2 About the TL1 Cartridge
This chapter describes the Oracle Communications Network Integrity TL1 cartridge and its components.
About Actions and Processors
The TL1 cartridge contains the following actions:
Discover Abstract Base TL1
Discover Abstract TL1
The Discover Abstract TL1 action extends the Discover Abstract Base TL1 action, pulling in all the functionality of that action to establish and manage the TL1 connection.
The Discover Abstract Base TL1 action contains the following processors run in the following order:
Figure 2-1 illustrates the processor workflow of the Discover Abstract Base TL1 action.
Figure 2-1 Discover Abstract Base TL1 Action Processor Workflow
Description of "Figure 2-1 Discover Abstract Base TL1 Action Processor Workflow"
The Discover Abstract TL1 action adds scan parameter groups to the Discover Abstract Base TL1 action, passing the property values to the TL1Properties object.
The Discover Abstract TL1 action contains the following processors run in the following order:
TL1 Property Initializer (inherited)
TL1 Connection Manager (inherited)
Figure 2-2 illustrates the processor workflow of the Discover Abstract TL1 action.
Figure 2-2 Discover Abstract TL1 Action Processor Workflow
Description of "Figure 2-2 Discover Abstract TL1 Action Processor Workflow"
This processor is part of the Discover Abstract Base TL1 action.
This processor initializes all the properties required for connecting to TL1 and puts all the properties into a TL1Properties object (a Java class).
Table 2-1 lists the values that are initialized by the TL1 Property Initializer processor.
Table 2-1 TL1 Properties Initialized by the TL1 Property Initializer Processor
| Parameter | Description |
host |
Host name or IP address of the TL1 agent. |
port |
Port number of the TL1 agent. |
userid |
The user identification name. It may be from 1 to 10 characters in length. Input is case-sensitive and can consist of numeric, upper- and lower-case alphabetic characters. |
password |
The user password or private identifier. It may be up to 10 characters in length. |
sshUser |
The user ID used to establish the SSH session. |
sshPassword |
The password used to establish the SSH session. |
knownHostFileLocation |
The location where the public keys of the TL1 server are stored if SSH is used. Leave blank to accept all public keys. If a directory is provided, the Network Integrity server must have permission to write to it, otherwise the TL1 cartridge defaults to accepting all public keys. |
timeout |
The timeout of the underlying socket connection in seconds. |
retries |
The number of retries that are attempted after a timeout. Obtained from the TL1 scan parameter groups. |
loginTargetIdentifier |
Identifies the routing information necessary for a login message sent by an OS to reach a network element (NE). Specifying this parameter is optional. |
loginCorrelationTag |
Used to correlate the login input command with a response. The default is empty. Specifying this parameter is optional. |
transportProtocol |
Identifies the TL1 protocol to use: SSH or OTHER. The default is SSH. |
customTransport |
An implementation of the TL1TransportProvider interface. If customTransport is specified, transportProtocol must be set to OTHER. The default is empty. Specifying this parameter is optional. |
connectionCustomizer |
An implementation of TL1Connection.Customizer that can be configured to handle non-standard behavior. |
gatewayDiscovery |
A Boolean value indicating whether the discovery target is a gateway. The default is false. |
gatewayCommand |
The command to retrieve the list of NEs from the gateway. Specifying this parameter is optional. |
gatewayNEFilter |
A filter on the NE ID returned from the TL1 gateway. Specifying this parameter is optional. |
gatewayNEFilterQualifier |
This property works in combination with GatewayNEFilter to match the collected NEs by name and qualifier. Possible values are EQUALS, EQUALS_IGNORE_CASE, CONTAINS, CONTAINS_IGNORE_CASE, STARTS_WITH, STARTS_WITH_IGNORE_CASE, ENDS_WITH, ENDS_WITH_IGNORE_CASE. Specifying this parameter is optional. |
gatewayNEIDResponseSectionPosition |
Identifies where the NE ID is located in the GetNEList command response. The default is 1. Specifying this parameter is optional. |
gatewayNEIDResponseFieldPosition |
Identifies the field where the NE ID is located in the GetNEList command response. The default is 1. Specifying this parameter is optional. |
mode |
Identifies the mode of the Record and Playback feature. Valid values are Normal (no record or playback), Record (recording mode enabled), and Playback (playback mode enabled). Specifying this parameter is optional. |
recordFileDir |
Identifies where the cartridge writes and retrieves recorded TL1 data files. Specifying this parameter is optional. |
In addition, the TL1 Property Initializer processor creates the command dictionary and loads it with all the command documents defined in the cartridge. The TL1 cartridge defines the following commands in the command dictionary:
ACT-USER-REQUEST
CANC-USER-REQUEST
See Network Integrity Developer's Guide for more information about command dictionaries. See "About the Command Dictionary for the TL1 Cartridge" for more information about using the command dictionary for TL1.
TL1 Property Customizer
This processor is part of the Discover Abstract TL1 action.
