1 About Cartridge Packs
This document provides an overview of the Oracle Communications Offline Mediation Controller cartridge packs.
Topics in this document:
Cartridge packs are optional Offline Mediation Controller components that provide functionality for specific mediation or pre-charging functions. Table 1-1 lists the cartridge packs.
Table 1-1 Cartridge Packs
| Cartridge Pack | Description |
AMA CDK Cartridge Pack |
Provides the functionality to collect and process AMA data. |
ECE Cartridge Pack |
Enables Offline Mediation Controller to submit offline charging requests to ECE. |
IMS CDF/CGF Cartridge Pack |
Collects raw diameter data from IMS devices, converts that data into 32.298 ASN.1 format, and outputs the data to downstream applications. |
IPDRv2 Distribution Cartridge Pack |
Processes IP detail records (IPDRs). |
NetFlow Collection and Processing Cartridge Pack |
Processes Netflow records |
Nortel CS 2000 AMADNS Collection Cartridge Pack |
Supports the collection of Nortel CS 2000 SN09 AMADNS records. |
Nortel DMS-100 MMP AMA Collection Cartridge Pack |
Supports the collection of Nortel DMS-100 MMP AMA (I) SN09 records generated by Nortel DMS-100 switches. |
Nortel DMS Operational Metrics Cartridge Pack |
Provides functionality to retrieve files containing OM records from various telecom switches and send them to external systems. The OM node chain does not modify OM records; there are no EP or AP nodes. |
Nortel DMS SMDR Cartridge Pack |
Provides the ability to collect SMDR records from DMS-100 switches. |
Nortel GSM/UMTS AMA Cartridge Pack |
Provides the functionality to collect AMA data from DMS-MSC SDMs, process that data and send it to downstream applications such as billing systems and/or databases. |
Real-Time ASCII File Collection CDK Cartridge Pack |
Collects ASCII records from files in realtime. |
SGSN06 Cartridge Pack |
Supports 3GPP TS 32.298 V6.4.1, 3GPP TS 32.298 7.3.0, and 3GPP TS 32.298 V10.5.0 for SGSN call data records (CDR). |
Syslog Collection Cartridge Pack |
Collects syslog files from multiple devices. |
