A NPL Syntax and Reserved Words
This appendix provides the NPL syntax and reserved words.
Table A-1 lists all the NPL methods and the corresponding syntax.
EBNF for NPL
Table A-1 NPL Methods, Operator and Syntax
Method Operator Syntax
Program
( MethodHandlerImportDecl )?
( ConfigDeclaration )?
( VariableDeclaration )+
( ExposeDeclaration )*
( Statement )
+<EOF>
"import" <IDENTIFIER> ( "." <IDENTIFIER> )* ";"
ConfigDeclaration
"Config" "{" ( ConfigAttribute )? "}"
ConfigAttribute
<IDENTIFIER> <STRING_LITERAL> ";"
VariableDeclaration
CompositeVariableDecl | SimpleVariableDecl
InputRecDecl | OutputRecDecl
InputRecDecl
"InputRec" "{" ( AttributeVariableDecl )+ "}"
<IDENTIFIER> ";"
OutputRecDecl
"OutputRec" "{" ( AttributeVariableDecl )+ "}"
<IDENTIFIER> ";"
AttributeType ( <ATTRIBUTE_NAME>
| <IDENTIFIER> | <INTEGER_LITERAL> ) ";"
SimpleVariableDecl
AttributeType <IDENTIFIER>
( SimpleVariableInit )? ";"
SimpleVariableInit
"=" Expression
AttributeType
"String"
| "Integer"
| "Long"
| "TimeInSecs"
| "IP"
| "TimeInMilliSecs"
| "MAC"
| "UInt128"
| "Byte"
| "Short"
| "IPv6"
| "Float"
| "Double"
| "Bytes"
| "Object"
| "List"
ExposeDeclaration
"Expose for" <IDENTIFIER> "{"
( ExposeAttribute )+ "}"
ExposeAttribute
<IDENTIFIER> "." ( <ATTRIBUTE_NAME>
| <IDENTIFIER>
| <INTEGER_LITERAL> )
( <STRING_LITERAL> )? ";"
Statement
IfStatement | AssignmentStmt
| FunctionStmt | JavaHookStmt
IfStatement
"if" "(" ConditionalExpression ")" IfAction
( "else" "if" "(" ConditionalExpression ")" IfAction )*
( "else" IfAction )?
RelationalExpression ( ConditionalOperator
RelationalExpression )*
ConditionalOperator
<OR> | <AND>
NestedRelationalExpression
| SimpleRelationalExpression
| BooleanFunctionExpr
BooleanFunctionExpr
FunctionExpression
Expression RelationalOperator Expression
RelationalOperator
<EQ> | <NE> | <LT> | <LE> | <GT> | <GE>
IfAction
StatementBlock | Statement
StatementBlock
"{" ( Statement )* "}"
AssignmentStmt
Variable "=" Expression ";"
Variable
<IDENTIFIER> ( "." ( <ATTRIBUTE_NAME>
| <IDENTIFIER>
| <INTEGER_LITERAL> ) )?
Expression
AdditiveExpression
AdditiveExpression
SubtractiveExpression
( "+" SubtractiveExpression )*
MultiplicativeExpression
( "-" MultiplicativeExpression )*
DivisionalExpression ( "*" DivisionalExpression )*
UnaryExpression ( "/" UnaryExpression )*
UnaryExpression
( "(" AttributeType ")" )?