This processor populates the TL1Properties object produced by the TL1 Property Initializer processor with the parameter values configured in the Network Integrity UI. Table 2-1 lists all the parameters that are customizable in the Network Integrity UI. The host property is initialized from the scan address.
This processor takes the TL1Properties object and command dictionary produced by the TL1 Property Initializer processor to establish a TL1 connection. It provides a TL1Connection object to any extending cartridges and succeeding processors.
To establish a TL1 connection, this processor performs the following operations:
Creates a connection to the TL1 agent using the values in the TL1 Properties object.
Logs in to the TL1 agent using the credentials in the TL1 Properties object.
If a TL1 gateway is configured, issues the TL1 gateway command to retrieve the list of NEs.
If the command is successful, returns the TL1Connection object and the list of NE IDs.
When the scan ends, logs out and disconnects from the TL1 agent.
This processor logs any errors and fails the scan if it cannot establish a TL1 connection with the TL1 agent.
About Record and Playback
The TL1 cartridge can be configured to record all discovered objects.
You enable the Record and Playback feature at runtime by setting a managed bean (MBean) configured on a property group on the Discover Abstract TL1 action.
When recording mode is enabled, the TL1Connection object writes the response data to a TL1 data file in Local_Dir/IP_HostName/Filename.rec, where:
Local_Dir is a local directory that you can configure in the MBean at runtime. If you do not set a value in the MBean, Local_Dir is set to Domain_Home/tl1Data, where Domain_Home is the Network Integrity domain.
IP_HostName is the host property on the TL1 Properties object.
Filename is either the command code passed to the TL1 Connection Manager processor or the full command string.
For example: Local_Dir/10/156/66/191/Filename.rec
When playback mode is enabled, TL1 Connection reads the TL1 data file (created in Record mode and stored on the local hard drive) and sends the data back to the discovery cartridge without polling any network devices. The resource adapter does not require a connection to the network device.
For more information about enabling or disabling the Record and Playback feature, see "About Using Record and Playback".
You can explicitly disable recording mode on a specific command, such as on commands that contain sensitive and unencrypted information (for example, plain-text user names and passwords) by calling the TL1Connection setRecordDisabled method.
The Record and Playback feature is not recommended for clustered environments because it relies on files being saved and loaded from the file system.
About Address Validation
The Discover Abstract TL1 action expects a valid IP address, host name, or IP address range in the Scope field on the Scope tab of the Network Integrity UI.
Any Discovery action extending the Discover Abstract TL1 action should use an address handler to validate entered addresses, such as the IPAddressHandler cartridge provided with Oracle Communications Design Studio.
About Dependent and Independent TL1 Commands
The TL1 cartridge can send independent TL1 commands and can send commands that are dependent on the results of another TL1 command.
For example, the TL1 cartridge can send an independent TL1 command to get the name and model type of a device. It can then send a dependent command to get additional information about the device depending on the device type:
If the device type is 15454, the TL1 cartridge collects additional equipment details.
If the model type is other than 15454, the TL1 cartridge does not collect additional equipment details.
You can send multiple independent and dependent commands. Response values are associated with their request.
The TL1 cartridge uses the command dictionary for formatting TL1 requests and parsing TL1 responses. The command dictionary is a framework for defining data dictionary structures for command requests and responses. It also provides utilities for converting the populated request types into command strings and converting device responses into structured data holders.
The command dictionary uses structures defined in the Design Studio data dictionary to define command requests and responses. The Design Studio data dictionary generates an XML schema compiled into Java classes using XML beans. Use the Java request and response classes to issue TL1 requests and receive TL1 responses.
The data dictionary provides the following functionality:
Defines the commands once so that a library of commands is available to be used in multiple cartridges.
Validates that mandatory parameters are specified and that the request message is valid. The request definition can specify enumerated values, data types, and ranges to provide more validation.
Provides a typed response for custom TL1 components so that parameters can be accessed based on name instead of position. For example, you can code getAid() rather than know that the AID is in parameter section 2, in field 3, and code getSection(2).getField(3).
See "About the Cisco ONS 15454 TL1 Reference Cartridge" for example TL1 commands.
Oracle recommends that you use the command dictionary when extending the Discover Abstract TL1 action. You can send a complete TL1 command string with TL1Connection.send, a TL1Message is returned, and you must extract lines, parameter blocks, and fields using TL1 API operations.
The TL1 cartridge defines structures in the data dictionary for TL1 message types: TL1Request and TL1Response. These must be used when defining new command dictionary Requests and responses for TL1.
Sending Commands Using the Command Dictionary
To send commands using the command dictionary:
In Design Studio, define TL1Request in the data dictionary. The name of the structure should match the TL1 command name, and the command request name should end with a request. See "TL1 Requests" for more information.
In Design Studio, define the matching TL1Response in the data dictionary. The name of the structure should match the TL1 command name, and the command response name should end with a response. See "TL1 Response" for more information.
Run the buildCommandSchema.xml Ant script.
