4 Sample Mapping for ECE Cartridge Pack
This chapter contains the sample mapping for the Oracle Communications Offline Mediation Controller Elastic Charging Engine (ECE) Distribution Cartridge (DC). The mapping includes:
  • The input attribute-value pairs (AVPs) in the call detail records (CDRs)
  • The values in the ECE payload specification files
  • The ECE usage requests and payload parameters Offline Mediation Controller uses to build the usage request to send to ECE
Supported Usage Types
The ECE DC supports the following usage types for offline usage requests:
  • Terminate
  • Update
  • Refund_Unit
  • Refund_Amount
  • Cancel
  • Debit_unit
  • Debit_amount
For refund usage types, the input CDR must contain the correlation_identifier value of the original debit request.
Mapping for ASCII
By default, the ECE DC supports the following ASCII product types:
  • Voice
  • Data
  • SMS
Voice
Product Type = VOICE
Event Type = USAGE
Usage Type = Terminate
Table 4-1 Sample ASCII Voice Mapping for the Terminate Usage Type
ASCII NPL Fields ECE Payload Fields ECE Usage Object Builder Parameter
duration
USED_UNITS[0].DURATION
NA
CalledId
NA
CALLED_ID
calling_number
NA
UserIdentity
session_id
NA
Session Id
start_time
NA
Start time
end_time
NA
End time
seq_no
NA
Seq number
Event Type = USAGE
Usage Type = Update
Table 4-2 Sample ASCII Voice Mapping for the Update Usage Type
Req_Duration
REQUESTED_UNITS[0].DURATION
NA
Used_Duration
NA
CalledId
NA
CALLED_ID
calling_number
NA
UserIdentity
session_id
NA
Session Id
start_time
NA
Start time
end_time
NA
End time
seq_no
NA
Seq number
Event Type = USAGE
Usage Type = Refund_Unit
Table 4-3 Sample ASCII Voice Mapping for Refund_Unit Usage Type
Used_duration
NA
CalledId
NA
CALLED_ID
calling_number
NA
UserIdentity
session_id
NA
Session Id
start_time
NA
Start time
end_time
NA
End time
seq_no
NA
Seq number
CORRELATION_IDENTIFIER
NA
Event Type = USAGE
Usage Type = Refund_Amount
Table 4-4 Sample ASCII Voice Mapping for the Refund_Amount Usage Type
CalledId
NA
CALLED_ID
calling_number
NA
UserIdentity
session_id
NA
Session Id
start_time
NA
Start time
end_time
NA
End time
seq_no
NA
Seq number
balance_element_id
IMPACT_AMOUNT[0].BALANCE_ELEMENT_ID
NA
amount
IMPACT_AMOUNT[0].AMOUNT
NA
NA
Data
Product Type = DATA
Event Type = USAGE
Table 4-5 Sample ASCII Data Mapping for the Terminate Usage Type
cell_id
CELL_ID
NA
usedUnitsInputVolume
USED_UNITS[0].INPUT_VOLUME
NA
usedUnitsOutputVolume
USED_UNITS[0].OUTPUT_VOLUME
NA
usedUnitsTotalVolume
USED_UNITS[0].TOTAL_VOLUME
NA
CalledId
NA
CALLED_ID
calling_number
NA
UserIdentity
session_id
NA
Session Id
start_time
NA
Start time
end_time
NA
End time
seq_no
NA
Seq number
Product Type = DATA
