5 Transferring Custom Node Chains
This chapter describes how to transfer custom node chains from one Offline Mediation Controller system to another. You can transfer the configuration of a system that has a custom node or nodes, to another system that may or may not have custom nodes.
There are two scenarios described in this chapter:
Scenario 1 describes how to transfer a configuration with custom nodes to a Offline Mediation Controller system that has an identical base node chain
Scenario 2 describes how to transfer a configuration with custom nodes and a secondary custom node chain to a Offline Mediation Controller system that has an identical base node chain
In both scenarios, the goal is to update System 1 with the System 2 node chain.
Scenario 1
In Scenario 1, System 1 is the original Offline Mediation Controller system that exists in the customer environment, as shown in Figure 5-1. The core nodes are shown in blue and a custom node is shown in green.
Figure 5-1 Original Offline Mediation System 1
Description of "Figure 5-1 Original Offline Mediation System 1"
On System 2 there is a node chain that has been verified in the lab and is ready to be deployed in the customer environment (System 1). System 2 has the identical base node chain as System 1, with two new custom nodes, shown in purple in Figure 5-2.
Updating the node chain
Use the following procedure to update System 1 with the System 2 node chain.
To update System 1 with the System 2 node chain
On System 2
To export the node configuration, tar the following directories:
OMC_Home_1/customization
OMC_Home_2/cartridges
On System 1
Ensure all data in the node chain has been processed, then delete the node chain.
Stop the Node Manager, Administration Server and GUI.
On the System 1, untar the OMC_Home_2/cartridges directory into the OMC_Home_1/cartridges directory.
On the System 1, untar the OMC_Home_2/customization directory into the OMC_Home_1/customization directory.
Start the Node Manager, Administration Server, and GUI.
Import the configuration from System 2.
System 1 now appears as in the following diagram.
Scenario 2
In Scenario 2, System 1 has a base node chain and a secondary node chain that contains custom nodes, shown in red in Figure 5-3.
System 2 has the same base node chain as System 1 but with a secondary node chain that contains custom code, shown in purple in Figure 5-4.
Use the following procedure to update System 1 with the System 2 node chain while still preserving the secondary node chain on System 1.
On System 2
Open the following file:
OMC_Home_2/customization/nodeTemplateDefs/nodeTemplateDef.xml
Locate and open the same file on System 1.
Examine the contents of the two files and ensure the contents of both files are captured in nodeTemplateDef.xml on System 2. Remove any duplication.
OMC_Home_2/customization/groupTemplateDefs/groupTemplateDef.xml
Examine the contents of the two files and ensure the contents of both files are captured in groupTemplateDef.xml on System 2. Remove any duplication.
To export the configuration, tar the following directories:
On System 1
Ensure all data in the node chain has been processed, then delete the routing link between the EP node on the base node chain and the AP node on the secondary node chain.
Delete the base node chain.
Stop the Node Manager, Administration Server, and GUI.
On System 1, untar the following directories into the following locations:
OMC_Home_2/cartridges into OMC_Home_1/cartridges
OMC_Home_2/customization into OMC_Home_1/customization
Start the Node Manager, Administration Server and GUI.
After the update, there is no routing link between the EP node of the base node chain and the AP node of the secondary node chain. You must manually restore this link via the Administration GUI.