( NestedExpression
| VariableExpression
| IntLiteralExpression
| FloatingPointLiteralExpression
| StringLiteralExpression
| FunctionExpression
| JavaHookExpression )
NestedExpression
( UnaryOperator )? "(" Expression ")"
VariableExpression
( UnaryOperator )? Variable
( UnaryOperator )? <STRING_LITERAL>
( UnaryOperator )? <FLOATING_POINT_LITERAL>
<STRING_LITERAL>
FunctionExpression
( "byte2bytes"
| "byte2str"
| "bytes2byte"
| "bytes2double"
| "bytes2float"
| "bytes2hexstr"
| "bytes2int"
| "bytes2IP"
| "bytes2long"
| "bytes2short"
| "bytes2str"
| "bytes2TimeInMilliSecs"
| "bytes2TimeInSecs"
| "clone"
| "convertDateTime"
| "copyBits"
| "currentTime"
| "double2bytes"
| "double2str"
| "fieldExists"
| "float2bytes"
| "float2str"
| "int2bytes"
| "int2str"
| "IP2bytes"
| "IP2str"
| "list2str"
| "long2bytes"
| "long2str"
| "object2str"
| "randomInt"
| "randomDouble"
| "short2bytes"
| "short2str"
| "strpos"
| "str2byte"
| "str2bytes"
| "str2double"
| "str2float"
| "str2int"
| "str2IP"
| "str2long"
| "str2lower"
| "str2short"
| "str2TimeInMilliSecs"
| "str2TimeInSecs"
| "str2upper"
| "strlen"
| "subbytes"
| "substr"
| "time2bytes"
| "time2str" )
"(" ( Expression ( "," Expression )* )? ")"
UnaryOperator
FunctionStmt
( "logError"
| "logWarning"
| "logInfo"
| "logTrace"
| "write" )
"(" ( Expression ( "," Expression )* )? ")" ";"
JavaHookStmt
JavaHookExpression ";"
JavaHookExpression
"Java" "." <IDENTIFIER>
<IDENTIFIER>
( <LETTER> | <UNDERSCORE> )
( <LETTER> | <DIGIT> | <UNDERSCORE>)*
<ATTRIBUTE_NAME>
( <LETTER> | <UNDERSCORE> | <COLON> )
| <COLON> | <HYPHEN> )*
<FUNCTION_NAME>
<LETTER> ( <LETTER> | <DIGIT> )*
<LETTER>
["a"-"z", "A"-"Z"]
<UNDERSCORE>
"_"
<COLON>
<DIGIT>
["0"-"9"]
<HYPHEN>
<MINUS>
<INTEGER_LITERAL>
<DECIMAL_LITERAL>
| <HEX_LITERAL>
| <OCTAL_LITERAL>
<DECIMAL_LITERAL>
["1"-"9"] (["0"-"9"])*
<HEX_LITERAL>
"0" ["x","X"] (["0"-"9","a"-"f","A"-"F"])+
<OCTAL_LITERAL>
"0" (["0"-"7"])*
(["0"-"9"])+ "." (["0"-"9"])* (<EXPONENT>)?
<EXPONENT>
["e","E"] (["+","-"])? (["0"-"9"])+
<STRING_LITERAL>
( (~["\"","\\","\n","\r"])
        ( ["n","t","b","r","f","\\","'","\""]
        | ["0"-"7"] ( ["0"-"7"] )?
        | ["0"-"3"] ["0"-"7"] ["0"-"7"]
<OR>
<AND>
<EQ>
<NE>
<LT>
<LE>
<GT>
<GE>
<MINUS>
NPL reserved words
  • Byte
  • byte2bytes
  • byte2str
  • Bytes
  • bytes2byte
  • bytes2double
  • bytes2float
  • bytes2hexstr
  • bytes2int
  • bytes2IP
  • bytes2long
  • bytes2short
  • bytes2str
  • bytes2TimeInMilliSecs
  • bytes2TimeInSecs
  • Config
  • convertDateTime
  • copyBits
  • currentTime
  • Double
  • double2bytes
  • double2str
  • else
  • Expose
  • fieldExists
  • Float
  • float2bytes
  • float2str
  • for
  • if
  • import
  • InputRec
  • int2bytesint2str
  • Integer
  • IP
  • IP2bytes
  • IP2str
  • IPv6
  • Java
  • List
  • list2str
  • logError
  • logInfo
  • logTrace
  • logWarning
  • Long
  • long2bytes
  • long2str
  • MAC
  • null
  • Object
  • object2str
  • OutputRec
  • randomInt
  • randomDouble
  • Short
  • short2bytes
  • short2str
  • str2byte
  • str2bytes
  • str2double
  • str2float
  • str2int
  • str2IP
  • str2long
  • str2lower
  • str2short
  • str2TimeInMilliSecs
  • str2TimeInSecs
  • str2upper
  • String
  • strlen
  • strpos
  • subbytes
  • substr
  • time2bytes
  • time2str
  • TimeInMilliSecs
  • TimeInSecs
  • UInt128
  • write