Event Type = USAGE
Usage Type = Update
Table 4-6 Sample ASCII Data Mapping for the Update Usage Type
cell_id
CELL_ID
NA
requestedInputVolume
REQUESTED_UNITS[0].INPUT_VOLUME
NA
requestedOutputVolume
REQUESTED_UNITS[0].OUTPUT_VOLUME
NA
requestedTotalVolume
REQUESTED_UNITS[0].TOTAL_VOLUME
NA
NA
NA
NA
CalledId
NA
CALLED_ID
calling_number
NA
UserIdentity
session_id
NA
Session Id
start_time
NA
Start time
end_time
NA
End time
seq_no
NA
Seq number
Product Type = DATA
Event Type = USAGE
Table 4-7 Sample ASCII Data Mapping for the Refund_Unit Usage Type
cell_id
CELL_ID
NA
NA
NA
NA
CalledId
NA
CALLED_ID
calling_number
NA
UserIdentity
session_id
NA
Session Id
start_time
NA
Start time
end_time
NA
End time
seq_no
NA
Seq number
NA
Product Type = DATA
Event Type = USAGE
Table 4-8 Sample ASCII Data Mapping for the Refund_Amount Usage Type
cell_id
CELL_ID
NA
CalledId
NA
CALLED_ID
calling_number
NA
UserIdentity
session_id
NA
Session Id
start_time
NA
Start time
end_time
NA
End time
seq_no
NA
Seq number
balance_element_id
NA
amount
NA
NA
Mapping for SGSN
The ECE DC supports the following SGSN product types:
  • Data
  • SMS
Data
SGSN PDP Record
Table 4-9 Sample SGSN Data Mapping for the SGSN PDP Record
ASN 1 Fields SGSN Cartridge NPL Fields ECE Payload Fields ECE Usage Object Builder Parameter
listOfTrafficVolumes.dataVolumeGPRSUplink
part of 20209
NA
listOfTrafficVolumes.dataVolumeGPRSDownlink
part of 20209
NA
cellIdentifier
20223(CellIdentifier)
CELL_ID
NA
servedIMSI
20234 (ServedIMSI)
NA
UserIdentity
chargingID
20001(ChargingID)
NA
Session id
recordOpeningTime
NA
NA
start time
duration
duration
NA
end_time(calculated from the duration)
recordSequenceNumber
20005 (record sequence number)
NA
sequence number
S-GW Record
Table 4-10 Sample SGSN Data Mapping for the S-GW Record
ASN1 Fields SGSN USED_UNITS[0].OUTPUT_VOLUME NA
part of 20209
NA
part of 20209
NA
servedIMSI
20234 (ServedIMSI )
NA
UserIdentity
chargingID
20001(ChargingID)
NA
Session id
startTime
20274(StartTime )
NA
Start time
stopTime
20275(StopTime ) if it exists, otherwise derived from duration(20004)
NA
End time
NA
sequence number
P-GW Record
Table 4-11 Sample SGSN Data Mapping for P-GW Record
ASN1 Fields SGSN cartridge NPL Fields ECE Payload Fields ECE Usage Object Builder Parameter
listOfServiceData.datavolumeFBCUplink
part of 20267
NA
listOfService.datavolumeFBCDownlink
part of 20267
NA
servedIMSI
20234 (ServedIMSI)
NA
UserIdentity
chargingID
20001(ChargingID)
NA
Session id
startTime
20274
NA
Start time
stopTime
NA
End time
NA
sequence number
SMS
The SGSNMMRecord (mobility management), SGSNMORecord (Mobile originated) and SGSNMTRecord (Mobile Terminated) record types are supported for Mobility management and SMS services.
