Cartridge UML Representation
Hierarchy Mapping
Oracle Communications Information Model Information
Specifications
Field Mappings
Specification Support in UIM
You must first model inventory (UIM) specifications in an inventory cartridge using Design Studio, define the cartridge dependency such that the Network Integrity cartridge is dependent on the inventory cartridge, and then use the inventory cartridge specifications in the Network Integrity cartridge model.
Specifications shared with Oracle Communications Unified Inventory Management (UIM) are defined in the ora_ni_uim_device cartridge. This cartridge is used to directly deploy specifications to UIM.
Oracle Communications Design Studio features are used to tag certain characteristics as specific to UIM. These characteristics appear on specifications deployed to UIM, but they do not appear on specifications deployed to Network Integrity.
Network Integrity specifications such as GenericMedia are defined in the MIB-II SNMP cartridge. This cartridge references ora_ni_uim_device for the shared deviceGeneric and interfaceGeneric specifications.
The following tables identify which characteristics on the shared specifications are specific to UIM.
Device Generic Characteristics
Table 4-1 shows Device Generic characteristics.
Table 4-1 Device Generic Characteristics
| Characteristic Name | Specific to UIM |
mgmtIpAddress |
No |
sysObjectId |
No |
nativeEmsAdminServiceState |
Yes |
nativeEmsServiceState |
Yes |
nativeEmsName |
Yes |
Interface Generic Characteristics
Table 4-2 shows Interface Generic characteristics.
Table 4-2 Interface Generic Characteristics
ifAlias |
No |
ifName |
No |
ifPromiscuousMode |
No |
ifType |
Yes |
minSpeed |
Yes |
maxSpeed |
Yes |
nominalSpeed |
Yes |
physicalAddress |
Yes |
physicalLocation |
Yes |
nativeEmsConnectorPresent |
Yes |
mtuCurrent |
Yes |
mtuSupported |
Yes |
Yes |
Yes |
nativeEmsName |
Yes |
ifSpeed |
Yes |
highSpeed |
Yes |
