2 Network Integrity System Requirements
Learn about Oracle Communications Network Integrity, including installation procedures, system requirements, hardware sizing, and supported software.
Software Requirements
Network Integrity consists of a base application that is installed on an Oracle WebLogic server domain. It connects with an Oracle database to store all relevant information. You must install and connect all required software with Network Integrity for optimal performance.
Supported Operating Systems
Table 2-1 lists operating systems that support the Network Integrity server. Use the My Oracle Support Certifications tab to access the latest software platform support information. See knowledge article 1491004.1 or the My Oracle Support Help on the My Oracle Support Web site for additional information:
https://support.oracle.com
Table 2-1 Supported Server-Side Operating Systems
Product Version
Oracle Linux on x86 (64-bit)
Linux 8.x or higher (with the latest available updates)
Linux 9.x or higher (with the latest available updates)
When installing Network Integrity in a multi-host shared-disk cluster environment, you must have full permissions on the NI_Home, MW_Home, WL_Home, and Domain_Home directories.
Refer to "Directory Placeholders Used in This Guide" for information on these directories.
Required Software
Table 2-2 lists software required on the server for installing and running Network Integrity.
Table 2-2 Required Server-Side Software
Product Version
Oracle Fusion Middleware Infrastructure 14c (14.1.2.0.0)
Oracle Java SE Development Kit (JDK) for Linux
Java 21 with latest critical patch update
Oracle Database Enterprise Edition
19c (19.25) or 236i
Oracle Access Manager (OAM), included with Oracle Identity and Access Management
14c (14.1.2.0.0)
The Network Integrity Installer checks for all required software and displays errors if it detects any missing or unavailable components, or if there are any connectivity related issues.
Table 2-3 lists software required to access the Network Integrity UI.
Table 2-3 Required Client-Side Software
Product Version
Operating System
Microsoft Windows 10, 11
(Windows is for development only)
Java Runtime Environment (JRE)
Web Browser
Google Chrome 131.x or later
Mozilla Firefox 132.0 or later
Oracle Communications Service Catalog and Design
See "Service Catalog and Design Compatibility" in SCD Compatibility Matrix (included in the Design Studio documentation) for Design Studio compatibility information.
Oracle Fusion Middleware JDeveloper Studio Generic
14c (14.1.2.0.0)
Design Studio is required for developing cartridges that extend Network Integrity. Install Design Studio on a computer with network access to the Network Integrity server.
For Oracle Communications Service Catalog and Design - Design Studio plug-in installation information, see "Design Studio Installation Overview" in Design Studio Installation Guide.
Supported Software
The additional software supported by Network Integrity is as follows:
  • Oracle Analytics Publisher: Oracle Analytics Publisher is required to use the reporting templates included with Network Integrity.
  • Oracle Communications Unified Inventory Management (UIM)
  • Oracle Communications MetaSolv Solution (MSS)
  • Oracle Internet Directory
Supported software is installed and licensed separately from Network Integrity. For more information on supported software versions, see Network Integrity Compatibility Matrix.
Hardware Requirements
The number and configuration of the systems that you employ for your Network Integrity installation depends on the scale and the kind of deployment you have planned according to your network(s).
The sizing estimates contained in this section are based on the assumptions of proper application configuration and tuning, in a manner consistent with leading practices of Oracle Communications consulting and performance engineering. This information is provided for informational purposes only and is not intended to be, nor shall it be construed as a commitment to deliver Oracle programs or services. This document shall not form the basis for any type of binding representation by Oracle and shall not be construed as containing express or implied warranties of any kind. You understand that information contained in this document will not be a part of any agreement for Oracle programs and services. Business parameters and operating environments vary substantially from customer to customer and as such not all factors, which may impact sizing, have been accounted for in this documentation.
Table 2-4 provides the minimal hardware requirement for Network Integrity installed on a single managed server in a WebLogic domain.
Table 2-4 Network Integrity Minimum Hardware Requirements
Component Requirement
Hard disk
Minimum 150 GB on each managed server.
Processor
Oracle recommends using a minimum of 4 OCPUs on each managed server.
Memory
Minimum 32 GB physical memory on each managed server.
Temporary disc space
Minimum 20 GB.
The Network Integrity Installer uses a temporary directory to extract all installation files.
Information Requirements
During Network Integrity installation, you must enter configuration values such as host names and port numbers. This section describes the information that you must provide during the installation process. You define some of these configuration values when you install and configure the Oracle database and WebLogic Server.
WebLogic Connection Information
Table 2-5 lists WebLogic Server and domain connection details that you are required to provide during installation.
Table 2-5 Application Server Connection Information
Information Type Description
Host name
The host name for the particular WebLogic server instance to define it uniquely for the specific purpose of installing, and working with, Network Integrity.
