7 NetFlow Collection and Processing Cartridge Pack
This document describes how to configure the nodes included in the Oracle Communications Offline Mediation Controller NetFlow Collection and Processing Cartridge Pack, which collects and aggregates Cisco NetFlow records.
Topics in this document:
About the NetFlow Collection and Processing Cartridge Pack
This cartridge pack is for NetFlow collection and processing:
The NetFlow Collection Cartridge (CC) collects the Cisco NetFlow v1, v5, and v7 records.
The NetFlow Session Aggregation Processor (AP) aggregates Cisco NetFlow (V1, V5, and V7) records which have the following attributes:
Source IP addresses
Destination IP addresses
Source port number
Destination port number
IP protocol type
Day of year and hour
Each aggregated NetFlow session record contains the above information as well as total bytes, and total packets.
The NetFlow Collection and Processing cartridge pack will aggregate, into a single record on an hourly basis, NetFlow records belonging to the same NetFlow session. The aggregated records will be output by the AP after the user-configured flush timer has expired.
Figure 7-1 displays the architecture of the solution.
Configuring the NetFlow CC Node
Table 7-1 shows the options to configure in the NetFlow tab.
Table 7-1 NetFlow Tab
| Field | Description |
NetFlow Port |
Port number that NetFlow uses to report mediation data. Default is 9995. |
Socket Buffer Size |
UDP receiving socket buffer size. Value recommended is 65 536 |