The script must be copied to the extension cartridge before you can run it. See "About the buildCommandSchema.xml Script" for more information.
Add the JAR file generated by the buildCommandSchema.xml script to the /lib directory in the project classpath.
Run the buildCommandDocument.xml Ant script.
The script must be copied to the extension cartridge before you can run it. See "About the buildCommandDocument.xml Script" for more information.
In the Collector Java implementation, add the generated command document into the run-time command dictionary by coding the following:
request.getCommandDictionary().addCommandDictionaryDocument(new String[] {"command_doc.xml"});where command_doc is the name of the command document in the src directory.
In the Java code, build and populate the TL1 request object. For example:
rtrvEqptRequest rtrvEqptRequest = RtrvEqptRequest.Factory.newInstance(); rtrvEqptRequest.setCTAG("1"); rtrvEqptRequest.setAID("myAID"); rtrvEqptRequest.setTID("myTID"); -
Send the command to the TL1 connection and assign the response.
RtrvEqptResponse eqptResponse = (RtrvEqptResponse)request.getTl1Connection().send(rtrvEqptRequest); if (!TL1Constants.COMPLETION_COMPLD.equalsIgnoreCase(eqptResponse.getCompletionCode())) { throw new ProcessorException(createErrorMessage(eqptResponse, rtrvEqptRequest, request.getCommandDictionary())); }
For more examples, refer to the Cisco 15454 TL1 reference cartridge, or see "Design Studio Extension".
TL1 Requests
TL1 requests must use the TL1Request type as the base for the request structure. When creating the TL1 request, select TL1Request from the Base list. This type is defined in the TL1 Cartridge BaseTL1Commands data dictionary.
Figure 2-3 shows a request definition for retrieving equipment. The TID and CTAG attributes are inherited from the base TL1Request, but must add and define the AID attribute.
Figure 2-3 Retrieve Equipment Request Definition
Description of "Figure 2-3 Retrieve Equipment Request Definition"
For examples of TL1 requests, see"About the Cisco ONS 15454 TL1 Reference Cartridge".
TL1 Response
TL1 responses must use the TL1Response type as the base for the response structure. When creating the TL1 response, select TL1Response from the Base list. This type is defined in the TL1 Cartridge BaseTL1Commands data dictionary.
The TL1 response must contain a single TL1ResponseLine child structure. Because TL1 commands return multiple lines of data, you must set the Maximum list of the TL1ResponseLine to Unbounded.
The TL1ResponseLine holds child parameter block structures that are of type TL1NamedParameterBlock or TL1PositionalParameterBlock. TL1 response parameter blocks are delimited by a colon. The TL1Line in the response must contain a child structure for each parameter block defined in the TL1 response.
For example, a typical TL1 Response is structured as follows (the number and type of parameter block defined is dependent on the TL1 command):
ResponseElement TL1Line (Maximum=Unbounded) TL1PositionalParameterBlock (Maximum=1) Parameter1 Parameter2 Parameter…n TL1PositionalParameterBlock (Maximum=1) Parameter1 Parameter2 Parameter…n TL1NamedParameterBlock (Maximum=1) Parameter1 Parameter2 Parameter…n
In the TL1 specification, parameter blocks have either positional fields or named fields. Positional fields place importance on the position of the value. Named fields consist of name-value pairs.
The following positional parameter block consists entirely of values, and does not contain any field names. Empty values are represented by consecutive commas.
SLOT-15,OC3-IR-4,,,1546.12
The following named parameter block contains name-value pairs.
PLUGTYPE=SX-IR-SW-SN,PN=87-31-00002,HWREV=004K, FWREV=76-99-00009-004A,SN=013510,CLEI=NOCLEI,TWL1=1546.12,TWL2=1546.92, TWL3=1547.72,TWL4=1548.51,PLUGINVENDORID=012345,PLUGINPN=ABCDE, PLUGINHWREV=ABCDE,PLUGINFWREV=01-02-03,PLUGINSN=01234,ILOSSREF=1.0, PID=CISCO_ONS15454,VID=V01,FPGA=F451,MODULETYPE=101
If a parameter block consists of positional fields and named fields, it is treated as a positional block.
For the TL1 response to be correctly populated, choose the correct parameter block when creating the TL1 response in the data dictionary.
Figure 2-4 shows a response definition for a Retrieve Equipment request, demonstrating the following elements:
Structure rtrv-eqpt-response is of type TL1Response.
The attributes timestamp, SID, CTAG, completionCode, and errorText are inherited from the base TL1Response.
The timestamp is the date and time the response was returned.
The SID is the NE Source Identifier returned by the TL1 agent.
The CTAG is the Correlation tag value returned from the TL1 agent.
The completion code contains the completion code returned by the TL1 agent. These are standard TL1 completion codes: COMPLD, DELAY, DENY, PRTL, RTRV.
The errorText field contains any error messages returned in the TL1 response from the agent. If the request completed successfully, the errorText field is empty.
The child structure responseLine is of type TL1Line and the Maximum attribute is set to Unbounded to handle multiple lines returned in the TL1 agent response.
