2 Installing Cartridge Packs
This document describes how to install and set up Oracle Communications Offline Mediation Controller cartridge packs.
Topics in this document:
Software Requirements
Offline Mediation Controller cartridge packs requires Offline Mediation Controller 12.0.
Before installing the Nortel CS 2000 AMADNS Collection Cartridge Pack or the Nortel DMS-100 MMP AMA Collection Cartridge Pack, install the AMA CDK Cartridge Pack.
To install cartridge kits:
Stop all node managers, administration servers, and administration clients on the system where you are installing the cartridge kit.
Delete any existing cartridge pack JAR file from the OMC_home/cartridges directory, where OMC_home is the directory in which Offline Mediation Controller is installed.
Table 2-2 lists the cartridge pack names and JAR file names.
Download the cartridge kit from the Oracle software delivery Web site:
Unzip the cartridge kit JAR file to the OMC_home/cartridges directory.
For these cartridges only, copy the JAR file to OMC_home/dbscripts:
Nortel DMS SMDR Cartridge Pack
Nortel GSM/UMTS AMA Cartridge Pack
Start all node managers, administration servers, and administration clients.
Verify that the cartridge pack has been properly installed by viewing Version Info from the Help menu in Administration Client.
Uninstalling Cartridge Pack
To uninstall a cartridge pack:
Go to the OMC_home/cartridges directory, where OMC_home is the directory in which Offline Mediation Controller is installed.
Delete the JAR file for the cartridge. See Table 2-2.
For these cartridges only, delete the JAR file from the OMC_home/dbscripts directory:
You must also remove these cartridges' scripts from the Oracle database. See "Removing Scripts From the Database".
The following cartridge packs include scripts that you must remove from the Oracle database when you uninstall them:
To remove the scripts from the Oracle database:
Run the following command:
Oracle_home/bin/oemapp dbastudio&
Where Oracle_home is the directory in which you installed the Oracle database software.
The Oracle Enterprise Console appears.
Log on using the following information:
user: system
password: oracle
service: NMCDRS
In the left frame, expand the schema directory and then expand the NMUSER1 directory, which lists the sub-directories.
Expand the sub-directories item by item as follows:
Tables
Source Types
Packages
Procedures
Functions
Java Sources
Java Classes
For each of the sub-directories mentioned above, there are files related to the schema.
Right-click on each file and then select Remove.
Expand the Storage directory.
Expand the TableSpace directory.
Right-click on each item and then select Remove for the tables listed in Table 2-1.
Table 2-1 Tables to Remove for Each Cartridge Pack
Cartridge Pack Tables Nortel GSM/UMTS AMA Cartridge Pack
ENHNMCDRS_MAIN
TBLSPC_NAME_YYYYMMDD (if a partition table was created) Where TBLSPC_NAME is configured in REPOMAN_CONFIGURATION table.
SMDR_MAIN
MSLV_YYYYMMDD (if a partition table was created)
(Nortel DMS SMDR Cartridge Pack only) Run the following command as the system user:
drop user nmuser1 cascade
List of Cartridge Packs and JAR Files
Table 2-2 lists the cartridge packs and their associated JAR file names.
Table 2-2 Cartridge Packs and Their JAR Files
| Cartridge Pack | JAR File |
AMA CDK Cartridge Pack |
ama_cdk_r12_0_0.jar |
ECE Cartridge Pack |
ocece_r12_0_0.jar |
IMS CDF/CGF Cartridge Pack |
IMS_R12_0_0.jar |
IPDRv2 Distribution Cartridge Pack |
ipdr_v2_r12_0_0.jar |
NetFlow Collection and Processing Cartridge Pack |
netflow_r12_0_0.jar |
Nortel CS 2000 AMADNS Collection Cartridge Pack |
cs2k_amadns_r12_0_0.jar |
Nortel DMS-100 MMP AMA Collection Cartridge Pack |
DMS_100_MMP_Collection_R12_0_0.jar |
Nortel DMS Operational Metrics Cartridge Pack |
om_r12_0_0.jar |
Nortel DMS SMDR Cartridge Pack |
smdr_r12_0_0.jar |
Nortel GSM/UMTS AMA Cartridge Pack |
ama_r12_0_0.jar |
Real-Time ASCII File Collection CDK Cartridge Pack |
realtime_ascii_r12__0_0.jar |
SGSN06 Cartridge Pack |
sgsn06_r12_0_0.jar |
Syslog Collection Cartridge Pack |
syslog_r12_0_0.jar |