20234 (ServedIMSI)
20219
Product Type = SMS
Event Type = USAGE
Table 4-12 Sample SGSN SMS Mapping for the Terminate Usage Type
cellIdentifier
CELL_ID
NA
destinationNumber
if SGSNMORecord 20303(DestinationNumber), if SGSNMTRecord same as 20234(servedIMSI)
CALLED_ID
NA
NA
NA
USED_UNITS[0].SPECIFIC_UNIT
NA
servedMSISDN or servedIMSI
NA
NA
UserIdentity
chargingID
20001(ChargingID)
NA
Session id
eventTimeStamp
20240(EventTimeStamp)
NA
Start time
eventTimeStamp
NA
end time
localSequenceNumber
NA
NA
seq number
Product Type = SMS
Event Type = USAGE
Usage Type = Update
Table 4-13 Sample SGSN SMS Mapping for the Update Usage Type
cellIdentifier
CELL_ID
NA
destinationNumber
CALLED_ID
NA
NA
NA
NA
NA
NA
UserIdentity
chargingID
20001(ChargingID)
NA
Session id
eventTimeStamp
NA
Start time
eventTimeStamp
NA
end time
localSequenceNumber
NA
NA
seq number
Product Type = SMS
Event Type = USAGE
Table 4-14 Sample SGSN SMS Mapping for the Refund_Unit Usage Type
cellIdentifier
CELL_ID
NA
destinationNumber
CALLED_ID
NA
NA
NA
NA
NA
NA
UserIdentity
chargingID
20001(ChargingID)
NA
Session id
eventTimeStamp
NA
Start time
eventTimeStamp
NA
end time
localSequenceNumber
NA
NA
seq number
NA
NA
Product Type = SMS
Event Type= USAGE
Table 4-15 Sample SGSN SMS Mapping for the Refund_Amount Usage Type
cellIdentifier
CELL_ID
NA
destinationNumber
CALLED_ID
NA
NA
NA
NA
NA
NA
UserIdentity
chargingID
20001(ChargingID)
NA
Session id
eventTimeStamp
NA
Start time
eventTimeStamp
NA
end time
localSequenceNumber
NA
NA
seq number
balance_element_id
NA
NA
amount
NA
NA
NA
NA
Mapping for IMS
The ECE DC supports the following IMS product types:
  • Voice
In case of IMS cartridge pack, the input is a Diameter ACR request, which the cartridge pack node chains convert into the 3GPP ASN1 format. The converted ASN1 format is the input to the ECE DC.
Voice
Table 4-16 Sample IMS Voice Mapping
ASN1 Fields IMS cartridge NPL Fields ECE Payload Fields
Called_Party_Address
CALLED_ID
derived using service delivery start time stamp and end time stamp
Duration
PrivateUserID
PrivateUserID
UserIdentity
ServiceDeliveryStartTimeStamp
start time
ServiceDeliveryEndTimeStamp
end time
Session_Id
Session_Id
session id
seqNo
seq number
Mapping for Oracle CDR Format
The ECE DC supports the following Oracle CDR format product types:
  • Voice
  • Data
  • SMS
  • TelcoGsmTelephony
  • TelcoGprs
Voice
Event Type = USAGE
Table 4-17 Sample Oracle CDR Format Voice Mapping for the Terminate Usage Type