Port number
This is the number assigned to this specific service. Port numbers are usually pre-defined and you can accept the provided default value.
User name
Your WebLogic Server user name. You define this name when you install Oracle WebLogic Server.
Password
Your password to connect to the WebLogic server as the user for which you provided the user name. You define this password along with the user name during the Oracle WebLogic Server installation.
Database Connection Information
Table 2-6 lists database connection details that you are required to provide during installation.
Table 2-6 Database Connection Information
Host name
Host name or IP address of the Oracle Database server for Network Integrity.
Port number
User name
Your database user name. You define the user name when you install the database.
Password
Your password to connect to the database as the user for which you provided the user name. You define this password along with the user name during database installation.
Service name
This is the name of the database service or instance to remotely connect to the database. For example, oracle.com.
Database Connection Information for Real Application Cluster Database
Table 2-7 lists database connection details for an Oracle Real Application Cluster (RAC) database that you are required to provide during installation.
Table 2-7 Database Connection Information for Oracle RAC Database
Oracle RAC database connection string
The information string that is used to connect to the Oracle RAC database. For example, HOST NAME1:PORT1:SERVICE NAME1, HOST NAME2:PORT2:SERVICE NAME2.
User name
A database user name with SYS privileges. You define the user name when you install the database.
Password
Schema User Name Information
Table 2-8 lists schema user details that you are required to provide during installation.
Table 2-8 Schema user Information
Schema user name
Your schema user name that you use to access the Network Integrity schema.
Schema user password
The password to access the Network Integrity schema for the schema user you defined.
Hardware Sizing Considerations
Use Table 2-9, Table 2-10, and Table 2-11 as a general guideline when planning the hardware for your Network Integrity system.
  • The information in this section is meant as a guideline only. The values in this section are approximate. Accurate sizing for a production system requires a detailed analysis of the proposed business requirements. The guidelines do not account for High Availability, Disaster Recovery environments or lower test and dev environments.
  • The below sizing information for each network domain is mutually exclusive and is considered at 70% CPU utilization. In case multiple domains need to be supported, it is necessary to add suggested sizing per domain and procure the resulting total.
  • Additionally, 4 OCPUs are required on the Inventory system (UIM) during the reconciliation and import process to ensure no impact on ongoing inventory/UIM system processing.
Table 2-9 Network Integrity Hardware Planning Guideline
Product Cartridge Network Domain Protocol NI Actions benchmarked Network Resources
TMF814Discovery_Cartridge
Optical_UIM_Cartridge
Optical
(SDH/DWDM/ SONET)
CORBA Discovery, Discrepancy Detection, Reconciliation, Import Physical Network Resources (Node, Equipment, Slot, Card, Port and Interface)
SDH_Discovery_Cartridge
SDH_UIM_Cartridge
SDH FTP Discovery, Discrepancy Detection, Reconciliation, Import Logical Network Resources (Topological links, Trails, Tunnels and Services)
DWDM_Logical_Discovery_Cartridge
DWDM_Logical_Assimilation_Cartridge
DWDM CORBA Discovery, Discrepancy Detection, Reconciliation, Import Logical Network Resources (Services, ODU, OTU, OCH, OMS and OTS)
Generic_SNMP_Cartridge
UIM_Integration_Cartridge
IP SNMP Discovery, Discrepancy Detection, Reconciliation, Import Physical Network Resources (Node, Equipment, Slot, Card, Port and Interface)
Netconf_Network_Discovery_Cartridge NETCONF NETCONF Discovery, Discrepancy Detection, Reconciliation, Import Physical Network Resources (Node, Equipment, Slot, Card, Port and Interface)
Restconf_Network_Discovery_Cartridge RESTCONF RESTCONF Discovery, Discrepancy Detection, Reconciliation, Import Physical Network Resources (Node, Equipment, Slot, Card, Port and Interface)