The child structures block1 and block2 are of type TL1PositionalParameterBlock because the AID, AIDTYPE, EQUIP, ROLE, and STATUS are not named fields in the response.
The block3 group structure is of type TL1NamedParameterBlock because all fields are named. If the names of the fields do not match the name of the field returned by the device, the field will not be mapped. You should specify every field in the named parameter blocks, because the command response definition may be used by another cartridge.
Figure 2-4 Retrieve Equipment Request Definition
Description of "Figure 2-4 Retrieve Equipment Request Definition"
Some complex TL1 commands return multiple structured lines that contain differing command blocks. The default TL1 response mapper provided with the TL1 cartridge does not support this type of response; however, you can treat this scenario in one of the following ways:
Provide a custom response mapper class that can handle the different line definitions. See Network Integrity Developer's Guide for more information.
Create a super-set of all the returned fields. If line 1 has fields A and B, and line 2 has fields C and D, define a single parameter block that has all four fields A, B, C, and D. On some lines, the A and B are populated; on other lines, C and D are populated. This solution only works with named parameter blocks.
The TL1 cartridge defines two commands in the command dictionary:
ACT-USER: for logging in to the TL1 Session.
CANC-USER: for logging out of the TL1 Session.
For examples of TL1 responses, see "About the Cisco ONS 15454 TL1 Reference Cartridge".
The buildCommandSchema.xml Ant script compiles any schema (XSD) files ending in Commands.xml found in the datadictionary directory. The schemas are compiled using the XML Beans framework. The generated Cartridge_NameCommands.jar file is written to the /lib directory. Add the Cartridge_NameCommands.jar file to the project classpath before running the buildCommandSchema.xml script.
If the script does not find any schemas when it is run, the script does nothing.
The buildCommandSchema.xml script is located in the base directory of the TL1 cartridge project.
When extending the TL1 cartridge, copy the buildCommandSchema.xml script to the base directory of the extending cartridge.
Running the buildCommandSchema.xml script is a prerequisite to running the buildCommandDocument.xml Ant script.
The buildCommandDocument.xml Ant script compiles command documents based on schema (XSD) files ending in Commands.xml found in the datadictionary directory. The generated Data_Dictionary_Name.xml file (for example, CiscoTL1Commands.xml) is written to the src directory. The script looks for types in the schema that end with the word "request" or "response" and correlates them into a single command. See "About the Command Document and Command Document Templates" for more information.
The buildCommandDocument.xml script is located in the base directory of the TL1 cartridge project.
When extending the TL1 cartridge, copy the buildCommandDocument.xml script to the base directory of the extending cartridge.
The JAR file produced by the buildCommandSchema.xml script must be added to the project classpath before you can run the buildCommandDocument.xml script.
You can create a template file to override any of the values generated in the command document. The template contains the values to override. See "About the Command Document and Command Document Templates" for more information.
Add the generated command document to the command dictionary in the runtime operation, as shown in the following example:
request.getCommandDictionary().addCommandDictionaryDocument(new String[] {"Cartridge_NameCommands.xml"});
Enter this code into the processor implementation before sending the TL1 commands.
If the script does not find any schemas ending in Commands.xml, the script does nothing.
You can create a command document template file to consistently override specific values generated in the command document. The buildCommandDocument.xml script automatically looks for such a template file.
The command document template file name must consist of the command file name and end in -template.xml. For example, if the command file name is CiscoTL1Commands.xml, name the template file CiscoTL1Commands-template.xml. Keep the template in the same directory as the command document.
The command document describes the list of supported commands. One or more command documents are added to the command dictionary to configure the supported commands. In the TL1 Cartridge, the command document is generated by the buildCommandDocument.xml Ant script. If the generated command document is incorrect, any field can be overridden by using a template.
The command document template matches the command document schema and structure exactly and is used as base values by the buildCommandDocument.xml script when creating the command document XML. As long as the commandDef name matches, the values specified in the template override the generated values.
You can specify the following information for each command in the command document template:
name: A unique name for the command. By default, the data dictionary structure name (minus the request or response suffix) is used for the name.
description (optional): A description of what the command does.
commandTemplate: Defines the template for the command syntax. By default, this is a velocity template string, but it could be anything depending on the CommandRequestHandler class. The buildCommandDocument.xml script inserts the data dictionary structure name (minus the request or response suffix) in this field and appends any child elements as arguments to the command. The commandTemplate field is the most likely to need to be overridden in a template file.
commandRequestType: Identifies the request type. By default, this is the request schema type and must be unique in the command dictionary. For example:
http://xmlns.oracle.com/communications/sce/dictionary/ CommandParserProject/Cisco+TL1+Commands/GetAlarmsRequestThis field is generated by buildCommandDocument.xml and populated by the data dictionary type ending in request.
