2 Offline Mediation Controller Software Compatibility
Learn about the software that is compatible with Oracle Communications Offline Mediation Controller 12.0 and 12.0 patch sets.
Topics in this document:
For hardware and information requirements, see "Offline Mediation Controller System Requirements" in Offline Mediation Controller Installation Guide.
Operating Systems
Table 2-1 lists the operating systems supported by Offline Mediation Controller.
Table 2-1 Supported Operating Systems for Offline Mediation Controller
| Operating System | Version | Notes |
| Red Hat Enterprise Linux, x86-64 (64-bit) |
Red Hat Enterprise Linux (RHEL) 7.2 and higher 7.x updates (with critical patch updates) RHEL 8.4 and higher 8.x updates (with critical patch updates) – Support added in 12.0 Patch Set 5 RHEL 8.5 and higher 8.x updates (with critical patch updates) – Support added in 12.0 Patch Set 6 RHEL 8.6 and higher 8.x updates (with critical patch updates) – Support added in 12.0 Patch Set 8 |
Important: To protect from security vulnerabilities, ensure you apply the latest critical patch updates. See "About Critical Patch Updates". Offline Mediation Controller is certified on RHEL 7.2, 8.4, 8.5, and 8.6. Regularly apply the latest patch set for RHEL to ensure that it has the latest security fixes. |
| Oracle Linux, x86-64 (64-bit) |
Oracle Linux 7.2 and higher 7.x updates (with critical patch updates) Oracle Linux 8.4 and higher 8.x updates (with critical patch updates) – Support added in 12.0 Patch Set 5 Oracle Linux 8.5 and higher 8.x updates (with critical patch updates) – Support added in 12.0 Patch Set 6 Oracle Linux 8.6 and higher 8.x updates (with critical patch updates) – Support added in 12.0 Patch Set 8 |
Important: To protect from security vulnerabilities, ensure you apply the latest critical patch updates. See "About Critical Patch Updates". Offline Mediation Controller is certified on Oracle Linux 7.2, 8.4, 8.4,and 8.6. Regularly apply the latest patch set for Oracle Linux to ensure that it has the latest security fixes. |
| Oracle Solaris for SPARC (64-bit) |
11.3 (plus latest patch updates) 11.4 (plus latest patch updates) – Support added in 12.0 Patch Set 6 |
N/A |
| Oracle Solaris for x86 (64-bit) |
N/A |
| Windows (64-bit) |
8.1 10 11 |
N/A |
You should install all critical patch updates as soon as possible. To download critical patch updates, find out about security alerts, and enable email notifications about critical patch updates, see "Critical Patch Updates, Security Alerts and Bulletins" on the Oracle website.
Web Browsers
Table 2-2 lists the web browsers that are compatible with Offline Mediation Controller.
Table 2-2 Supported Web Browsers
| Web Browser | Version |
Mozilla Firefox |
54.0.1 and later patch levels – Support added in 12.0 58.0 and later patch levels – Support added in 12.0 Patch Set 1 65.0 and later patch levels – Support added in 12.0 Patch Set 2 78.10 and later patch levels – Support added in 12.0 Patch Set 4 83.0 and later patch levels – Support added in 12.0 Patch Set 5 96.0 and later patch levels – Support added in 12.0 Patch Set 6 99.0 and later patch levels – Support added in 12.0 Patch Set 7 106.0 and later patch levels – Support added in 12.0 Patch Set 8 |
Microsoft Internet Explorer |
Not supported |
Microsoft Edge |
Default version with operating system |
Google Chrome |
72.0 and later patch levels – Support added in 12.0 90.0 and later patch levels – Support added in 12.0 Patch Set 4 92.0 and later patch levels – Support added in 12.0 Patch Set 5 97.0 and later patch levels – Support added in 12.0 Patch Set 6 104.0 and later patch levels – Support added in 12.0 Patch Set 8 |
Apple Safari |
12.0 and later patch levels – Support added in 12.0 14.1 and later patch levels – Support added in 12.0 Patch Set 4 15.2 and later patch levels – Support added in 12.0 Patch Set 6 15.4 and later patch levels – Support added in 12.0 Patch Set 7 16.0 and later patch levels – Support added in 12.0 Patch Set 8 |
Additional Offline Mediation Controller Software Requirements
Table 2-3 lists the software required for running Offline Mediation Controller.
Table 2-3 Required Third-Party Software for Offline Mediation Controller
| Product | Version | Notes |
| Oracle Database 12c Server Enterprise Edition (for single or Oracle Real Application Clusters (RAC) installation) |
Oracle 12c Database (Oracle Enterprise 12.2.0 and later patch levels) – Support added in 12.0 Oracle 18c Database (Oracle Enterprise 18.1.0 and later patch levels) – Support added in 12.0 Patch Set 1 Oracle 19c Database (Oracle Enterprise 19.3.0 and later patch levels) – Support added in 12.0 Patch Set 2 Oracle 19c Database (Oracle Enterprise 19.13 and later patch levels) – Support added in 12.0 Patch Set 5 Oracle 19c Database (Oracle Enterprise 19.15 and later patch levels) – Support added in 12.0 Patch Set 7 Oracle 19c Database (Oracle Enterprise 19.17 and later patch levels) – Support added in 12.0 Patch Set 8 |
Note: Oracle Database is required only if you use JDBC Distribution Cartridge (DC) to persist data. |
| Oracle Java Platform, Standard Edition (Java SE) |
8 (1.8.0_144) – Support added in 12.0 8 (1.8.0_221) – Support added in 12.0 Patch Set 2 8 (1.8.0_241) – Support added in 12.0 Patch Set 3 8 (1.8.0_291) – Support added in 12.0 Patch Set 4 8 (1.8.0_301) – Support added in 12.0 Patch Set 5 8 (1.8.0_321) – Support added in 12.0 Patch Set 6 8 (1.8.0_341) – Support added in 12.0 Patch Set 7 8 (1.8.0_351) – Support added in 12.0 Patch Set 8 |
N/A |
| Oracle Unified Directory |
11.1.2.3.0 – Support added in 12.0 12.2.1.3.0 – Support added in 12.0 Patch Set 1 12.2.1.4.0 – Support added in 12.0 Patch Set 3 |
N/A |
| Oracle Communications Billing and Revenue Management Elastic Charging Engine (ECE) |
For Offline Mediation Controller 12.0:
For Offline Mediation Controller 12.0 Patch Set 1:
For later patch sets, the ECE patch set version is the same as the Offline Mediation Controller patch set version. |
N/A |
| Grafana |
7.5.6 – Support added in 12.0 Patch Set 4 8.2.1 – Support added in 12.0 Patch Set 5 8.3.5 – Support added in 12.0 Patch Set 6 9.2.4 – Support added in 12.0 Patch Set 8 |
N/A |
| Micrometer Registry Prometheus |
1.6.6 – Support added in 12.0 Patch Set 4 |
N/A |
| Prometheus |
2.27.1 – Support added in 12.0 Patch Set 4 2.40.0 – Support added in 12.0 Patch Set 8 |
N/A |
| Prometheus Alertmanager |
0.21.0 – Support added in 12.0 Patch Set 4 0.24.0 – Support added in 12.0 Patch Set 7 |
N/A |
The Offline Mediation Controller Installer checks for all required software and displays errors if it detects any missing or unavailable components, or if there are any connectivity-related issues.
For BRM Suite compatibility, see "BRM Software Compatibility" in BRM Compatibility Matrix.