Layer2_VPN_Service_Discovery IP SNMP Discovery, Assimilation, Import, Discrepancy Detection, Reconciliation Logical Network Resources (VPLS Service ,VLL Service ,Pseudowires , Attachment circuits ,vlan,bridge group and bridge domain,VFI)
MPLS_L3_VPN_Service_Discovery_Cartridge IP SNMP Discovery, Assimilation, Import, Discrepancy Detection, Reconciliation Logical Network Resources (MPLS Service, MPLS Traffic Engineering Tunnels, VRF, Quality of Service(QOS), Routing Protocol details (EIGRP, BPG, OSPF, ISIS))
Table 2-10 Network Integrity Hardware Planning Guideline
Network Domain Supported chunk size in single scan Minimum Required Resources Oracle Cloud Infrastructure Equivalent
Optical
(SDH/DWDM/ SONET)
5k Devices
NI 4*4 OCPU and 128 GB RAM
(4 MS each with 4 OCPUs and 32 GB RAM)
4 * VM.Standard3.Flex
SDH assimilated topology 100k Resources
DWDM assimilated topology 100k SNCs
IP 2k Devices
NETCONF 10k Devices NI 4*4 OCPU and 128 GB RAM (4 MS each with 4 OCPUs and 32 GB RAM) 4 * VM.Standard3.Flex
RESTCONF 10k Devices NI 4*4 OCPU and 128 GB RAM (4 MS each with 4 OCPUs and 32 GB RAM) 4 * VM.Standard3.Flex
Layer 2 VPN Services 10k services NI 4*4 OCPU and 128 GB RAM (4 MS each with 4 OCPUs and 32 GB RAM) 4 * VM.Standard3.Flex
Layer 3 VPN Services 10k services NI 4*4 OCPU and 128 GB RAM (4 MS each with 4 OCPUs and 32 GB RAM) 4 * VM.Standard3.Flex
Example: NI 4*4 OCPU and 128 GB RAM
  • NI Admin Server → Machine 1 → 4 OCPU → 2 GB RAM
  • NI Proxy → Machine 1 → 4 OCPU → 2 GB RAM
  • NI MS1→ Machine 1 → 4 OCPU → 24 GB RAM
  • NI MS2 → Machine 2 → 4 OCPU → 28 GB RAM
  • NI MS3 → Machine 3 → 4 OCPU → 28 GB RAM
  • NI MS4 → Machine 4 → 4 OCPU → 28 GB RAM
It is recommended to reserve approximately 4 GB of RAM accessible for Linux utility tasks rather than using the entire 32 GB of RAM of the system for NI application processes.
Table 2-11 Hardware Sizing Guideline for Network Integrity Deployment
System Size and Range Linux Oracle Database Server Sample Scan Configuration
Small
  • Up to 20k device
  • Up to 50k assimilated topology
  • CPU: 4 x 4 core - 2.55 GHz
  • AMD EPYC™ 77J3: 8 threads
  • RAM: 4 x 32 GB
  • HDD: 4 X 150 GB
  • CPU: 1 x 8 core - 2.55 GHz
  • AMD EPYC™ 77J3: 16 threads
  • RAM: 1 x 120 GB
  • Initial storage: 500 GB
  • Network Integrity tablespace: 200 GB
Up to 20k device
  • Scenario 1: Four scan for 5k chunk size for optical domain covering 20k device.
  • Scenario 2: Ten scan for 2k chunk size for IP domain covering 20k device.
  • Scenario 3: Five scans for a 2k chunk size for IP domains spanning 10k devices and two scans for a 5k chunk size for Optical domain spanning 10k devices.
  • Scenario 4:Two scan for 10k chunk size for NETCONF domain covering 20k device.
  • Scenario 5:Two scan for 10k chunk size for RESTCONF domain covering 20k device.
  • Scenario 6: One scan with a 4k chunk covering 4k L2 VPN services.
  • Scenario 7: One scan with a 4k chunk covering 4k L3 VPN services.
  • Scenario 8: One 2k L2 scan and one 2k L3 scan, covering a total of 4k VPN services.
  • Scenario 1: One scan for 50k chunk size covering 50k SDH assimilated topology.
  • Scenario 2: One scan for 50k chunk size covering 50k DWDM assimilated topology.
  • Scenario 3: One scan for a 25k chunk size for SDH domains spanning 25k SDH topology and one scans for a 25k chunk size for DWDM domain spanning 25k DWDM topology.
  • Scenario 4: Two scans for a 10k chunk size for NETCONF domain spanning 20k devices.
  • Scenario 5: Two scans for a 10k chunk size for RESTCONF domain spanning 20k devices.
Medium
  • Up to 50k device
  • Up to 100k assimilated topology
  • CPU: 8 x 4 core - 2.55 GHz
  • RAM: 8 x 32 GB
  • HDD: 8 X 150 GB
  • CPU: 2 x 16 core - 2.55 GHz
  • AMD EPYC™ 77J3: 64 threads
  • RAM: 2 x 240 GB
  • Initial storage: 800 GB
  • Network Integrity tablespace - 300 GB
Up to 50k device
  • Scenario 1: Ten scans for 5k chunk size for optical domain covering 50k device.
  • Scenario 2: Twenty five scans for 2k chunk size for IP domain covering 50k device.
  • Scenario 3: Ten scans for a 2k chunk size for IP domains spanning 20k devices and six scans for a 5k chunk size for Optical domain spanning 30k devices.