commandResponseType (optional): The class name that holds the response data. Not all commands have responses. The value is used by the registered CommandResponseHandler interface. For example:
com.oracle.communications.sce.dictionary.CommandParserProject.Cisco_TL1_Commands.GetAlarmsResponse
This field is generated by buildCommandDocument.xml and populated by the data dictionary type ending in response.
errorResponseType (optional): The class name that holds the error response data. Not all commands have responses. This field is not used by the TL1 cartridge.
requestFormatter (optional): Implements the CommandRequestHandler interface and is responsible for validating the request object and merging the data in the request object with the command template and returning a command string. If a CommandRequestHandler interface is not specified at the command or dictionary level, a default implementation is used that assumes the request object is an XML object and the command template is a velocity template. The TL1 cartridge uses the default implementation of the CommandRequestHandler interface.
responseParser (optional): Implements the CommandResponseParser interface and is responsible for populating the response object based on the response string provided. If a responseParser is not specified at the command level or the dictionary level, the response is not parsed. For the TL1 cartridge, there is a single CommandResponseHandler called oracle.communications.integrity.tl1cartridge.TL1ResponseParser that can format any TL1 response.
About the Command Dictionary API
As a general rule, you should not need to use the command dictionary API.
The addCommandDictionaryDocument() operation is used to add the command document into the runtime command dictionary, as in the following example:
The CommandDictionary class provides a general interface for:
Adding command definitions to and removing command definitions from the command dictionary.
Retrieving information about dictionaries and loaded commands, such as getDictionaryNames() and getCommandNames().
Setting default formatters, parsers, resolver, and types, such as setDefaultResponseType() and setDefaultRequestFormatter().
The CommandHandler class provides methods for performing the following operations on a single command:
Formatting requests.
Parsing responses.
Checking for errors and returning messages.
Sending a Command Using the Command Dictionary
TL1 commands can be sent to the TL1 agent over the TL1 connection, and TL1 responses can be parsed, after the following tasks are completed:
Define TL1 requests and responses in the Design Studio data dictionary.
Run the buildCommandSchema.xml script to generate XML Beans JARs.
Run the buildCommandDocument.xml to generate the command document XML file.
Add the command document to the runtime command dictionary.
To send a command:
Add the tl1Connection to the processor input parameters.
Create the request object and populate the parameters. For example:
RtrvEqptRequest rtrvEqptRequest = RtrvEqptRequest.Factory.newInstance(); rtrvEqptRequest.setCTAG("1"); rtrvEqptRequest.setAID("myAID"); rtrvEqptRequest.setTID("myTID"); -
Send the request instance and cast the response object. For example:
RtrvEqptResponse response = (RtrvEqptResponse)request.getTl1Connection().send(rtrvEqptRequest);
Check the completion code. For example:
if (!TL1Constants.COMPLETION_COMPLD.equalsIgnoreCase(eqptResponse.getCompletionCode())) { throw new ProcessorException(createErrorMessage(eqptResponse, rtrvEqptRequest, request.getCommandDictionary())); } -
Extract any data necessary for modeling. For example:
for (RtrvEqptLine line : eqptResponse.getRtrvEqptLineArray()) { String aid = line.getRtrvEqptBlock1().getAID(); String equip = line.getRtrvEqptBlock2().getEQUIP(); String status = line.getRtrvEqptBlock2().getSTATUS(); }
SSH Login Behavior
The following sequence describes the SSH login behavior:
If the SSH Known Host File Location parameter is not set, the TL1 cartridge accepts all public keys from target devices.
If the SSH Known Host File Location parameter is set:
And Network Integrity cannot write to the specified directory, the behavior is to accept all public keys from target devices.
And Network Integrity can write to the specified directory, all public keys are stored in the directory for each connection to a device, and all public keys are verified when the cartridge reconnects with a device to ensure that keys match. If the keys do not match, the public key is replaced.
Using the TL1 Cartridge
This section describes how to use the TL1 cartridge after it is deployed to the server.
Creating a Discovery Scan Action Type for TL1 Devices
You can create a discovery scan to discover TL1 device information in one or more network systems.
The TL1 cartridge has the following scan parameter groups:
TL1Parameters: A group of the most commonly configured parameters for TL1 devices.
TL1AdvancedParameters: A group of additional parameters that do not need to be configured for most TL1 devices because the default values are accepted by most.
To create a TL1 discovery scan, follow the instructions explained in the Network Integrity Help and do the following during the creation process:
On the General tab, do the following:
From the Scan Action list, select the name of your TL1 Discovery action.
The Scan Type field displays Discovery.
Configure the following mandatory parameters:
In the User Name field, enter the user ID to start the TL1 session.
In the Password field, enter the password for the user ID.
In the Port field, enter the TL1 connection port.
In the Timeout field, enter the timeout length of the underlying socket connection in seconds.
In the Retries field, enter the number of retries that the cartridge attempts after a timeout.
(Optional) Configure the following optional parameters:
To retry to connect after a timeout, enter the number of retries in the Retries field.
To specify the transport protocol used by the TL1 device, select a protocol from the Transport Protocol list.