Oracle CDR Format NPL Fields ECE Payload Fields ECE Usage Object Builder Parameter
A_NUMBER
NA
UserIdentity
NA
NA
Seq number
NA
NA
Session Id
CHARGING_START_TIMESTAMP
NA
Start time
CHARGING_END_TIMESTAMP
NA
End time
BASIC_SERVICE
NA
cdr_service
DURATION
NA
B_NUMBER
CALLED_ID
NA
CELL_ID
CELL_ID
NA
USAGE_DIRECTION
USAGE_DIRECTION
NA
CALL_COMPLETION_INDICATOR
TERMINATION_CAUSE
NA
QOS_USED
QUALITY_OF_SERVICE
NA
Data
Product Type = DATA
Event Type = DATA_USAGE
Table 4-18 Sample Oracle CDR Format Data Mapping for the Terminate Usage Type
A_NUMBER
NA
UserIdentity
NA
NA
Seq number
NA
NA
Session Id
NA
Start time
NA
End time
BASIC_SERVICE
NA
cdr_service
VOLUME_SENT
NA
VOLUME_SENT + VOLUME_RECEIVED
NA
NA
USED_UNITS[0].CC_TIME
NA
USED_UNITS[0].VALIDITY_START
NA
USED_UNITS[0].VALIDITY_END
NA
B_NUMBER
CALLED_ID
NA
CELL_ID
CELL_ID
NA
TERMINATION_CAUSE
NA
SMS
Product Type = SMS
Event Type = SMS_USAGE
Table 4-19 Sample Oracle CDR Format SMS Mapping for the Terminate Usage Type
A_NUMBER
NA
UserIdentity
NA
NA
Seq number
NA
NA
Session Id
NA
Start time
NA
End time
BASIC_SERVICE
NA
cdr_service
DURATION
NA
TERMINATION_CAUSE
NA
B_NUMBER
CALLED_ID
NA
CELL_ID
CELL_ID
NA
TelcoGsmTelephony
Product Type = TelcoGsmTelephony
Event Type = ConvergentVoice
Table 4-20 Sample Oracle CDR Format TelcoGsmTelephony Mapping for the Terminate Usage Type
A_NUMBER
NA
UserIdentity
NA
NA
Seq number
NA
NA
Session Id
NA
Start time
NA
End time
BASIC_SERVICE
NA
cdr_service
TERMINATION_CAUSE
NA
NA
ZONE_ORIGIN
NA
NA
ZONE_DEST
NA
USAGE_TYPE
USAGE_TYPE
NA
B_NUMBER
CALLED_ID
NA
NA
TELCO_INFO[0].NETWORK_SESSION_ID
NA
NA
TELCO_INFO[0].NETWORK_SESSION_CORRELATION_ID
NA
DESTINATION_NETWORK
TELCO_INFO[0].DESTINATION_NETWORK
NA
MSID
TELCO_INFO[0].PRIMARY_MSID
NA
NA
TELCO_INFO[0].SECONDARY_MSID
NA
A_NUMBER
TELCO_INFO[0].CALLING_FROM
NA
B_NUMBER
TELCO_INFO[0].CALLED_TO
NA
NA
TELCO_INFO[0].SVC_TYPE
NA
NA
TELCO_INFO[0].SVC_CODE
NA
USAGE_CLASS
TELCO_INFO[0].USAGE_CLASS
NA
VOLUME_RECEIVED
TELCO_INFO[0].BYTES_DOWNLINK
NA
VOLUME_SENT
TELCO_INFO[0].BYTES_UPLINK
NA
ACTION_CODE
SERVICE_CODES[0].SS_ACTION_CODE
NA
SS_CODE
SERVICE_CODES[0].SS_CODE
NA
ESN_IMEI
GSM_INFO[0].IMEI
NA
B_MODIFICATION_INDICATOR
GSM_INFO[0].CALLED_NUM_MODIF_MARK
NA
USAGE_DIRECTION or CALL_DIRECTION
GSM_INFO[0].DIRECTION
NA
B_NUMBER
GSM_INFO[0].DIALED_NUMBER
NA
QOS_REQUESTED
GSM_INFO[0].QOS_REQUESTED
NA
QOS_USED
GSM_INFO[0].QOS_NEGOTIATED
NA
LONG_DURATION_INDICATOR
GSM_INFO[0].SUB_TRANS_ID
NA
HOME_CARRIER_SID
GSM_INFO[0].ORIGIN_SID
NA