  • Scenario 4: Five scans for a 10k chunk size for NETCONF domain spanning 50k devices.
  • Scenario 5: Five scans for a 10k chunk size for RESTCONF domain spanning 50k devices.
  • Scenario 6: One scan with a 10k chunk covering 10k L2 VPN services.
  • Scenario 7: One scan with a 10k chunk covering 10k L3 VPN services.
  • Scenario 8: One 5k L2 scan and one 5k L3 scan, covering a total of 10k VPN services.
  • Scenario 1: One scan for 100k chunk size covering 100k SDH assimilated topology.
  • Scenario 2: One scan for 100k chunk size covering 100k DWDM assimilated topology.
  • Scenario 3: One scan for a 50k chunk size for SDH domains spanning 50k SDH topology and one scans for a 50k chunk size for DWDM domain spanning 50k DWDM topology.
Large
  • Up to 75k device
  • Up to 200k assimilated topology
  • CPU: 12 x 4 core - 2.55 GHz
  • RAM: 12 x 32 GB
  • HDD: 12 X 150 GB
  • CPU: 2 x 24 core - 2.55 GHz
  • AMD EPYC™ 77J3: 96 threads
  • RAM: 2 x 320 GB
  • Initial storage: 2 TB
  • Network Integrity tablespace: 400 GB
Up to 75k device
  • Scenario 1: Fifteen scans for 5k chunk size for optical domain covering 75k device.
  • Scenario 2: Thirty eight scans for 2k chunk size for IP domain covering 75k device.
  • Scenario 3: Ten scans for 2k chunk size for IP domains spanning 20k devices and eleven scans for 5k chunk size for Optical domain spanning 55k devices.
  • Scenario 4: Seven scans for a 10k chunk size for NETCONF domain spanning 70k devices and one scan for a 5k chunk size of Optical domain spanning 5k devices.
  • Scenario 5: Seven scans for a 10k chunk size for RESTCONF domain spanning 70k devices and one scan for 5k chunk size of Optical domain spanning 5k devices.
  • Scenario 6: Two L2 scans: one 10k chunk and one 5k chunk, covering 15k L2 VPN services.
  • Scenario 7: Two L3 scans: one 10k chunk and one 5k chunk, covering 15k L3 VPN services.
  • Scenario 8: One 7.5k L2 scan and one 7.5k L3 scan, covering a total of 15k VPN services.
  • Scenario 9: One5k L2 scan and one 10k L3 scan, covering a total of 15k VPN services.
  • Scenario 10: One 10k L2 scan and one 5k L3 scan, covering a total of 15k VPN services.
  • Scenario 1: Two scans for 100k chunk size covering 100k SDH assimilated topology.
  • Scenario 2: Two scans for 100k chunk size covering100k DWDM assimilated topology.
  • Scenario 3: One scan for a 100k chunk size for SDH domains spanning 100k SDH topology and one scans for a 100k chunk size for DWDM domain spanning 100k DWDM topology.
Extra-large
  • Up to 200k device
  • Up to 400k assimilated topology
  • CPU: 16 x 4 core: 2.55 GHz
  • AMD EPYC™ 77J3: 112 threads
  • RAM: 16 x 32 GB
  • HDD: 16 X 150 GB
  • RAM: 2 x 320 GB
  • Initial storage: 3.5 TB
  • Network Integrity tablespace: 500 GB
Up to 200k device
  • Scenario 1: Forty scans for 5k chunk size for optical domain covering 200k device.
  • Scenario 2: Hundred scans for 2k chunk size for IP domain covering 200k device.
  • Scenario 3: Ten scans for 2k chunk size for IP domains spanning 20k devices and thirty six scans for a 5k chunk size for Optical domain spanning 180k devices.
  • Scenario 4: Twenty scans for a 10k chunk size for NETCONF domain covering 200k devices.
  • Scenario 5: Twenty scans for a 10k chunk size for RESTCONF domain covering 200k devices.
  • Scenario 6: Five scans with a 10k chunk covering 40k L2 VPN services.
  • Scenario 7: Five scans with a 10k chunk covering 40k L3 VPN services.
  • Scenario 8: two L2 scans with 10k chunks and two L3 scans with 10k chunks, covering 20k L2 and 20k L3 VPN services.
  • Scenario 1: Four scans for 100k chunk size covering 400k SDH assimilated topology.
  • Scenario 2: Four scans for 100k chunk size covering 400k DWDM assimilated topology.
  • Scenario 3: Two scans for 100k chunk size for SDH domains spanning 200k SDH topology and two scans for a 100k chunk size for DWDM domain spanning 200k DWDM topology.
Tablespace needs to be increased periodically, based on the scan's frequency and data volume.