If you selected SSH from the Transport Protocol list, enter the SSH session user ID and password in the SSH User and SSH Password fields.
To specify where TL1 server SSH public keys are stored, enter a directory path in the SSH Known Host File Location field. All public keys are accepted when this field is left blank.
See Table 2-3 for more information.
(Optional) Configure the advanced TL1 parameters:
To identify the routing information for Network Integrity to send login messages to an NE, enter the target device in the Login Target Identifier (TID) field.
To correlate an input command with an output response, enter the TL1 identifier in the Login CTAG field.
To indicate whether the TL1 discovery scan is being used to discover the NEs from specific gateways, select True from the Gateway Discovery list.
If the Gateway Discovery list is set to True, configure the Gateway NE List Command field, Gateway NE Filter field, Gateway NEFilter Qualifier list, Gateway Response ID Section field, and Gateway Response ID field to filter the TL1 gateway being discovered.
See Table 2-4 for more information.
On the Scope tab, do one of the following:
Enter an IP address.
Enter a range of IP addresses (for example, 10.156.12.* or 11.155.12.11-23 or 10.156.67.0/24).
Enter a host name.
The TL1 cartridge supports IPv4 and IPv6 IP address formats.
You can enter multiple addresses.
Make any other required configurations.
The record feature allows you to record TL1 responses from devices for auditing, demonstration, or debugging the cartridge. The playback feature allows you to replay recorded files to simulate interaction with the device.
When record mode is enabled, the raw TL1 responses are written to a TL1 data file stored on the server.
When playback mode is enabled, the TL1 connection reads the TL1 data file (created in Record mode and stored on the server) and sends the data back to the discovery cartridge. The resource adapter does not require a connection to the network device.
Record and Playback are not recommended for clustered environments because it relies on files being saved and loaded from the file system.
A property group on the Discover Abstract TL1 action controls the Record and Playback feature. MBeans allow you to adjust the record and playback functionality in the runtime system without the need to restart systems or servers.
The Record and Playback feature mode property has three valid values:
Normal: The Record and Playback feature recording mode and playback mode are disabled.
Record: The Record and Playback feature recording mode is enabled.
Playback: The Record and Playback feature playback mode is enabled.
Viewing and Configuring the Current Record and Playback Mode
The MBean Browser in Oracle Enterprise Manager is used to view the mode property of the Record and Playback feature. See Network Integrity System Administrator's Guide for more information.
To view the current Record and Playback feature mode:
In the MBean Browser, navigate to the oracle.communications.integrity.ActionProperty.ActionProperties MBean.
Run the listPropertyGroups operation.
This operation lists the configurable property groups. The Returned Value table displays the current mode.
To configure the Record and Playback feature mode:
Select the Action_Name:TL1 Property Initializer:RecordPlayback property group, where Action_Name is the name of the extending action.
Run the listProperties action, using the full property group name in the argument.
Copy the Action_Name:TL1 Property Initializer:RecordPlayback:mode string from the Return Value table.
Open the setProperty operation and paste the string into the Property field.
In the Value field, set the value of the Record and Playback feature to either Normal, Record, or Playback.
Click the Invoke button.
To set the location where the recorded data is saved, open the recordFileDir action property and specify the desired directory. The directory must exist on the server and must be accessible by the Oracle WebLogic Server user.
Design Studio Construction
This section provides information about the composition of the TL1 cartridge from the Design Studio perspective.
Actions
The following tables outline the Design Studio construction of the TL1 cartridge actions and associated components.
Table 2-2 TL1 Cartridge Actions
| Action Name | Result Category | Address Handler | Scan Parameter Group | Processors |
Discover Abstract Base TL1 |
Device |
IPAddressHandler |
N/A |
Discover Abstract TL1 |
Device |
IPAddressHandler |
Table 2-3 TL1 Cartridge Scan Parameter Groups
| Characteristic Name | Parameter Type | Description | UI Label |
tl1user |
Text field |
The user ID to start the TL1 Session. It can consist of up to 10 alphanumeric case-sensitive characters. |
User Name |
tl1Password |
Text field |
The password associated with the user name. It can consist of up to 10 alphanumeric case-sensitive characters. |
Password |
tl1Port |
Text field |
The port used for the TL1 connection. Valid range is 1 through 65535. The default is 6252 (TL1 SSH). |
Port |
tl1Timeout |
Text field |
The timeout of the underlying socket connection in seconds. The default is 5 seconds. |
Timeout (Seconds) |
tl1Retries |
Text field |
The number of retries that are attempted after a timeout. The default is 0. |
Retries |
transportProtocol |
Drop down |
Transport Protocol |
sshUser |
Text field |
The user ID used to establish the SSH session. This field is mandatory if transportProtocol is set to SSH. |
SSH User |
sshPassword |
Text field |
The password used to establish the SSH session. This field is mandatory if transportProtocol is set to SSH. |
SSH Password |