HOME_CARRIER_SID
GSM_INFO[0].DESTINATION_SID
NA
LOCATION_AREA_INDICATOR
GSM_INFO[0].LOC_AREA_CODE
NA
CELL_ID
GSM_INFO[0].CELL_ID
NA
VOLUME_RECEIVED
GSM_INFO[0].BYTES_IN
NA
VOLUME_SENT
GSM_INFO[0].BYTES_OUT
NA
USAGE_CLASS
GSM_INFO[0].USAGE_CLASS
NA
NUMBER_OF_UNITS
GSM_INFO[0].NUMBER_OF_UNIT
NA
DURATION
NA
NA
NA
TelcoGprs
Product Type = TelcoGprs
Event Type = ConvergentData
Table 4-21 Sample Oracle CDR Format TelcoGprs Mapping for the Terminate Usage Type
A_NUMBER
NA
UserIdentity
NA
NA
Seq number
NA
NA
Session Id
NA
Start time
NA
End time
BASIC_SERVICE
NA
cdr_service
TERMINATION_CAUSE
NA
USAGE_TYPE
USAGE_TYPE
NA
B_NUMBER
CALLED_ID
NA
NA
NA
NA
NA
DESTINATION_NETWORK
NA
MSID
NA
PORT_NUMBER
NA
A_NUMBER
NA
B_NUMBER
NA
NA
NA
NA
NA
USAGE_CLASS
NA
VOLUME_RECEIVED
NA
VOLUME_SENT
NA
ROUTING_AREA
GPRS_INFO[0].ROUTING_AREA
NA
GPRS_INFO[0].LOC_AREA_CODE
NA
CELL_ID
GPRS_INFO[0].CELL_ID
NA
SESSION_ID
GPRS_INFO[0].SESSION_ID
NA
SGSN_ADDRESS
GPRS_INFO[0].SGSN_ADDRESS
NA
NODE_ID
GPRS_INFO[0].NODE_ID
NA
TRANS_ID
GPRS_INFO[0].TRANS_ID
NA
NA
GPRS_INFO[0].EXTENSIONS
NA
NA
GPRS_INFO[0].STATUS
NA
NETWORK_INITIATED_PDP
GPRS_INFO[0].NI_PDP
NA
CONNECT_TYPE
GPRS_INFO[0].ANONYMOUS_LOGIN
NA
PDP_TYPE
GPRS_INFO[0].PDP_TYPE
NA
PDP_ADDRESS
GPRS_INFO[0].PDP_ADDRESS
NA
PDP_REMOTE_ADDRESS
GPRS_INFO[0].PDP_RADDRESS
NA
PDP_DYNAMIC_ADDRESS
GPRS_INFO[0].PDP_DYNADDR
NA
DIAGNOSTICS
GPRS_INFO[0].DIAGNOSTICS
NA
APN_ADDRESS
GPRS_INFO[0].APN
NA
NUMBER_OF_UNITS
GPRS_INFO[0].NUMBER_OF_UNITS
NA
NETWORK_CAPABILITY
GPRS_INFO[0].NETWORK_CAPABILITY
NA
SGSN_CHANGE
GPRS_INFO[0].SGSN_CHANGE
NA
CHANGE_CONDITION
GPRS_INFO[0].CHANGE_CONDITION
NA
QOS_REQUESTED_PRECEDENCE
GPRS_INFO[0].QOS_REQ_PRECEDENCE
NA
QOS_REQUESTED_DELAY
GPRS_INFO[0].QOS_REQ_DELAY
NA
QOS_REQUESTED_RELIABILITY
GPRS_INFO[0].QOS_REQ_RELIABILITY
NA
QOS_REQUESTED_PEAK_THROUGHPUT
GPRS_INFO[0].QOS_REQ_PEAK_THROUGH
NA
QOS_REQUESTED_MEAN_THROUGHPUT
GPRS_INFO[0].QOS_REQ_MEAN_THROUGH
NA
QOS_USED_PRECEDENCE
GPRS_INFO[0].QOS_NEGO_PRECEDENCE
NA
QOS_USED_DELAY
GPRS_INFO[0].QOS_NEGO_DELAY
NA
QOS_USED_RELIABILITY
GPRS_INFO[0].QOS_NEGO_RELIABILITY
NA
QOS_USED_PEAK_THROUGHPUT
GPRS_INFO[0].QOS_NEGO_PEAK_THROUGH
NA
QOS_USED_MEAN_THROUGHPUT
GPRS_INFO[0].QOS_NEGO_MEAN_THROUGH
NA
NA
GPRS_INFO[0].SGSN_PLMN_ID
NA
NA
GPRS_INFO[0].MM_STATE
NA
NA
GPRS_INFO[0].PTMSI
NA
NA
GPRS_INFO[0].PTMSI_SIGNATURE
NA
NA
GPRS_INFO[0].SERVICE_AREA_CODE
NA
NA
GPRS_INFO[0].EXT_CHARGING_ID
NA
NA
GPRS_INFO[0].PS_CHARGING_DESCR
NA
VOLUME_SENT
NA
VOLUME_RECEIVED
NA
NA