sshKnownHostFileDir |
Text field |
SSH Known Host File Location |
Table 2-4 TL1 Cartridge Advanced Scan Parameter Groups
tl1LoginTID (optional) |
Text field |
Identifies the routing information necessary for a login message sent by an OS to reach an NE. |
Login Target Identifier (TID) |
tl1LoginCTAG (optional) |
Text field |
Correlates the login input command with a response. Default value is 1. |
Login CTAG |
tl1GatewayFlag |
Drop down |
A Boolean value to indicate whether the discovery target is a gateway. The default is false. |
Gateway Discovery |
tl1GatewayNEListCommand (optional) |
Text field |
The command to retrieve the list of NEs from the gateway. This field is mandatory if tl1GatewayFlag is set to True. |
Gateway NE List Command |
tl1GatewayNEFilter (optional) |
Text field |
A filter on the NE ID returned from TL1 gateway. |
Gateway NE Filter |
tl1GatewayNEFilterQualifier (optional) |
Drop down |
This property works in combination with Gateway NE Filter to match the collected NEs by name and qualifier. |
Gateway NE Filter Qualifier |
gatewayNEIDResponseSectionPosition (optional) |
Text field |
Identifies where the NE ID is located in the GetNEList command response. The default value is 0. |
Gateway Response ID Section |
gatewayNEIDResponseFieldPosition (optional) |
Text field |
Identifies the field where the NE ID is located in the GetNEList command response. The default value is 0. |
Gateway Response ID Field |
Table 2-5 TL1 Cartridge Processors
| Processor Name | Variable |
TL1 Property Initializer |
Input: N/A Output:
TL1 Property Customizer |
Input:
Output: N/A |
TL1 Connection Manager |
Input: tl1Properties, commandDictionary Output:
Table 2-6 TL1 Cartridge Data Dictionary Structure
| Element | Parameters | Notes |
TL1Request |
The TL1Request is the base type of all TL1 Requests. It is expected that all TL1 command requests extend this type. |
TL1Response |
The TL1Response is the base type of all TL1 Responses. It is expected that all TL1 command responses extend this type. |
ACT-USER-REQUEST (TL1Request) |
The TL1 request is used to log the user in to the TL1 session. |
ACT-USER-RESPONSE (TL1Response) |
The TL1 response is the response login of the TL1 session. |
CANC-USER-REQUEST (TL1Request) |
The TL1 request is used to log the user off from the TL1 session. |
CANC-USER-RESPONSE (TL1Response) |
The TL1 response is the response from logging off the user from the TL1 session. |
TL1ResponseLine |
N/A |
The base structure type for a TL1 Response Line. |
TL1NamedParameterBlock |
N/A |
The base structure type for a named parameter block in a TL1 Response. All child elements must be named exactly as they are in the TL1 response. Not all child parameters from the TL1 message section must be specified. A subset is possible. |
TL1PositionalParameterBlock |
N/A |
The base structure type for a positional parameter block in a TL1 Response. Position (order) of the child attributes is more important than the name of the attribute. Because position is important, all parameters should be specified, but parameters can be truncated off the end if they are not needed. |
This section contains examples and explanations about how to extend certain aspects of the TL1 cartridge. See Network Integrity Developer's Guide for more information. For guidelines and best practices for extending cartridges see Network Integrity Concepts. The following examples are explained in this section:
Sending New Commands and Model Results
This example explains how to create a discovery action that sends new commands and model results defined in the command dictionary. In this example, the extending action models the collected data into the Information Model using the TL1Connection and TL1 commands defined in the command dictionary.
To create a discovery action that sends new commands and model results:
Open Design Studio in the Design perspective.
Create a new cartridge project called SampleTL1.
Open the Package Explorer view and expand TL1_Cartridge.
Copy buildCommandDocument.xml and buildCommandSchema.xml from the TL1_Cartridge directory and paste them in the SampleTL1 directory.
In your SampleTL1 cartridge project, create a Discovery action called Discover Sample TL1 and extend it with the Discover Abstract TL1 action.
Create a data dictionary called SampleTL1Commands to hold the TL1 command request and response definitions.
Ending the dictionary name with Commands ensures that it automatically builds with the run script.
In SampleTL1Commands, define new TL1 request structures:
Each new TL1 request structure must extend the TL1Request structure: select TL1Request from the Base list.
Each TL1 request structure name should end with a request so that the run script can generate a correct command template for the requests and responses.
For example, define a structure named rtrv-eqpt-request.
Add a child element called AID.
See ""the Cisco 15454 TL1 reference cartridge for an example command request structure.
In SampleTL1Commands, define new TL1 response structures:
Each new TL1 response structure must extend the TL1Response structure: select TL1Response from the Base list.
Each TL1 response structure name should end with a response so that the run script can generate a correct command template for the requests and responses.
For example, define a structure named rtrv-eqpt-response.
See the Cisco 15454 TL1 reference cartridge for an example command response structure.
The response structure must match the response structure being returned by the TL1 agent.
Under rtrv-eqpt-response, add a child structure called rtrv-eqpt-line:
From the Type list, select TL1ResponseLine.
From the Maximum list, select Unbounded.
Under rtrv-eqpt-line, add a child structure called rtrv-eqpt-block1:
From the Type list, select TL1PositionalParameterBlock.
The position of the response parameter is significant for this block. See "TL1 Response" for more information about child structure types and parameter blocks.
Add a child element called AID and set the Type list to String.
Continue to add parameter blocks until the response definition resembles Figure 2-5, then save your changes.
Open the Package Explorer view and run the buildCommandSchema.xml Ant script.
The buildCommandSchema.xml file builds the data dictionary schema using XML Beans and creates SampleTL1Commands.jar in the /lib directory.
Add SampleTL1Commands.jar to the build path.
Run the buildCommandDocument.xml Ant file.
The buildCommandDocument.xml file creates SampleTL1Commands.xml in the /src directory.
Open SampleTL1Commands.xml and make note of the commandTemplate field value.
Close SampleTL1Commands.xml.
Create a command document template by making a copy of SampleTL1Commands.xml and naming it SampleTL1Commands-template.xml.
Open SampleTL1Commands-template.xml and modify the CTAG value from $!cmd.CTAG to 12345. Also, delete the requestType and responseType elements because those values are not being overridden.
Re-run buildCommandDocument.xml.
Open SampleTL1Commands.xml and verify that the commandTemplate field value is set to the version from the command document template.
Open the Discover Sample TL1 action editor.
On the Processor tab, add a For Each processor after the TL1 Connection Manager processor and select gatewayNEList as the parameter to iterate over. Name the iteration variable neID.
Create a new discovery processor named Sample TL1 Collector that creates and sends TL1 requests to collect data. Place it inside the For Each processor.
Open the Sample TL1 Collector processor.
On the Context Parameters tab, add the following parameters as input:
The commandDictionary parameter from the TL1 Property Initializer processor.
The tl1Connection parameter from the TL1 Connection Manager processor.
The neID parameter from the Discover Sample TL1 processor.
Add an output parameter:
In the Parameter Name field, enter rtrvEqptResponse.
In the Parameter Type field, enter com.oracle.xmlns.communications.sce.dictionary.sampleTL1.sampleTL1Commands.RtrvEqptResponse.
On the Details tab, click Implementation Class.
The Java implementation for the processor is created.
Add the following code to the invoke method of the implementation class:
try { request.getCommandDictionary().addCommandDictionaryDocument(new String[] {"SampleTL1Commands.xml"});This method adds the commands defined in the XML file to the runtime command dictionary.
RtrvEqptRequest rtrvEqptRequest = RtrvEqptRequest.Factory.newInstance(); rtrvEqptRequest.setCTAG("1"); rtrvEqptRequest.setAID("myAID"); rtrvEqptRequest.setTID("myTID"); RtrvEqptResponse response = (RtrvEqptResponse)request.getTl1Connection().send(rtrvEqptRequest); return new SampleTL1CollectorProcessorResponse(response); } catch (Exception e) { throw new ProcessorException(e); }This code creates a new RTRV-EQPT request, sets request arguments, sends the request to the TL1Connection, and gets a response. The RtrvEqptResponse instance is returned by the processor so that subsequent processors can use the value.
Create a new discovery processor called Sample TL1 Modeler to model the TL1 response data output from the Sample TL1 Collector processor. Place it in the For Each processor after the Sample TL1 Collector processor.
Open the Sample TL1 Modeler processor to the Context Parameters tab.
Add rtrvEqptResponse from the Sample TL1 Collector processor as an input parameter.
Design an implementation for the Sample TL1 Modeler processor that converts the TL1 responses to the Oracle Communications Information Model.
Build, deploy, and test your cartridge.
The new processors are run in the order shown in Figure 2-6.
Figure 2-6 Sending New Commands and Modeling Results Processor Workflow
Description of "Figure 2-6 Sending New Commands and Modeling Results Processor Workflow"
Bypassing the Custom Banner for TL1 Devices
Certain TL1 devices display a banner after connecting, which is not handled by the default implementation. This example explains how to create a discovery action that extends the Discover TL1 action to bypass the custom banner.
To bypass the custom banner for TL1 devices:
Create a new discovery action that extends the Discover TL1 action.
Create a new discovery processor called TL1 Connection Customizer Initializer. Place it before the TL1 Connection Manager processor.
Implement a TL1 ConnectionHandler class, SkipBannerConnectionHandler. In the postConnect method, get the transport provider from the TL1Session and issue appropriate reads to bypass the banner.
In the new processor, register your customizer:
properties.setConnectionCustomizer(new Customizer() { @Override public void customize(TL1Connection connection) { connection.setConnectionHandler(new SkipBannerConnectionHandler()); } -
The new processor is run in the order shown in Figure 2-7.
Figure 2-7 TL1 Connection Customizer Extension Cartridge Workflow
Description of "Figure 2-7 TL1 Connection Customizer Extension Cartridge Workflow"
